[U-Boot] [PATCH v2 1/2] disk: part: scan the disk if the part_type is unknown
If a DUT do not have partition table, and we write one with 'gpt write' cmd, we should able to list the partition with 'part list' cmd. It's reasonable to scan the disk again if the initial part_type is unknown in case we just write a new one into disk.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: - update commit message to make it more clear why we need this patch
disk/part.c | 24 ++++++++++++++++++------ 1 file changed, 18 insertions(+), 6 deletions(-)
diff --git a/disk/part.c b/disk/part.c index 66b8101..df0d50d 100644 --- a/disk/part.c +++ b/disk/part.c @@ -27,16 +27,28 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef HAVE_BLOCK_DEVICE -static struct part_driver *part_driver_lookup_type(int part_type) +static struct part_driver *part_driver_lookup_type(struct blk_desc *dev_desc) { struct part_driver *drv = ll_entry_start(struct part_driver, part_driver); const int n_ents = ll_entry_count(struct part_driver, part_driver); struct part_driver *entry;
- for (entry = drv; entry != drv + n_ents; entry++) { - if (part_type == entry->part_type) - return entry; + if (dev_desc->part_type == PART_TYPE_UNKNOWN) { + for (entry = drv; entry != drv + n_ents; entry++) { + int ret; + + ret = entry->test(dev_desc); + if (!ret) { + dev_desc->part_type = entry->part_type; + return entry; + } + } + } else { + for (entry = drv; entry != drv + n_ents; entry++) { + if (dev_desc->part_type == entry->part_type) + return entry; + } }
/* Not found */ @@ -285,7 +297,7 @@ void part_print(struct blk_desc *dev_desc) { struct part_driver *drv;
- drv = part_driver_lookup_type(dev_desc->part_type); + drv = part_driver_lookup_type(dev_desc); if (!drv) { printf("## Unknown partition table type %x\n", dev_desc->part_type); @@ -314,7 +326,7 @@ int part_get_info(struct blk_desc *dev_desc, int part, info->type_guid[0] = 0; #endif
- drv = part_driver_lookup_type(dev_desc->part_type); + drv = part_driver_lookup_type(dev_desc); if (!drv) { debug("## Unknown partition table type %x\n", dev_desc->part_type);
Do not need to scan disk every time when we get part info by name.
Changes in v2: - rebase to latest version - add error handle for partition tbale not exist
disk/part.c | 35 ++++++++++++++++------------------- 1 file changed, 16 insertions(+), 19 deletions(-)
diff --git a/disk/part.c b/disk/part.c index df0d50d..b80a4b1 100644 --- a/disk/part.c +++ b/disk/part.c @@ -644,28 +644,25 @@ cleanup: int part_get_info_by_name_type(struct blk_desc *dev_desc, const char *name, disk_partition_t *info, int part_type) { - struct part_driver *first_drv = - ll_entry_start(struct part_driver, part_driver); - const int n_drvs = ll_entry_count(struct part_driver, part_driver); struct part_driver *part_drv; - - for (part_drv = first_drv; part_drv != first_drv + n_drvs; part_drv++) { - int ret; - int i; - for (i = 1; i < part_drv->max_entries; i++) { - if (part_type >= 0 && part_type != part_drv->part_type) - break; - ret = part_drv->get_info(dev_desc, i, info); - if (ret != 0) { - /* no more entries in table */ - break; - } - if (strcmp(name, (const char *)info->name) == 0) { - /* matched */ - return i; - } + int ret; + int i; + + part_drv = part_driver_lookup_type(dev_desc); + if (!part_drv) + return -1; + for (i = 1; i < part_drv->max_entries; i++) { + ret = part_drv->get_info(dev_desc, i, info); + if (ret != 0) { + /* no more entries in table */ + break; + } + if (strcmp(name, (const char *)info->name) == 0) { + /* matched */ + return i; } } + return -1; }
Kever Yang
