[PATCH v2 1/3] rpi5: initial support
rpi5: add initial memory map for bcm2712
includes: * 1GB of RAM (from 4GB or 8GB total) * VPU memory interface * SOC range (main peripherals)
Signed-off-by: Dmitry Malkin dmitry@bedrocksystems.com --- v2: new patch --- arch/arm/mach-bcm283x/init.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/arch/arm/mach-bcm283x/init.c b/arch/arm/mach-bcm283x/init.c index 7265faf6ce..362838e9b9 100644 --- a/arch/arm/mach-bcm283x/init.c +++ b/arch/arm/mach-bcm283x/init.c @@ -68,6 +68,33 @@ static struct mm_region bcm2711_mem_map[MEM_MAP_MAX_ENTRIES] = { } };
+static struct mm_region bcm2712_mem_map[MEM_MAP_MAX_ENTRIES] = { + { + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 0x3f800000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0x3f800000UL, + .phys = 0x3f800000UL, + .size = 0x00800000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + .virt = 0x107c000000UL, + .phys = 0x107c000000UL, + .size = 0x0004000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; + struct mm_region *mem_map = bcm283x_mem_map;
/* @@ -78,6 +105,7 @@ static const struct udevice_id board_ids[] = { { .compatible = "brcm,bcm2837", .data = (ulong)&bcm283x_mem_map}, { .compatible = "brcm,bcm2838", .data = (ulong)&bcm2711_mem_map}, { .compatible = "brcm,bcm2711", .data = (ulong)&bcm2711_mem_map}, + { .compatible = "brcm,bcm2712", .data = (ulong)&bcm2712_mem_map}, { }, };
includes:
- 1GB of RAM (from 4GB or 8GB total)
- VPU memory interface
- SOC range (main peripherals)
I'm curious if the memory map portion of: https://patchwork.ozlabs.org/project/uboot/patch/20231121-b4-qcom-common-tar... could be used as inspiration here too?
On Tue, Nov 21, 2023 at 10:54 PM Dmitry Malkin dmitry@bedrocksystems.com wrote:
Could this be the title for the patch, "initial support" is fine for the cover letter, but doesn't really out line what this specific patch actually does.
includes:
Could you include details where this information came from as well please?
v2: new patch
0,
- { .compatible = "brcm,bcm2712", .data = (ulong)&bcm2712_mem_map}, { },
-- 2.40.1
Dmitry Malkin
Peter Robinson
