[U-Boot] [PATCH 1/2] ARM: dts: exynos5: remove the duplicated nodes
Remove the duplicated gic and combiner nodes in exynos5.dtsi.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- arch/arm/dts/exynos5.dtsi | 27 --------------------------- 1 file changed, 27 deletions(-)
diff --git a/arch/arm/dts/exynos5.dtsi b/arch/arm/dts/exynos5.dtsi index 8650800f52..8b725c0ddc 100644 --- a/arch/arm/dts/exynos5.dtsi +++ b/arch/arm/dts/exynos5.dtsi @@ -45,33 +45,6 @@ #size-cells = <0>; };
- combiner: interrupt-controller@10440000 { - compatible = "samsung,exynos4210-combiner"; - #interrupt-cells = <2>; - interrupt-controller; - samsung,combiner-nr = <32>; - reg = <0x10440000 0x1000>; - interrupts = <0 0 0>, <0 1 0>, <0 2 0>, <0 3 0>, - <0 4 0>, <0 5 0>, <0 6 0>, <0 7 0>, - <0 8 0>, <0 9 0>, <0 10 0>, <0 11 0>, - <0 12 0>, <0 13 0>, <0 14 0>, <0 15 0>, - <0 16 0>, <0 17 0>, <0 18 0>, <0 19 0>, - <0 20 0>, <0 21 0>, <0 22 0>, <0 23 0>, - <0 24 0>, <0 25 0>, <0 26 0>, <0 27 0>, - <0 28 0>, <0 29 0>, <0 30 0>, <0 31 0>; - }; - - gic: interrupt-controller@10481000 { - compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x10481000 0x1000>, - <0x10482000 0x1000>, - <0x10484000 0x2000>, - <0x10486000 0x2000>; - interrupts = <1 9 0xf04>; - }; - i2c_0: i2c@12C60000 { compatible = "samsung,s3c2440-i2c"; reg = <0x12C60000 0x100>;
Add the interrupt-parent property as gic.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- arch/arm/dts/exynos5.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/exynos5.dtsi b/arch/arm/dts/exynos5.dtsi index 8b725c0ddc..19e0d0a45a 100644 --- a/arch/arm/dts/exynos5.dtsi +++ b/arch/arm/dts/exynos5.dtsi @@ -11,6 +11,8 @@ / { compatible = "samsung,exynos5";
+ interrupt-parent = <&gic>; + combiner: interrupt-controller@10440000 { compatible = "samsung,exynos4210-combiner"; #interrupt-cells = <2>;
Hi Jaehoo,
Please add my
Reviewed-by: Anand Moon linux.amoon@gmail.com
-- 2.15.1
2018년 1월 15일 (월) 20:50, Anand Moon linux.amoon@gmail.com님이 작성:
Hi Jaehoo,
Please add my
-- 2.15.1
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Hi Jaehoon
-- 2.15.1
Hi Jaehoon,
-- 2.15.1
Looks like this series of patch is missing in u-boot git repository.
Best Regards -Anand
2018년 5월 9일 (수) 12:53, Anand Moon linux.amoon@gmail.com님이 작성:
Hi Jaehoon,
-- 2.15.1
Best Regards -Anand _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Anand Moon
Jaehoon Chung
Minkyu Kang
