[U-Boot] [tiU16.05 PATCH v1] keystone: k2h/e/l: Fix DMA coherency for QM PDSP
commit 1f807a9f32aa ("ARM: keystone2: Refactor MSMC macros to avoid left under a macro KS2_MSMC_SEGMENT_QM_PDSP which is no longer valid. This, in effect disabled DMA coherency for QM PDSP.
Given that msmc_k2hkle_common_setup is valid for all K2H/K/L/E SoCs, the #ifdef should been removed in the first place. Do the same.
Fixes: 1f807a9f32aa ("ARM: keystone2: Refactor MSMC macros to avoid #ifdeffery") Signed-off-by: Murali Karicheri m-karicheri2@ti.com Acked-by: Nishanth Menon nm@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- - v2 - adding Fixes per comments arch/arm/mach-keystone/init.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/mach-keystone/init.c b/arch/arm/mach-keystone/init.c index 3b6d5ef..6e5a1e1 100644 --- a/arch/arm/mach-keystone/init.c +++ b/arch/arm/mach-keystone/init.c @@ -101,9 +101,7 @@ static void msmc_k2hkle_common_setup(void) msmc_share_all_segments(KS2_MSMC_SEGMENT_C6X_0); msmc_share_all_segments(K2HKLE_MSMC_SEGMENT_ARM); msmc_share_all_segments(K2HKLE_MSMC_SEGMENT_NETCP); -#ifdef KS2_MSMC_SEGMENT_QM_PDSP msmc_share_all_segments(K2HKLE_MSMC_SEGMENT_QM_PDSP); -#endif msmc_share_all_segments(K2HKLE_MSMC_SEGMENT_PCIE0); msmc_share_all_segments(KS2_MSMC_SEGMENT_DEBUG); }
Murali Karicheri
