[U-Boot] undefined reference to `environment'
Hi Simon / Tom,
It seems the SH4 build is failing with the current trunk. Or at least my test build is failing and the change seems to have nothing to do with the failure.
https://travis-ci.org/jhershbe/u-boot/jobs/269330102
Cheers, -Joe
+Thomas
Hi Joe,
On 29 August 2017 at 06:59, Joe Hershberger joe.hershberger@ni.com wrote:
Hi Simon / Tom,
A bisect shows this came in with:
f40ad66f (refs/bisect/bad) arch/sh: don't bring common/env_embedded.o into the link
Thomas, could you please take a look?
Cheers, -Joe
Hello,
On Wed, 30 Aug 2017 04:16:39 +0800, Simon Glass wrote:
Hi Joe,
Hi Simon / Tom,
Sure, I'll have a look. I guess I should be able to reproduce by building ms7722se_defconfig ?
Thomas
Hello,
env/embedded.o is missing in the link. It is added to extra-y by:
extra-$(CONFIG_ENV_IS_IN_FLASH) += embedded.o
I dumped extra-y right after this line, and it does contain embedded.o. However, it does not get added to the link stage.
Why is this an extra-$() rather than an obj-$() ?
Thomas
On Tue, Aug 29, 2017 at 4:50 PM, Thomas Petazzoni thomas.petazzoni@free-electrons.com wrote:
Hello,
So there's something extra funny going on in the linking. See https://patchwork.ozlabs.org/patch/806263/ which I have included, but haven't been able to push out.
Hello,
At this point, I don't think it's the correct fix. I don't see why it should be the responsibility of the linker script to include env/embedded.o. Almost no other architecture has env/embedded.o referenced in its linker script. Only a few m68k platforms, with custom linker script in their include/configs/.h file include env/embedded.o in their linker script, plus one Freescale platform.
Again, changing extra- to obj- in env/Makefile also fixes the issue.
Thomas
On Wed, Aug 30, 2017 at 6:07 AM, Thomas Petazzoni thomas.petazzoni@free-electrons.com wrote:
Hello,
Yep, looks to me obj- is the correct way to fix.
Regards, Bin
Hello,
How did you end up solving this problem? As I said, I don't think https://patchwork.ozlabs.org/patch/806263/ is the correct solution.
Thomas
On Thu, Sep 14, 2017 at 12:29:11AM +0200, Thomas Petazzoni wrote:
Hello,
It wasn't my favorite patch but I wouldn't have let the original in if I had noticed the fail-to-build in the first place. So coming up with a better rework (and understanding of) why only that combination of settings was failing without forcing env/embedded.o being linked in is on the TODO list somewhere.
participants (5)
Bin Meng
Joe Hershberger
Thomas Petazzoni
