[U-Boot] [PATCH v3 1/6] display_options: Refactor to allow obtaining the banner
Move the display options code into a separate function so that the U-Boot banner can be obtained from other code. Adjust the 'version' command to use it.
Changes in v3: None Changes in v2: - Update the code to be more testable - Avoid a warning on spring, etc.
cmd/version.c | 4 +++- include/display_options.h | 19 +++++++++++++++++++ lib/display_options.c | 36 +++++++++++++++++++++++++++++++----- 3 files changed, 53 insertions(+), 6 deletions(-)
diff --git a/cmd/version.c b/cmd/version.c index 1be0667f09..15aab5dc18 100644 --- a/cmd/version.c +++ b/cmd/version.c @@ -17,7 +17,9 @@ const char __weak version_string[] = U_BOOT_VERSION_STRING;
static int do_version(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - printf("\n%s\n", version_string); + char buf[DISPLAY_OPTIONS_BANNER_LENGTH]; + + printf(display_options_get_banner(false, buf, sizeof(buf))); #ifdef CC_VERSION_STRING puts(CC_VERSION_STRING "\n"); #endif diff --git a/include/display_options.h b/include/display_options.h index ac44c459b3..ad707a344c 100644 --- a/include/display_options.h +++ b/include/display_options.h @@ -56,4 +56,23 @@ int print_buffer(ulong addr, const void *data, uint width, uint count, */ int display_options(void);
+/* Suggested length of the buffer to pass to display_options_get_banner() */ +#define DISPLAY_OPTIONS_BANNER_LENGTH 200 + +/** + * display_options_get_banner() - Get the U-Boot banner as a string + * + * This returns the U-Boot banner string + * + * @newlines: true to include two newlines at the start + * @buf: place to put string + * @size: Size of buf (string is truncated to fit) + * @return buf + */ +char *display_options_get_banner(bool newlines, char *buf, int size); + +/** This function is used for testing only */ +char *display_options_get_banner_priv(bool newlines, const char *build_tag, + char *buf, int size); + #endif diff --git a/lib/display_options.c b/lib/display_options.c index 29343fc00e..4ea27ca99d 100644 --- a/lib/display_options.c +++ b/lib/display_options.c @@ -13,13 +13,39 @@ #include <linux/ctype.h> #include <asm/io.h>
-int display_options (void) +char *display_options_get_banner_priv(bool newlines, const char *build_tag, + char *buf, int size) { -#if defined(BUILD_TAG) - printf ("\n\n%s, Build: %s\n\n", version_string, BUILD_TAG); -#else - printf ("\n\n%s\n\n", version_string); + int len; + + len = snprintf(buf, size, "%s%s", newlines ? "\n\n" : "", + version_string); + if (build_tag && len < size) + len += snprintf(buf + len, size - len, ", Build: %s", + build_tag); + if (len > size - 3) + len = size - 3; + strcpy(buf + len, "\n\n"); + + return buf; +} + +#ifndef BUILD_TAG +#define BUILD_TAG NULL #endif + +char *display_options_get_banner(bool newlines, char *buf, int size) +{ + return display_options_get_banner_priv(newlines, BUILD_TAG, buf, size); +} + +int display_options(void) +{ + char buf[DISPLAY_OPTIONS_BANNER_LENGTH]; + + display_options_get_banner(true, buf, sizeof(buf)); + printf("%s", buf); + return 0; }
At present the U-Boot banner is only displayed on the serial console. If this is not visible to the user, the banner does not show. Some devices have a video display which can usefully display this information.
Add a banner which is printed after relocation only on non-serial devices if CONFIG_DISPLAY_BOARDINFO_LATE is defined.
Changes in v3: None Changes in v2: - Reword function comment for console_announce_r() slighty
common/board_r.c | 1 + common/console.c | 17 +++++++++++++---- include/console.h | 12 ++++++++++++ 3 files changed, 26 insertions(+), 4 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index adc1f1937e..8d9f0a3c5e 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -832,6 +832,7 @@ static init_fnc_t init_sequence_r[] = { #endif console_init_r, /* fully init console as a device */ #ifdef CONFIG_DISPLAY_BOARDINFO_LATE + console_announce_r, show_board_info, #endif #ifdef CONFIG_ARCH_MISC_INIT diff --git a/common/console.c b/common/console.c index 1232808df5..60e7a94a56 100644 --- a/common/console.c +++ b/common/console.c @@ -202,7 +202,6 @@ static void console_putc(int file, const char c) } }
-#if CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) static void console_puts_noserial(int file, const char *s) { int i; @@ -214,7 +213,6 @@ static void console_puts_noserial(int file, const char *s) dev->puts(dev, s); } } -#endif
static void console_puts(int file, const char *s) { @@ -248,13 +246,11 @@ static inline void console_putc(int file, const char c) stdio_devices[file]->putc(stdio_devices[file], c); }
-#if CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) static inline void console_puts_noserial(int file, const char *s) { if (strcmp(stdio_devices[file]->name, "serial") != 0) stdio_devices[file]->puts(stdio_devices[file], s); } -#endif
static inline void console_puts(int file, const char *s) { @@ -699,6 +695,19 @@ static void console_update_silent(void) #endif }
+int console_announce_r(void) +{ +#if !CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) + char buf[DISPLAY_OPTIONS_BANNER_LENGTH]; + + display_options_get_banner(false, buf, sizeof(buf)); + + console_puts_noserial(stdout, buf); +#endif + + return 0; +} + /* Called before relocation - use serial functions */ int console_init_f(void) { diff --git a/include/console.h b/include/console.h index 3d37f6a53b..cea29ed6dc 100644 --- a/include/console.h +++ b/include/console.h @@ -42,6 +42,18 @@ void console_record_reset(void); */ void console_record_reset_enable(void);
+/** + * console_announce_r() - print a U-Boot console on non-serial consoles + * + * When U-Boot starts up with a display it generally does not announce itself + * on the display. The banner is instead emitted on the UART before relocation. + * This function prints a banner on devices which (we assume) did not receive + * it before relocation. + * + * @return 0 (meaning no errors) + */ +int console_announce_r(void); + /* * CONSOLE multiplexing. */
Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
Applied to u-boot-dm, thanks!
Add a simple test to make sure that these functions obey the buffer size passed into them.
Changes in v3: None Changes in v2: - Fix buffer overflow problem when there is not enough space for the build tag - Add test to check for buffer overflow problems
test/Makefile | 1 + test/print_ut.c | 83 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 84 insertions(+) create mode 100644 test/print_ut.c
diff --git a/test/Makefile b/test/Makefile index 0f5de57399..6305afb211 100644 --- a/test/Makefile +++ b/test/Makefile @@ -8,4 +8,5 @@ obj-$(CONFIG_UNIT_TEST) += cmd_ut.o obj-$(CONFIG_UNIT_TEST) += ut.o obj-$(CONFIG_SANDBOX) += command_ut.o obj-$(CONFIG_SANDBOX) += compression.o +obj-$(CONFIG_SANDBOX) += print_ut.o obj-$(CONFIG_UT_TIME) += time_ut.o diff --git a/test/print_ut.c b/test/print_ut.c new file mode 100644 index 0000000000..baad289972 --- /dev/null +++ b/test/print_ut.c @@ -0,0 +1,83 @@ +/* + * Copyright (c) 2012, The Chromium Authors + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define DEBUG + +#include <common.h> +#include <display_options.h> +#include <version.h> + +#define FAKE_BUILD_TAG "jenkins-u-boot-denx_uboot_dm-master-build-aarch64" \ + "and a lot more text to come" + +static int do_ut_print(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + char big_str[400]; + int big_str_len; + char str[10], *s; + int len; + + printf("%s: Testing print\n", __func__); + + snprintf(str, sizeof(str), "testing"); + assert(!strcmp("testing", str)); + + snprintf(str, sizeof(str), "testing but too long"); + assert(!strcmp("testing b", str)); + + snprintf(str, 1, "testing none"); + assert(!strcmp("", str)); + + *str = 'x'; + snprintf(str, 0, "testing none"); + assert(*str == 'x'); + + /* Test the banner function */ + s = display_options_get_banner(true, str, sizeof(str)); + assert(s == str); + assert(!strcmp("\n\nU-Boo\n\n", s)); + + s = display_options_get_banner(true, str, 1); + assert(s == str); + assert(!strcmp("", s)); + + s = display_options_get_banner(true, str, 2); + assert(s == str); + assert(!strcmp("\n", s)); + + s = display_options_get_banner(false, str, sizeof(str)); + assert(s == str); + assert(!strcmp("U-Boot \n\n", s)); + + /* Give it enough space for some of the version */ + big_str_len = strlen(version_string) - 5; + s = display_options_get_banner_priv(false, FAKE_BUILD_TAG, big_str, + big_str_len); + assert(s == big_str); + assert(!strncmp(version_string, s, big_str_len - 3)); + assert(!strcmp("\n\n", s + big_str_len - 3)); + + /* Give it enough space for the version and some of the build tag */ + big_str_len = strlen(version_string) + 9 + 20; + s = display_options_get_banner_priv(false, FAKE_BUILD_TAG, big_str, + big_str_len); + assert(s == big_str); + len = strlen(version_string); + assert(!strncmp(version_string, s, len)); + assert(!strncmp(", Build: ", s + len, 9)); + assert(!strncmp(FAKE_BUILD_TAG, s + 9 + len, 12)); + assert(!strcmp("\n\n", s + big_str_len - 3)); + + printf("%s: Everything went swimmingly\n", __func__); + return 0; +} + +U_BOOT_CMD( + ut_print, 1, 1, do_ut_print, + "Very basic test of printf(), etc.", + "" +);
At present this feature casts the address to a pointer. Use the map_sysmem() function so that it will work correctly on sandbox.
Changes in v3: - Add new patch to use map_sysmem() for the pre-relocation console
Changes in v2: None
common/console.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/common/console.c b/common/console.c index 60e7a94a56..762d5f291c 100644 --- a/common/console.c +++ b/common/console.c @@ -11,6 +11,7 @@ #include <stdarg.h> #include <iomux.h> #include <malloc.h> +#include <mapmem.h> #include <os.h> #include <serial.h> #include <stdio_dev.h> @@ -416,9 +417,13 @@ int tstc(void)
static void pre_console_putc(const char c) { - char *buffer = (char *)CONFIG_PRE_CON_BUF_ADDR; + char *buffer; + + buffer = map_sysmem(CONFIG_PRE_CON_BUF_ADDR, CONFIG_PRE_CON_BUF_SZ);
buffer[CIRC_BUF_IDX(gd->precon_buf_idx++)] = c; + + unmap_sysmem(buffer); }
static void pre_console_puts(const char *s) @@ -430,14 +435,16 @@ static void pre_console_puts(const char *s) static void print_pre_console_buffer(int flushpoint) { unsigned long in = 0, out = 0; - char *buf_in = (char *)CONFIG_PRE_CON_BUF_ADDR; char buf_out[CONFIG_PRE_CON_BUF_SZ + 1]; + char *buf_in;
+ buf_in = map_sysmem(CONFIG_PRE_CON_BUF_ADDR, CONFIG_PRE_CON_BUF_SZ); if (gd->precon_buf_idx > CONFIG_PRE_CON_BUF_SZ) in = gd->precon_buf_idx - CONFIG_PRE_CON_BUF_SZ;
while (in < gd->precon_buf_idx) buf_out[out++] = buf_in[CIRC_BUF_IDX(in++)]; + unmap_sysmem(buf_in);
buf_out[out] = 0;
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
Enable the pre-console buffer, displaying the model and post-relocation console announce on sandbox. Also add a model name to the device tree. This allows testing of these features.
Changes in v3: - Add new patch to enable more console options on sandbox
Changes in v2: None
arch/sandbox/dts/sandbox.dts | 1 + common/Kconfig | 2 +- configs/sandbox_defconfig | 2 ++ include/configs/sandbox.h | 1 + 4 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/dts/sandbox.dts b/arch/sandbox/dts/sandbox.dts index 40f423da25..0aba6c9a6d 100644 --- a/arch/sandbox/dts/sandbox.dts +++ b/arch/sandbox/dts/sandbox.dts @@ -5,6 +5,7 @@ / { #address-cells = <1>; #size-cells = <1>; + model = "sandbox";
aliases { eth5 = "/eth@90000000"; diff --git a/common/Kconfig b/common/Kconfig index c49199bb1a..4853863470 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -472,7 +472,7 @@ config DISPLAY_CPUINFO
config DISPLAY_BOARDINFO bool "Display information about the board during start up" - default y if ARM || M68K || MIPS || PPC || XTENSA + default y if ARM || M68K || MIPS || PPC || SANDBOX || XTENSA help Display information about the board that U-Boot is running on when U-Boot starts up. The board function checkboard() is called diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 6a6e7741d8..7a1b9ef052 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -14,6 +14,8 @@ CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 CONFIG_SILENT_CONSOLE=y +CONFIG_PRE_CONSOLE_BUFFER=y +CONFIG_PRE_CON_BUF_ADDR=0 CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y CONFIG_CMD_BOOTZ=y diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 9276cf9734..1e8404cbdf 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -41,6 +41,7 @@
#define CONFIG_SYS_LONGHELP /* #undef to save memory */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_DISPLAY_BOARDINFO_LATE
/* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16)
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
At present sandbox has a special case where it directly calls os_putc() when it does not have a console yet.
Now that we have the pre-console buffer enabled we can drop this. Any early characters will be buffered and output later.
Changes in v3: - Add new patch to drop special case console code for sandbox
Changes in v2: None
common/console.c | 13 ------------- 1 file changed, 13 deletions(-)
diff --git a/common/console.c b/common/console.c index 762d5f291c..c6156f33bb 100644 --- a/common/console.c +++ b/common/console.c @@ -465,13 +465,6 @@ static inline void print_pre_console_buffer(int flushpoint) {}
void putc(const char c) { -#ifdef CONFIG_SANDBOX - /* sandbox can send characters to stdout before it has a console */ - if (!gd || !(gd->flags & GD_FLG_SERIAL_READY)) { - os_putc(c); - return; - } -#endif #ifdef CONFIG_DEBUG_UART /* if we don't have a console yet, use the debug UART */ if (!gd || !(gd->flags & GD_FLG_SERIAL_READY)) { @@ -508,12 +501,6 @@ void putc(const char c)
void puts(const char *s) { -#ifdef CONFIG_SANDBOX - if (!gd || !(gd->flags & GD_FLG_SERIAL_READY)) { - os_puts(s); - return; - } -#endif #ifdef CONFIG_DEBUG_UART if (!gd || !(gd->flags & GD_FLG_SERIAL_READY)) { while (*s) {
Changes in v3:
Changes in v2: None
Changes in v3:
Changes in v2: None
One nits below.
- display_options_get_banner() - Get the U-Boot banner as a string
- This returns the U-Boot banner string
- @newlines: true to include two newlines at the start
- @buf: place to put string
- @size: Size of buf (string is truncated to fit)
- @return buf
nits: /*
#endif
[snip]
Regards, Bin
Bin Meng
sjg@google.com
