[U-Boot] [PATCH 1/3] lib/crc16.c: Coding-style cleanup
lib/crc16.c is changed to match the common U-Boot coding-style.
Signed-off-by: Stefan Roese sr@denx.de --- lib/crc16.c | 81 ++++++++++++++++++++++++++++++------------------------------- 1 file changed, 40 insertions(+), 41 deletions(-)
diff --git a/lib/crc16.c b/lib/crc16.c index c63fde9..57e46f8 100644 --- a/lib/crc16.c +++ b/lib/crc16.c @@ -27,49 +27,48 @@
/* Table of CRC constants - implements x^16+x^12+x^5+1 */ static const uint16_t crc16_tab[] = { - 0x0000, 0x1021, 0x2042, 0x3063, 0x4084, 0x50a5, 0x60c6, 0x70e7, - 0x8108, 0x9129, 0xa14a, 0xb16b, 0xc18c, 0xd1ad, 0xe1ce, 0xf1ef, - 0x1231, 0x0210, 0x3273, 0x2252, 0x52b5, 0x4294, 0x72f7, 0x62d6, - 0x9339, 0x8318, 0xb37b, 0xa35a, 0xd3bd, 0xc39c, 0xf3ff, 0xe3de, - 0x2462, 0x3443, 0x0420, 0x1401, 0x64e6, 0x74c7, 0x44a4, 0x5485, - 0xa56a, 0xb54b, 0x8528, 0x9509, 0xe5ee, 0xf5cf, 0xc5ac, 0xd58d, - 0x3653, 0x2672, 0x1611, 0x0630, 0x76d7, 0x66f6, 0x5695, 0x46b4, - 0xb75b, 0xa77a, 0x9719, 0x8738, 0xf7df, 0xe7fe, 0xd79d, 0xc7bc, - 0x48c4, 0x58e5, 0x6886, 0x78a7, 0x0840, 0x1861, 0x2802, 0x3823, - 0xc9cc, 0xd9ed, 0xe98e, 0xf9af, 0x8948, 0x9969, 0xa90a, 0xb92b, - 0x5af5, 0x4ad4, 0x7ab7, 0x6a96, 0x1a71, 0x0a50, 0x3a33, 0x2a12, - 0xdbfd, 0xcbdc, 0xfbbf, 0xeb9e, 0x9b79, 0x8b58, 0xbb3b, 0xab1a, - 0x6ca6, 0x7c87, 0x4ce4, 0x5cc5, 0x2c22, 0x3c03, 0x0c60, 0x1c41, - 0xedae, 0xfd8f, 0xcdec, 0xddcd, 0xad2a, 0xbd0b, 0x8d68, 0x9d49, - 0x7e97, 0x6eb6, 0x5ed5, 0x4ef4, 0x3e13, 0x2e32, 0x1e51, 0x0e70, - 0xff9f, 0xefbe, 0xdfdd, 0xcffc, 0xbf1b, 0xaf3a, 0x9f59, 0x8f78, - 0x9188, 0x81a9, 0xb1ca, 0xa1eb, 0xd10c, 0xc12d, 0xf14e, 0xe16f, - 0x1080, 0x00a1, 0x30c2, 0x20e3, 0x5004, 0x4025, 0x7046, 0x6067, - 0x83b9, 0x9398, 0xa3fb, 0xb3da, 0xc33d, 0xd31c, 0xe37f, 0xf35e, - 0x02b1, 0x1290, 0x22f3, 0x32d2, 0x4235, 0x5214, 0x6277, 0x7256, - 0xb5ea, 0xa5cb, 0x95a8, 0x8589, 0xf56e, 0xe54f, 0xd52c, 0xc50d, - 0x34e2, 0x24c3, 0x14a0, 0x0481, 0x7466, 0x6447, 0x5424, 0x4405, - 0xa7db, 0xb7fa, 0x8799, 0x97b8, 0xe75f, 0xf77e, 0xc71d, 0xd73c, - 0x26d3, 0x36f2, 0x0691, 0x16b0, 0x6657, 0x7676, 0x4615, 0x5634, - 0xd94c, 0xc96d, 0xf90e, 0xe92f, 0x99c8, 0x89e9, 0xb98a, 0xa9ab, - 0x5844, 0x4865, 0x7806, 0x6827, 0x18c0, 0x08e1, 0x3882, 0x28a3, - 0xcb7d, 0xdb5c, 0xeb3f, 0xfb1e, 0x8bf9, 0x9bd8, 0xabbb, 0xbb9a, - 0x4a75, 0x5a54, 0x6a37, 0x7a16, 0x0af1, 0x1ad0, 0x2ab3, 0x3a92, - 0xfd2e, 0xed0f, 0xdd6c, 0xcd4d, 0xbdaa, 0xad8b, 0x9de8, 0x8dc9, - 0x7c26, 0x6c07, 0x5c64, 0x4c45, 0x3ca2, 0x2c83, 0x1ce0, 0x0cc1, - 0xef1f, 0xff3e, 0xcf5d, 0xdf7c, 0xaf9b, 0xbfba, 0x8fd9, 0x9ff8, - 0x6e17, 0x7e36, 0x4e55, 0x5e74, 0x2e93, 0x3eb2, 0x0ed1, 0x1ef0, + 0x0000, 0x1021, 0x2042, 0x3063, 0x4084, 0x50a5, 0x60c6, 0x70e7, + 0x8108, 0x9129, 0xa14a, 0xb16b, 0xc18c, 0xd1ad, 0xe1ce, 0xf1ef, + 0x1231, 0x0210, 0x3273, 0x2252, 0x52b5, 0x4294, 0x72f7, 0x62d6, + 0x9339, 0x8318, 0xb37b, 0xa35a, 0xd3bd, 0xc39c, 0xf3ff, 0xe3de, + 0x2462, 0x3443, 0x0420, 0x1401, 0x64e6, 0x74c7, 0x44a4, 0x5485, + 0xa56a, 0xb54b, 0x8528, 0x9509, 0xe5ee, 0xf5cf, 0xc5ac, 0xd58d, + 0x3653, 0x2672, 0x1611, 0x0630, 0x76d7, 0x66f6, 0x5695, 0x46b4, + 0xb75b, 0xa77a, 0x9719, 0x8738, 0xf7df, 0xe7fe, 0xd79d, 0xc7bc, + 0x48c4, 0x58e5, 0x6886, 0x78a7, 0x0840, 0x1861, 0x2802, 0x3823, + 0xc9cc, 0xd9ed, 0xe98e, 0xf9af, 0x8948, 0x9969, 0xa90a, 0xb92b, + 0x5af5, 0x4ad4, 0x7ab7, 0x6a96, 0x1a71, 0x0a50, 0x3a33, 0x2a12, + 0xdbfd, 0xcbdc, 0xfbbf, 0xeb9e, 0x9b79, 0x8b58, 0xbb3b, 0xab1a, + 0x6ca6, 0x7c87, 0x4ce4, 0x5cc5, 0x2c22, 0x3c03, 0x0c60, 0x1c41, + 0xedae, 0xfd8f, 0xcdec, 0xddcd, 0xad2a, 0xbd0b, 0x8d68, 0x9d49, + 0x7e97, 0x6eb6, 0x5ed5, 0x4ef4, 0x3e13, 0x2e32, 0x1e51, 0x0e70, + 0xff9f, 0xefbe, 0xdfdd, 0xcffc, 0xbf1b, 0xaf3a, 0x9f59, 0x8f78, + 0x9188, 0x81a9, 0xb1ca, 0xa1eb, 0xd10c, 0xc12d, 0xf14e, 0xe16f, + 0x1080, 0x00a1, 0x30c2, 0x20e3, 0x5004, 0x4025, 0x7046, 0x6067, + 0x83b9, 0x9398, 0xa3fb, 0xb3da, 0xc33d, 0xd31c, 0xe37f, 0xf35e, + 0x02b1, 0x1290, 0x22f3, 0x32d2, 0x4235, 0x5214, 0x6277, 0x7256, + 0xb5ea, 0xa5cb, 0x95a8, 0x8589, 0xf56e, 0xe54f, 0xd52c, 0xc50d, + 0x34e2, 0x24c3, 0x14a0, 0x0481, 0x7466, 0x6447, 0x5424, 0x4405, + 0xa7db, 0xb7fa, 0x8799, 0x97b8, 0xe75f, 0xf77e, 0xc71d, 0xd73c, + 0x26d3, 0x36f2, 0x0691, 0x16b0, 0x6657, 0x7676, 0x4615, 0x5634, + 0xd94c, 0xc96d, 0xf90e, 0xe92f, 0x99c8, 0x89e9, 0xb98a, 0xa9ab, + 0x5844, 0x4865, 0x7806, 0x6827, 0x18c0, 0x08e1, 0x3882, 0x28a3, + 0xcb7d, 0xdb5c, 0xeb3f, 0xfb1e, 0x8bf9, 0x9bd8, 0xabbb, 0xbb9a, + 0x4a75, 0x5a54, 0x6a37, 0x7a16, 0x0af1, 0x1ad0, 0x2ab3, 0x3a92, + 0xfd2e, 0xed0f, 0xdd6c, 0xcd4d, 0xbdaa, 0xad8b, 0x9de8, 0x8dc9, + 0x7c26, 0x6c07, 0x5c64, 0x4c45, 0x3ca2, 0x2c83, 0x1ce0, 0x0cc1, + 0xef1f, 0xff3e, 0xcf5d, 0xdf7c, 0xaf9b, 0xbfba, 0x8fd9, 0x9ff8, + 0x6e17, 0x7e36, 0x4e55, 0x5e74, 0x2e93, 0x3eb2, 0x0ed1, 0x1ef0, };
-uint16_t -cyg_crc16(unsigned char *buf, int len) +uint16_t cyg_crc16(unsigned char *buf, int len) { - int i; - uint16_t cksum; + int i; + uint16_t cksum;
- cksum = 0; - for (i = 0; i < len; i++) { - cksum = crc16_tab[((cksum>>8) ^ *buf++) & 0xFF] ^ (cksum << 8); - } - return cksum; + cksum = 0; + for (i = 0; i < len; i++) + cksum = crc16_tab[((cksum>>8) ^ *buf++) & 0xff] ^ (cksum << 8); + + return cksum; }
The original name of this function is unclear. This patch renames this CRC16 function to crc16_ccitt() matching its name with its implementation.
To make the usage of this function more flexible, lets add the CRC start value as parameter to this function. This way it can be used by other functions requiring different start values than 0 as well.
Signed-off-by: Stefan Roese sr@denx.de --- common/xyzModem.c | 2 +- drivers/mmc/mmc_spi.c | 4 ++-- include/crc.h | 4 ++-- lib/crc16.c | 4 ++-- 4 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/common/xyzModem.c b/common/xyzModem.c index 56f4bca..5656aac 100644 --- a/common/xyzModem.c +++ b/common/xyzModem.c @@ -446,7 +446,7 @@ xyzModem_get_hdr (void) /* Verify checksum/CRC */ if (xyz.crc_mode) { - cksum = cyg_crc16 (xyz.pkt, xyz.len); + cksum = crc16_ccitt(0, xyz.pkt, xyz.len); if (cksum != ((xyz.crc1 << 8) | xyz.crc2)) { ZM_DEBUG (zm_dprintf ("CRC error - recvd: %02x%02x, computed: %x\n", diff --git a/drivers/mmc/mmc_spi.c b/drivers/mmc/mmc_spi.c index 9032a73..7547e1a 100644 --- a/drivers/mmc/mmc_spi.c +++ b/drivers/mmc/mmc_spi.c @@ -91,7 +91,7 @@ static uint mmc_spi_readdata(struct mmc *mmc, void *xbuf, spi_xfer(spi, bsize * 8, NULL, buf, 0); spi_xfer(spi, 2 * 8, NULL, &crc, 0); #ifdef CONFIG_MMC_SPI_CRC_ON - if (be_to_cpu16(cyg_crc16(buf, bsize)) != crc) { + if (be_to_cpu16(crc16_ccitt(0, buf, bsize)) != crc) { debug("%s: CRC error\n", mmc->cfg->name); r1 = R1_SPI_COM_CRC; break; @@ -120,7 +120,7 @@ static uint mmc_spi_writedata(struct mmc *mmc, const void *xbuf, tok[1] = multi ? SPI_TOKEN_MULTI_WRITE : SPI_TOKEN_SINGLE; while (bcnt--) { #ifdef CONFIG_MMC_SPI_CRC_ON - crc = cpu_to_be16(cyg_crc16((u8 *)buf, bsize)); + crc = cpu_to_be16(crc16_ccitt(0, (u8 *)buf, bsize)); #endif spi_xfer(spi, 2 * 8, tok, NULL, 0); spi_xfer(spi, bsize * 8, buf, NULL, 0); diff --git a/include/crc.h b/include/crc.h index 5085d4e..b0031b2 100644 --- a/include/crc.h +++ b/include/crc.h @@ -62,8 +62,8 @@ cyg_ether_crc32(unsigned char *s, int len); extern uint32_t cyg_ether_crc32_accumulate(uint32_t crc, unsigned char *s, int len);
-/* 16 bit CRC with polynomial x^16+x^12+x^5+1 */ +/* 16 bit CRC with polynomial x^16+x^12+x^5+1 (CRC-CCITT) */
-extern uint16_t cyg_crc16(unsigned char *s, int len); +uint16_t crc16_ccitt(uint16_t crc_start, unsigned char *s, int len);
#endif /* _SERVICES_CRC_CRC_H_ */ diff --git a/lib/crc16.c b/lib/crc16.c index 57e46f8..753b987 100644 --- a/lib/crc16.c +++ b/lib/crc16.c @@ -61,12 +61,12 @@ static const uint16_t crc16_tab[] = { 0x6e17, 0x7e36, 0x4e55, 0x5e74, 0x2e93, 0x3eb2, 0x0ed1, 0x1ef0, };
-uint16_t cyg_crc16(unsigned char *buf, int len) +uint16_t crc16_ccitt(uint16_t crc_start, unsigned char *buf, int len) { int i; uint16_t cksum;
- cksum = 0; + cksum = crc_start; for (i = 0; i < len; i++) cksum = crc16_tab[((cksum>>8) ^ *buf++) & 0xff] ^ (cksum << 8);
Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Tom Rini trini@konsulko.com
These cyg_ prototypes are not referenced anywhere in current mainline U-Boot. So lets remove them.
Signed-off-by: Stefan Roese sr@denx.de --- include/crc.h | 26 -------------------------- 1 file changed, 26 deletions(-)
diff --git a/include/crc.h b/include/crc.h index b0031b2..111cb4a 100644 --- a/include/crc.h +++ b/include/crc.h @@ -36,32 +36,6 @@ # endif #endif
-/* Compute a CRC, using the POSIX 1003 definition */ -extern uint32_t -cyg_posix_crc32(unsigned char *s, int len); - -/* Gary S. Brown's 32 bit CRC */ - -extern uint32_t -cyg_crc32(unsigned char *s, int len); - -/* Gary S. Brown's 32 bit CRC, but accumulate the result from a */ -/* previous CRC calculation */ - -extern uint32_t -cyg_crc32_accumulate(uint32_t crc, unsigned char *s, int len); - -/* Ethernet FCS Algorithm */ - -extern uint32_t -cyg_ether_crc32(unsigned char *s, int len); - -/* Ethernet FCS algorithm, but accumulate the result from a previous */ -/* CRC calculation. */ - -extern uint32_t -cyg_ether_crc32_accumulate(uint32_t crc, unsigned char *s, int len); - /* 16 bit CRC with polynomial x^16+x^12+x^5+1 (CRC-CCITT) */
Stefan Roese
