[U-Boot] [PATCH] fsl: update CRC after system EEPROM identifier
The "mac id" command is used to initialize the EEPROM data to a specific format, but it was not updating the CRC. This didn't cause any real problems, because writing the data to the EEPROM will always update the CRC anyway, but it did result in a bogus CRC warning.
Signed-off-by: Timur Tabi timur@freescale.com --- board/freescale/common/sys_eeprom.c | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index 11dfd84..3ecfb06 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -361,6 +361,7 @@ int do_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #else memcpy(e.id, "CCID", sizeof(e.id)); #endif + update_crc(); return 0; }
That should say, "after setting EEPROM identifier"
Fixed, committed to 85xx
- k
Kumar Gala
Timur Tabi
