[U-Boot] [PATCH v2 0/5] colibri imx8qxp 2gb wb it v1.0b module support
This series fixes the i.MX 8QXP SCFW API header file, adds support for more lpuart instances, cleans-up and extends the Toradex SKU handling and last but not least introduces support for the Toradex Colibri iMX8QXP 2GB WB IT V1.0B module.
This series is available together with my previous series addressing Apalis and Colibri iMX6 as well as Colibri Vybrid aka VF50/VF61 and Colibri iMX6ULL on our git server [1].
[1] http://git.toradex.com/cgit/u-boot-toradex.git/log/?h=for-next
Changes in v2: - Added Peng and Igor's reviewed-by. - Added Peng and Igor's reviewed-by. - Added Igor's reviewed-by. - Added Igor's reviewed-by. - Changed imx-atf git clone command to include initial branch information as suggested by Igor. - Sorted board file includes alphabetically as suggested by Igor. - Got rid of SPL configuration in legacy header file as suggested by Igor and the whole use of SPL on i.MX 8X anyway neither works well nor makes any much sense at all.
Marcel Ziswiler (5): misc: imx8: remove duplicates from scfw api arm: dts: imx8dx: add lpuart1, lpuart2, lpuart3 board: toradex: tdx-cfg-block: clean-up sku handling board: toradex: tdx-cfg-block: add new skus board: toradex: add colibri imx8qxp 2gb wb it v1.0b module support
arch/arm/dts/Makefile | 4 +- arch/arm/dts/fsl-imx8dx.dtsi | 54 +++ arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi | 112 ++++++ arch/arm/dts/fsl-imx8qxp-colibri.dts | 328 ++++++++++++++++++ arch/arm/include/asm/arch-imx8/sci/sci.h | 4 - arch/arm/mach-imx/imx8/Kconfig | 6 + board/toradex/colibri-imx8qxp/Kconfig | 30 ++ board/toradex/colibri-imx8qxp/MAINTAINERS | 9 + board/toradex/colibri-imx8qxp/Makefile | 7 + board/toradex/colibri-imx8qxp/README | 66 ++++ .../toradex/colibri-imx8qxp/colibri-imx8qxp.c | 212 +++++++++++ board/toradex/colibri-imx8qxp/imximage.cfg | 24 ++ board/toradex/common/tdx-cfg-block.c | 19 +- board/toradex/common/tdx-cfg-block.h | 29 +- configs/colibri-imx8qxp_defconfig | 53 +++ include/configs/colibri-imx8qxp.h | 214 ++++++++++++ 16 files changed, 1152 insertions(+), 19 deletions(-) create mode 100644 arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi create mode 100644 arch/arm/dts/fsl-imx8qxp-colibri.dts create mode 100644 board/toradex/colibri-imx8qxp/Kconfig create mode 100644 board/toradex/colibri-imx8qxp/MAINTAINERS create mode 100644 board/toradex/colibri-imx8qxp/Makefile create mode 100644 board/toradex/colibri-imx8qxp/README create mode 100644 board/toradex/colibri-imx8qxp/colibri-imx8qxp.c create mode 100644 board/toradex/colibri-imx8qxp/imximage.cfg create mode 100644 configs/colibri-imx8qxp_defconfig create mode 100644 include/configs/colibri-imx8qxp.h
Remove duplicate function declarations from the SCFW API header file.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
arch/arm/include/asm/arch-imx8/sci/sci.h | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/arch/arm/include/asm/arch-imx8/sci/sci.h b/arch/arm/include/asm/arch-imx8/sci/sci.h index d1621669e2..97377697f0 100644 --- a/arch/arm/include/asm/arch-imx8/sci/sci.h +++ b/arch/arm/include/asm/arch-imx8/sci/sci.h @@ -62,10 +62,6 @@ int sc_pm_set_clock_rate(sc_ipc_t ipc, sc_rsrc_t resource, sc_pm_clk_t clk, sc_pm_clock_rate_t *rate); int sc_pm_get_clock_rate(sc_ipc_t ipc, sc_rsrc_t resource, sc_pm_clk_t clk, sc_pm_clock_rate_t *rate); -int sc_pm_set_clock_rate(sc_ipc_t ipc, sc_rsrc_t resource, sc_pm_clk_t clk, - sc_pm_clock_rate_t *rate); -int sc_pm_get_clock_rate(sc_ipc_t ipc, sc_rsrc_t resource, sc_pm_clk_t clk, - sc_pm_clock_rate_t *rate); int sc_pm_clock_enable(sc_ipc_t ipc, sc_rsrc_t resource, sc_pm_clk_t clk, sc_bool_t enable, sc_bool_t autog);
From: Marcel Ziswiler marcel.ziswiler@toradex.com Remove duplicate function declarations from the SCFW API header file. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
Best regards, Stefano Babic
Add support for lpuart1, lpuart2 and lpuart3.
arch/arm/dts/fsl-imx8dx.dtsi | 54 ++++++++++++++++++++++++++++++++++++ 1 file changed, 54 insertions(+)
diff --git a/arch/arm/dts/fsl-imx8dx.dtsi b/arch/arm/dts/fsl-imx8dx.dtsi index 3b1a2a20e3..715abb413d 100644 --- a/arch/arm/dts/fsl-imx8dx.dtsi +++ b/arch/arm/dts/fsl-imx8dx.dtsi @@ -236,6 +236,21 @@ power-domains = <&pd_dma>; wakeup-irq = <225>; }; + pd_dma_lpuart1: PD_DMA_UART1 { + reg = <SC_R_UART_1>; + #power-domain-cells = <0>; + power-domains = <&pd_dma>; + }; + pd_dma_lpuart2: PD_DMA_UART2 { + reg = <SC_R_UART_2>; + #power-domain-cells = <0>; + power-domains = <&pd_dma>; + }; + pd_dma_lpuart3: PD_DMA_UART3 { + reg = <SC_R_UART_3>; + #power-domain-cells = <0>; + power-domains = <&pd_dma>; + }; }; };
@@ -402,6 +417,45 @@ status = "disabled"; };
+ lpuart1: serial@5a070000 { + compatible = "fsl,imx8qm-lpuart"; + reg = <0x0 0x5a070000 0x0 0x1000>; + interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8QXP_UART1_CLK>, + <&clk IMX8QXP_UART1_IPG_CLK>; + clock-names = "per", "ipg"; + assigned-clocks = <&clk IMX8QXP_UART1_CLK>; + assigned-clock-rates = <80000000>; + power-domains = <&pd_dma_lpuart1>; + status = "disabled"; + }; + + lpuart2: serial@5a080000 { + compatible = "fsl,imx8qm-lpuart"; + reg = <0x0 0x5a080000 0x0 0x1000>; + interrupts = <GIC_SPI 227 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8QXP_UART2_CLK>, + <&clk IMX8QXP_UART2_IPG_CLK>; + clock-names = "per", "ipg"; + assigned-clocks = <&clk IMX8QXP_UART2_CLK>; + assigned-clock-rates = <80000000>; + power-domains = <&pd_dma_lpuart2>; + status = "disabled"; + }; + + lpuart3: serial@5a090000 { + compatible = "fsl,imx8qm-lpuart"; + reg = <0x0 0x5a090000 0x0 0x1000>; + interrupts = <GIC_SPI 228 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8QXP_UART3_CLK>, + <&clk IMX8QXP_UART3_IPG_CLK>; + clock-names = "per", "ipg"; + assigned-clocks = <&clk IMX8QXP_UART3_CLK>; + assigned-clock-rates = <80000000>; + power-domains = <&pd_dma_lpuart3>; + status = "disabled"; + }; + usdhc1: usdhc@5b010000 { compatible = "fsl,imx8qm-usdhc", "fsl,imx6sl-usdhc"; interrupt-parent = <&gic>;
From: Marcel Ziswiler marcel.ziswiler@toradex.com Add support for lpuart1, lpuart2 and lpuart3. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
Clean-up handling of several SKUs.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
Changes in v2: - Added Igor's reviewed-by.
board/toradex/common/tdx-cfg-block.c | 12 ++++++++---- board/toradex/common/tdx-cfg-block.h | 22 ++++++++++++---------- 2 files changed, 20 insertions(+), 14 deletions(-)
diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 71ff40cfad..7e529afc7f 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -6,7 +6,9 @@ #include <common.h> #include "tdx-cfg-block.h"
-#if defined(CONFIG_TARGET_APALIS_IMX6) || defined(CONFIG_TARGET_COLIBRI_IMX6) +#if defined(CONFIG_TARGET_APALIS_IMX6) || \ + defined(CONFIG_TARGET_COLIBRI_IMX6) || \ + defined(CONFIG_TARGET_COLIBRI_IMX8QXP) #include <asm/arch/sys_proto.h> #else #define is_cpu_type(cpu) (0) @@ -92,10 +94,10 @@ const char * const toradex_modules[] = { [34] = "Apalis TK1 2GB", [35] = "Apalis iMX6 Dual 1GB IT", [36] = "Colibri iMX6ULL 256MB", - [37] = "Apalis iMX8 QuadMax 4GB Wi-Fi / Bluetooth", - [38] = "Colibri iMX8X", + [37] = "Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT", + [38] = "Colibri iMX8 QuadXPlus 2GB Wi-Fi / BT IT", [39] = "Colibri iMX7 Dual 1GB (eMMC)", - [40] = "Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT", + [40] = "Colibri iMX6ULL 512MB Wi-Fi / BT IT", [41] = "Colibri iMX7 Dual 512MB EPDC", [42] = "Apalis TK1 4GB", [43] = "Colibri T20 512MB IT SETEK", @@ -340,6 +342,8 @@ static int get_cfgblock_interactive(void) tdx_hw_tag.prodid = COLIBRI_IMX7D; else if (!strcmp("imx7s", soc)) tdx_hw_tag.prodid = COLIBRI_IMX7S; + else if (is_cpu_type(MXC_CPU_IMX8QXP)) + tdx_hw_tag.prodid = COLIBRI_IMX8QXP_WIFI_BT_IT; else if (!strcmp("tegra20", soc)) { if (it == 'y' || it == 'Y') if (gd->ram_size == 0x10000000) diff --git a/board/toradex/common/tdx-cfg-block.h b/board/toradex/common/tdx-cfg-block.h index 961bb4394f..b20b522e1d 100644 --- a/board/toradex/common/tdx-cfg-block.h +++ b/board/toradex/common/tdx-cfg-block.h @@ -25,42 +25,44 @@ enum { COLIBRI_PXA270_V1_520MHZ, COLIBRI_PXA320, COLIBRI_PXA300, - COLIBRI_PXA310, + COLIBRI_PXA310, /* 5 */ COLIBRI_PXA320_IT, COLIBRI_PXA300_XT, COLIBRI_PXA270_312MHZ, COLIBRI_PXA270_520MHZ, - COLIBRI_VF50, /* not currently on sale */ - COLIBRI_VF61, + COLIBRI_VF50, /* 10 */ + COLIBRI_VF61, /* not currently on sale */ COLIBRI_VF61_IT, COLIBRI_VF50_IT, COLIBRI_IMX6S, - COLIBRI_IMX6DL, + COLIBRI_IMX6DL, /* 15 */ COLIBRI_IMX6S_IT, COLIBRI_IMX6DL_IT, + /* 18 */ + /* 19 */ COLIBRI_T20_256MB = 20, COLIBRI_T20_512MB, COLIBRI_T20_512MB_IT, COLIBRI_T30, COLIBRI_T20_256MB_IT, - APALIS_T30_2GB, + APALIS_T30_2GB, /* 25 */ APALIS_T30_1GB, APALIS_IMX6Q, APALIS_IMX6Q_IT, APALIS_IMX6D, - COLIBRI_T30_IT, + COLIBRI_T30_IT, /* 30 */ APALIS_T30_IT, COLIBRI_IMX7S, COLIBRI_IMX7D, APALIS_TK1_2GB, - APALIS_IMX6D_IT, + APALIS_IMX6D_IT, /* 35 */ COLIBRI_IMX6ULL, - APALIS_IMX8QM, /* 37 */ - COLIBRI_IMX8X, + APALIS_IMX8QM_WIFI_BT_IT, + COLIBRI_IMX8QXP_WIFI_BT_IT, COLIBRI_IMX7D_EMMC, COLIBRI_IMX6ULL_WIFI_BT_IT, /* 40 */ COLIBRI_IMX7D_EPDC, - APALIS_TK1_4GB, + APALIS_TK1_4GB, /* not currently on sale */ COLIBRI_T20_512MB_IT_SETEK, COLIBRI_IMX6ULL_IT, COLIBRI_IMX6ULL_WIFI_BT, /* 45 */
From: Marcel Ziswiler marcel.ziswiler@toradex.com Clean-up handling of several SKUs. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
Add all the latest new SKUs: - Apalis iMX8 QuadXPlus 2GB Wi-Fi / BT IT - Apalis iMX8 QuadMax 4GB IT - Apalis iMX8 QuadPlus 2GB Wi-Fi / BT - Apalis iMX8 QuadPlus 2GB", - Colibri iMX8 QuadXPlus 2GB IT - Colibri iMX8 DualX 1GB Wi-Fi / Bluetooth - Colibri iMX8 DualX 1GB
board/toradex/common/tdx-cfg-block.c | 7 +++++++ board/toradex/common/tdx-cfg-block.h | 7 +++++++ 2 files changed, 14 insertions(+)
diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 7e529afc7f..f69c4433b2 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -103,6 +103,13 @@ const char * const toradex_modules[] = { [43] = "Colibri T20 512MB IT SETEK", [44] = "Colibri iMX6ULL 512MB IT", [45] = "Colibri iMX6ULL 512MB Wi-Fi / Bluetooth", + [46] = "Apalis iMX8 QuadXPlus 2GB Wi-Fi / BT IT", + [47] = "Apalis iMX8 QuadMax 4GB IT", + [48] = "Apalis iMX8 QuadPlus 2GB Wi-Fi / BT", + [49] = "Apalis iMX8 QuadPlus 2GB", + [50] = "Colibri iMX8 QuadXPlus 2GB IT", + [51] = "Colibri iMX8 DualX 1GB Wi-Fi / Bluetooth", + [52] = "Colibri iMX8 DualX 1GB", };
#ifdef CONFIG_TDX_CFG_BLOCK_IS_IN_MMC diff --git a/board/toradex/common/tdx-cfg-block.h b/board/toradex/common/tdx-cfg-block.h index b20b522e1d..bfdc8b7f70 100644 --- a/board/toradex/common/tdx-cfg-block.h +++ b/board/toradex/common/tdx-cfg-block.h @@ -66,6 +66,13 @@ enum { COLIBRI_T20_512MB_IT_SETEK, COLIBRI_IMX6ULL_IT, COLIBRI_IMX6ULL_WIFI_BT, /* 45 */ + APALIS_IMX8QXP_WIFI_BT_IT, + APALIS_IMX8QM_IT, + APALIS_IMX8QP_WIFI_BT, + APALIS_IMX8QP, + COLIBRI_IMX8QXP_IT, /* 50 */ + COLIBRI_IMX8DX_WIFI_BT, + COLIBRI_IMX8DX, };
extern const char * const toradex_modules[];
From: Marcel Ziswiler marcel.ziswiler@toradex.com Add all the latest new SKUs:
This commit adds initial support for the Toradex Colibri iMX8QXP 2GB WB IT V1.0B module. Unlike the V1.0A early access samples exclusively booting from SD card, they are now strapped to boot from eFuses which are factory fused to properly boot from their on-module eMMC. U-Boot supports either booting from the on-module eMMC or may be used for recovery purpose using the universal update utility (uuu) aka mfgtools 3.0.
Functionality wise the following is known to be working: - eMMC and MMC/SD card - Ethernet - GPIOs - I2C
Unfortunately, there is no USB functionality for the i.MX 8QXP as of yet.
Changes in v2: - Changed imx-atf git clone command to include initial branch information as suggested by Igor. - Sorted board file includes alphabetically as suggested by Igor. - Got rid of SPL configuration in legacy header file as suggested by Igor and the whole use of SPL on i.MX 8X anyway neither works well nor makes any much sense at all.
arch/arm/dts/Makefile | 4 +- arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi | 112 ++++++ arch/arm/dts/fsl-imx8qxp-colibri.dts | 328 ++++++++++++++++++ arch/arm/mach-imx/imx8/Kconfig | 6 + board/toradex/colibri-imx8qxp/Kconfig | 30 ++ board/toradex/colibri-imx8qxp/MAINTAINERS | 9 + board/toradex/colibri-imx8qxp/Makefile | 7 + board/toradex/colibri-imx8qxp/README | 66 ++++ .../toradex/colibri-imx8qxp/colibri-imx8qxp.c | 212 +++++++++++ board/toradex/colibri-imx8qxp/imximage.cfg | 24 ++ configs/colibri-imx8qxp_defconfig | 53 +++ include/configs/colibri-imx8qxp.h | 214 ++++++++++++ 12 files changed, 1064 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi create mode 100644 arch/arm/dts/fsl-imx8qxp-colibri.dts create mode 100644 board/toradex/colibri-imx8qxp/Kconfig create mode 100644 board/toradex/colibri-imx8qxp/MAINTAINERS create mode 100644 board/toradex/colibri-imx8qxp/Makefile create mode 100644 board/toradex/colibri-imx8qxp/README create mode 100644 board/toradex/colibri-imx8qxp/colibri-imx8qxp.c create mode 100644 board/toradex/colibri-imx8qxp/imximage.cfg create mode 100644 configs/colibri-imx8qxp_defconfig create mode 100644 include/configs/colibri-imx8qxp.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 13d1d67624..2a551d42a4 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -559,7 +559,9 @@ dtb-$(CONFIG_MX7) += imx7d-sdb.dtb \
dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-evk.dtb
-dtb-$(CONFIG_ARCH_IMX8) += fsl-imx8qxp-mek.dtb +dtb-$(CONFIG_ARCH_IMX8) += \ + fsl-imx8qxp-colibri.dtb \ + fsl-imx8qxp-mek.dtb
dtb-$(CONFIG_ARCH_IMX8M) += fsl-imx8mq-evk.dtb
diff --git a/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi b/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi new file mode 100644 index 0000000000..f8686befdf --- /dev/null +++ b/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi @@ -0,0 +1,112 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * Copyright 2019 Toradex AG + */ + +&mu { + u-boot,dm-spl; +}; + +&clk { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&pd_lsio { + u-boot,dm-spl; +}; + +&pd_lsio_gpio0 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio1 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio2 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio3 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio4 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio5 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio6 { + u-boot,dm-spl; +}; + +&pd_lsio_gpio7 { + u-boot,dm-spl; +}; + +&pd_conn { + u-boot,dm-spl; +}; + +&pd_conn_sdch0 { + u-boot,dm-spl; +}; + +&pd_conn_sdch1 { + u-boot,dm-spl; +}; + +&pd_conn_sdch2 { + u-boot,dm-spl; +}; + +&gpio0 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&gpio6 { + u-boot,dm-spl; +}; + +&gpio7 { + u-boot,dm-spl; +}; + +&lpuart3 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/fsl-imx8qxp-colibri.dts b/arch/arm/dts/fsl-imx8qxp-colibri.dts new file mode 100644 index 0000000000..0c20edf2cf --- /dev/null +++ b/arch/arm/dts/fsl-imx8qxp-colibri.dts @@ -0,0 +1,328 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * Copyright 2019 Toradex AG + */ + +/dts-v1/; + +#include "fsl-imx8qxp.dtsi" +#include "fsl-imx8qxp-colibri-u-boot.dtsi" + +/ { + model = "Toradex Colibri iMX8QXP"; + compatible = "toradex,colibri-imx8qxp", "fsl,imx8qxp"; + + chosen { + bootargs = "console=ttyLP3,115200 earlycon=lpuart32,0x5a090000,115200"; + stdout-path = &lpuart3; + }; + + reg_usbh_vbus: regulator-usbh-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbh1_reg>; + regulator-name = "usbh_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 3 GPIO_ACTIVE_LOW>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog0>, <&pinctrl_hog1>, <&pinctrl_hog2>; + + colibri-imx8qxp { + pinctrl_lpuart0: lpuart0grp { + fsl,pins = < + SC_P_UART0_RX_ADMA_UART0_RX 0x06000020 + SC_P_UART0_TX_ADMA_UART0_TX 0x06000020 + >; + }; + + pinctrl_lpuart3: lpuart3grp { + fsl,pins = < + SC_P_FLEXCAN2_RX_ADMA_UART3_RX 0x06000020 + SC_P_FLEXCAN2_TX_ADMA_UART3_TX 0x06000020 + >; + }; + + pinctrl_lpuart3_ctrl: lpuart3ctrlgrp { + fsl,pins = < + SC_P_MIPI_DSI1_GPIO0_01_LSIO_GPIO2_IO00 0x00000020 /* DTR */ + SC_P_SAI1_RXD_LSIO_GPIO0_IO29 0x00000020 /* CTS */ + SC_P_SAI1_RXC_LSIO_GPIO0_IO30 0x00000020 /* RTS */ + SC_P_CSI_RESET_LSIO_GPIO3_IO03 0x00000020 /* DSR */ + SC_P_USDHC1_CD_B_LSIO_GPIO4_IO22 0x00000020 /* DCD */ + SC_P_CSI_EN_LSIO_GPIO3_IO02 0x00000020 /* RI */ + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETB0_PAD 0x000014a0 /* Use pads in 3.3V mode */ + SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETB1_PAD 0x000014a0 /* Use pads in 3.3V mode */ + SC_P_ENET0_MDC_CONN_ENET0_MDC 0x06000020 + SC_P_ENET0_MDIO_CONN_ENET0_MDIO 0x06000020 + SC_P_ENET0_RGMII_TX_CTL_CONN_ENET0_RGMII_TX_CTL 0x00000061 + SC_P_ENET0_RGMII_TXC_CONN_ENET0_RCLK50M_OUT 0x06000061 + SC_P_ENET0_RGMII_TXD0_CONN_ENET0_RGMII_TXD0 0x00000061 + SC_P_ENET0_RGMII_TXD1_CONN_ENET0_RGMII_TXD1 0x00000061 + SC_P_ENET0_RGMII_RX_CTL_CONN_ENET0_RGMII_RX_CTL 0x00000061 + SC_P_ENET0_RGMII_RXD0_CONN_ENET0_RGMII_RXD0 0x00000061 + SC_P_ENET0_RGMII_RXD1_CONN_ENET0_RGMII_RXD1 0x00000061 + SC_P_ENET0_RGMII_RXD2_CONN_ENET0_RMII_RX_ER 0x00000061 + >; + }; + + pinctrl_gpio_bl_on: gpio-bl-on { + fsl,pins = < + SC_P_QSPI0A_DATA3_LSIO_GPIO3_IO12 0x00000040 + >; + }; + + pinctrl_hog0: hog0grp { + fsl,pins = < + SC_P_COMP_CTL_GPIO_1V8_3V3_GPIORHB_PAD 0x000514a0 /* Use pads in 3.3V mode */ + >; + }; + + pinctrl_hog1: hog1grp { + fsl,pins = < + SC_P_QSPI0A_DATA1_LSIO_GPIO3_IO10 0x00000020 /* 45 */ + SC_P_ENET0_RGMII_TXD3_LSIO_GPIO5_IO02 0x06000020 /* 65 */ + SC_P_CSI_D07_CI_PI_D09 0x00000061 + SC_P_QSPI0A_DATA2_LSIO_GPIO3_IO11 0x00000020 /* 69 */ + SC_P_QSPI0A_DQS_LSIO_GPIO3_IO13 0x00000020 /* 73 */ + SC_P_SAI0_TXC_LSIO_GPIO0_IO26 0x00000020 /* 79 */ + SC_P_CSI_D02_CI_PI_D04 0x00000061 + SC_P_ENET0_RGMII_RXC_LSIO_GPIO5_IO03 0x06000020 /* 85 */ + SC_P_CSI_D06_CI_PI_D08 0x00000061 + SC_P_QSPI0B_SCLK_LSIO_GPIO3_IO17 0x00000020 /* 95 */ + SC_P_SAI0_RXD_LSIO_GPIO0_IO27 0x00000020 /* 97 */ + SC_P_CSI_D03_CI_PI_D05 0x00000061 + SC_P_QSPI0B_DATA0_LSIO_GPIO3_IO18 0x00000020 /* 99 */ + SC_P_SAI0_TXFS_LSIO_GPIO0_IO28 0x00000020 /* 101 */ + SC_P_CSI_D00_CI_PI_D02 0x00000061 + SC_P_SAI0_TXD_LSIO_GPIO0_IO25 0x00000020 /* 103 */ + SC_P_CSI_D01_CI_PI_D03 0x00000061 + SC_P_QSPI0B_DATA1_LSIO_GPIO3_IO19 0x00000020 /* 105 */ + SC_P_QSPI0B_DATA2_LSIO_GPIO3_IO20 0x00000020 /* 107 */ + SC_P_USB_SS3_TC2_LSIO_GPIO4_IO05 0x00000020 /* 127 */ + SC_P_USB_SS3_TC3_LSIO_GPIO4_IO06 0x00000020 /* 131 */ + SC_P_USB_SS3_TC1_LSIO_GPIO4_IO04 0x00000020 /* 133 */ + SC_P_CSI_PCLK_LSIO_GPIO3_IO00 0x00000020 /* 96 */ + SC_P_QSPI0B_DATA3_LSIO_GPIO3_IO21 0x00000020 /* 98 */ + SC_P_SAI1_RXFS_LSIO_GPIO0_IO31 0x00000020 /* 100 */ + SC_P_QSPI0B_DQS_LSIO_GPIO3_IO22 0x00000020 /* 102 */ + SC_P_QSPI0B_SS0_B_LSIO_GPIO3_IO23 0x00000020 /* 104 */ + SC_P_QSPI0B_SS1_B_LSIO_GPIO3_IO24 0x00000020 /* 106 */ + >; + }; + + pinctrl_hog2: hog2grp { + fsl,pins = < + SC_P_CSI_MCLK_LSIO_GPIO3_IO01 0x00000020 /* 75 */ + SC_P_QSPI0A_SS0_B_LSIO_GPIO3_IO14 0x00000020 /* 77 */ + SC_P_QSPI0A_SS1_B_LSIO_GPIO3_IO15 0x00000020 /* 89 */ + SC_P_QSPI0A_SCLK_LSIO_GPIO3_IO16 0x00000020 /* 93 */ + >; + }; + + /* Off Module I2C */ + pinctrl_i2c1: i2c1grp { + fsl,pins = < + SC_P_MIPI_DSI0_GPIO0_00_ADMA_I2C1_SCL 0x06000021 + SC_P_MIPI_DSI0_GPIO0_01_ADMA_I2C1_SDA 0x06000021 + >; + }; + + /*INT*/ + pinctrl_usb3503a: usb3503a-grp { + fsl,pins = < + SC_P_MIPI_CSI0_MCLK_OUT_LSIO_GPIO3_IO04 0x00000061 + >; + }; + + pinctrl_usbc_det: usbc-det { + fsl,pins = < + SC_P_ENET0_REFCLK_125M_25M_LSIO_GPIO5_IO09 0x06000040 + >; + }; + + pinctrl_usbh1_reg: usbh1-reg { + fsl,pins = < + SC_P_USB_SS3_TC0_LSIO_GPIO4_IO03 0x06000040 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000021 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000021 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000021 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000021 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000021 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000021 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000021 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000021 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000021 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x00000041 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000021 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000021 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000021 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000021 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000021 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000021 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000021 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000021 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000021 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000021 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x00000041 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000021 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 + SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x00000021 + SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x00000021 + SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x00000021 + SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x00000021 + SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x00000021 + SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x00000021 + SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x00000021 + SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x00000021 + SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x00000021 + SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x00000041 + SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x00000021 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2gpiogrp { + fsl,pins = < + SC_P_QSPI0A_DATA0_LSIO_GPIO3_IO09 0x06000021 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000021 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000021 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000021 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000021 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000021 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000021 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000021 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000021 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000021 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000021 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000021 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000021 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 + SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x00000021 + SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x00000021 + SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x00000021 + SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x00000021 + SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x00000021 + SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x00000021 + >; + }; + }; +}; + +&lpuart0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart0>; + status = "okay"; +}; + +&lpuart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart3>, <&pinctrl_lpuart3_ctrl>; + status = "okay"; +}; + +&gpio0 { + status = "okay"; +}; + +&gpio1 { + status = "okay"; +}; + +&gpio3 { + status = "okay"; +}; + +&gpio4 { + status = "okay"; +}; + +&fec1 { + phy-handle = <ðphy0>; + phy-mode = "rmii"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@2 { + compatible = "ethernet-phy-ieee802.3-c22"; + max-speed = <100>; + reg = <2>; + }; + }; +}; + +&i2c1 { + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&usdhc1 { + bus-width = <8>; + non-removable; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + status = "okay"; +}; + +&usdhc2 { + bus-width = <4>; + cd-gpios = <&gpio3 9 GPIO_ACTIVE_LOW>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + status = "okay"; +}; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index f76a139684..feea07f135 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -22,6 +22,11 @@ choice prompt "i.MX8 board select" optional
+config TARGET_COLIBRI_IMX8QXP + bool "Support Colibri iMX8QXP module" + select BOARD_LATE_INIT + select IMX8QXP + config TARGET_IMX8QXP_MEK bool "Support i.MX8QXP MEK board" select BOARD_LATE_INIT @@ -30,5 +35,6 @@ config TARGET_IMX8QXP_MEK endchoice
source "board/freescale/imx8qxp_mek/Kconfig" +source "board/toradex/colibri-imx8qxp/Kconfig"
endif diff --git a/board/toradex/colibri-imx8qxp/Kconfig b/board/toradex/colibri-imx8qxp/Kconfig new file mode 100644 index 0000000000..340fe72816 --- /dev/null +++ b/board/toradex/colibri-imx8qxp/Kconfig @@ -0,0 +1,30 @@ +if TARGET_COLIBRI_IMX8QXP + +config SYS_BOARD + default "colibri-imx8qxp" + +config SYS_VENDOR + default "toradex" + +config SYS_CONFIG_NAME + default "colibri-imx8qxp" + +config TDX_CFG_BLOCK + default y + +config TDX_HAVE_MMC + default y + +config TDX_CFG_BLOCK_DEV + default "0" + +config TDX_CFG_BLOCK_PART + default "1" + +# Toradex config block in eMMC, at the end of 1st "boot sector" +config TDX_CFG_BLOCK_OFFSET + default "-512" + +source "board/toradex/common/Kconfig" + +endif diff --git a/board/toradex/colibri-imx8qxp/MAINTAINERS b/board/toradex/colibri-imx8qxp/MAINTAINERS new file mode 100644 index 0000000000..39a9eb79b7 --- /dev/null +++ b/board/toradex/colibri-imx8qxp/MAINTAINERS @@ -0,0 +1,9 @@ +Colibri iMX8QXP +M: Marcel Ziswiler marcel.ziswiler@toradex.com +W: http://developer.toradex.com/software/linux/linux-software +S: Maintained +F: arch/arm/dts/fsl-imx8qxp-colibri.dts +F: arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi +F: board/toradex/colibri-imx8qxp/ +F: configs/colibri-imx8qxp_defconfig +F: include/configs/colibri-imx8qxp.h diff --git a/board/toradex/colibri-imx8qxp/Makefile b/board/toradex/colibri-imx8qxp/Makefile new file mode 100644 index 0000000000..f6342e1dca --- /dev/null +++ b/board/toradex/colibri-imx8qxp/Makefile @@ -0,0 +1,7 @@ +# +# Copyright 2019 Toradex +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += colibri-imx8qxp.o diff --git a/board/toradex/colibri-imx8qxp/README b/board/toradex/colibri-imx8qxp/README new file mode 100644 index 0000000000..e68d183fe6 --- /dev/null +++ b/board/toradex/colibri-imx8qxp/README @@ -0,0 +1,66 @@ +U-Boot for the Toradex Colibri iMX8QXP V1.0B module + +Quick Start +=========== + +- Build the ARM trusted firmware binary +- Get scfw_tcm.bin and ahab-container.img +- Build U-Boot +- Load U-Boot binary using uuu +- Flash U-Boot binary into the eMMC +- Boot + +Get and Build the ARM Trusted Firmware +====================================== + +$ git clone -b imx_4.14.78_1.0.0_ga https://source.codeaurora.org/external/imx/imx-atf +$ cd imx-atf/ +$ make PLAT=imx8qxp bl31 + +Get scfw_tcm.bin and ahab-container.img +======================================= + +$ wget https://github.com/toradex/meta-fsl-bsp-release/blob/toradex-sumo-4.14.78-1.... +$ mv mx8qx-colibri-scfw-tcm.bin?raw=true mx8qx-colibri-scfw-tcm.bin +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-7.6.bin +$ chmod +x firmware-imx-7.6.bin +$ ./firmware-imx-7.6.bin + +Copy the following binaries to the U-Boot folder: + +$ cp imx-atf/build/imx8qxp/release/bl31.bin . +$ cp u-boot/u-boot.bin . + +Copy the following firmware to the U-Boot folder: + +$ cp firmware-imx-7.6/firmware/seco/ahab-container.img . + +Build U-Boot +============ + +$ make colibri-imx8qxp_defconfig +$ make u-boot-dtb.imx + +Load the U-Boot Binary Using UUU +================================ + +Get the latest version of the universal update utility (uuu) aka mfgtools 3.0: + +https://community.nxp.com/external-link.jspa?url=https%3A%2F%2Fgithub.com%2F... + +Put the module into USB recovery aka serial downloader mode, connect USB device +to your host and execute uuu: + +sudo ./uuu u-boot/u-boot-dtb.imx + +Flash the U-Boot Binary into the eMMC +===================================== + +Burn the u-boot-dtb.imx binary to the primary eMMC hardware boot area partition: + +load mmc 1:1 $loadaddr u-boot-dtb.imx +setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200 +mmc dev 0 1 +mmc write ${loadaddr} 0x0 ${blkcnt} + +Boot diff --git a/board/toradex/colibri-imx8qxp/colibri-imx8qxp.c b/board/toradex/colibri-imx8qxp/colibri-imx8qxp.c new file mode 100644 index 0000000000..9aa0f096d2 --- /dev/null +++ b/board/toradex/colibri-imx8qxp/colibri-imx8qxp.c @@ -0,0 +1,212 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 Toradex + */ + +#include <common.h> + +#include <asm/arch/clock.h> +#include <asm/arch/imx8-pins.h> +#include <asm/arch/iomux.h> +#include <asm/arch/sci/sci.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/mach-imx/video.h> +#include <dm.h> +#include <environment.h> +#include <errno.h> +#include <fdt_support.h> +#include <fsl_esdhc.h> +#include <fsl_ifc.h> +#include <i2c.h> +#include <linux/libfdt.h> +#include <malloc.h> +#include <netdev.h> +#include <power-domain.h> +#include <usb.h> + +#include "../common/tdx-cfg-block.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define GPIO_PAD_CTRL ((SC_PAD_CONFIG_NORMAL << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +#define UART_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ + (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ + (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ + (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) + +static iomux_cfg_t uart3_pads[] = { + SC_P_FLEXCAN2_RX | MUX_MODE_ALT(2) | MUX_PAD_CTRL(UART_PAD_CTRL), + SC_P_FLEXCAN2_TX | MUX_MODE_ALT(2) | MUX_PAD_CTRL(UART_PAD_CTRL), + /* Transceiver FORCEOFF# signal, mux to use pullup */ + SC_P_QSPI0B_DQS | MUX_MODE_ALT(4) | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx8_iomux_setup_multiple_pads(uart3_pads, ARRAY_SIZE(uart3_pads)); +} + +int board_early_init_f(void) +{ + sc_pm_clock_rate_t rate; + sc_err_t err = 0; + + /* + * This works around that having only UART3 up the baudrate is 1.2M + * instead of 115.2k. Set UART0 clock root to 80 MHz + */ + rate = 80000000; + err = sc_pm_set_clock_rate(-1, SC_R_UART_0, SC_PM_CLK_PER, &rate); + if (err != SC_ERR_NONE) + return 0; + + /* Power up UART3 */ + err = sc_pm_set_resource_power_mode(-1, SC_R_UART_3, SC_PM_PW_MODE_ON); + if (err != SC_ERR_NONE) + return 0; + + /* Set UART3 clock root to 80 MHz */ + rate = 80000000; + err = sc_pm_set_clock_rate(-1, SC_R_UART_3, SC_PM_CLK_PER, &rate); + if (err != SC_ERR_NONE) + return 0; + + /* Enable UART3 clock root */ + err = sc_pm_clock_enable(-1, SC_R_UART_3, SC_PM_CLK_PER, true, false); + if (err != SC_ERR_NONE) + return 0; + + setup_iomux_uart(); + + return 0; +} + +#undef CONFIG_MXC_GPIO /* TODO */ +#ifdef CONFIG_MXC_GPIO +#define IOEXP_RESET IMX_GPIO_NR(1, 1) + +static iomux_cfg_t board_gpios[] = { + SC_P_SPI2_SDO | MUX_MODE_ALT(4) | MUX_PAD_CTRL(GPIO_PAD_CTRL), + SC_P_ENET0_REFCLK_125M_25M | MUX_MODE_ALT(4) | \ + MUX_PAD_CTRL(GPIO_PAD_CTRL), +}; + +static void board_gpio_init(void) +{ + struct gpio_desc desc; + int ret; + + ret = dm_gpio_lookup_name("gpio@1a_3", &desc); + if (ret) + return; + + ret = dm_gpio_request(&desc, "bb_per_rst_b"); + if (ret) + return; + + dm_gpio_set_dir_flags(&desc, GPIOD_IS_OUT); + dm_gpio_set_value(&desc, 0); + udelay(50); + dm_gpio_set_value(&desc, 1); + + imx8_iomux_setup_multiple_pads(board_gpios, ARRAY_SIZE(board_gpios)); + + /* enable i2c port expander assert reset line */ + gpio_request(IOEXP_RESET, "ioexp_rst"); + gpio_direction_output(IOEXP_RESET, 1); +} +#else +static inline void board_gpio_init(void) {} +#endif + +#if IS_ENABLED(CONFIG_FEC_MXC) +#include <miiphy.h> + +int board_phy_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} +#endif + +void build_info(void) +{ + u32 sc_build = 0, sc_commit = 0; + + /* Get SCFW build and commit id */ + sc_misc_build_info(-1, &sc_build, &sc_commit); + if (!sc_build) { + printf("SCFW does not support build info\n"); + sc_commit = 0; /* Display 0 if build info not supported */ + } + printf("Build: SCFW %x\n", sc_commit); +} + +int checkboard(void) +{ + puts("Model: Toradex Colibri iMX8X\n"); + + build_info(); + print_bootinfo(); + + return 0; +} + +int board_init(void) +{ + board_gpio_init(); + + return 0; +} + +void detail_board_ddr_info(void) +{ + puts("\nDDR "); +} + +/* + * Board specific reset that is system reset. + */ +void reset_cpu(ulong addr) +{ + /* TODO */ +} + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + return ft_common_board_setup(blob, bd); +} +#endif + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} + +int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +/* TODO move to common */ + env_set("board_name", "Colibri iMX8QXP"); + env_set("board_rev", "v1.0"); +#endif + + return 0; +} diff --git a/board/toradex/colibri-imx8qxp/imximage.cfg b/board/toradex/colibri-imx8qxp/imximage.cfg new file mode 100644 index 0000000000..ce9e66c64d --- /dev/null +++ b/board/toradex/colibri-imx8qxp/imximage.cfg @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 Toradex + * + * Refer doc/README.imx8image for more details about how-to configure + * and create imx8image boot image + */ + +#define __ASSEMBLY__ + +/* Boot from SD, sector size 0x400 */ +BOOT_FROM EMMC_FASTBOOT 0x400 +/* SoC type IMX8QX */ +SOC_TYPE IMX8QX +/* Append seco container image */ +APPEND ahab-container.img +/* Create the 2nd container */ +CONTAINER +/* Add scfw image with exec attribute */ +IMAGE SCU mx8qx-colibri-scfw-tcm.bin +/* Add ATF image with exec attribute */ +IMAGE A35 bl31.bin 0x80000000 +/* Add U-Boot image with load attribute */ +DATA A35 u-boot-dtb.bin 0x80020000 diff --git a/configs/colibri-imx8qxp_defconfig b/configs/colibri-imx8qxp_defconfig new file mode 100644 index 0000000000..d697546ed7 --- /dev/null +++ b/configs/colibri-imx8qxp_defconfig @@ -0,0 +1,53 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8=y +CONFIG_SYS_TEXT_BASE=0x80020000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_COLIBRI_IMX8QXP=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri-imx8qxp/imximage.cfg" +CONFIG_LOG=y +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_CMD_CPU=y +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_UUID=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-imx8qxp-colibri" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_CLK_IMX8=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_MICREL=y +CONFIG_DM_ETH=y +CONFIG_FEC_MXC_SHARE_MDIO=y +CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_DM_THERMAL=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/colibri-imx8qxp.h b/include/configs/colibri-imx8qxp.h new file mode 100644 index 0000000000..33cbcb44a9 --- /dev/null +++ b/include/configs/colibri-imx8qxp.h @@ -0,0 +1,214 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 Toradex + */ + +#ifndef __COLIBRI_IMX8QXP_H +#define __COLIBRI_IMX8QXP_H + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> + +#define CONFIG_REMAKE_ELF + +#define CONFIG_DISPLAY_BOARDINFO_LATE + +#undef CONFIG_CMD_EXPORTENV +#undef CONFIG_CMD_IMPORTENV +#undef CONFIG_CMD_IMLS + +#undef CONFIG_CMD_CRC32 +#undef CONFIG_BOOTM_NETBSD + +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define USDHC1_BASE_ADDR 0x5B010000 +#define USDHC2_BASE_ADDR 0x5B020000 +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + +#define FEC_QUIRK_ENET_MAC + +#define CONFIG_IP_DEFRAG +#define CONFIG_TFTP_BLOCKSIZE 4096 +#define CONFIG_TFTP_TSIZE + +#define CONFIG_IPADDR 192.168.10.2 +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_SERVERIP 192.168.10.1 + +#define MEM_LAYOUT_ENV_SETTINGS \ + "fdt_addr_r=0x84000000\0" \ + "kernel_addr_r=0x82000000\0" \ + "ramdisk_addr_r=0x84100000\0" + +#ifdef CONFIG_AHAB_BOOT +#define AHAB_ENV "sec_boot=yes\0" +#else +#define AHAB_ENV "sec_boot=no\0" +#endif + +/* Boot M4 */ +#define M4_BOOT_ENV \ + "m4_0_image=m4_0.bin\0" \ + "loadm4image_0=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} " \ + "${m4_0_image}\0" \ + "m4boot_0=run loadm4image_0; dcache flush; bootaux ${loadaddr} 0\0" \ + +#define MFG_NAND_PARTITION "" + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> +#undef BOOTENV_RUN_NET_USB_START +#define BOOTENV_RUN_NET_USB_START "" + +#define CONFIG_MFG_ENV_SETTINGS \ + "mfgtool_args=setenv bootargs console=${console},${baudrate} " \ + "rdinit=/linuxrc g_mass_storage.stall=0 " \ + "g_mass_storage.removable=1 g_mass_storage.idVendor=0x066F " \ + "g_mass_storage.idProduct=0x37FF " \ + "g_mass_storage.iSerialNumber="" "\ + MFG_NAND_PARTITION \ + "video=imxdpufb5:off video=imxdpufb6:off video=imxdpufb7:off " \ + "clk_ignore_unused "\ + "\0" \ + "initrd_addr=0x83800000\0" \ + "initrd_high=0xffffffff\0" \ + "bootcmd_mfg=run mfgtool_args;booti ${loadaddr} ${initrd_addr} " \ + "${fdt_addr};\0" \ + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + AHAB_ENV \ + BOOTENV \ + CONFIG_MFG_ENV_SETTINGS \ + M4_BOOT_ENV \ + MEM_LAYOUT_ENV_SETTINGS \ + "boot_fdt=try\0" \ + "bootscript=echo Running bootscript from mmc ...; source\0" \ + "console=ttyLP3,115200 earlycon=lpuart32,0x5a090000,115200\0" \ + "fdt_addr=0x83000000\0" \ + "fdt_file=fsl-imx8qxp-colibri-eval-v3.dtb\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "finduuid=part uuid mmc ${mmcdev}:2 uuid\0" \ + "image=Image\0" \ + "initrd_addr=0x83800000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} " \ + "${script};\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=PARTUUID=${uuid} rootwait " \ + "mmcautodetect=yes\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run finduuid; run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "echo wait for boot; " \ + "fi;\0" \ + "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "netargs=setenv bootargs console=${console} root=/dev/nfs ip=dhcp " \ + "nfsroot=${serverip}:${nfsroot},v3,tcp video=imxdpufb5:off " \ + "video=imxdpufb6:off video=imxdpufb7:off\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "booti; " \ + "fi;\0" \ + "nfsboot=run netargs; dhcp ${loadaddr} ${image}; tftp ${fdt_addr} " \ + "colibri-imx8qxp/${fdt_file}; booti ${loadaddr} - " \ + "${fdt_addr}\0" \ + "panel=NULL\0" \ + "script=boot.scr\0" \ + "video=imxdpufb5:off video=imxdpufb6:off video=imxdpufb7:off\0" + +#undef CONFIG_BOOTCOMMAND +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else booti ${loadaddr} - ${fdt_addr}; fi" + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x80280000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_SP_ADDR 0x80200000 + +#define CONFIG_SYS_MEMTEST_START 0x88000000 +#define CONFIG_SYS_MEMTEST_END 0x89000000 + +/* Environment in eMMC, before config block at the end of 1st "boot sector" */ +#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ + CONFIG_TDX_CFG_BLOCK_OFFSET) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 1 + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +/* On Colibri iMX8 USDHC1 is eMMC, USDHC2 is 4-bit SD */ +#define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC1 eMMC */ +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN ((CONFIG_ENV_SIZE + (32 * 1024)) * 1024) + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_NR_DRAM_BANKS 3 +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_2 0x880000000 +#define PHYS_SDRAM_1_SIZE 0x80000000 /* 2 GB */ +#define PHYS_SDRAM_2_SIZE 0x00000000 /* 0 GB */ + +/* Serial */ +#define CONFIG_BAUDRATE 115200 + +/* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 8000000 /* 8MHz */ + +#define BOOTAUX_RESERVED_MEM_BASE 0x88000000 +#define BOOTAUX_RESERVED_MEM_SIZE 0x08000000 /* Reserve from second 128MB */ + +#endif /* __COLIBRI_IMX8QXP_H */
Hi Marcel,
Some minor comments below (can be addressed in different patch):
- Ethernet
- GPIOs
- I2C
Changes in v2:
fsl-imx8qxp-mek.dtb
- Copyright 2019 Toradex AG
+&mu {
u-boot,dm-spl;
+&clk {
u-boot,dm-spl;
+&iomuxc {
u-boot,dm-spl;
+&pd_lsio {
u-boot,dm-spl;
+&pd_lsio_gpio0 {
u-boot,dm-spl;
+&pd_lsio_gpio1 {
u-boot,dm-spl;
+&pd_lsio_gpio2 {
u-boot,dm-spl;
+&pd_lsio_gpio3 {
u-boot,dm-spl;
+&pd_lsio_gpio4 {
u-boot,dm-spl;
+&pd_lsio_gpio5 {
u-boot,dm-spl;
+&pd_lsio_gpio6 {
u-boot,dm-spl;
+&pd_lsio_gpio7 {
u-boot,dm-spl;
+&pd_conn {
u-boot,dm-spl;
+&pd_conn_sdch0 {
u-boot,dm-spl;
+&pd_conn_sdch1 {
u-boot,dm-spl;
+&pd_conn_sdch2 {
u-boot,dm-spl;
+&gpio0 {
u-boot,dm-spl;
+&gpio1 {
u-boot,dm-spl;
+&gpio2 {
u-boot,dm-spl;
+&gpio3 {
u-boot,dm-spl;
+&gpio4 {
u-boot,dm-spl;
+&gpio5 {
u-boot,dm-spl;
+&gpio6 {
u-boot,dm-spl;
+&gpio7 {
u-boot,dm-spl;
+&lpuart3 {
u-boot,dm-spl;
+&usdhc1 {
u-boot,dm-spl;
+&usdhc2 {
u-boot,dm-spl;
+/dts-v1/;
chosen {
+&iomuxc {
colibri-imx8qxp {
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
I seems that in 20 lines above alignment is broken a bit.
fsl,pins = <
fsl,pins = <
/*INT*/
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
+&lpuart0 {
status = "okay";
+&lpuart3 {
status = "okay";
+&gpio0 {
status = "okay";
+&gpio1 {
status = "okay";
+&gpio3 {
status = "okay";
+&gpio4 {
status = "okay";
+&fec1 {
phy-mode = "rmii";
status = "okay";
mdio {
#size-cells = <0>;
max-speed = <100>;
reg = <2>;
+&i2c1 {
#size-cells = <0>;
status = "okay";
+&usdhc1 {
bus-width = <8>;
non-removable;
status = "okay";
+&usdhc2 {
bus-width = <4>;
status = "okay";
select IMX8QXP
+config SYS_BOARD
+config SYS_VENDOR
default "toradex"
default y
default y
default "0"
default "1"
default "-512"
SPDX line should be in the beginning of the file.
sc_err_t err = 0;
rate = 80000000;
rate = 80000000;
setup_iomux_uart();
int ret;
if (ret)
return;
if (ret)
return;
udelay(50);
+} +#endif
if (!sc_build) {
build_info();
print_bootinfo();
board_gpio_init();
puts("\nDDR ");
- Board specific reset that is system reset.
/* TODO */
+} +#endif
return devno;
- Refer doc/README.imx8image for more details about how-to configure
- and create imx8image boot image
4096 can be replaced with SZ_4K (from include/linux/sizes.h)
"${m4_0_image}\0" \
func(MMC, mmc, 0) \
func(MMC, mmc, 1) \
"g_mass_storage.iSerialNumber=\"\" "\
"\0" \
"${fdt_addr};\0" \
AHAB_ENV \
BOOTENV \
M4_BOOT_ENV \
"boot_fdt=try\0" \
"image=Image\0" \
"${script};\0" \
"else " \
"fi; " \
"else " \
"fi;\0" \
"run netargs; " \
"else " \
"fi; " \
"else " \
"fi; " \
"else " \
"booti; " \
"fi;\0" \
"${fdt_addr}\0" \
"panel=NULL\0" \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
(8 * 1024) can be replaced with SZ_8K (from include/linux/sizes.h)
0x80000000 can be replaced with SZ_2G (from include/linux/sizes.h)
Same as above
Same as above
2.20.1
Hi Igor
Sorry, somehow I missed your comments below (;-p).
I will send out a v4 (yes there already was a v3 BTW) shortly including the SPL resp. without SPL build fix.
On Thu, 2019-04-11 at 12:47 +0200, Igor Opaniuk wrote:
Hi Marcel,
This commit adds initial support for the Toradex Colibri iMX8QXP 2GB WB IT V1.0B module. Unlike the V1.0A early access samples exclusively booting from SD card, they are now strapped to boot from eFuses which are factory fused to properly boot from their on-module eMMC. U- Boot supports either booting from the on-module eMMC or may be used for recovery purpose using the universal update utility (uuu) aka mfgtools 3.0.
- Ethernet
- GPIOs
- I2C
Changes in v2:
fsl-imx8qxp-mek.dtb
+&mu {
u-boot,dm-spl;
+&clk {
u-boot,dm-spl;
+&iomuxc {
u-boot,dm-spl;
+&pd_lsio {
u-boot,dm-spl;
+&pd_lsio_gpio0 {
u-boot,dm-spl;
+&pd_lsio_gpio1 {
u-boot,dm-spl;
+&pd_lsio_gpio2 {
u-boot,dm-spl;
+&pd_lsio_gpio3 {
u-boot,dm-spl;
+&pd_lsio_gpio4 {
u-boot,dm-spl;
+&pd_lsio_gpio5 {
u-boot,dm-spl;
+&pd_lsio_gpio6 {
u-boot,dm-spl;
+&pd_lsio_gpio7 {
u-boot,dm-spl;
+&pd_conn {
u-boot,dm-spl;
+&pd_conn_sdch0 {
u-boot,dm-spl;
+&pd_conn_sdch1 {
u-boot,dm-spl;
+&pd_conn_sdch2 {
u-boot,dm-spl;
+&gpio0 {
u-boot,dm-spl;
+&gpio1 {
u-boot,dm-spl;
+&gpio2 {
u-boot,dm-spl;
+&gpio3 {
u-boot,dm-spl;
+&gpio4 {
u-boot,dm-spl;
+&gpio5 {
u-boot,dm-spl;
+&gpio6 {
u-boot,dm-spl;
+&gpio7 {
u-boot,dm-spl;
+&lpuart3 {
u-boot,dm-spl;
+&usdhc1 {
u-boot,dm-spl;
+&usdhc2 {
u-boot,dm-spl;
+/dts-v1/;
chosen {
+&iomuxc {
<&pinctrl_hog2>;
colibri-imx8qxp {
fsl,pins = <
6000020
6000020
fsl,pins = <
6000020
6000020
fsl,pins = <
0x00000020 /* CTS */SC_P_SAI1_RXD_LSIO_GPIO0_IO29
0x00000020 /* RTS */SC_P_SAI1_RXC_LSIO_GPIO0_IO30
0x00000020 /* DSR */SC_P_CSI_RESET_LSIO_GPIO3_IO03
0x00000020 /* DCD */SC_P_USDHC1_CD_B_LSIO_GPIO4_IO22
0x00000020 /* RI */SC_P_CSI_EN_LSIO_GPIO3_IO02
fsl,pins = <
K50M_OUT 0x06000061
MII_TXD0 0x00000061
MII_TXD1 0x00000061
MII_RXD0 0x00000061
MII_RXD1 0x00000061
II_RX_ER 0x00000061
fsl,pins = <
0x00000040SC_P_QSPI0A_DATA3_LSIO_GPIO3_IO12
fsl,pins = <
fsl,pins = <
0x00000020 /* 45 */SC_P_QSPI0A_DATA1_LSIO_GPIO3_IO10
0x00000061SC_P_CSI_D07_CI_PI_D09
0x00000020 /* 69 */SC_P_QSPI0A_DATA2_LSIO_GPIO3_IO11
0x00000020 /* 73 */SC_P_QSPI0A_DQS_LSIO_GPIO3_IO13
0x00000020 /* 79 */SC_P_SAI0_TXC_LSIO_GPIO0_IO26
0x00000061SC_P_CSI_D02_CI_PI_D04
0x00000061SC_P_CSI_D06_CI_PI_D08
0x00000020 /* 95 */SC_P_QSPI0B_SCLK_LSIO_GPIO3_IO17
0x00000020 /* 97 */SC_P_SAI0_RXD_LSIO_GPIO0_IO27
0x00000061SC_P_CSI_D03_CI_PI_D05
0x00000020 /* 99 */SC_P_QSPI0B_DATA0_LSIO_GPIO3_IO18
0x00000020 /* 101 */SC_P_SAI0_TXFS_LSIO_GPIO0_IO28
0x00000061SC_P_CSI_D00_CI_PI_D02
0x00000020 /* 103 */SC_P_SAI0_TXD_LSIO_GPIO0_IO25
0x00000061SC_P_CSI_D01_CI_PI_D03
No, I believe Max intentionally did it that way downstream indicating that those SODIMM pins are each multiplexed onto two SoC balls. Toradex does this at times to gain greater pin compatibility across our module families.
Further comments down below taken into account. Thanks!
Cheers
Marcel
0x00000020 /* 105 */SC_P_QSPI0B_DATA1_LSIO_GPIO3_IO19
0x00000020 /* 107 */SC_P_QSPI0B_DATA2_LSIO_GPIO3_IO20
0x00000020 /* 127 */SC_P_USB_SS3_TC2_LSIO_GPIO4_IO05
0x00000020 /* 131 */SC_P_USB_SS3_TC3_LSIO_GPIO4_IO06
0x00000020 /* 133 */SC_P_USB_SS3_TC1_LSIO_GPIO4_IO04
0x00000020 /* 96 */SC_P_CSI_PCLK_LSIO_GPIO3_IO00
0x00000020 /* 98 */SC_P_QSPI0B_DATA3_LSIO_GPIO3_IO21
0x00000020 /* 100 */SC_P_SAI1_RXFS_LSIO_GPIO0_IO31
0x00000020 /* 102 */SC_P_QSPI0B_DQS_LSIO_GPIO3_IO22
0x00000020 /* 104 */SC_P_QSPI0B_SS0_B_LSIO_GPIO3_IO23
0x00000020 /* 106 */SC_P_QSPI0B_SS1_B_LSIO_GPIO3_IO24
fsl,pins = <
0x00000020 /* 75 */SC_P_CSI_MCLK_LSIO_GPIO3_IO01
0x00000020 /* 77 */SC_P_QSPI0A_SS0_B_LSIO_GPIO3_IO14
0x00000020 /* 89 */SC_P_QSPI0A_SS1_B_LSIO_GPIO3_IO15
0x00000020 /* 93 */SC_P_QSPI0A_SCLK_LSIO_GPIO3_IO16
fsl,pins = <
CL 0x06000021
DA 0x06000021
/*INT*/
fsl,pins = <
IO04 0x00000061
fsl,pins = <
O5_IO09 0x06000040
fsl,pins = <
0x06000040SC_P_USB_SS3_TC0_LSIO_GPIO4_IO03
fsl,pins = <
0x06000041SC_P_EMMC0_CLK_CONN_EMMC0_CLK
0x00000021SC_P_EMMC0_CMD_CONN_EMMC0_CMD
0x00000021SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0
0x00000021SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1
0x00000021SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2
0x00000021SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3
0x00000021SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4
0x00000021SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5
0x00000021SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6
0x00000021SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7
0x00000041SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE
_B 0x00000021
fsl,pins = <
_B 0x00000021
fsl,pins = <
_B 0x00000021
fsl,pins = <
0x06000021SC_P_QSPI0A_DATA0_LSIO_GPIO3_IO09
fsl,pins = <
0x06000041SC_P_USDHC1_CLK_CONN_USDHC1_CLK
0x00000021SC_P_USDHC1_CMD_CONN_USDHC1_CMD
0x00000021SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0
0x00000021SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1
0x00000021SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2
0x00000021SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3
LECT 0x00000021
fsl,pins = <
LECT 0x00000021
fsl,pins = <
LECT 0x00000021
+&lpuart0 {
status = "okay";
+&lpuart3 {
status = "okay";
+&gpio0 {
status = "okay";
+&gpio1 {
status = "okay";
+&gpio3 {
status = "okay";
+&gpio4 {
status = "okay";
+&fec1 {
phy-mode = "rmii";
status = "okay";
mdio {
#size-cells = <0>;
max-speed = <100>;
reg = <2>;
+&i2c1 {
#size-cells = <0>;
status = "okay";
+&usdhc1 {
bus-width = <8>;
non-removable;
status = "okay";
+&usdhc2 {
bus-width = <4>;
status = "okay";
+}; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach- imx/imx8/Kconfig index f76a139684..feea07f135 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -22,6 +22,11 @@ choice prompt "i.MX8 board select" optional
select IMX8QXP
+config SYS_BOARD
+config SYS_VENDOR
default "toradex"
default y
default y
default "0"
default "1"
default "-512"
+$ wget https://github.com/toradex/meta-fsl-bsp-release/blob/toradex-sumo-4.14.78-1.... +$ mv mx8qx-colibri-scfw-tcm.bin?raw=true mx8qx-colibri-scfw- tcm.bin +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-7.6.bin +$ chmod +x firmware-imx-7.6.bin +$ ./firmware-imx-7.6.bin
sc_err_t err = 0;
is 1.2M
rate = 80000000;
&rate);
SC_PM_PW_MODE_ON);
rate = 80000000;
&rate);
true, false);
setup_iomux_uart();
int ret;
if (ret)
return;
if (ret)
return;
udelay(50);
+} +#endif
if (!sc_build) {
supported */
build_info();
print_bootinfo();
board_gpio_init();
puts("\nDDR ");
/* TODO */
+} +#endif
return devno;
configure
+/* Boot from SD, sector size 0x400 */ +BOOT_FROM EMMC_FASTBOOT 0x400 +/* SoC type IMX8QX */ +SOC_TYPE IMX8QX +/* Append seco container image */ +APPEND ahab-container.img +/* Create the 2nd container */ +CONTAINER +/* Add scfw image with exec attribute */ +IMAGE SCU mx8qx-colibri-scfw-tcm.bin +/* Add ATF image with exec attribute */ +IMAGE A35 bl31.bin 0x80000000 +/* Add U-Boot image with load attribute */ +DATA A35 u-boot-dtb.bin 0x80020000 diff --git a/configs/colibri-imx8qxp_defconfig b/configs/colibri- imx8qxp_defconfig new file mode 100644 index 0000000000..d697546ed7 --- /dev/null +++ b/configs/colibri-imx8qxp_defconfig @@ -0,0 +1,53 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8=y +CONFIG_SYS_TEXT_BASE=0x80020000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_COLIBRI_IMX8QXP=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=3 +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri- imx8qxp/imximage.cfg" +CONFIG_LOG=y +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_CMD_CPU=y +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_UUID=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-imx8qxp-colibri" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_CLK_IMX8=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_MICREL=y +CONFIG_DM_ETH=y +CONFIG_FEC_MXC_SHARE_MDIO=y +CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_DM_THERMAL=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/colibri-imx8qxp.h b/include/configs/colibri-imx8qxp.h new file mode 100644 index 0000000000..33cbcb44a9 --- /dev/null +++ b/include/configs/colibri-imx8qxp.h @@ -0,0 +1,214 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
"${m4_0_image}\0" \
${loadaddr} 0\0" \
func(MMC, mmc, 0) \
func(MMC, mmc, 1) \
"\0" \
${initrd_addr} " \
"${fdt_addr};\0" \
AHAB_ENV \
BOOTENV \
M4_BOOT_ENV \
"boot_fdt=try\0" \
"image=Image\0" \
${loadaddr} " \
"${script};\0" \
${fdt_file}\0" \
${image}\0" \
try; then " \
"else " \
"fi; " \
"else " \
"fi;\0" \
ip=dhcp " \
"run netargs; " \
"else " \
"fi; " \
try; then " \
then " \
"else " \
"fi; " \
"else " \
"booti; " \
"fi;\0" \
${fdt_addr} " \
"${fdt_addr}\0" \
"panel=NULL\0" \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
Same as above
Same as above
2.20.1
On 26/04/19 11:20, Marcel Ziswiler wrote:
Hi Igor
Fine - the series (without 5/5) is already applied on u-boot-imx. Please just send 5/5.
Regards, Stefano
Hi Marcel,
- Ethernet
- GPIOs
- I2C
Changes in v2:
fsl-imx8qxp-mek.dtb
+&mu {
u-boot,dm-spl;
+&clk {
u-boot,dm-spl;
+&iomuxc {
u-boot,dm-spl;
+&pd_lsio {
u-boot,dm-spl;
+&pd_lsio_gpio0 {
u-boot,dm-spl;
+&pd_lsio_gpio1 {
u-boot,dm-spl;
+&pd_lsio_gpio2 {
u-boot,dm-spl;
+&pd_lsio_gpio3 {
u-boot,dm-spl;
+&pd_lsio_gpio4 {
u-boot,dm-spl;
+&pd_lsio_gpio5 {
u-boot,dm-spl;
+&pd_lsio_gpio6 {
u-boot,dm-spl;
+&pd_lsio_gpio7 {
u-boot,dm-spl;
+&pd_conn {
u-boot,dm-spl;
+&pd_conn_sdch0 {
u-boot,dm-spl;
+&pd_conn_sdch1 {
u-boot,dm-spl;
+&pd_conn_sdch2 {
u-boot,dm-spl;
+&gpio0 {
u-boot,dm-spl;
+&gpio1 {
u-boot,dm-spl;
+&gpio2 {
u-boot,dm-spl;
+&gpio3 {
u-boot,dm-spl;
+&gpio4 {
u-boot,dm-spl;
+&gpio5 {
u-boot,dm-spl;
+&gpio6 {
u-boot,dm-spl;
+&gpio7 {
u-boot,dm-spl;
+&lpuart3 {
u-boot,dm-spl;
+&usdhc1 {
u-boot,dm-spl;
+&usdhc2 {
u-boot,dm-spl;
+/dts-v1/;
chosen {
+&iomuxc {
<&pinctrl_hog2>;
colibri-imx8qxp {
fsl,pins = <
6000020
6000020
fsl,pins = <
6000020
6000020
fsl,pins = <
fsl,pins = <
K50M_OUT 0x06000061
MII_TXD0 0x00000061
MII_TXD1 0x00000061
MII_RXD0 0x00000061
MII_RXD1 0x00000061
II_RX_ER 0x00000061
fsl,pins = <
fsl,pins = <
fsl,pins = <
Cheers
Marcel
fsl,pins = <
fsl,pins = <
CL 0x06000021
DA 0x06000021
/*INT*/
fsl,pins = <
IO04 0x00000061
fsl,pins = <
O5_IO09 0x06000040
fsl,pins = <
fsl,pins = <
_B 0x00000021
fsl,pins = <
_B 0x00000021
fsl,pins = <
_B 0x00000021
fsl,pins = <
fsl,pins = <
LECT 0x00000021
fsl,pins = <
LECT 0x00000021
fsl,pins = <
LECT 0x00000021
+&lpuart0 {
status = "okay";
+&lpuart3 {
status = "okay";
+&gpio0 {
status = "okay";
+&gpio1 {
status = "okay";
+&gpio3 {
status = "okay";
+&gpio4 {
status = "okay";
+&fec1 {
phy-mode = "rmii";
status = "okay";
mdio {
#size-cells = <0>;
max-speed = <100>;
reg = <2>;
+&i2c1 {
#size-cells = <0>;
status = "okay";
+&usdhc1 {
bus-width = <8>;
non-removable;
status = "okay";
+&usdhc2 {
bus-width = <4>;
status = "okay";
select IMX8QXP
+config SYS_BOARD
+config SYS_VENDOR
default "toradex"
default y
default y
default "0"
default "1"
default "-512"
sc_err_t err = 0;
is 1.2M
rate = 80000000;
&rate);
SC_PM_PW_MODE_ON);
rate = 80000000;
&rate);
true, false);
setup_iomux_uart();
int ret;
if (ret)
return;
if (ret)
return;
udelay(50);
+} +#endif
if (!sc_build) {
supported */
build_info();
print_bootinfo();
board_gpio_init();
puts("\nDDR ");
/* TODO */
+} +#endif
return devno;
configure
"${m4_0_image}\0" \
${loadaddr} 0\0" \
func(MMC, mmc, 0) \
func(MMC, mmc, 1) \
"\0" \
${initrd_addr} " \
"${fdt_addr};\0" \
AHAB_ENV \
BOOTENV \
M4_BOOT_ENV \
"boot_fdt=try\0" \
"image=Image\0" \
${loadaddr} " \
"${script};\0" \
${fdt_file}\0" \
${image}\0" \
try; then " \
"else " \
"fi; " \
"else " \
"fi;\0" \
ip=dhcp " \
"run netargs; " \
"else " \
"fi; " \
try; then " \
then " \
"else " \
"fi; " \
"else " \
"booti; " \
"fi;\0" \
${fdt_addr} " \
"${fdt_addr}\0" \
"panel=NULL\0" \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
Same as above
Same as above
2.20.1
Hi Stefano
Hi Igor
OK, strange. While I thought I just checked on git.denx.de I somehow missed that. Will just send 5/5 plus the SPL fix. Thanks!
Regards, Stefano
Cheers
Marcel
Hi Marcel,
On 26/04/19 11:58, Marcel Ziswiler wrote:
Hi Stefano
Hi Igor
It does not depend on you, but on my changed work-flow. Because Tom does not accept PR that does not pass Travis' build, I push currently first to my github account (where I rebase often and I fix myself small issues), and I push later to git.denx.de just after build passed. This avoids that my rebasess make people unhappy because history is broken, and tree on git.denx.de is always in a good state.
Regards, Stefano
Hi Marcel,
- Ethernet
- GPIOs
- I2C
I merged the series and build locally (fine), but Travis complains and stops with error:
+cc1: fatal error: opening output file spl/u-boot-spl.cfgout: No such file or directory +compilation terminated.
Can you take a look at it ?
Regards, Stefano
Changes in v2:
- fsl-imx8qxp-colibri.dtb \
- fsl-imx8qxp-mek.dtb
+&mu {
- u-boot,dm-spl;
+&clk {
- u-boot,dm-spl;
+&iomuxc {
- u-boot,dm-spl;
+&pd_lsio {
- u-boot,dm-spl;
+&pd_lsio_gpio0 {
- u-boot,dm-spl;
+&pd_lsio_gpio1 {
- u-boot,dm-spl;
+&pd_lsio_gpio2 {
- u-boot,dm-spl;
+&pd_lsio_gpio3 {
- u-boot,dm-spl;
+&pd_lsio_gpio4 {
- u-boot,dm-spl;
+&pd_lsio_gpio5 {
- u-boot,dm-spl;
+&pd_lsio_gpio6 {
- u-boot,dm-spl;
+&pd_lsio_gpio7 {
- u-boot,dm-spl;
+&pd_conn {
- u-boot,dm-spl;
+&pd_conn_sdch0 {
- u-boot,dm-spl;
+&pd_conn_sdch1 {
- u-boot,dm-spl;
+&pd_conn_sdch2 {
- u-boot,dm-spl;
+&gpio0 {
- u-boot,dm-spl;
+&gpio1 {
- u-boot,dm-spl;
+&gpio2 {
- u-boot,dm-spl;
+&gpio3 {
- u-boot,dm-spl;
+&gpio4 {
- u-boot,dm-spl;
+&gpio5 {
- u-boot,dm-spl;
+&gpio6 {
- u-boot,dm-spl;
+&gpio7 {
- u-boot,dm-spl;
+&lpuart3 {
- u-boot,dm-spl;
+&usdhc1 {
- u-boot,dm-spl;
+&usdhc2 {
- u-boot,dm-spl;
+/dts-v1/;
- model = "Toradex Colibri iMX8QXP";
- compatible = "toradex,colibri-imx8qxp", "fsl,imx8qxp";
- chosen {
- reg_usbh_vbus: regulator-usbh-vbus {
+&iomuxc {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_hog0>, <&pinctrl_hog1>, <&pinctrl_hog2>;
- colibri-imx8qxp {
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
/*INT*/
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
+&lpuart0 {
- pinctrl-0 = <&pinctrl_lpuart0>;
- status = "okay";
+&lpuart3 {
- pinctrl-0 = <&pinctrl_lpuart3>, <&pinctrl_lpuart3_ctrl>;
- status = "okay";
+&gpio0 {
- status = "okay";
+&gpio1 {
- status = "okay";
+&gpio3 {
- status = "okay";
+&gpio4 {
- status = "okay";
+&fec1 {
- phy-handle = <ðphy0>;
- phy-mode = "rmii";
- pinctrl-0 = <&pinctrl_fec1>;
- status = "okay";
- mdio {
#size-cells = <0>;
max-speed = <100>;
reg = <2>;
+&i2c1 {
- #address-cells = <1>;
- #size-cells = <0>;
- clock-frequency = <100000>;
- pinctrl-0 = <&pinctrl_i2c1>;
- status = "okay";
+&usdhc1 {
- bus-width = <8>;
- non-removable;
- pinctrl-names = "default", "state_100mhz", "state_200mhz";
- pinctrl-0 = <&pinctrl_usdhc1>;
- pinctrl-1 = <&pinctrl_usdhc1_100mhz>;
- pinctrl-2 = <&pinctrl_usdhc1_200mhz>;
- status = "okay";
+&usdhc2 {
- bus-width = <4>;
- cd-gpios = <&gpio3 9 GPIO_ACTIVE_LOW>;
- pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>;
- pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>;
- pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>;
- status = "okay";
- bool "Support Colibri iMX8QXP module"
- select BOARD_LATE_INIT
- select IMX8QXP
+config SYS_BOARD
- default "colibri-imx8qxp"
+config SYS_VENDOR
- default "toradex"
- default y
- default y
- default "0"
- default "1"
- default "-512"
- SC_P_FLEXCAN2_RX | MUX_MODE_ALT(2) | MUX_PAD_CTRL(UART_PAD_CTRL),
- SC_P_FLEXCAN2_TX | MUX_MODE_ALT(2) | MUX_PAD_CTRL(UART_PAD_CTRL),
- /* Transceiver FORCEOFF# signal, mux to use pullup */
- SC_P_QSPI0B_DQS | MUX_MODE_ALT(4) | MUX_PAD_CTRL(UART_PAD_CTRL),
- imx8_iomux_setup_multiple_pads(uart3_pads, ARRAY_SIZE(uart3_pads));
- sc_pm_clock_rate_t rate;
- sc_err_t err = 0;
- rate = 80000000;
- err = sc_pm_set_clock_rate(-1, SC_R_UART_0, SC_PM_CLK_PER, &rate);
- if (err != SC_ERR_NONE)
- /* Power up UART3 */
- err = sc_pm_set_resource_power_mode(-1, SC_R_UART_3, SC_PM_PW_MODE_ON);
- /* Set UART3 clock root to 80 MHz */
- rate = 80000000;
- err = sc_pm_set_clock_rate(-1, SC_R_UART_3, SC_PM_CLK_PER, &rate);
- /* Enable UART3 clock root */
- err = sc_pm_clock_enable(-1, SC_R_UART_3, SC_PM_CLK_PER, true, false);
- setup_iomux_uart();
- SC_P_SPI2_SDO | MUX_MODE_ALT(4) | MUX_PAD_CTRL(GPIO_PAD_CTRL),
- SC_P_ENET0_REFCLK_125M_25M | MUX_MODE_ALT(4) | \
- struct gpio_desc desc;
- int ret;
- ret = dm_gpio_lookup_name("gpio@1a_3", &desc);
- if (ret)
return;
- ret = dm_gpio_request(&desc, "bb_per_rst_b");
- if (ret)
return;
- dm_gpio_set_dir_flags(&desc, GPIOD_IS_OUT);
- dm_gpio_set_value(&desc, 0);
- udelay(50);
- dm_gpio_set_value(&desc, 1);
- imx8_iomux_setup_multiple_pads(board_gpios, ARRAY_SIZE(board_gpios));
- /* enable i2c port expander assert reset line */
- gpio_request(IOEXP_RESET, "ioexp_rst");
- gpio_direction_output(IOEXP_RESET, 1);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x00);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x82ee);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100);
- if (phydev->drv->config)
+} +#endif
- u32 sc_build = 0, sc_commit = 0;
- /* Get SCFW build and commit id */
- sc_misc_build_info(-1, &sc_build, &sc_commit);
- if (!sc_build) {
- printf("Build: SCFW %x\n", sc_commit);
- puts("Model: Toradex Colibri iMX8X\n");
- build_info();
- print_bootinfo();
- board_gpio_init();
- puts("\nDDR ");
- /* TODO */
- return ft_common_board_setup(blob, bd);
+} +#endif
- return devno;
- env_set("board_name", "Colibri iMX8QXP");
- env_set("board_rev", "v1.0");
- "fdt_addr_r=0x84000000\0" \
- "kernel_addr_r=0x82000000\0" \
- "ramdisk_addr_r=0x84100000\0"
- "m4_0_image=m4_0.bin\0" \
- "loadm4image_0=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} " \
"${m4_0_image}\0" \
- "m4boot_0=run loadm4image_0; dcache flush; bootaux ${loadaddr} 0\0" \
- func(MMC, mmc, 0) \
- func(MMC, mmc, 1) \
- func(DHCP, dhcp, na)
- "mfgtool_args=setenv bootargs console=${console},${baudrate} " \
"\0" \
- "initrd_addr=0x83800000\0" \
- "initrd_high=0xffffffff\0" \
- "bootcmd_mfg=run mfgtool_args;booti ${loadaddr} ${initrd_addr} " \
"${fdt_addr};\0" \
- AHAB_ENV \
- BOOTENV \
- CONFIG_MFG_ENV_SETTINGS \
- M4_BOOT_ENV \
- MEM_LAYOUT_ENV_SETTINGS \
- "boot_fdt=try\0" \
- "bootscript=echo Running bootscript from mmc ...; source\0" \
- "console=ttyLP3,115200 earlycon=lpuart32,0x5a090000,115200\0" \
- "fdt_addr=0x83000000\0" \
- "fdt_file=fsl-imx8qxp-colibri-eval-v3.dtb\0" \
- "fdt_high=0xffffffffffffffff\0" \
- "finduuid=part uuid mmc ${mmcdev}:2 uuid\0" \
- "image=Image\0" \
- "initrd_high=0xffffffffffffffff\0" \
- "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} " \
"${script};\0" \
- "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \
- "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \
- "mmcargs=setenv bootargs console=${console},${baudrate} " \
- "mmcautodetect=yes\0" \
- "mmcboot=echo Booting from mmc ...; " \
"else " \
"fi; " \
"else " \
"fi;\0" \
- "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \
- "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \
- "netargs=setenv bootargs console=${console} root=/dev/nfs ip=dhcp " \
- "netboot=echo Booting from net ...; " \
"run netargs; " \
"else " \
"fi; " \
"else " \
"fi; " \
"else " \
"booti; " \
"fi;\0" \
- "nfsboot=run netargs; dhcp ${loadaddr} ${image}; tftp ${fdt_addr} " \
"${fdt_addr}\0" \
- "panel=NULL\0" \
- "script=boot.scr\0" \
- "video=imxdpufb5:off video=imxdpufb6:off video=imxdpufb7:off\0"
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
Hi Stefano
On Thu, 2019-04-25 at 12:48 +0200, Stefano Babic wrote:
Hi Marcel,
- Ethernet
- GPIOs
- I2C
Sure, looks like Peng's commit caceb739ea07 ("imx: build flash.bin for i.MX8") takes SPL for granted while my patchset currently avoids it.
BTW: I still don't believe SPL makes much sense on i.MX 8X given all the other proprietary parts involved in booting. Plus currently SPL actually breaks the USB serial downloader aka recovery mode using the universal update utility (uuu) aka mfgtools 3.0.
Regards, Stefano
Cheers
Marcel
Changes in v2:
+&mu {
- u-boot,dm-spl;
+&clk {
- u-boot,dm-spl;
+&iomuxc {
- u-boot,dm-spl;
+&pd_lsio {
- u-boot,dm-spl;
+&pd_lsio_gpio0 {
- u-boot,dm-spl;
+&pd_lsio_gpio1 {
- u-boot,dm-spl;
+&pd_lsio_gpio2 {
- u-boot,dm-spl;
+&pd_lsio_gpio3 {
- u-boot,dm-spl;
+&pd_lsio_gpio4 {
- u-boot,dm-spl;
+&pd_lsio_gpio5 {
- u-boot,dm-spl;
+&pd_lsio_gpio6 {
- u-boot,dm-spl;
+&pd_lsio_gpio7 {
- u-boot,dm-spl;
+&pd_conn {
- u-boot,dm-spl;
+&pd_conn_sdch0 {
- u-boot,dm-spl;
+&pd_conn_sdch1 {
- u-boot,dm-spl;
+&pd_conn_sdch2 {
- u-boot,dm-spl;
+&gpio0 {
- u-boot,dm-spl;
+&gpio1 {
- u-boot,dm-spl;
+&gpio2 {
- u-boot,dm-spl;
+&gpio3 {
- u-boot,dm-spl;
+&gpio4 {
- u-boot,dm-spl;
+&gpio5 {
- u-boot,dm-spl;
+&gpio6 {
- u-boot,dm-spl;
+&gpio7 {
- u-boot,dm-spl;
+&lpuart3 {
- u-boot,dm-spl;
+&usdhc1 {
- u-boot,dm-spl;
+&usdhc2 {
- u-boot,dm-spl;
+/dts-v1/;
- chosen {
+&iomuxc {
- colibri-imx8qxp {
fsl,pins = <
fsl,pins = <
6000020
6000020
fsl,pins = <
0000020 /* DCD */
0000020 /* RI */
fsl,pins = <
0x06000020SC_P_ENET0_MDC_CONN_ENET0_MDC
0x06000020SC_P_ENET0_MDIO_CONN_ENET0_MDIO
I_TX_CTL 0x00000061
_OUT 0x06000061
TXD0 0x00000061
TXD1 0x00000061
I_RX_CTL 0x00000061
RXD0 0x00000061
RXD1 0x00000061
X_ER 0x00000061
fsl,pins = <
0000040
fsl,pins = <
fsl,pins = <
0000020 /* 45 */
0x06000020 /* 65 */
0x00000061
0000020 /* 69 */
0x00000020 /* 73 */
0x00000020 /* 79 */
0x00000061
0x06000020 /* 85 */
0x00000061
0000020 /* 95 */
0x00000020 /* 97 */
0x00000061
0000020 /* 99 */
0x00000061
0x00000061
0000020 /* 105 */
0000020 /* 107 */
0000020 /* 127 */
0000020 /* 131 */
0000020 /* 133 */
0x00000020 /* 96 */
0000020 /* 98 */
0000020 /* 104 */
0000020 /* 106 */
fsl,pins = <
0x00000020 /* 75 */
0000020 /* 77 */
0000020 /* 89 */
0000020 /* 93 */
fsl,pins = <
0x06000021
0x06000021
/*INT*/
fsl,pins = <
0x00000061
fsl,pins = <
O09 0x06000040
fsl,pins = <
6000040
fsl,pins = <
0x06000041
0x00000021
0000021
0000021
0000021
0000021
0000021
0000021
0000021
0000021
0000041
0x00000021
fsl,pins = <
0x06000041
0x00000021
0000021
0000021
0000021
0000021
0000021
0000021
0000021
0000021
0000041
0x00000021
fsl,pins = <
0x06000041
0x00000021
0000021
0000021
0000021
0000021
0000021
0000021
0000021
0000021
0000041
0x00000021
fsl,pins = <
6000021
fsl,pins = <
0x06000041
0x00000021
0000021
0000021
0000021
0000021
0x00000021SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT
fsl,pins = <
0x06000041
0x00000021
0000021
0000021
0000021
0000021
fsl,pins = <
0x06000041
0x00000021
0000021
0000021
0000021
0000021
+&lpuart0 {
- status = "okay";
+&lpuart3 {
- status = "okay";
+&gpio0 {
- status = "okay";
+&gpio1 {
- status = "okay";
+&gpio3 {
- status = "okay";
+&gpio4 {
- status = "okay";
+&fec1 {
- status = "okay";
- mdio {
#size-cells = <0>;
max-speed = <100>;
reg = <2>;
+&i2c1 {
- status = "okay";
+&usdhc1 {
- bus-width = <8>;
- non-removable;
- status = "okay";
+&usdhc2 {
- bus-width = <4>;
- status = "okay";
- select IMX8QXP
+config SYS_BOARD
+config SYS_VENDOR
- default "toradex"
- default y
- default y
- default "0"
- default "1"
- default "-512"
- sc_err_t err = 0;
1.2M
- rate = 80000000;
&rate);
SC_PM_PW_MODE_ON);
- rate = 80000000;
&rate);
false);
- int ret;
- if (ret)
return;
- if (ret)
return;
- udelay(50);
+} +#endif
- if (!sc_build) {
- build_info();
- print_bootinfo();
- puts("\nDDR ");
- /* TODO */
+} +#endif
- return devno;
configure
"${m4_0_image}\0" \
0\0" \
"\0" \
"${fdt_addr};\0" \
- AHAB_ENV \
- BOOTENV \
- M4_BOOT_ENV \
- "image=Image\0" \
"${script};\0" \
${fdt_file}\0" \
${image}\0" \
then " \
"else " \
"fi; " \
"else " \
"fi;\0" \
ip=dhcp " \
"run netargs; " \
"else " \
"fi; " \
then " \
"else " \
"fi; " \
"else " \
"booti; " \
"fi;\0" \
${fdt_addr} " \
"${fdt_addr}\0" \
- "panel=NULL\0" \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
- 1024)) * 1024)
Hi Marcel,
On 25/04/19 14:35, Marcel Ziswiler wrote:
Hi Stefano
Hi Marcel,
- Ethernet
- GPIOs
- I2C
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
It looks so, yes.
SPL makes more sense if it is possible to detect at runtime the HW and change the configuration - for i.MX6, this means RAMS detection, which boot device is booting, and so on.
On i.MX8 there is a lot of proprietary parts - we lose the flexibility of SPL, and most features are lost (or must be provided by proprietary code). I agree that on this platform SPL makes less sense, and i.MX8 should be built independently if CONFIG_SPL is set (this is also for i.MX6 / MX5, there are boards without SPL and using the DCD image to set up the RAM controller).
Regards, Stefano
Hi Stefano,
Subject: Re: [PATCH v2 5/5] board: toradex: add colibri imx8qxp 2gb wb it v1.0b module support
Hi Marcel,
Hi Stefano
Hi Marcel,
may
Functionality wise the following is known to be working:
- eMMC and MMC/SD card
- Ethernet
- GPIOs
- I2C
Unfortunately, there is no USB functionality for the i.MX 8QXP as of yet.
It looks so, yes.
The reason we move to use SPL on i.MX8 is that we would like to avoid bind ATF/OP-TEE/U-Boot into a flat image with hacked offset in an image.
So the bootflow now is SPL->ATF->OPTEE->ATF->U-Boot
Without SPL, when generating flash.bin, we have to hack ATF to copy OP-TEE image from flash.bin to the runtime location.
The usb related function for i.MX8 is not ready now. we are almost run out of ocram with SPL DM, thinking to use OF_PLATDATA now, then move to usb functions.
Thanks, Peng.
Regards, Stefano
======= DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de ============================================================== =======
Hi Peng,
On 26/04/19 04:10, Peng Fan wrote:
Hi Stefano,
Hi Marcel,
Hi Stefano
Hi Marcel,
may
- Ethernet
- GPIOs
- I2C
It looks so, yes.
It seemed I have missed some point. Thanks for clarification. This makes sense.
Nevertheless, I understand that it is not strictly required to enable OPTEE to boot the kernel, and in some applications a secure zone is not required. The thing is not that SPL is used here, but to constrain all other users like Marcel to do the same. With i.MX6, even if I strongly suggested to do this to allow run time detection, I let boards without SPL and with just u-boot.imx (with built-in DCD) to flow into mainline - the board maintainer rules as he knows better where the device is used.
So I will prefer that the build assume to have SPL just if SPL is configured and not in any case, letting boards without SPL (like this colibri-mx8) to build.
That is ok - it s WIP, it will be merged when ready. I agree with you, this is *not* a reason to avoid SPL.
Understood.
Best regards, Stefano
Hi Stefano,
Hi Peng,
Hi Stefano,
Hi Marcel,
Hi Stefano
Hi Marcel,
on-module
eMMC or
may
- Ethernet
- GPIOs
- I2C
+cc1: fatal error: opening output file spl/u-boot-spl.cfgout: No +such file or directory +compilation terminated.
It looks so, yes.
ok. Then need to think about how to bind bl31.bin and u-boot.bin,
the binded image will be copied to 0x80000000 by ROM.
Consider bl31 is 128KB now, so uboot entry could be hardcoded to 0x80020000, and u-boot.bin is 128KB offset of the final image.
Could use binman. And then need to generate flash.bin.
Regards, Peng.
Understood.
Hi Peng and Stefano
On Fri, 2019-04-26 at 10:38 +0200, Stefano Babic wrote:
Hi Peng,
Hi Stefano,
Hi Marcel,
Hi Stefano
Hi Marcel,
may
- Ethernet
- GPIOs
- I2C
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com >
It looks so, yes.
OK, I was also not aware of this.
However, currently I am just happy the current tooling kinda works. Which is we can ship stuff to customers and they may use uuu to recover bricked modules. So far nobody is talking about OP-TEE and such advanced use cases yet.
On the other hand enabling SPL currently does not seem to work at all on our hardware. Neither booting from eMMC nor recovering using uuu. That is really the main reason I decided against it at least for now.
Thanks!
Colibri iMX8X that is while on the Apalis family we have the Apalis iMX8 (e.g. with the i.MX 8QuadMax or i.MX 8QuadPlus) and the new Apalis iMX8X with ECC RAM still in the works. Welcome to the i.MX 8 series with the i.MX 8 and i.MX 8X families and careful with NXP's brilliant naming scheme (;-p).
) to build.
Don't worry. I believe I found a fix for the issue at hand and will send a patch shortly.
Agreed. However, it is kinda painful requiring different U-Boot configuration flavours for regular boot vs. recovery. That said we used to previously do this on Apalis/Colibri iMX6 as well so it is definitely no show stopper.
Understood.
Yeah, I also played with OF_PLATDATA once before however was not entirely happy with the result as of yet. I guess WIP patches welcome (;-p).
Cheers
Marcel
Hi Peng and Stefano
Hi Peng,
Hi Stefano,
Hi Marcel,
Hi Stefano
Hi Marcel,
On 09/04/19 17:25, Marcel Ziswiler wrote: > From: Marcel Ziswiler marcel.ziswiler@toradex.com > > This commit adds initial support for the Toradex Colibri > iMX8QXP 2GB WB IT V1.0B module. Unlike the V1.0A early > access samples exclusively booting from SD card, they are > now strapped to boot from eFuses which are factory fused to > properly boot from their on-module eMMC. U- Boot supports > either booting from the on-module eMMC or
may
> be used for recovery purpose using the universal update > utility > (uuu) aka mfgtools 3.0. > > Functionality wise the following is known to be working: > - eMMC and MMC/SD card > - Ethernet > - GPIOs > - I2C > > Unfortunately, there is no USB functionality for the i.MX > 8QXP as of yet. > > Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com > > > > --- >
It looks so, yes.
In vendor tree, we use SPL to load i.MX8 container image. To UUU, 1st need to enable usb gadget functions in SPL, then enable container for the 2nd image. So with uuu, it not work with upstream U-Boot now.
Thanks!
) to build.
ok.
Regards, Peng.
Understood.
Cheers
Marcel
Hi Peng and Stefano
Hi Peng,
Hi Stefano,
Hi Marcel,
Hi Stefano
On Thu, 2019-04-25 at 12:48 +0200, Stefano Babic wrote: > Hi Marcel, > > On 09/04/19 17:25, Marcel Ziswiler wrote: > > From: Marcel Ziswiler marcel.ziswiler@toradex.com > > > > This commit adds initial support for the Toradex > > Colibri > > iMX8QXP 2GB WB IT V1.0B module. Unlike the V1.0A early > > access samples exclusively booting from SD card, they > > are > > now strapped to boot from eFuses which are factory > > fused to > > properly boot from their on-module eMMC. U- Boot > > supports > > either booting from the on-module eMMC or
may
> > be used for recovery purpose using the universal update > > utility > > (uuu) aka mfgtools 3.0. > > > > Functionality wise the following is known to be > > working: > > - eMMC and MMC/SD card > > - Ethernet > > - GPIOs > > - I2C > > > > Unfortunately, there is no USB functionality for the > > i.MX > > 8QXP as of yet. > > > > Signed-off-by: Marcel Ziswiler < > > marcel.ziswiler@toradex.com > > > > --- > > > > I merged the series and build locally (fine), but Travis > complains and stops with error: > > +cc1: fatal error: opening output file spl/u-boot- > spl.cfgout: > No such > file or directory > +compilation terminated. > > Can you take a look at it ?
It looks so, yes.
Strange, for me this works just fine with mainline just not with SPL being enabled e.g. as per board/toradex/colibri-imx8qxp/README:
[user@host uuu]$ sudo ./uuu u-boot/u-boot-dtb.imx uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.2.66-0- ga1a8e69
Success 1 Failure 0
1:33 2/ 2 [Done ] SDPS: done
U-Boot 2019.04-rc4-00169-g42dd45e2d9-dirty (Apr 26 2019 - 11:30:58 +0200)
CPU: NXP i.MX8QXP RevB A35 at 1200 MHz
DRAM: 2 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@5a090000 Out: serial@5a090000 Err: serial@5a090000 Model: Toradex Colibri iMX8 QuadXPlus 2GB Wi-Fi / BT IT V1.0B, Serial# 06410651 Net: eth0: ethernet@5b040000 Hit any key to stop autoboot: 0 =>
Thanks!
) to build.
ok.
Regards, Peng.
Understood.
Cheers
Marcel
-----Original Message----- From: Marcel Ziswiler [mailto:marcel.ziswiler@toradex.com] Sent: 2019年4月26日 17:38 To: Peng Fan peng.fan@nxp.com; u-boot@lists.denx.de; sbabic@denx.de Cc: siva.durga.paladugu@xilinx.com; marek.vasut+renesas@gmail.com; maxime.ripard@bootlin.com; festevam@gmail.com; michal.simek@xilinx.com; wens@csie.org; dl-uboot-imx uboot-imx@nxp.com; yamada.masahiro@socionext.com; sr@denx.de; jagan@amarulasolutions.com; agust@denx.de; albert.u.boot@aribaud.net Subject: Re: [PATCH v2 5/5] board: toradex: add colibri imx8qxp 2gb wb it v1.0b module support
Hi Peng and Stefano
Hi Peng,
Hi Stefano,
Hi Marcel,
On 25/04/19 14:35, Marcel Ziswiler wrote: > Hi Stefano > > On Thu, 2019-04-25 at 12:48 +0200, Stefano Babic wrote: > > Hi Marcel, > > > > On 09/04/19 17:25, Marcel Ziswiler wrote: > > > From: Marcel Ziswiler marcel.ziswiler@toradex.com > > > > > > This commit adds initial support for the Toradex Colibri > > > iMX8QXP 2GB WB IT V1.0B module. Unlike the V1.0A early > > > access samples exclusively booting from SD card, they > > > are now strapped to boot from eFuses which are factory > > > fused to properly boot from their on-module eMMC. U- > > > Boot supports either booting from the on-module eMMC or may > > > be used for recovery purpose using the universal update > > > utility > > > (uuu) aka mfgtools 3.0. > > > > > > Functionality wise the following is known to be > > > working: > > > - eMMC and MMC/SD card > > > - Ethernet > > > - GPIOs > > > - I2C > > > > > > Unfortunately, there is no USB functionality for the > > > i.MX 8QXP as of yet. > > > > > > Signed-off-by: Marcel Ziswiler < > > > marcel.ziswiler@toradex.com > > > > > > --- > > > > > > > I merged the series and build locally (fine), but Travis > > complains and stops with error: > > > > +cc1: fatal error: opening output file spl/u-boot- > > spl.cfgout: > > No such > > file or directory > > +compilation terminated. > > > > Can you take a look at it ? > > Sure, looks like Peng's commit caceb739ea07 ("imx: build > flash.bin for > i.MX8") takes SPL for granted while my patchset currently > avoids it.
It looks so, yes.
> BTW: I still don't believe SPL makes much sense on i.MX 8X > given all the other proprietary parts involved in booting.
For flash.bin with SPL, UUU will not work for upstream uboot to load 2nd images. For flash.bin without SPL, UUU will able to work. So it works for you.
Regards, Peng.
Success 1 Failure 0
Thanks!
) to build.
ok.
Regards, Peng.
> Plus currently SPL > actually breaks the USB serial downloader aka recovery mode > using the universal update utility (uuu) aka mfgtools 3.0.
Understood.
Cheers
Marcel
participants (6)
Igor Opaniuk
Marcel Ziswiler
Marcel Ziswiler
Peng Fan
sbabic@denx.de
Stefano Babic
