[U-Boot-Users] linking u-boot for mips little endian w/ hardhat tools.
I am trying to port u-boot to a system w/ a mips 4kc little endian processor.
in looking at other cpu/boards to use as a starting point/template, I chose the tb0229 board as it looked to also be a 4kc little endian cpu.
when I build, I get the an undefined reference to _GLOBAL_OFFSET_TABLE_.
I did some fiddling aroud, and comparing to linker command files for other boards and I found that the line:
OUTPUT_FORMAT("elf32-tradlittlemips", "elf32-tradlittlemips",\ "elf32-tradlittlemips")
if changed to:
OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradbigmips")
will allow me to compile and link fine...
my question is then:
1) what does this really do? 2) if I'm using a little endian cpu, do I really need it set to elf32-tradlittlemips? 3) if so how do I solve my problem? 4) if not why?
one more note the compiler/toolchain that I'm using is from montavista, the -v option displays the following:
====================================== mips_fp_le-gcc -v Reading specs from /opt/hardhat/devkit/mips/fp_le/lib/gcc-lib/ mipsel-hardhat-linux/3.2.1/specs Configured with: ../configure --host=i686-pc-linux-gnu --target=mipsel-hardhat-linux --prefix=/opt/hardhat/devkit/mips/fp_le --exec-prefix=/opt/hardhat/devkit/mips/fp_le --bindir=/opt/hardhat/devkit/ mips/fp_le/bin --sbindir=/opt/hardhat/devkit/mips/fp_le/sbin --sysconfdir=/ opt/hardhat/devkit/mips/fp_le/etc --datadir=/opt/hardhat/devkit/mips/fp_le/ share --includedir=/opt/hardhat/devkit/mips/fp_le/include --libdir=/opt/ hardhat/devkit/mips/fp_le/lib --libexecdir=/opt/hardhat/devkit/mips/fp_le/ libexec --localstatedir=/opt/hardhat/devkit/mips/fp_le/var --sharedstatedir=/ opt/hardhat/devkit/mips/fp_le/share --mandir=/opt/hardhat/devkit/mips/fp_le/ man --infodir=/opt/hardhat/devkit/mips/fp_le/info --program-transform-name=s,^,mips_fp_le-, --enable-cross --with-gxx-include-dir=${prefix}/mipsel-hardhat-linux/include/g++-v3 --enable-shared --enable-languages=c,c++ --enable-threads=posix --enable-__cxa_atexit --disable-multilib Thread model: posix gcc version 3.2.1 20020930 (MontaVista) =======================================
thanks for any help you can offer...(sorry this is maybe more of a tool related question, but monta vista has not been much help as of yet).
Mike ~
Hi Mike,
If you change the file format to tradlittlemips then you'll also need to compile using the little endian flag (-EL) instead of the default big endian flag (-EB) flag. If you haven't already you'll probably have to do something like this:
--- cpu/mips/config.mk 2003-06-27 17:32:33.000000000 -0400 +++ cpu/mips/config.mk 2004-10-04 16:09:31.612045528 -0400 @@ -21,4 +21,4 @@ # MA 02111-1307 USA #
-PLATFORM_CPPFLAGS += -mcpu=4kc -EB -mabicalls +PLATFORM_CPPFLAGS += -mcpu=4kc -EL -mabicalls
Hope that helps, Charles
if changed to:
- what does this really do?
- if I'm using a little endian cpu, do I really need it set to
Mike ~
This SF.net email is sponsored by: IT Product Guide on ITManagersJournal Use IT products in your business? Tell us what you think of them. Give us Your Opinions, Get Free ThinkGeek Gift Certificates! Click to find out more http://productguide.itmanagersjournal.com/guidepromo.tmpl _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
In message 200410081126.38970.msundius@sundius.com you wrote:
OUTPUT_FORMAT("elf32-tradlittlemips", "elf32-tradlittlemips",\ "elf32-tradlittlemips") if changed to: OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradbigmips") will allow me to compile and link fine...
Maybe it changes the output format from little endian to big endian?
Depending on your toolchain, yes.
- if so how do I solve my problem?
Use different tools?
- if not why?
Why what?
The attached file is a patch to comiple and link for tb0229 using MIPS technologies SDE.
ftp://ftp.mips.com/pub/tools/software/sde-for-linux/
Masami Komiya
if changed to:
Mike ~
I'm sorry, but I have to reject this patch as it breaks support for all other existing MIPS boards. Please resubmit a new patch which modifies compile and linker options in a board (or at least configuration) dependent way.
I understand your meanings. There is no need to add to CVS. This is a only reference to compile U-BOOT for tb0229 and other MIPS little endian board.
Masami Komiya
C Michael Sundius
Charles Eidsness
Masami Komiya
