[U-Boot] [PATCH][v2] powerpc/T1040EMU: Add T1040 emulator support
Add emulator support for T1040. Emulator has limited peripherals and interfaces. Difference between T1040QDS and emulator includes: -ECC for DDR is disabled due to procedure to load images -Depends on raw timing for DDR initialization -No board FPGA (Qixis) -No PCI -No SPI -No flash support
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- Changes for v2: Incorporated Wolfgang Denk's review comments
Based on u-boot-mpc85xx/next branch. This patch depends upon following patches: 1)[U-Boot] powerpc/t1040qds: Add DDR Raw Timing support http://patchwork.ozlabs.org/patch/286112/ 2)[U-Boot] powerpc/t1040qds: Correct Maintainer name in boards.cfg http://patchwork.ozlabs.org/patch/286113/
board/freescale/t1040qds/Makefile | 3 +- board/freescale/t1040qds/ddr.c | 3 + board/freescale/t1040qds/ddr.h | 13 ++ board/freescale/t1040qds/t1040emu.c | 75 ++++++++ board/freescale/t1040qds/tlb.c | 4 + boards.cfg | 1 + include/configs/T1040EMU.h | 344 +++++++++++++++++++++++++++++++++++ 7 files changed, 442 insertions(+), 1 deletions(-) create mode 100644 board/freescale/t1040qds/t1040emu.c create mode 100644 include/configs/T1040EMU.h
diff --git a/board/freescale/t1040qds/Makefile b/board/freescale/t1040qds/Makefile index 8f0057b..4bd7103 100644 --- a/board/freescale/t1040qds/Makefile +++ b/board/freescale/t1040qds/Makefile @@ -8,7 +8,8 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-COBJS-y += $(BOARD).o +COBJS-$(CONFIG_T1040QDS) += t1040qds.o +COBJS-$(CONFIG_T1040EMU) += t1040emu.o COBJS-y += ddr.o COBJS-$(CONFIG_PCI) += pci.o COBJS-y += law.o diff --git a/board/freescale/t1040qds/ddr.c b/board/freescale/t1040qds/ddr.c index 16ab829..d46021b 100644 --- a/board/freescale/t1040qds/ddr.c +++ b/board/freescale/t1040qds/ddr.c @@ -123,6 +123,9 @@ phys_size_t initdram(int board_type) puts("Initializing....using SPD\n");
dram_size = fsl_ddr_sdram(); +#ifdef CONFIG_T1040EMU + dram_size = CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; +#endif
dram_size = setup_ddr_tlbs(dram_size / 0x100000); dram_size *= 0x100000; diff --git a/board/freescale/t1040qds/ddr.h b/board/freescale/t1040qds/ddr.h index 4a4f76a..5e0a078 100644 --- a/board/freescale/t1040qds/ddr.h +++ b/board/freescale/t1040qds/ddr.h @@ -54,6 +54,18 @@ struct board_specific_parameters { * for each n_ranks group. */
+#ifdef CONFIG_T1040EMU +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ + {2, 2140, 4, 4, 8, 0x0, 0x0, 0xff, 2, 0}, + {1, 2140, 4, 4, 8, 0x0, 0x0, 0xff, 2, 0}, + {} +}; +#else static const struct board_specific_parameters udimm0[] = { /* * memory controller 0 @@ -72,6 +84,7 @@ static const struct board_specific_parameters udimm0[] = { {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, {} }; +#endif
static const struct board_specific_parameters *udimms[] = { udimm0, diff --git a/board/freescale/t1040qds/t1040emu.c b/board/freescale/t1040qds/t1040emu.c new file mode 100644 index 0000000..e9362d6 --- /dev/null +++ b/board/freescale/t1040qds/t1040emu.c @@ -0,0 +1,75 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <netdev.h> +#include <linux/compiler.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#include <fm_eth.h> + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + struct cpu_type *cpu = gd->arch.cpu; + printf("Board: %sEMU\n", cpu->name); + return 0; +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash + promjet */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + set_liodns(); +#ifdef CONFIG_SYS_DPAA_QBMAN + setup_portals(); +#endif + + return 0; +} + + +int misc_init_r(void) +{ + return 0; +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + base = getenv_bootm_low(); + size = getenv_bootm_size(); + fdt_fixup_memory(blob, (u64)base, (u64)size); + fdt_fixup_liodn(blob); +} diff --git a/board/freescale/t1040qds/tlb.c b/board/freescale/t1040qds/tlb.c index 412c591..0bc3960 100644 --- a/board/freescale/t1040qds/tlb.c +++ b/board/freescale/t1040qds/tlb.c @@ -53,15 +53,19 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_256M, 1),
+#ifdef CONFIG_SYS_PCIE1_MEM_PHYS /* *I*G* - PCI */ SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 3, BOOKE_PAGESZ_1G, 1), +#endif
+#ifdef CONFIG_SYS_PCIE1_IO_PHYS /* *I*G* - PCI I/O */ SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_IO_VIRT, CONFIG_SYS_PCIE1_IO_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 4, BOOKE_PAGESZ_256K, 1), +#endif
/* Bman/Qman */ #ifdef CONFIG_SYS_BMAN_MEM_PHYS diff --git a/boards.cfg b/boards.cfg index dfe1c59..11efdd4 100644 --- a/boards.cfg +++ b/boards.cfg @@ -962,6 +962,7 @@ Active powerpc mpc85xx - freescale t4qds Active powerpc mpc85xx - freescale t4qds T4240QDS_SDCARD T4240QDS:PPC_T4240,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - Active powerpc mpc85xx - freescale t4qds T4240QDS_SPIFLASH T4240QDS:PPC_T4240,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - Active powerpc mpc85xx - freescale t4qds T4240QDS_SRIO_PCIE_BOOT T4240QDS:PPC_T4240,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t1040qds T1040EMU T1040EMU:PPC_T1040 Poonam Aggrwal poonam.aggrwal@freescale.com Active powerpc mpc85xx - freescale t1040qds T1040QDS T1040QDS:PPC_T1040 Poonam Aggrwal poonam.aggrwal@freescale.com Active powerpc mpc85xx - gdsys p1022 controlcenterd_36BIT_SDCARD controlcenterd:36BIT,SDCARD Dirk Eibach eibach@gdsys.de Active powerpc mpc85xx - gdsys p1022 controlcenterd_36BIT_SDCARD_DEVELOP controlcenterd:36BIT,SDCARD,DEVELOP Dirk Eibach eibach@gdsys.de diff --git a/include/configs/T1040EMU.h b/include/configs/T1040EMU.h new file mode 100644 index 0000000..8c547f2 --- /dev/null +++ b/include/configs/T1040EMU.h @@ -0,0 +1,344 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * T1040 Emulator configuration file + */ +#define CONFIG_T1040EMU +#define CONFIG_PHYS_64BIT + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_E500MC /* BOOKE e500mc family */ +#define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ +#define CONFIG_MPC85xx /* MPC85xx/PQ3 platform */ +#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ +#define CONFIG_MP /* support multiple processors */ +#define CONFIG_SYS_NO_FLASH 1 +#define CONFIG_SYS_FSL_DDR_EMU 1 +#define CONFIG_SYS_FSL_NO_QIXIS 1 +#define CONFIG_SYS_FSL_NO_SERDES 1 + +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xeff80000 +#endif + +#ifndef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc +#endif + +#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ +#define CONFIG_SYS_NUM_CPC CONFIG_NUM_DDR_CONTROLLERS +#define CONFIG_FSL_IFC /* Enable IFC Support */ + +#define CONFIG_FSL_LAW /* Use common FSL init code */ + +#define CONFIG_ENV_OVERWRITE + +#ifdef CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#else +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#endif +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 0x2000 +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_SYS_CACHE_STASHING +#define CONFIG_BACKSIDE_L2_CACHE +#define CONFIG_SYS_INIT_L2CSR0 L2CSR0_L2E +#define CONFIG_BTB /* toggle branch predition */ +#ifdef CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#endif + +#define CONFIG_ENABLE_36BIT_PHYS + +#define CONFIG_ADDR_MAP +#define CONFIG_SYS_NUM_ADDR_MAP 64 /* number of TLB1 entries */ + +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +/* + * Config the L3 Cache as L3 SRAM + */ +#define CONFIG_SYS_INIT_L3_ADDR CONFIG_RAMBOOT_TEXT_BASE + +#define CONFIG_SYS_DCSRBAR 0xf0000000 +#define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull + +/* + * DDR Setup + */ +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +/* CONFIG_NUM_DDR_CONTROLLERS is defined in include/asm/config_mpc85xx.h */ +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (4 * CONFIG_DIMM_SLOTS_PER_CTLR) + +#define CONFIG_DDR_SPD +#define CONFIG_SYS_DDR_RAW_TIMING +#define CONFIG_FSL_DDR3 + +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define SPD_EEPROM_ADDRESS 0x51 + +#define CONFIG_SYS_SDRAM_SIZE 1024 /* for fixed parameter use */ + +/* + * IFC Definitions + */ +#define CONFIG_SYS_FLASH_BASE 0xe0000000 +#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) + +#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +/* NOR Flash Timing Params */ +#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(0) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x1) | \ + FTIM0_NOR_TEADC(0x1) | \ + FTIM0_NOR_TEAHC(0x1)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x1) | \ + FTIM1_NOR_TRAD_NOR(0x1)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x0) | \ + FTIM2_NOR_TCH(0x0) | \ + FTIM2_NOR_TWP(0x1)) +#define CONFIG_SYS_NOR_FTIM3 0x04000000 +#define CONFIG_SYS_IFC_CCR 0x01000000 + +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#if defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_SYS_RAMBOOT +#endif + +#define CONFIG_BOARD_EARLY_INIT_R +#define CONFIG_MISC_INIT_R + +#define CONFIG_HWCONFIG + +/* define to use L1 as initial stack */ +#define CONFIG_L1_INIT_RAM +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xfdd00000 /* Initial L1 address */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xfe0ec000 +/* The assembler doesn't like typecast */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ + ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ + CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) + +/* + * Serial Port + * open - index 2 + * shorted - index 1 + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK 300000000 + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x11C500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) +#define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) +#define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) +#define CONFIG_SERIAL_MULTI /* Enable both serial ports */ +#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* FIT support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* I2C support */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_FSL /* Use FSL common I2C driver */ +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed in Hz */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C2_SPEED 400000 /* I2C speed in Hz */ +#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x118000 +#define CONFIG_SYS_FSL_I2C2_OFFSET 0x119000 + +/* Qman/Bman */ +#ifndef CONFIG_NOBQFMAN +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ +#define CONFIG_SYS_BMAN_NUM_PORTALS 25 +#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 +#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull +#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_NUM_PORTALS 25 +#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 +#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull +#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 + +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_DPAA_PME + +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000 +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) +#endif + +/* + * Environment + */ +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_I2C + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks*/ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 64 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial map for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ +#define CONFIG_ROOTPATH "/opt/nfsroot" +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_UBOOTPATH "u-boot.bin"/* U-Boot image on TFTP server*/ + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ + +#define CONFIG_BAUDRATE 14745600 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:ctlr_intlv=cacheline," \ + "bank_intlv=cs0_cs1;\0" \ + "netdev=eth0\0" \ + "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ + "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=t1040emu/ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=t1040emu/t1040emu.dtb\0" \ + "bdev=sda3\0" +/* + * For emulation this causes u-boot to jump to the start of the proof point + * app code automatically + */ +#define CONFIG_PROOF_POINTS \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x29000000 - - -;" \ + "cpu 2 release 0x29000000 - - -;" \ + "cpu 3 release 0x29000000 - - -;" \ + "cpu 4 release 0x29000000 - - -;" \ + "cpu 5 release 0x29000000 - - -;" \ + "cpu 6 release 0x29000000 - - -;" \ + "cpu 7 release 0x29000000 - - -;" \ + "go 0x29000000\0" + +#define CONFIG_LINUX \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "setenv ramdiskaddr 0x02000000;" \ + "setenv fdtaddr 0x00c00000;" \ + "setenv loadaddr 0x1000000;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr\0" + +#define CONFIG_BOOTCOMMAND CONFIG_LINUX + +#endif /* __CONFIG_H */
Dependency of below patch marked under --- [U-Boot] powerpc/t1040qds: Add DDR Raw Timing support http://patchwork.ozlabs.org/patch/286112/ no longer holds true as thi patch has been deferred.
But below emulator patch will work as it is with SPD method. No changes required.
Regards Priyanka
-----Original Message----- From: Jain Priyanka-B32167 Sent: Monday, October 28, 2013 3:53 PM To: u-boot@lists.denx.de; wd@denx.de Cc: sun york-R58495; Jain Priyanka-B32167; Aggrwal Poonam-B10812; Kushwaha Prabhakar-B32579 Subject: [PATCH][v2] powerpc/T1040EMU: Add T1040 emulator support
dram_size = CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; #endif
- for each n_ranks group.
|wrdata|2T
- {2, 2140, 4, 4, 8, 0x0, 0x0, 0xff, 2, 0},
- {1, 2140, 4, 4, 8, 0x0, 0x0, 0xff, 2, 0},
- Copyright 2013 Freescale Semiconductor, Inc.
- struct cpu_type *cpu = gd->arch.cpu;
- printf("Board: %sEMU\n", cpu->name);
- const unsigned int flashbase = CONFIG_SYS_FLASH_BASE;
- const u8 flash_esel = find_tlb_idx((void *)flashbase, 1);
- /* Flush d-cache and invalidate i-cache of any FLASH data */
- flush_dcache();
- invalidate_icache();
- /* invalidate existing TLB entry for flash + promjet */
- disable_tlb(flash_esel);
- set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS,
- set_liodns();
- setup_portals();
+void ft_board_setup(void *blob, bd_t *bd) {
- phys_addr_t base;
- phys_size_t size;
- ft_cpu_setup(blob, bd);
- base = getenv_bootm_low();
- size = getenv_bootm_size();
- fdt_fixup_memory(blob, (u64)base, (u64)size);
- fdt_fixup_liodn(blob);
- T1040 Emulator configuration file
+#ifdef CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#else +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE #endif #define +CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 0x2000 +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif
- These can be toggled for performance analysis, otherwise use default.
- Config the L3 Cache as L3 SRAM
- DDR Setup
- IFC Definitions
+#define CONFIG_SYS_FLASH_BASE 0xe0000000 +#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | +CONFIG_SYS_FLASH_BASE)
+ 0x8000000) | \
CSPR_MSEL_NOR | \
CSPR_V)
CSPR_MSEL_NOR | \
CSPR_V)
FTIM2_NOR_TWP(0x1))
+/* define to use L1 as initial stack */ #define CONFIG_L1_INIT_RAM +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xfdd00000 /* Initial L1 address */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xfe0ec000 +/* The assembler doesn't like typecast */ #define +CONFIG_SYS_INIT_RAM_ADDR_PHYS \
- ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \
- Serial Port
- open - index 2
- shorted - index 1
- {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
- Environment
- Command line configuration.
- Miscellaneous configurable options
- For booting Linux, the board info and command line data
- have to be in the first 64 MB of memory, since this is
- the maximum mapped by the Linux kernel during initialization.
- Environment Configuration
- "hwconfig=fsl_ddr:ctlr_intlv=cacheline," \
- "netdev=eth0\0" \
- "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \
- "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \
- "consoledev=ttyS0\0" \
- "ramdiskaddr=2000000\0" \
- "ramdiskfile=t1040emu/ramdisk.uboot\0" \
- "fdtaddr=c00000\0" \
- "fdtfile=t1040emu/t1040emu.dtb\0" \
- "bdev=sda3\0"
- For emulation this causes u-boot to jump to the start of the proof
+point
- app code automatically
- "setenv bootargs root=/dev/$bdev rw " \
- "cpu 1 release 0x29000000 - - -;" \
- "cpu 2 release 0x29000000 - - -;" \
- "cpu 3 release 0x29000000 - - -;" \
- "cpu 4 release 0x29000000 - - -;" \
- "cpu 5 release 0x29000000 - - -;" \
- "cpu 6 release 0x29000000 - - -;" \
- "cpu 7 release 0x29000000 - - -;" \
- "go 0x29000000\0"
- "setenv bootargs root=/dev/ram rw " \
- "setenv ramdiskaddr 0x02000000;" \
- "setenv fdtaddr 0x00c00000;" \
- "setenv loadaddr 0x1000000;" \
- "bootm $loadaddr $ramdiskaddr $fdtaddr\0"
1.7.4.1
Regards Priyanka
This T1040EMU.h should merge with T1040QDS.h and only host the difference, like the way we did for T4240QDS and T4240EMU.
- dram_size = CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; #endif
Why do you set the size to a fixed value if using SPD?
York
Priyanka Jain
York Sun
