[U-Boot] uefi: x86: uboot as uefi payload
im trying to run u-boot as uefi-payload for qemu this works totally fine. My real target is a Minnowboard Turbot. I did use the minnowmax_defconfig enabled CONFIG_EFI, CONFIG_EFI_STUB and CONFIG_EFI_STUB_64BIT. The Board has the latest uefi by Intel installed(0.93, X64).
When i load U-Boot as payload for the board-uefi the efi_main function gets executed but the call to "cpu_call32" seems to get stuck ( i think its at the "retf" arch/x86/cpu/call32.S:37).
Debuglog:
Shell> u-boot-payload_64.efi U-Boot EFI Payload gdt: 00000047, addr: 00000000784fd570 00: 00000000 00000000 08: 00cf9200 0000ffff 10: 00af9a00 0000ffff 18: 00cf9300 0000ffff 20: 00cf9a00 0000ffff 28: 00000000 00000000 30: 00cf9200 0000ffff 38: 00af9b00 0000ffff 40: 00000000 00000000 32-bit code segment: 20 page_table: 79313000 EFI table at 78787018 size 00000760
Does anyone have experiences with this issue or with running u-boot as uefi-64 payload at all?
regard Markus
Hi Markus,
Debuglog:
I have used this on the original Minnowboard and it is used on some broadwell platforms.
I did hit a similar problem due to the 'ret' not generating the right instruction. I thought it was fixed but I suppose it is not impossible that the gcc toolchains might generate different op codes in different situations.
Which toolchain are you using?
Hi Simon, Am Mittwoch, den 30.11.2016, 19:20 -0700 schrieb Simon Glass:
Hi Markus,
Debuglog:
Great so i should be able to get it working too.
Im using the gcc6 from Debian/testing,(6.2.0-13) and glibc6 2.24-5.
Can you suggest a Toolchain? Mine is probably too "current"?
Regards Markus
Hi Markus,
Hi Markus,
Debuglog:
I was using 4.9.0 now but I'm not sure if that is what I tested with. I'll try it again when I get a chance, but it will be a week or so as I am travelling.
Hi Simon, On Sun, 2016-12-04 at 23:24 -0700, Simon Glass wrote:
Hi Markus,
Hi Markus,
Debuglog:
I was not a matter of the the toolchain my SYS_TEXT_BASE was wrong (0xfff00000) for unknown reason.
Once i created my own defconfig-file which sets the required KConfig- variables, the default from board/intel/minnowmax/Kconfig gets properly applied I did use menuconfig before which did somehow not put the changes to the .config file.
Regards Markus
Hi Markus,
Hi Markus,
Hi Markus,
Debuglog:
That's the base used for U-Boot running from ROM. I thought it would be relocatable to the text base would not matter, but indeed, that value seems more like a ROM value than a RAM value.
Anyway I'm please you have it running.
Markus Valentin
