DM SPI flash improvements
Hi Simon,
I'm investigating a problem with the Thecus N2350 board that has SPI flash on controller 1, but not on controller 0. Booting with SPI SPL is not possible with CONFIG_SF_DEFAULT_BUS=1.
Reference: https://lists.denx.de/pipermail/u-boot/2023-March/511517.html
That led me to the drivers/mtd/spi/sf-uclass.c and drivers/spi/spi-uclass.c.
And I found there are some problems in the spi_flash_probe(), as well as _spi_get_bus_and_cs(). But seeing your comment in the spi_flash_probe function header, I'm thinking perhaps I should not try to fix them.
/* * TODO(sjg@chromium.org): This is an old-style function. We should remove * it when all SPI flash drivers use dm */ struct spi_flash *spi_flash_probe(unsigned int busnum, unsigned int cs, unsigned int max_hz, unsigned int spi_mode)
Could you or Jagan clarify the TODO above meaning? Are we fully in DM SPI yet? If we are, should this be replaced with other means to probe the SPI bus? Or it should have been automatically probed by DM SPI infrastructure, and we just need to tag the SPI 1 DTS node with boot-phase? If that's the case then perhaps this function should be defined out with some configs wrapping.
My current SPI configs:
CONFIG_SPL_DM_SPI=y CONFIG_SPL_DM_SPI_FLASH=y # CONFIG_DM_HWSPINLOCK is not set CONFIG_DM_SPI_FLASH=y CONFIG_DM_SPI=y CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SF_DEFAULT_MODE=0x0 # CONFIG_CMD_SF_TEST is not set CONFIG_SF_DEFAULT_BUS=1 CONFIG_SF_DEFAULT_CS=0
Thanks, Tony
Hi Tony,
On Mon, 27 Mar 2023 at 12:28, Tony Dinh mibodhi@gmail.com wrote:
Hi Simon,
- TODO(sjg@chromium.org): This is an old-style function. We should remove
- it when all SPI flash drivers use dm
Ideally you would obtain the SPI-flash device using spi_flash_std_probe(). The SPI buses can be added to the device tree with 'spi0' and 'spi1' aliases. Then you can add a child noe of spi1 with your flash chip.
There is definitely some work needed to remove the old code. We don't have a proper way to select the boot device yet, Probably what is needed ultimately is something like the u-boot.spl-device-order used by Rockchip boards. We should really get away from using SPI-bus numbers.
Thanks, Tony
Hi Simon,
On Sun, Mar 26, 2023 at 9:01 PM Simon Glass sjg@chromium.org wrote:
Hi Tony,
Hi Simon,
Thanks! What you said about spi_flash_std_probe() has confirmed what I've been reading and thinking too.
Yes, indeed. Using SPI-bus numbers is problematic in this scenario.
Thanks, Tony
Thanks, Tony
Tony Dinh
