[PATCH 0/5] board: imx8mm: Add Engicam i.Core MX8M Mini SoM
Patch series for Engicam i.Core MX8M Mini SOM and it's associated carrier board dts(i) support.
dts(i) patches are part of Linux mainling-list.
patch 1-2: exiting imx8mm dts, header improvement code
patch 3: Engicam i.Core MX8M Mini SoM dts
patch 4-5: EDIMM2.2, C.TOUCH 2.0 Carrier boards
Any inputs? Jagan.
Jagan Teki (5): arm64: dts: imx8mm: Add common -u-boot.dtsi configs: Add imx8mm-common header arm64: dts: imx8mm: Add Engicam i.Core MX8M Mini SoM board: imx8mm: Add Engicam i.Core MX8M Mini EDIMM2.2 Starter Kit board: imx8mm: Add Engicam i.Core MX8M Mini C.TOUCH 2.0
arch/arm/dts/Makefile | 2 + arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi | 37 +- arch/arm/dts/imx8mm-evk-u-boot.dtsi | 37 +- .../imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi | 31 + arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts | 97 + .../imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi | 31 + arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts | 97 + arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi | 27 + arch/arm/dts/imx8mm-icore-mx8mm.dtsi | 232 +++ arch/arm/dts/imx8mm-u-boot.dtsi | 39 + arch/arm/dts/imx8mm-verdin-u-boot.dtsi | 38 +- arch/arm/dts/phycore-imx8mm-u-boot.dtsi | 37 +- arch/arm/mach-imx/imx8m/Kconfig | 19 + board/engicam/imx8mm/Kconfig | 14 + board/engicam/imx8mm/MAINTAINERS | 13 + board/engicam/imx8mm/Makefile | 12 + board/engicam/imx8mm/icore_mx8mm.c | 21 + board/engicam/imx8mm/lpddr4_timing.c | 1847 +++++++++++++++++ board/engicam/imx8mm/spl.c | 101 + configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 84 + configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 84 + include/configs/imx8mm-common.h | 48 + include/configs/imx8mm_beacon.h | 48 +- include/configs/imx8mm_evk.h | 45 +- include/configs/imx8mm_icore_mx8mm.h | 58 + include/configs/phycore_imx8mm.h | 43 +- include/configs/verdin-imx8mm.h | 42 +- 27 files changed, 2881 insertions(+), 303 deletions(-) create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm.dtsi create mode 100644 arch/arm/dts/imx8mm-u-boot.dtsi create mode 100644 board/engicam/imx8mm/Kconfig create mode 100644 board/engicam/imx8mm/MAINTAINERS create mode 100644 board/engicam/imx8mm/Makefile create mode 100644 board/engicam/imx8mm/icore_mx8mm.c create mode 100644 board/engicam/imx8mm/lpddr4_timing.c create mode 100644 board/engicam/imx8mm/spl.c create mode 100644 configs/imx8mm-icore-mx8mm-ctouch2_defconfig create mode 100644 configs/imx8mm-icore-mx8mm-edimm2.2_defconfig create mode 100644 include/configs/imx8mm-common.h create mode 100644 include/configs/imx8mm_icore_mx8mm.h
/soc@0 aips1 aips2 aips3 clk iomuxc osc_24m
are common node enablements across imx8mm platform for dm-spi, dm-pre-reloc stages.
Move them into common dtsi, imx8mm-u-boot.dtsi
Cc: Adam Ford aford173@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Teresa Remmet t.remmet@phytec.de Cc: Igor Opaniuk igor.opaniuk@toradex.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi | 37 ++------------------ arch/arm/dts/imx8mm-evk-u-boot.dtsi | 37 ++------------------ arch/arm/dts/imx8mm-u-boot.dtsi | 39 ++++++++++++++++++++++ arch/arm/dts/imx8mm-verdin-u-boot.dtsi | 38 ++------------------- arch/arm/dts/phycore-imx8mm-u-boot.dtsi | 37 ++------------------ 5 files changed, 48 insertions(+), 140 deletions(-) create mode 100644 arch/arm/dts/imx8mm-u-boot.dtsi
diff --git a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi index 6d80a529ae..73ddfdade6 100644 --- a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2020 Compass Electronics Group, LLC */
+#include "imx8mm-u-boot.dtsi" + / { wdt-reboot { compatible = "wdt-reboot"; @@ -11,32 +13,6 @@ }; };
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - -&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - -&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - ®_usdhc2_vmmc { u-boot,off-on-delay-us = <20000>; }; @@ -65,15 +41,6 @@ u-boot,dm-spl; };
-&iomuxc { - u-boot,dm-spl; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - &pca6416_0 { compatible = "ti,tca6416"; }; diff --git a/arch/arm/dts/imx8mm-evk-u-boot.dtsi b/arch/arm/dts/imx8mm-evk-u-boot.dtsi index e843a5648e..79dffe7ccd 100644 --- a/arch/arm/dts/imx8mm-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-evk-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2019 NXP */
+#include "imx8mm-u-boot.dtsi" + / { wdt-reboot { compatible = "wdt-reboot"; @@ -11,41 +13,6 @@ }; };
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - -&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - -&iomuxc { - u-boot,dm-spl; -}; - ®_usdhc2_vmmc { u-boot,off-on-delay-us = <20000>; }; diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi new file mode 100644 index 0000000000..f833d9df59 --- /dev/null +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Jagan Teki jagan@amarulasolutions.com + */ + +&{/soc@0} { + u-boot,dm-pre-reloc; + u-boot,dm-spl; +}; + +&aips1 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips2 { + u-boot,dm-spl; +}; + +&aips3 { + u-boot,dm-spl; +}; + +&clk { + u-boot,dm-spl; + u-boot,dm-pre-reloc; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ assigned-clock-rates; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&osc_24m { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/imx8mm-verdin-u-boot.dtsi b/arch/arm/dts/imx8mm-verdin-u-boot.dtsi index 249b0f8f66..67c31c49b6 100644 --- a/arch/arm/dts/imx8mm-verdin-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-verdin-u-boot.dtsi @@ -2,6 +2,9 @@ /* * Copyright 2020 Toradex */ + +#include "imx8mm-u-boot.dtsi" + / { wdt-reboot { compatible = "wdt-reboot"; @@ -10,27 +13,6 @@ }; };
-&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - -&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - &gpio1 { u-boot,dm-spl; }; @@ -55,15 +37,6 @@ u-boot,dm-spl; };
-&iomuxc { - u-boot,dm-spl; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - &pinctrl_i2c1 { u-boot,dm-spl; }; @@ -84,11 +57,6 @@ u-boot,dm-spl; };
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - &{/soc@0/bus@30800000/i2c@30a20000/pmic} { u-boot,dm-spl; }; diff --git a/arch/arm/dts/phycore-imx8mm-u-boot.dtsi b/arch/arm/dts/phycore-imx8mm-u-boot.dtsi index fc0fa22d1b..91515b8df9 100644 --- a/arch/arm/dts/phycore-imx8mm-u-boot.dtsi +++ b/arch/arm/dts/phycore-imx8mm-u-boot.dtsi @@ -4,6 +4,8 @@ * Author: Teresa Remmet t.remmet@phytec.de */
+#include "imx8mm-u-boot.dtsi" + / { wdt-reboot { compatible = "wdt-reboot"; @@ -12,41 +14,6 @@ }; };
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - -&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - -&iomuxc { - u-boot,dm-spl; -}; - &pinctrl_uart3 { u-boot,dm-spl; };
Move the redundant config item like SPL, memory-related across all imx8mm config files in the common config header, imx8mm-common.h
Verified the built files, seems almost the same as before.
Cc: Adam Ford aford173@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Teresa Remmet t.remmet@phytec.de Cc: Igor Opaniuk igor.opaniuk@toradex.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- include/configs/imx8mm-common.h | 48 ++++++++++++++++++++++++++++++++ include/configs/imx8mm_beacon.h | 48 ++++---------------------------- include/configs/imx8mm_evk.h | 45 ++---------------------------- include/configs/phycore_imx8mm.h | 43 ++-------------------------- include/configs/verdin-imx8mm.h | 42 +++------------------------- 5 files changed, 63 insertions(+), 163 deletions(-) create mode 100644 include/configs/imx8mm-common.h
diff --git a/include/configs/imx8mm-common.h b/include/configs/imx8mm-common.h new file mode 100644 index 0000000000..f1afa5c5a9 --- /dev/null +++ b/include/configs/imx8mm-common.h @@ -0,0 +1,48 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2019 NXP + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#ifndef __IMX8MM_COMMON_H +#define __IMX8MM_COMMON_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_MAX_SIZE (148 * 1024) +#define CONFIG_SPL_STACK 0x920000 +#define CONFIG_SPL_BSS_START_ADDR 0x910000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K + +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x930000 +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE +#endif /* CONFIG_SPL_BUILD */ + +#define CONFIG_SYS_MONITOR_LEN SZ_512K +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 +#define CONFIG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN SZ_32M + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 + +#define CONFIG_LOADADDR 0x40480000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#endif /* __IMX8MM_COMMON_H */ diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 94f4a1232f..65a44a9ed9 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -6,29 +6,13 @@ #ifndef __IMX8MM_BEACON_H #define __IMX8MM_BEACON_H
-#include <linux/sizes.h> -#include <asm/arch/imx-regs.h> +#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 +#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) +#include "imx8mm-common.h"
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - -#endif +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (PHYS_SDRAM_SIZE >> 1))
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ @@ -92,28 +76,6 @@ "fi; " \ "fi;"
-/* Link Definitions */ -#define CONFIG_LOADADDR 0x40480000 - -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN SZ_32M - -#define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define PHYS_SDRAM 0x40000000 -#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */ - -#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (PHYS_SDRAM_SIZE >> 1)) - #define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
/* Monitor Command Prompt */ diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index fd9a6cbb8c..d74bc2ea4f 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -6,31 +6,11 @@ #ifndef __IMX8MM_EVK_H #define __IMX8MM_EVK_H
-#include <linux/sizes.h> -#include <linux/stringify.h> -#include <asm/arch/imx-regs.h> - #define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M) -#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE +#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 +#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#endif +#include "imx8mm-common.h"
#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ @@ -56,27 +36,8 @@ "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \
-/* Link Definitions */ -#define CONFIG_LOADADDR 0x40480000 - -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
-/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN SZ_32M - -#define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define PHYS_SDRAM 0x40000000 -#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */ - #define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
/* Monitor Command Prompt */ diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index fd69dc41a8..86f4ee3f23 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -7,30 +7,11 @@ #ifndef __PHYCORE_IMX8MM_H #define __PHYCORE_IMX8MM_H
-#include <linux/sizes.h> -#include <linux/stringify.h> -#include <asm/arch/imx-regs.h> - #define CONFIG_SYS_BOOTM_LEN SZ_64M -#define CONFIG_SPL_MAX_SIZE (148 * SZ_1K) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K +#define CONFIG_SYS_INIT_RAM_SIZE SZ_512K +#define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */
-/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE -#endif +#include "imx8mm-common.h"
#define CONFIG_EXTRA_ENV_SETTINGS \ "image=Image\0" \ @@ -81,26 +62,8 @@ "fi; " \ "fi;"
-/* Link Definitions */ -#define CONFIG_LOADADDR 0x40480000 -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE SZ_512K -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - #define CONFIG_MMCROOT "/dev/mmcblk2p2" /* USDHC3 */
-/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN SZ_32M -#define CONFIG_SYS_SDRAM_BASE 0x40000000 - -#define PHYS_SDRAM SZ_1G -#define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */ - /* UART */ #define CONFIG_MXC_UART_BASE UART3_BASE_ADDR
diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 4751bf5a5a..5485bc23aa 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -6,28 +6,12 @@ #ifndef __VERDIN_IMX8MM_H #define __VERDIN_IMX8MM_H
-#include <asm/arch/imx-regs.h> -#include <linux/sizes.h> - -#define CONFIG_SPL_MAX_SIZE (148 * 1024) -#define CONFIG_SYS_MONITOR_LEN SZ_512K -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 -#define CONFIG_SYS_UBOOT_BASE \ - (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) +#define CONFIG_SYS_INIT_RAM_SIZE SZ_2M
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_STACK 0x920000 -#define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ -#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ +/* SDRAM configuration */ +#define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */
#define MEM_LAYOUT_ENV_SETTINGS \ "fdt_addr_r=0x44000000\0" \ @@ -35,9 +19,6 @@ "ramdisk_addr_r=0x46400000\0" \ "scriptaddr=0x46000000\0"
-#define CONFIG_LOADADDR 0x40480000 -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - /* Enable Distro Boot */ #ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ @@ -75,25 +56,10 @@ "${blkcnt} / 0x200; mmc dev 0 1; mmc write ${loadaddr} 0x2 " \ "${blkcnt}; fi\0"
-#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE SZ_2M -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - #if defined(CONFIG_ENV_IS_IN_MMC) /* Environment in eMMC, before config block at the end of 1st "boot sector" */ #endif
-/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN SZ_32M -#define CONFIG_SYS_SDRAM_BASE 0x40000000 - -/* SDRAM configuration */ -#define PHYS_SDRAM 0x40000000 -#define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */ - /* UART */ #define CONFIG_MXC_UART_BASE UART1_BASE_ADDR
i.Core MX8M Mini is an EDIMM SoM based on NXP i.MX8M Mini from Engicam.
General features: - NXP i.MX8M Mini - Up to 2GB LDDR4 - 8/16GB eMMC - Gigabit Ethernet - USB 2.0 Host/OTG - PCIe Gen2 interface - I2S - MIPI DSI to LVDS - rest of i.MX8M Mini features
i.Core MX8M Mini needs to mount on top of Engicam baseboards for creating complete platform solutions.
Add support for it.
Signed-off-by: Matteo Lisi matteo.lisi@engicam.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx8mm-icore-mx8mm.dtsi | 232 +++++++++++++++++++++++++++ 1 file changed, 232 insertions(+) create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm.dtsi
diff --git a/arch/arm/dts/imx8mm-icore-mx8mm.dtsi b/arch/arm/dts/imx8mm-icore-mx8mm.dtsi new file mode 100644 index 0000000000..b40148d728 --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm.dtsi @@ -0,0 +1,232 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 NXP + * Copyright (c) 2019 Engicam srl + * Copyright (c) 2020 Amarula Solutons(India) + */ + +/ { + compatible = "engicam,icore-mx8mm", "fsl,imx8mm"; +}; + +&A53_0 { + cpu-supply = <®_buck4>; +}; + +&A53_1 { + cpu-supply = <®_buck4>; +}; + +&A53_2 { + cpu-supply = <®_buck4>; +}; + +&A53_3 { + cpu-supply = <®_buck4>; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy>; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy: ethernet-phy@3 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <3>; + reset-gpios = <&gpio3 7 GPIO_ACTIVE_LOW>; + reset-assert-us = <10000>; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + pmic@8 { + compatible = "nxp,pf8121a"; + reg = <0x08>; + + regulators { + reg_ldo1: ldo1 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_ldo2: ldo2 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_ldo3: ldo3 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_ldo4: ldo4 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck1: buck1 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck2: buck2 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck3: buck3 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck4: buck4 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck5: buck5 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck6: buck6 { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_buck7: buck7 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + + reg_vsnvs: vsnvs { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + }; + }; +}; + +&iomuxc { + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MM_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MM_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 + MX8MM_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MM_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MM_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MM_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MM_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MM_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MM_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MM_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MM_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MM_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MM_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MM_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MM_IOMUXC_NAND_DATA01_GPIO3_IO7 0x19 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MM_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 + MX8MM_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x190 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x194 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_NAND_WE_B_USDHC3_CLK 0x196 + MX8MM_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 + MX8MM_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 + MX8MM_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 + MX8MM_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 + MX8MM_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 + MX8MM_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 + MX8MM_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 + MX8MM_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 + MX8MM_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 + MX8MM_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 + >; + }; +}; + +/* eMMC */ +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +};
Engicam EDIMM2.2 Starter Kit is an EDIMM 2.2 Form Factor Capacitive Evaluation Board.
Genaral features: - LCD 7" C.Touch - microSD slot - Ethernet 1Gb - Wifi/BT - 2x LVDS Full HD interfaces - 3x USB 2.0 - 1x USB 3.0 - HDMI Out - Mini PCIe - MIPI CSI - 2x CAN - Audio Out
i.Core MX8M Mini needs to mount on top of this Evaluation board for creating complete i.Core MX8M Mini EDIMM2.2 Starter Kit.
Add support for it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 1 + .../imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi | 31 + arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts | 97 + arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi | 27 + arch/arm/mach-imx/imx8m/Kconfig | 14 + board/engicam/imx8mm/Kconfig | 14 + board/engicam/imx8mm/MAINTAINERS | 7 + board/engicam/imx8mm/Makefile | 12 + board/engicam/imx8mm/icore_mx8mm.c | 21 + board/engicam/imx8mm/lpddr4_timing.c | 1847 +++++++++++++++++ board/engicam/imx8mm/spl.c | 101 + configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 84 + include/configs/imx8mm_icore_mx8mm.h | 58 + 13 files changed, 2314 insertions(+) create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi create mode 100644 board/engicam/imx8mm/Kconfig create mode 100644 board/engicam/imx8mm/MAINTAINERS create mode 100644 board/engicam/imx8mm/Makefile create mode 100644 board/engicam/imx8mm/icore_mx8mm.c create mode 100644 board/engicam/imx8mm/lpddr4_timing.c create mode 100644 board/engicam/imx8mm/spl.c create mode 100644 configs/imx8mm-icore-mx8mm-edimm2.2_defconfig create mode 100644 include/configs/imx8mm_icore_mx8mm.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 33e483f4fb..accf96bfc3 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -782,6 +782,7 @@ dtb-$(CONFIG_ARCH_IMX8) += \ imx8-giedi.dtb
dtb-$(CONFIG_ARCH_IMX8M) += \ + imx8mm-icore-mx8mm-edimm2.2.dtb \ imx8mm-evk.dtb \ imx8mm-verdin.dtb \ phycore-imx8mm.dtb \ diff --git a/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi b/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi new file mode 100644 index 0000000000..8b67bcff7d --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2-u-boot.dtsi @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#include "imx8mm-icore-mx8mm-u-boot.dtsi" + +&gpio1 { + u-boot,dm-spl; +}; + +&pinctrl_uart2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1 { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts b/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts new file mode 100644 index 0000000000..a4a2ada148 --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm-edimm2.2.dts @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 NXP + * Copyright (c) 2019 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +/dts-v1/; +#include "imx8mm.dtsi" +#include "imx8mm-icore-mx8mm.dtsi" + +/ { + model = "Engicam i.Core MX8M Mini EDIMM2.2 Starter Kit"; + compatible = "engicam,icore-mx8mm-edimm2.2", "engicam,icore-mx8mm", + "fsl,imx8mm"; + + chosen { + stdout-path = &uart2; + }; +}; + +&fec1 { + status = "okay"; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c4 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; +}; + +&iomuxc { + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MM_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MM_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SCL_I2C4_SCL 0x400001c3 + MX8MM_IOMUXC_I2C4_SDA_I2C4_SDA 0x400001c3 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MM_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 + MX8MM_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 + >; + }; + + pinctrl_usdhc1_gpio: usdhc1gpiogrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x41 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MM_IOMUXC_SD1_CLK_USDHC1_CLK 0x190 + MX8MM_IOMUXC_SD1_CMD_USDHC1_CMD 0x1d0 + MX8MM_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x1d0 + MX8MM_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x1d0 + MX8MM_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x1d0 + MX8MM_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x1d0 + >; + }; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +/* SD */ +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>, <&pinctrl_usdhc1_gpio>; + cd-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>; + max-frequency = <50000000>; + bus-width = <4>; + no-1-8-v; + pm-ignore-notify; + keep-power-in-suspend; + status = "okay"; +}; diff --git a/arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi new file mode 100644 index 0000000000..e7d179d632 --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm-u-boot.dtsi @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#include "imx8mm-u-boot.dtsi" + +&iomuxc { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3_100mhz { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3_200mhz { + u-boot,dm-spl; +}; + +&usdhc3 { + u-boot,dm-spl; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index c455f7b5eb..3410462907 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -43,6 +43,19 @@ config TARGET_IMX8MM_EVK select SUPPORT_SPL select IMX8M_LPDDR4
+config TARGET_IMX8MM_ICORE_MX8MM + bool "Engicam i.Core MX8M Mini SOM" + select IMX8MM + select SUPPORT_SPL + select IMX8M_LPDDR4 + help + i.Core MX8M Mini is an EDIMM SOM based on NXP i.MX8MM. + + i.Core MX8M Mini EDIMM2.2: + * EDIMM2.2 is a Form Factor Capacitive Evaluation Board. + * i.Core MX8M Mini needs to mount on top of EDIMM2.2 for + creating complete i.Core MX8M Mini EDIMM2.2 Starter Kit. + config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" select IMX8MN @@ -91,6 +104,7 @@ config TARGET_PHYCORE_IMX8MP select IMX8M_LPDDR4 endchoice
+source "board/engicam/imx8mm/Kconfig" source "board/freescale/imx8mq_evk/Kconfig" source "board/freescale/imx8mm_evk/Kconfig" source "board/freescale/imx8mn_evk/Kconfig" diff --git a/board/engicam/imx8mm/Kconfig b/board/engicam/imx8mm/Kconfig new file mode 100644 index 0000000000..ed68516df4 --- /dev/null +++ b/board/engicam/imx8mm/Kconfig @@ -0,0 +1,14 @@ +if TARGET_IMX8MM_ICORE_MX8MM + +config SYS_BOARD + default "imx8mm" + +config SYS_VENDOR + default "engicam" + +config SYS_CONFIG_NAME + default "imx8mm_icore_mx8mm" + +source "board/freescale/common/Kconfig" + +endif diff --git a/board/engicam/imx8mm/MAINTAINERS b/board/engicam/imx8mm/MAINTAINERS new file mode 100644 index 0000000000..044a9392ac --- /dev/null +++ b/board/engicam/imx8mm/MAINTAINERS @@ -0,0 +1,7 @@ +i.Core-MX8M-Mini-EDIMM2.2 +M: Jagan Teki jagan@amarulasolutions.com +M: Matteo Lisi matteo.lisi@engicam.com +S: Maintained +F: board/engicam/imx8mm +F: include/configs/imx8mm_icore_mx8mm.h +F: configs/imx8mm-icore-mx8mm-edimm2.2_defconfig diff --git a/board/engicam/imx8mm/Makefile b/board/engicam/imx8mm/Makefile new file mode 100644 index 0000000000..3392d61920 --- /dev/null +++ b/board/engicam/imx8mm/Makefile @@ -0,0 +1,12 @@ +# +# Copyright (C) 2020 Amarula Solutions(India) +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += icore_mx8mm.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-y += lpddr4_timing.o +endif diff --git a/board/engicam/imx8mm/icore_mx8mm.c b/board/engicam/imx8mm/icore_mx8mm.c new file mode 100644 index 0000000000..d948d3adb5 --- /dev/null +++ b/board/engicam/imx8mm/icore_mx8mm.c @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <asm-generic/gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} diff --git a/board/engicam/imx8mm/lpddr4_timing.c b/board/engicam/imx8mm/lpddr4_timing.c new file mode 100644 index 0000000000..3900d52dd8 --- /dev/null +++ b/board/engicam/imx8mm/lpddr4_timing.c @@ -0,0 +1,1847 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2018.03_4.14.78_1.0.0_ga + */ + +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /* Initialize DDRC registers */ + {0x3d400304, 0x1}, + {0x3d400030, 0x1}, + {0x3d400000, 0xa1080020}, + {0x3d400020, 0x223}, + {0x3d400024, 0x3a980}, + {0x3d400064, 0x5b0087}, + {0x3d4000d0, 0xc00305ba}, + {0x3d4000d4, 0x940000}, + {0x3d4000dc, 0xd4002d}, + {0x3d4000e0, 0x210000}, + {0x3d4000e8, 0x44004d}, + {0x3d4000ec, 0x14004d}, + {0x3d400100, 0x191f1920}, + {0x3d400104, 0x60630}, + {0x3d40010c, 0xb0b000}, + {0x3d400110, 0xe04080e}, + {0x3d400114, 0x2040c0c}, + {0x3d400118, 0x1010007}, + {0x3d40011c, 0x401}, + {0x3d400130, 0x20600}, + {0x3d400134, 0xc100002}, + {0x3d400138, 0x8d}, + {0x3d400144, 0x96004b}, + {0x3d400180, 0x2ee0017}, + {0x3d400184, 0x2605b8e}, + {0x3d400188, 0x0}, + {0x3d400190, 0x497820a}, + {0x3d400194, 0x80303}, + {0x3d4001b4, 0x170a}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0xdf00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x11}, + {0x3d4001c0, 0x1}, + {0x3d4001c4, 0x0}, + {0x3d4000f4, 0xc99}, + {0x3d400108, 0x70e1617}, + {0x3d400200, 0x1f}, + {0x3d40020c, 0x0}, + {0x3d400210, 0x1f1f}, + {0x3d400204, 0x80808}, + {0x3d400214, 0x7070707}, + {0x3d400218, 0xf070707}, + {0x3d400250, 0x29001701}, + {0x3d400254, 0x2c}, + {0x3d40025c, 0x4000030}, + {0x3d400264, 0x900093e7}, + {0x3d40026c, 0x2005574}, + {0x3d400400, 0x111}, + {0x3d400408, 0x72ff}, + {0x3d400494, 0x2100e07}, + {0x3d400498, 0x620096}, + {0x3d40049c, 0x1100e07}, + {0x3d4004a0, 0xc8012c}, + {0x3d402020, 0x21}, + {0x3d402024, 0x7d00}, + {0x3d402050, 0x20d040}, + {0x3d402064, 0xc0012}, + {0x3d4020dc, 0x840000}, + {0x3d4020e0, 0x310000}, + {0x3d4020e8, 0x66004d}, + {0x3d4020ec, 0x16004d}, + {0x3d402100, 0xa050305}, + {0x3d402104, 0x30407}, + {0x3d402108, 0x203060b}, + {0x3d40210c, 0x505000}, + {0x3d402110, 0x2040202}, + {0x3d402114, 0x2030202}, + {0x3d402118, 0x1010004}, + {0x3d40211c, 0x301}, + {0x3d402130, 0x20300}, + {0x3d402134, 0xa100002}, + {0x3d402138, 0x13}, + {0x3d402144, 0x14000a}, + {0x3d402180, 0x640004}, + {0x3d402190, 0x3818200}, + {0x3d402194, 0x80303}, + {0x3d4021b4, 0x100}, + {0x3d403020, 0x21}, + {0x3d403024, 0x1f40}, + {0x3d403050, 0x20d040}, + {0x3d403064, 0x30005}, + {0x3d4030dc, 0x840000}, + {0x3d4030e0, 0x310000}, + {0x3d4030e8, 0x66004d}, + {0x3d4030ec, 0x16004d}, + {0x3d403100, 0xa020102}, + {0x3d403104, 0x30404}, + {0x3d403108, 0x203060b}, + {0x3d40310c, 0x505000}, + {0x3d403110, 0x2040202}, + {0x3d403114, 0x2030202}, + {0x3d403118, 0x1010004}, + {0x3d40311c, 0x301}, + {0x3d403130, 0x20300}, + {0x3d403134, 0xa100002}, + {0x3d403138, 0x5}, + {0x3d403144, 0x50003}, + {0x3d403180, 0x190004}, + {0x3d403190, 0x3818200}, + {0x3d403194, 0x80303}, + {0x3d4031b4, 0x100}, + {0x3d400028, 0x0}, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x3}, + {0x110a3, 0x4}, + {0x110a4, 0x5}, + {0x110a5, 0x2}, + {0x110a6, 0x7}, + {0x110a7, 0x6}, + {0x120a0, 0x0}, + {0x120a1, 0x1}, + {0x120a2, 0x3}, + {0x120a3, 0x2}, + {0x120a4, 0x5}, + {0x120a5, 0x4}, + {0x120a6, 0x7}, + {0x120a7, 0x6}, + {0x130a0, 0x0}, + {0x130a1, 0x1}, + {0x130a2, 0x2}, + {0x130a3, 0x3}, + {0x130a4, 0x4}, + {0x130a5, 0x5}, + {0x130a6, 0x6}, + {0x130a7, 0x7}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x1205f, 0x1ff}, + {0x1215f, 0x1ff}, + {0x1305f, 0x1ff}, + {0x1315f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x11205f, 0x1ff}, + {0x11215f, 0x1ff}, + {0x11305f, 0x1ff}, + {0x11315f, 0x1ff}, + {0x21005f, 0x1ff}, + {0x21015f, 0x1ff}, + {0x21105f, 0x1ff}, + {0x21115f, 0x1ff}, + {0x21205f, 0x1ff}, + {0x21215f, 0x1ff}, + {0x21305f, 0x1ff}, + {0x21315f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x3055, 0x1ff}, + {0x4055, 0x1ff}, + {0x5055, 0x1ff}, + {0x6055, 0x1ff}, + {0x7055, 0x1ff}, + {0x8055, 0x1ff}, + {0x9055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0x7}, + {0x2200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x2}, + {0x22002e, 0x2}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x20024, 0x1ab}, + {0x2003a, 0x0}, + {0x120024, 0x1ab}, + {0x2003a, 0x0}, + {0x220024, 0x1ab}, + {0x2003a, 0x0}, + {0x20056, 0x3}, + {0x120056, 0xa}, + {0x220056, 0xa}, + {0x1004d, 0xe00}, + {0x1014d, 0xe00}, + {0x1104d, 0xe00}, + {0x1114d, 0xe00}, + {0x1204d, 0xe00}, + {0x1214d, 0xe00}, + {0x1304d, 0xe00}, + {0x1314d, 0xe00}, + {0x11004d, 0xe00}, + {0x11014d, 0xe00}, + {0x11104d, 0xe00}, + {0x11114d, 0xe00}, + {0x11204d, 0xe00}, + {0x11214d, 0xe00}, + {0x11304d, 0xe00}, + {0x11314d, 0xe00}, + {0x21004d, 0xe00}, + {0x21014d, 0xe00}, + {0x21104d, 0xe00}, + {0x21114d, 0xe00}, + {0x21204d, 0xe00}, + {0x21214d, 0xe00}, + {0x21304d, 0xe00}, + {0x21314d, 0xe00}, + {0x10049, 0xeba}, + {0x10149, 0xeba}, + {0x11049, 0xeba}, + {0x11149, 0xeba}, + {0x12049, 0xeba}, + {0x12149, 0xeba}, + {0x13049, 0xeba}, + {0x13149, 0xeba}, + {0x110049, 0xeba}, + {0x110149, 0xeba}, + {0x111049, 0xeba}, + {0x111149, 0xeba}, + {0x112049, 0xeba}, + {0x112149, 0xeba}, + {0x113049, 0xeba}, + {0x113149, 0xeba}, + {0x210049, 0xeba}, + {0x210149, 0xeba}, + {0x211049, 0xeba}, + {0x211149, 0xeba}, + {0x212049, 0xeba}, + {0x212149, 0xeba}, + {0x213049, 0xeba}, + {0x213149, 0xeba}, + {0x43, 0x63}, + {0x1043, 0x63}, + {0x2043, 0x63}, + {0x3043, 0x63}, + {0x4043, 0x63}, + {0x5043, 0x63}, + {0x6043, 0x63}, + {0x7043, 0x63}, + {0x8043, 0x63}, + {0x9043, 0x63}, + {0x20018, 0x3}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x20008, 0x2ee}, + {0x120008, 0x64}, + {0x220008, 0x19}, + {0x20088, 0x9}, + {0x200b2, 0xdc}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x12043, 0x5a1}, + {0x12143, 0x5a1}, + {0x13043, 0x5a1}, + {0x13143, 0x5a1}, + {0x1200b2, 0xdc}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x112043, 0x5a1}, + {0x112143, 0x5a1}, + {0x113043, 0x5a1}, + {0x113143, 0x5a1}, + {0x2200b2, 0xdc}, + {0x210043, 0x5a1}, + {0x210143, 0x5a1}, + {0x211043, 0x5a1}, + {0x211143, 0x5a1}, + {0x212043, 0x5a1}, + {0x212143, 0x5a1}, + {0x213043, 0x5a1}, + {0x213143, 0x5a1}, + {0x200fa, 0x1}, + {0x1200fa, 0x1}, + {0x2200fa, 0x1}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x220019, 0x1}, + {0x200f0, 0x660}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5665}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x22002d, 0x0}, + {0x200c7, 0x21}, + {0x1200c7, 0x21}, + {0x2200c7, 0x21}, + {0x200ca, 0x24}, + {0x1200ca, 0x24}, + {0x2200ca, 0x24}, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xbb8}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x21}, + {0x5401b, 0x4d44}, + {0x5401c, 0x4d00}, + {0x5401e, 0x14}, + {0x5401f, 0x2dd4}, + {0x54020, 0x21}, + {0x54021, 0x4d44}, + {0x54022, 0x4d00}, + {0x54024, 0x14}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xd400}, + {0x54033, 0x212d}, + {0x54034, 0x4400}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1400}, + {0x54038, 0xd400}, + {0x54039, 0x212d}, + {0x5403a, 0x4400}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1400}, + {0xd0000, 0x1}, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x101}, + {0x54003, 0x190}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x102}, + {0x54003, 0x64}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x84}, + {0x5401a, 0x31}, + {0x5401b, 0x4d66}, + {0x5401c, 0x4d00}, + {0x5401e, 0x16}, + {0x5401f, 0x84}, + {0x54020, 0x31}, + {0x54021, 0x4d66}, + {0x54022, 0x4d00}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0x8400}, + {0x54033, 0x3100}, + {0x54034, 0x6600}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1600}, + {0x54038, 0x8400}, + {0x54039, 0x3100}, + {0x5403a, 0x6600}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xbb8}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400f, 0x100}, + {0x54010, 0x1f7f}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x21}, + {0x5401b, 0x4d44}, + {0x5401c, 0x4d00}, + {0x5401e, 0x14}, + {0x5401f, 0x2dd4}, + {0x54020, 0x21}, + {0x54021, 0x4d44}, + {0x54022, 0x4d00}, + {0x54024, 0x14}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xd400}, + {0x54033, 0x212d}, + {0x54034, 0x4400}, + {0x54035, 0x4d}, + {0x54036, 0x4d}, + {0x54037, 0x1400}, + {0x54038, 0xd400}, + {0x54039, 0x212d}, + {0x5403a, 0x4400}, + {0x5403b, 0x4d}, + {0x5403c, 0x4d}, + {0x5403d, 0x1400}, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xf}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x630}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x630}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x630}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x630}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x630}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x630}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x630}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x630}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x630}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x630}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x630}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x630}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x630}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xa}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x2}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x900a4, 0x10}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x623}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x623}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x790}, + {0x900a9, 0x11a}, + {0x900aa, 0x8}, + {0x900ab, 0x7aa}, + {0x900ac, 0x2a}, + {0x900ad, 0x10}, + {0x900ae, 0x7b2}, + {0x900af, 0x2a}, + {0x900b0, 0x0}, + {0x900b1, 0x7c8}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x0}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xc}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x0}, + {0x90169, 0x8}, + {0x9016a, 0x8}, + {0x9016b, 0x448}, + {0x9016c, 0x109}, + {0x9016d, 0xf}, + {0x9016e, 0x7c0}, + {0x9016f, 0x109}, + {0x90170, 0x0}, + {0x90171, 0xe8}, + {0x90172, 0x109}, + {0x90173, 0x47}, + {0x90174, 0x630}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0x618}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0xe0}, + {0x9017b, 0x109}, + {0x9017c, 0x0}, + {0x9017d, 0x7c8}, + {0x9017e, 0x109}, + {0x9017f, 0x8}, + {0x90180, 0x8140}, + {0x90181, 0x10c}, + {0x90182, 0x0}, + {0x90183, 0x1}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x4}, + {0x90187, 0x8}, + {0x90188, 0x8}, + {0x90189, 0x7c8}, + {0x9018a, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2a}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x5d}, + {0x2000c, 0xbb}, + {0x2000d, 0x753}, + {0x2000e, 0x2c}, + {0x12000b, 0xc}, + {0x12000c, 0x19}, + {0x12000d, 0xfa}, + {0x12000e, 0x10}, + {0x22000b, 0x3}, + {0x22000c, 0x6}, + {0x22000d, 0x3e}, + {0x22000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x60}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x220010, 0x5a}, + {0x220011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x240080, 0xe0}, + {0x240081, 0x12}, + {0x240082, 0xe0}, + {0x240083, 0x12}, + {0x240084, 0xe0}, + {0x240085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x12011, 0x1}, + {0x12012, 0x1}, + {0x12013, 0x180}, + {0x12018, 0x1}, + {0x12002, 0x6209}, + {0x120b2, 0x1}, + {0x121b4, 0x1}, + {0x122b4, 0x1}, + {0x123b4, 0x1}, + {0x124b4, 0x1}, + {0x125b4, 0x1}, + {0x126b4, 0x1}, + {0x127b4, 0x1}, + {0x128b4, 0x1}, + {0x13011, 0x1}, + {0x13012, 0x1}, + {0x13013, 0x180}, + {0x13018, 0x1}, + {0x13002, 0x6209}, + {0x130b2, 0x1}, + {0x131b4, 0x1}, + {0x132b4, 0x1}, + {0x133b4, 0x1}, + {0x134b4, 0x1}, + {0x135b4, 0x1}, + {0x136b4, 0x1}, + {0x137b4, 0x1}, + {0x138b4, 0x1}, + {0x2003a, 0x2}, + {0xc0080, 0x2}, + {0xd0000, 0x1} +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3000mts 1D */ + .drate = 3000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3000mts 2D */ + .drate = 3000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3000, 400, 100, }, +}; + diff --git a/board/engicam/imx8mm/spl.c b/board/engicam/imx8mm/spl.c new file mode 100644 index 0000000000..f9be769ec5 --- /dev/null +++ b/board/engicam/imx8mm/spl.c @@ -0,0 +1,101 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Engicam s.r.l. + * Copyright (C) 2020 Amarula Solutions(India) + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <hang.h> +#include <init.h> +#include <log.h> +#include <spl.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx8mm_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/arch/ddr.h> + +DECLARE_GLOBAL_DATA_PTR; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + switch (boot_dev_spl) { + case SD1_BOOT: + case SD2_BOOT: + case MMC2_BOOT: + return BOOT_DEVICE_MMC1; + case SD3_BOOT: + case MMC3_BOOT: + return BOOT_DEVICE_MMC2; + default: + return BOOT_DEVICE_NONE; + } +} + +static void spl_dram_init(void) +{ + ddr_init(&dram_timing); +} + +void spl_board_init(void) +{ + debug("Normal Boot\n"); +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static iomux_v3_cfg_t const uart_pads[] = { + IMX8MM_PAD_UART2_RXD_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MM_PAD_UART2_TXD_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + return 0; +} + +void board_init_f(ulong dummy) +{ + int ret; + + arch_cpu_init(); + + init_uart_clk(1); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + + enable_tzc380(); + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig new file mode 100644 index 0000000000..a553d89f05 --- /dev/null +++ b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig @@ -0,0 +1,84 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_IMX8MM_ICORE_MX8MM=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-icore-mx8mm-edimm2.2" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg" +CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-edimm2.2.dtb" +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="u-boot=> " +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_MII=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=2 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_CONS_INDEX=2 +CONFIG_DM_SERIAL=y +# CONFIG_SPL_DM_SERIAL is not set +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h new file mode 100644 index 0000000000..9f63f32fc3 --- /dev/null +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -0,0 +1,58 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#ifndef __IMX8MM_ICORE_MX8MM_H +#define __IMX8MM_ICORE_MX8MM_H + +#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 +#define PHYS_SDRAM_SIZE 0x40000000 /* 2GB DDR */ + +#include "imx8mm-common.h" + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (PHYS_SDRAM_SIZE >> 1)) + +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 2) \ + func(MMC, mmc, 0) +#include <config_distro_bootcmd.h> +#undef CONFIG_ISO_PARTITION +#else +#define BOOTENV +#endif + +#define ENV_MEM_LAYOUT_SETTINGS \ + "fdt_addr_r=0x44000000\0" \ + "kernel_addr_r=0x42000000\0" \ + "ramdisk_addr_r=0x46400000\0" \ + "scriptaddr=0x46000000\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + ENV_MEM_LAYOUT_SETTINGS \ + "fdt_addr=0x43000000\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "console=ttymxc1,115200\0" \ + BOOTENV + +#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* USDHC */ +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 100000 + +#endif /* __IMX8MM_ICORE_MX8MM_H */
Engicam C.TOUCH 2.0 is an EDIMM compliant general purpose Carrier board.
Genaral features: - Ethernet 10/100 - Wifi/BT - USB Type A/OTG - Audio Out - CAN - LVDS panel connector
i.Core MX8M Mini needs to mount on top of this Carrier board for creating complete i.Core MX8M Mini C.TOUCH 2.0 board.
Add support for it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 1 + .../imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi | 31 ++++++ arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts | 97 +++++++++++++++++++ arch/arm/mach-imx/imx8m/Kconfig | 5 + board/engicam/imx8mm/MAINTAINERS | 6 ++ configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 84 ++++++++++++++++ 6 files changed, 224 insertions(+) create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts create mode 100644 configs/imx8mm-icore-mx8mm-ctouch2_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index accf96bfc3..f478f6f18f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -782,6 +782,7 @@ dtb-$(CONFIG_ARCH_IMX8) += \ imx8-giedi.dtb
dtb-$(CONFIG_ARCH_IMX8M) += \ + imx8mm-icore-mx8mm-ctouch2.dtb \ imx8mm-icore-mx8mm-edimm2.2.dtb \ imx8mm-evk.dtb \ imx8mm-verdin.dtb \ diff --git a/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi b/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi new file mode 100644 index 0000000000..8b67bcff7d --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2-u-boot.dtsi @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +#include "imx8mm-icore-mx8mm-u-boot.dtsi" + +&gpio1 { + u-boot,dm-spl; +}; + +&pinctrl_uart2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1 { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts b/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts new file mode 100644 index 0000000000..5389d6f2be --- /dev/null +++ b/arch/arm/dts/imx8mm-icore-mx8mm-ctouch2.dts @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 NXP + * Copyright (c) 2019 Engicam srl + * Copyright (c) 2020 Amarula Solutions(India) + */ + +/dts-v1/; +#include "imx8mm.dtsi" +#include "imx8mm-icore-mx8mm.dtsi" + +/ { + model = "Engicam i.Core MX8M Mini C.TOUCH 2.0"; + compatible = "engicam,icore-mx8mm-ctouch2", "engicam,icore-mx8mm", + "fsl,imx8mm"; + + chosen { + stdout-path = &uart2; + }; +}; + +&fec1 { + status = "okay"; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c4 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; +}; + +&iomuxc { + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MM_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MM_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SCL_I2C4_SCL 0x400001c3 + MX8MM_IOMUXC_I2C4_SDA_I2C4_SDA 0x400001c3 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MM_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 + MX8MM_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 + >; + }; + + pinctrl_usdhc1_gpio: usdhc1gpiogrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x41 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MM_IOMUXC_SD1_CLK_USDHC1_CLK 0x190 + MX8MM_IOMUXC_SD1_CMD_USDHC1_CMD 0x1d0 + MX8MM_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x1d0 + MX8MM_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x1d0 + MX8MM_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x1d0 + MX8MM_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x1d0 + >; + }; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +/* SD */ +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>, <&pinctrl_usdhc1_gpio>; + cd-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>; + max-frequency = <50000000>; + bus-width = <4>; + no-1-8-v; + pm-ignore-notify; + keep-power-in-suspend; + status = "okay"; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 3410462907..5801bcf282 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -56,6 +56,11 @@ config TARGET_IMX8MM_ICORE_MX8MM * i.Core MX8M Mini needs to mount on top of EDIMM2.2 for creating complete i.Core MX8M Mini EDIMM2.2 Starter Kit.
+ i.Core MX8M Mini C.TOUCH 2.0 + * C.TOUCH 2.0 is a general purpose Carrier board. + * i.Core MX8M Mini needs to mount on top of this Carrier board + for creating complete i.Core MX8M Mini C.TOUCH 2.0 board. + config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" select IMX8MN diff --git a/board/engicam/imx8mm/MAINTAINERS b/board/engicam/imx8mm/MAINTAINERS index 044a9392ac..2e99a5995f 100644 --- a/board/engicam/imx8mm/MAINTAINERS +++ b/board/engicam/imx8mm/MAINTAINERS @@ -1,3 +1,9 @@ +i.Core-MX8M-Mini-CTOUCH2.0 +M: Jagan Teki jagan@amarulasolutions.com +M: Matteo Lisi matteo.lisi@engicam.com +S: Maintained +F: configs/imx8mm-icore-mx8mm-ctouch2_defconfig + i.Core-MX8M-Mini-EDIMM2.2 M: Jagan Teki jagan@amarulasolutions.com M: Matteo Lisi matteo.lisi@engicam.com diff --git a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig new file mode 100644 index 0000000000..5bef3d5954 --- /dev/null +++ b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig @@ -0,0 +1,84 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_IMX8MM_ICORE_MX8MM=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-icore-mx8mm-ctouch2" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg" +CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-ctouch2.dtb" +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="u-boot=> " +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_MII=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=2 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_CONS_INDEX=2 +CONFIG_DM_SERIAL=y +# CONFIG_SPL_DM_SERIAL is not set +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y
Jagan Teki
