[U-Boot] [PATCH] arm:goni:mmc: Add sd card detection and initialization.
This change allow to use sd card on Goni the same like mmc 0. SD card is mmc dev 1, so it can be used like this: "fatls mmc 1:2". SD card is inited even if eMMC initialization fails.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- board/samsung/goni/goni.c | 33 +++++++++++++++++++++++++++++++-- 1 file changed, 31 insertions(+), 2 deletions(-)
diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index 5b3d6ef..d63e902 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -72,7 +72,7 @@ int checkboard(void) #ifdef CONFIG_GENERIC_MMC int board_mmc_init(bd_t *bis) { - int i; + int i, ret, ret_sd = 0;
/* MASSMEMORY_EN: XMSMDATA7: GPJ2[7] output high */ s5p_gpio_direction_output(&s5pc110_gpio->j2, 7, 1); @@ -95,7 +95,36 @@ int board_mmc_init(bd_t *bis) s5p_gpio_set_drv(&s5pc110_gpio->g0, i, GPIO_DRV_4X); }
- return s5p_mmc_init(0, 4); + ret = s5p_mmc_init(0, 4); + if (ret) + puts("MMC: Failed to init MMC:0.\n"); + + /* + * SD card (T_FLASH) detect and init + * T_FLASH_DETECT: EINT28: GPH3[4] input mode + */ + s5p_gpio_cfg_pin(&s5pc110_gpio->h3, 4, GPIO_INPUT); + s5p_gpio_set_pull(&s5pc110_gpio->h3, 4, GPIO_PULL_UP); + + if (!s5p_gpio_get_value(&s5pc110_gpio->h3, 4)) { + for (i = 0; i < 7; i++) { + if (i == 2) + continue; + + /* GPG2[0:6] special function 2 */ + s5p_gpio_cfg_pin(&s5pc110_gpio->g2, i, 0x2); + /* GPG2[0:6] pull disable */ + s5p_gpio_set_pull(&s5pc110_gpio->g2, i, GPIO_PULL_NONE); + /* GPG2[0:6] drv 4x */ + s5p_gpio_set_drv(&s5pc110_gpio->g2, i, GPIO_DRV_4X); + } + + ret_sd = s5p_mmc_init(2, 4) + if (ret_sd) + puts("MMC: Failed to init SD card (MMC:2).\n"); + } + + return ret | ret_sd; } #endif
Dear Przemyslaw,
- int i;
- ret = s5p_mmc_init(0, 4);
- if (ret)
- s5p_gpio_cfg_pin(&s5pc110_gpio->h3, 4, GPIO_INPUT);
- s5p_gpio_set_pull(&s5pc110_gpio->h3, 4, GPIO_PULL_UP);
- if (!s5p_gpio_get_value(&s5pc110_gpio->h3, 4)) {
if (i == 2)
continue;
if (ret_sd)
I think you can refer to trats.c.
Best Regards, Jaehoon Chung
- return ret | ret_sd;
} #endif
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - add ret_sd for sd card initialization errors - return bit OR of ret and ret_sd values
Changes for v3: - change puts() to error() when prints error message - chance BIT OR on ret and sd_ret to BIT AND
Now return value is 0 if any card will init succeed and -1 if both fails.
diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index 5b3d6ef..366f648 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -72,7 +72,7 @@ int checkboard(void) #ifdef CONFIG_GENERIC_MMC int board_mmc_init(bd_t *bis) { - int i; + int i, ret, ret_sd = 0;
- return s5p_mmc_init(0, 4); + ret = s5p_mmc_init(0, 4); + if (ret) + error("MMC: Failed to init MMC:0.\n"); + + /* + * SD card (T_FLASH) detect and init + * T_FLASH_DETECT: EINT28: GPH3[4] input mode + */ + s5p_gpio_cfg_pin(&s5pc110_gpio->h3, 4, GPIO_INPUT); + s5p_gpio_set_pull(&s5pc110_gpio->h3, 4, GPIO_PULL_UP); + + if (!s5p_gpio_get_value(&s5pc110_gpio->h3, 4)) { + for (i = 0; i < 7; i++) { + if (i == 2) + continue; + + /* GPG2[0:6] special function 2 */ + s5p_gpio_cfg_pin(&s5pc110_gpio->g2, i, 0x2); + /* GPG2[0:6] pull disable */ + s5p_gpio_set_pull(&s5pc110_gpio->g2, i, GPIO_PULL_NONE); + /* GPG2[0:6] drv 4x */ + s5p_gpio_set_drv(&s5pc110_gpio->g2, i, GPIO_DRV_4X); + } + + ret_sd = s5p_mmc_init(2, 4); + if (ret_sd) + error("MMC: Failed to init SD card (MMC:2).\n"); + } + + return ret & ret_sd; } #endif
Looks good to me.
Acked-by: Jaehoon Chung jh80.chung@samsung.com
Changes for v2:
Changes for v3:
- int i;
- if (ret)
if (i == 2)
continue;
if (ret_sd)
- return ret & ret_sd;
} #endif
On 10/09/13 19:28, Jaehoon Chung wrote:
Looks good to me.
Changes for v2:
Changes for v3:
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Jaehoon Chung
Minkyu Kang
Przemyslaw Marczak
