[PATCH 1/1] doc: building documentation
Provide a man-page describing how to build the U-Boot documentation.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- doc/build/documentation.rst | 90 +++++++++++++++++++++++++++++++++++++ doc/build/index.rst | 1 + 2 files changed, 91 insertions(+) create mode 100644 doc/build/documentation.rst
diff --git a/doc/build/documentation.rst b/doc/build/documentation.rst new file mode 100644 index 0000000000..896264dd7c --- /dev/null +++ b/doc/build/documentation.rst @@ -0,0 +1,90 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +Building documentation +====================== + +The U-Boot documentation is based on the Sphinx documentation generator. + +HTML documentation +------------------ + +The *htmldocs* target is used to build the HTML documentation. It uses the +`Read the Docs Sphinx theme https://sphinx-rtd-theme.readthedocs.io/en/stable/`_. + +.. code-block:: bash + + # Create Python environment 'myenv' + python3 -m venv myenv + # Activate the Python environment + . myenv/bin/activate + # Install build requirements + python3 -m pip install -r doc/sphinx/requirements.txt + # Build the documentation + make htmldocs + # Deactivate the Python environment + deactivate + # Display the documentation in a graphical web browser + x-www-browser doc/output/index.html + +Infodoc documentation +--------------------- + +The *infodocs* target builds both a texinfo and an info file: + +.. code-block:: bash + + # Create Python environment 'myenv' + python3 -m venv myenv + # Activate the Python environment + . myenv/bin/activate + # Install build requirements + python3 -m pip install -r doc/sphinx/requirements.txt + # Build the documentation + make infodocs + # Deactivate the Python environment + deactivate + # Display the documentation + info doc/output/texinfo/u-boot.info + +PDF documentation +----------------- + +The *pdfdocs* target is meant to be used to build PDF documenation. +As v2023.01 it fails with 'LaTeX Error: Too deeply nested'. + +We can use texi2pdf instead: + +.. code-block:: bash + + # Create Python environment 'myenv' + python3 -m venv myenv + # Activate the Python environment + . myenv/bin/activate + # Install build requirements + python3 -m pip install -r doc/sphinx/requirements.txt + # Build the documentation + make texinfodocs + # Deactivate the Python environment + deactivate + # Convert to PDF + texi2pdf doc/output/texinfo/u-boot.texi + +Texinfo documentation +--------------------- + +To build only the texinfo documentation the *texinfodocs* target is used: + +.. code-block:: bash + + # Create Python environment 'myenv' + python3 -m venv myenv + # Activate the Python environment + . myenv/bin/activate + # Install build requirements + python3 -m pip install -r doc/sphinx/requirements.txt + # Build the documentation + make texinfodocs + # Deactivate the Python environment + deactivate + +The output is in file *doc/output/texinfo/u-boot.texi*. diff --git a/doc/build/index.rst b/doc/build/index.rst index 9a8105db21..dc9cde4001 100644 --- a/doc/build/index.rst +++ b/doc/build/index.rst @@ -12,3 +12,4 @@ Build U-Boot docker tools buildman + documentation
Hi Heinrich,
On Thu, 29 Dec 2022 at 22:08, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
- # Create Python environment 'myenv'
- python3 -m venv myenv
- # Activate the Python environment
- . myenv/bin/activate
- # Install build requirements
- python3 -m pip install -r doc/sphinx/requirements.txt
- # Build the documentation
- make htmldocs
- # Deactivate the Python environment
- deactivate
- # Display the documentation in a graphical web browser
- x-www-browser doc/output/index.html
If this is necessary then it is a bit of a sad indictment on Python. I would use:
pip3 install -r doc/sphinx/requirements.txt make htmldocs
- make infodocs
- deactivate
- info doc/output/texinfo/u-boot.info
- make texinfodocs
- deactivate
- # Convert to PDF
- texi2pdf doc/output/texinfo/u-boot.texi
- make texinfodocs
- deactivate
- documentation
-- 2.37.2
On Fri, Dec 30, 2022 at 11:51:15AM -0600, Simon Glass wrote:
Hi Heinrich,
- make htmldocs
- deactivate
Which part, exactly? Using a virtual environment is I believe a normal best practice and "python3 -m pip" rather than "pip3" I assume is another best practice for portability. Then maybe the final step should say "Review" not "Display" ?
Hi Heinrich,
- make htmldocs
- deactivate
Review only applies to documentation developers. Normal users just want to read the documentation.
Best regards
Heinrich
On Fri, 30 Dec 2022 at 12:31, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
- make htmldocs
- deactivate
Using a virtual environment seems annoying to me. Should we put that in a separate section for those who want to do it?
Hi Heinrich,
- make htmldocs
- deactivate
I think that's the opposite. As best I can see, virtual environments are a python best practice, and if you don't want to use one you just skip those steps.
Hi Heinrich,
- make htmldocs
- deactivate
Current Ubuntu packages are incompatible with the readthedocs theme. Therefore I describe a way of building that works for most users.
Best regards
Heinrich
Hi Heinrich,
On Fri, 30 Dec 2022 at 12:08, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
- make htmldocs
- deactivate
OK I see. Somehow it builds OK for me on 22.04 but I have not tried newer versions.
Would it be possible to have the virtual env start/stop stuff in a separate place? I suppose that would not be ideal either, since it would make the instructions more complicated for those that have trouble...
On Sat, Jan 07, 2023 at 11:55:59AM -0700, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
On Thu, 29 Dec 2022 at 22:08, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote: > > Provide a man-page describing how to build the U-Boot documentation. > > Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com > --- > doc/build/documentation.rst | 90 +++++++++++++++++++++++++++++++++++++ > doc/build/index.rst | 1 + > 2 files changed, 91 insertions(+) > create mode 100644 doc/build/documentation.rst > > diff --git a/doc/build/documentation.rst b/doc/build/documentation.rst > new file mode 100644 > index 0000000000..896264dd7c > --- /dev/null > +++ b/doc/build/documentation.rst > @@ -0,0 +1,90 @@ > +.. SPDX-License-Identifier: GPL-2.0+: > + > +Building documentation > +====================== > + > +The U-Boot documentation is based on the Sphinx documentation generator. > + > +HTML documentation > +------------------ > + > +The *htmldocs* target is used to build the HTML documentation. It uses the > +`Read the Docs Sphinx theme https://sphinx-rtd-theme.readthedocs.io/en/stable/`_. > + > +.. code-block:: bash > + > + # Create Python environment 'myenv' > + python3 -m venv myenv > + # Activate the Python environment > + . myenv/bin/activate > + # Install build requirements > + python3 -m pip install -r doc/sphinx/requirements.txt > + # Build the documentation > + make htmldocs > + # Deactivate the Python environment > + deactivate > + # Display the documentation in a graphical web browser > + x-www-browser doc/output/index.html
As virtualenv is a python best practice, I believe we should just assume that users that want to skip it, know how to skip it.
On 1/7/23 19:55, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
make htmldocs builds but the formatting of the HTML does not conform to the readthedocs style. Just open the documentation in a browser.
Best regards
Heinrich
Hi Heinrich,
On Sat, 7 Jan 2023 at 15:16, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
On Fri, Dec 30, 2022 at 11:51:15AM -0600, Simon Glass wrote: > Hi Heinrich, > > On Thu, 29 Dec 2022 at 22:08, Heinrich Schuchardt > heinrich.schuchardt@canonical.com wrote: >> >> Provide a man-page describing how to build the U-Boot documentation. >> >> Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com >> --- >> doc/build/documentation.rst | 90 +++++++++++++++++++++++++++++++++++++ >> doc/build/index.rst | 1 + >> 2 files changed, 91 insertions(+) >> create mode 100644 doc/build/documentation.rst >> >> diff --git a/doc/build/documentation.rst b/doc/build/documentation.rst >> new file mode 100644 >> index 0000000000..896264dd7c >> --- /dev/null >> +++ b/doc/build/documentation.rst >> @@ -0,0 +1,90 @@ >> +.. SPDX-License-Identifier: GPL-2.0+: >> + >> +Building documentation >> +====================== >> + >> +The U-Boot documentation is based on the Sphinx documentation generator. >> + >> +HTML documentation >> +------------------ >> + >> +The *htmldocs* target is used to build the HTML documentation. It uses the >> +`Read the Docs Sphinx theme https://sphinx-rtd-theme.readthedocs.io/en/stable/`_. >> + >> +.. code-block:: bash >> + >> + # Create Python environment 'myenv' >> + python3 -m venv myenv >> + # Activate the Python environment >> + . myenv/bin/activate >> + # Install build requirements >> + python3 -m pip install -r doc/sphinx/requirements.txt >> + # Build the documentation >> + make htmldocs >> + # Deactivate the Python environment >> + deactivate >> + # Display the documentation in a graphical web browser >> + x-www-browser doc/output/index.html > > If this is necessary then it is a bit of a sad indictment on Python. I > would use: > > pip3 install -r doc/sphinx/requirements.txt > make htmldocs
It looks OK for me...what should I be seeing?
On 1/7/23 23:54, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
On 12/30/22 19:12, Tom Rini wrote: > On Fri, Dec 30, 2022 at 11:51:15AM -0600, Simon Glass wrote: >> Hi Heinrich, >> >> On Thu, 29 Dec 2022 at 22:08, Heinrich Schuchardt >> heinrich.schuchardt@canonical.com wrote: >>> >>> Provide a man-page describing how to build the U-Boot documentation. >>> >>> Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com >>> --- >>> doc/build/documentation.rst | 90 +++++++++++++++++++++++++++++++++++++ >>> doc/build/index.rst | 1 + >>> 2 files changed, 91 insertions(+) >>> create mode 100644 doc/build/documentation.rst >>> >>> diff --git a/doc/build/documentation.rst b/doc/build/documentation.rst >>> new file mode 100644 >>> index 0000000000..896264dd7c >>> --- /dev/null >>> +++ b/doc/build/documentation.rst >>> @@ -0,0 +1,90 @@ >>> +.. SPDX-License-Identifier: GPL-2.0+: >>> + >>> +Building documentation >>> +====================== >>> + >>> +The U-Boot documentation is based on the Sphinx documentation generator. >>> + >>> +HTML documentation >>> +------------------ >>> + >>> +The *htmldocs* target is used to build the HTML documentation. It uses the >>> +`Read the Docs Sphinx theme https://sphinx-rtd-theme.readthedocs.io/en/stable/`_. >>> + >>> +.. code-block:: bash >>> + >>> + # Create Python environment 'myenv' >>> + python3 -m venv myenv >>> + # Activate the Python environment >>> + . myenv/bin/activate >>> + # Install build requirements >>> + python3 -m pip install -r doc/sphinx/requirements.txt >>> + # Build the documentation >>> + make htmldocs >>> + # Deactivate the Python environment >>> + deactivate >>> + # Display the documentation in a graphical web browser >>> + x-www-browser doc/output/index.html >> >> If this is necessary then it is a bit of a sad indictment on Python. I >> would use: >> >> pip3 install -r doc/sphinx/requirements.txt >> make htmldocs > > Which part, exactly? Using a virtual environment is I believe a normal > best practice and "python3 -m pip" rather than "pip3" I assume is > another best practice for portability. Then maybe the final step should > say "Review" not "Display" ? >
This is the output without Python environment: https://gist.github.com/xypron/aef88822a1f2f34e29faf5302313de6a
This is what it should look like: https://u-boot.readthedocs.io/en/latest/
Best regards
Heinrich
Hi Heinrich,
On Sat, 7 Jan 2023 at 17:11, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Hi Heinrich,
On Fri, 30 Dec 2022 at 12:31, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote: > > > > On 12/30/22 19:12, Tom Rini wrote: >> On Fri, Dec 30, 2022 at 11:51:15AM -0600, Simon Glass wrote: >>> Hi Heinrich, >>> >>> On Thu, 29 Dec 2022 at 22:08, Heinrich Schuchardt >>> heinrich.schuchardt@canonical.com wrote: >>>> >>>> Provide a man-page describing how to build the U-Boot documentation. >>>> >>>> Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com >>>> --- >>>> doc/build/documentation.rst | 90 +++++++++++++++++++++++++++++++++++++ >>>> doc/build/index.rst | 1 + >>>> 2 files changed, 91 insertions(+) >>>> create mode 100644 doc/build/documentation.rst >>>> >>>> diff --git a/doc/build/documentation.rst b/doc/build/documentation.rst >>>> new file mode 100644 >>>> index 0000000000..896264dd7c >>>> --- /dev/null >>>> +++ b/doc/build/documentation.rst >>>> @@ -0,0 +1,90 @@ >>>> +.. SPDX-License-Identifier: GPL-2.0+: >>>> + >>>> +Building documentation >>>> +====================== >>>> + >>>> +The U-Boot documentation is based on the Sphinx documentation generator. >>>> + >>>> +HTML documentation >>>> +------------------ >>>> + >>>> +The *htmldocs* target is used to build the HTML documentation. It uses the >>>> +`Read the Docs Sphinx theme https://sphinx-rtd-theme.readthedocs.io/en/stable/`_. >>>> + >>>> +.. code-block:: bash >>>> + >>>> + # Create Python environment 'myenv' >>>> + python3 -m venv myenv >>>> + # Activate the Python environment >>>> + . myenv/bin/activate >>>> + # Install build requirements >>>> + python3 -m pip install -r doc/sphinx/requirements.txt >>>> + # Build the documentation >>>> + make htmldocs >>>> + # Deactivate the Python environment >>>> + deactivate >>>> + # Display the documentation in a graphical web browser >>>> + x-www-browser doc/output/index.html >>> >>> If this is necessary then it is a bit of a sad indictment on Python. I >>> would use: >>> >>> pip3 install -r doc/sphinx/requirements.txt >>> make htmldocs >> >> Which part, exactly? Using a virtual environment is I believe a normal >> best practice and "python3 -m pip" rather than "pip3" I assume is >> another best practice for portability. Then maybe the final step should >> say "Review" not "Display" ? >> > > Review only applies to documentation developers. > Normal users just want to read the documentation.
Strangely, for me, it looks like the second thing even without the environment. I have seen the first one though, but not for a while.I vaguely remember installing some style package?
On Sat, Jan 07, 2023 at 07:37:03PM -0700, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
On 12/30/22 20:02, Simon Glass wrote: > Hi, > > On Fri, 30 Dec 2022 at 12:31, Heinrich Schuchardt > heinrich.schuchardt@canonical.com wrote: >> >> >> >> On 12/30/22 19:12, Tom Rini wrote: >>> On Fri, Dec 30, 2022 at 11:51:15AM -0600, Simon Glass wrote: >>>> Hi Heinrich, >>>> >>>> On Thu, 29 Dec 2022 at 22:08, Heinrich Schuchardt >>>> heinrich.schuchardt@canonical.com wrote: >>>>> >>>>> Provide a man-page describing how to build the U-Boot documentation. >>>>> >>>>> Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com >>>>> --- >>>>> doc/build/documentation.rst | 90 +++++++++++++++++++++++++++++++++++++ >>>>> doc/build/index.rst | 1 + >>>>> 2 files changed, 91 insertions(+) >>>>> create mode 100644 doc/build/documentation.rst >>>>> >>>>> diff --git a/doc/build/documentation.rst b/doc/build/documentation.rst >>>>> new file mode 100644 >>>>> index 0000000000..896264dd7c >>>>> --- /dev/null >>>>> +++ b/doc/build/documentation.rst >>>>> @@ -0,0 +1,90 @@ >>>>> +.. SPDX-License-Identifier: GPL-2.0+: >>>>> + >>>>> +Building documentation >>>>> +====================== >>>>> + >>>>> +The U-Boot documentation is based on the Sphinx documentation generator. >>>>> + >>>>> +HTML documentation >>>>> +------------------ >>>>> + >>>>> +The *htmldocs* target is used to build the HTML documentation. It uses the >>>>> +`Read the Docs Sphinx theme https://sphinx-rtd-theme.readthedocs.io/en/stable/`_. >>>>> + >>>>> +.. code-block:: bash >>>>> + >>>>> + # Create Python environment 'myenv' >>>>> + python3 -m venv myenv >>>>> + # Activate the Python environment >>>>> + . myenv/bin/activate >>>>> + # Install build requirements >>>>> + python3 -m pip install -r doc/sphinx/requirements.txt >>>>> + # Build the documentation >>>>> + make htmldocs >>>>> + # Deactivate the Python environment >>>>> + deactivate >>>>> + # Display the documentation in a graphical web browser >>>>> + x-www-browser doc/output/index.html >>>> >>>> If this is necessary then it is a bit of a sad indictment on Python. I >>>> would use: >>>> >>>> pip3 install -r doc/sphinx/requirements.txt >>>> make htmldocs >>> >>> Which part, exactly? Using a virtual environment is I believe a normal >>> best practice and "python3 -m pip" rather than "pip3" I assume is >>> another best practice for portability. Then maybe the final step should >>> say "Review" not "Display" ? >>> >> >> Review only applies to documentation developers. >> Normal users just want to read the documentation. > > Using a virtual environment seems annoying to me. Should we put that > in a separate section for those who want to do it?
See, stuff like this is why the virtualenv is the default and a python best practice. You don't have to guess why things randomly look different than expected (or even more fun, unexpectedly work) because everyone is on the same environment. Skipping virtualenv is a user beware kind of thing and not what we want to encourage.
Hi Tom,
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
On Fri, 30 Dec 2022 at 12:08, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote: > > > > On 12/30/22 20:02, Simon Glass wrote: >> Hi, >> >> On Fri, 30 Dec 2022 at 12:31, Heinrich Schuchardt >> heinrich.schuchardt@canonical.com wrote: >>> >>> >>> >>> On 12/30/22 19:12, Tom Rini wrote: >>>> On Fri, Dec 30, 2022 at 11:51:15AM -0600, Simon Glass wrote: >>>>> Hi Heinrich, >>>>> >>>>> On Thu, 29 Dec 2022 at 22:08, Heinrich Schuchardt >>>>> heinrich.schuchardt@canonical.com wrote: >>>>>> >>>>>> Provide a man-page describing how to build the U-Boot documentation. >>>>>> >>>>>> Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com >>>>>> --- >>>>>> doc/build/documentation.rst | 90 +++++++++++++++++++++++++++++++++++++ >>>>>> doc/build/index.rst | 1 + >>>>>> 2 files changed, 91 insertions(+) >>>>>> create mode 100644 doc/build/documentation.rst >>>>>> >>>>>> diff --git a/doc/build/documentation.rst b/doc/build/documentation.rst >>>>>> new file mode 100644 >>>>>> index 0000000000..896264dd7c >>>>>> --- /dev/null >>>>>> +++ b/doc/build/documentation.rst >>>>>> @@ -0,0 +1,90 @@ >>>>>> +.. SPDX-License-Identifier: GPL-2.0+: >>>>>> + >>>>>> +Building documentation >>>>>> +====================== >>>>>> + >>>>>> +The U-Boot documentation is based on the Sphinx documentation generator. >>>>>> + >>>>>> +HTML documentation >>>>>> +------------------ >>>>>> + >>>>>> +The *htmldocs* target is used to build the HTML documentation. It uses the >>>>>> +`Read the Docs Sphinx theme https://sphinx-rtd-theme.readthedocs.io/en/stable/`_. >>>>>> + >>>>>> +.. code-block:: bash >>>>>> + >>>>>> + # Create Python environment 'myenv' >>>>>> + python3 -m venv myenv >>>>>> + # Activate the Python environment >>>>>> + . myenv/bin/activate >>>>>> + # Install build requirements >>>>>> + python3 -m pip install -r doc/sphinx/requirements.txt >>>>>> + # Build the documentation >>>>>> + make htmldocs >>>>>> + # Deactivate the Python environment >>>>>> + deactivate >>>>>> + # Display the documentation in a graphical web browser >>>>>> + x-www-browser doc/output/index.html >>>>> >>>>> If this is necessary then it is a bit of a sad indictment on Python. I >>>>> would use: >>>>> >>>>> pip3 install -r doc/sphinx/requirements.txt >>>>> make htmldocs >>>> >>>> Which part, exactly? Using a virtual environment is I believe a normal >>>> best practice and "python3 -m pip" rather than "pip3" I assume is >>>> another best practice for portability. Then maybe the final step should >>>> say "Review" not "Display" ? >>>> >>> >>> Review only applies to documentation developers. >>> Normal users just want to read the documentation. >> >> Using a virtual environment seems annoying to me. Should we put that >> in a separate section for those who want to do it? > > Current Ubuntu packages are incompatible with the readthedocs theme. > Therefore I describe a way of building that works for most users.
Yes I do understand that. I have sent the review tag a while back.
It's just that it is so broken. This is the sort of thing that gives Python a bad name...what is missing here that it shouldn't 'just work'? Is it some sort of version conflict?
