[PATCH RFC v2 00/11] Integration of sysfw, tispl and tiboot3
Devices that belong to the K3 architecture require SYSFW which is a FIT image consisting of a signed system firmware image and board config binaries.
Board config binaries are needed to bring up SYSFW during U-Boot SPL startup. The board config data is given in YAML as input. These board configs contain board-specific information such as resource management, power management and security.
The following series intends to plumb the system firmware generation into U-Boot using binman for packaging. Thus it will eliminate the need for additional custom repositories for SYSFW generation and also moves t owards the community standard build flow. We use binman to package tiboot3.bin and sysfw.itb images.
These images also require x509 certificates which are created using the etype x509-cert.
The series also plumbs the generation of tispl.bin into the build flow. This image is required for loading u-boot in K3 devices. The image is packaged using ATF, OPTEE and DM (Device Manager).
Please note that the following series has implemented the above for J721E general purpose board. The board configs and device trees added are specific to J721E GP devices.
Also note the introduction of three new etypes: ti-sysfw, ti-dm and x509-cert.
On running CI tests on Github, errors were produced during world builds of keystone2_keystone3 and siemens (I0T2050 which is based on AM65x). This patch series is intended for only J721E and future work is to expand to the remaining K3 devices as well. The errors that come are mainly due to the boards other than J721E trying to generate tispl.bin.
v2: - Added etype x509-cert for creating x509 Texas Instruments certificate binary - Added packaging of tiboot3.bin - Packaging of tiboot3.bin and sysfw.itb using new etype x509 - sysfw --> ti-sysfw - Reformatted and re-arranged patches - Removed k3_fit_atf.sh and k3_gen_x509_cert.sh as their functionality is provided by binman now
Neha Malcom Francis (11): j721e_evm: schema: yaml: Add general schema and J721E board config files ti: tools: config: Add board config class to generate config binaries ti: etype: sysfw: Add entry type for sysfw ti: etype: dm: Add entry type for TI DM ti: etype: x509: Add etype for x509 certificate for K3 devices ti: sysfw: Add support for packaging sysfw.itb ti: tiboot3.bin: Remove tiboot3.bin target from makefile ti: tispl.bin: Removed script that packages tispl.bin ti: x509: Remove shell script used for signing ti: dtsi: j721e: Use binman to package sysfw.itb and tiboot3.bin ti: dtsi: j721e: Use binman to package tispl.bin
Makefile | 2 + arch/arm/dts/k3-j721e-a72-binman.dtsi | 86 + .../k3-j721e-common-proc-board-u-boot.dtsi | 1 + arch/arm/dts/k3-j721e-r5-binman.dtsi | 88 + .../k3-j721e-r5-common-proc-board-u-boot.dtsi | 1 + arch/arm/mach-k3/config.mk | 64 +- board/ti/common/schema.yaml | 355 ++ board/ti/j721e/Kconfig | 2 + board/ti/j721e/config.yaml | 3162 +++++++++++++++++ scripts/Makefile.spl | 4 - test/py/requirements.txt | 1 + tools/binman/entries.rst | 36 + tools/binman/etype/ti_dm.py | 23 + tools/binman/etype/ti_sysfw.py | 28 + tools/binman/etype/x509_cert.py | 248 ++ tools/binman/ftest.py | 21 + tools/binman/test/225_ti_dm.dts | 13 + tools/binman/test/232_ti_sysfw.dts | 13 + tools/binman/test/232_x509_cert.dts | 18 + tools/k3_fit_atf.sh | 123 - tools/k3_gen_x509_cert.sh | 252 -- tools/tibcfg_gen.py | 114 + 22 files changed, 4227 insertions(+), 428 deletions(-) create mode 100644 arch/arm/dts/k3-j721e-a72-binman.dtsi create mode 100644 arch/arm/dts/k3-j721e-r5-binman.dtsi create mode 100644 board/ti/common/schema.yaml create mode 100644 board/ti/j721e/config.yaml create mode 100644 tools/binman/etype/ti_dm.py create mode 100644 tools/binman/etype/ti_sysfw.py create mode 100644 tools/binman/etype/x509_cert.py create mode 100644 tools/binman/test/225_ti_dm.dts create mode 100644 tools/binman/test/232_ti_sysfw.dts create mode 100644 tools/binman/test/232_x509_cert.dts delete mode 100755 tools/k3_fit_atf.sh delete mode 100755 tools/k3_gen_x509_cert.sh create mode 100644 tools/tibcfg_gen.py
Schema file in YAML must be provided in board/ti/common for validating input config files and packaging system firmware. The schema includes entries for rm-cfg, board-cfg, pm-cfg and sec-cfg.
Board config file must be provided in board/ti/<devicename> in YAML. These can then be consumed for generation of binaries to package system firmware. Added YAML config for J721E EVM in particular.
It is to be noted that the bootflow followed by J721E requires tiboot3.bin, TIFS and board config binaries to be packaged into sysfw.itb along with u-boot.img. It also requires DM, ATF, OPTEE packaged into tispl.bin.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: prepared patch for upstreaming] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/common/schema.yaml | 355 ++++ board/ti/j721e/config.yaml | 3162 +++++++++++++++++++++++++++++++++++ 2 files changed, 3517 insertions(+) create mode 100644 board/ti/common/schema.yaml create mode 100644 board/ti/j721e/config.yaml
diff --git a/board/ti/common/schema.yaml b/board/ti/common/schema.yaml new file mode 100644 index 0000000000..070ff797e0 --- /dev/null +++ b/board/ti/common/schema.yaml @@ -0,0 +1,355 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Config schema for TI K3 devices +# + +--- + +definitions: + u8: + type: integer + minimum: 0 + maximum: 0xff + u16: + type: integer + minimum: 0 + maximum: 0xffff + u32: + type: integer + minimum: 0 + maximum: 0xffffffff + + + +type: object +properties: + pm-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + board-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + control: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + main_isolation_enable: + $ref: "#/definitions/u8" + main_isolation_hostid: + $ref: "#/definitions/u16" + + + secproxy: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + scaling_factor: + $ref: "#/definitions/u8" + scaling_profile: + $ref: "#/definitions/u8" + disable_main_nav_secure_proxy: + $ref: "#/definitions/u8" + + msmc: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + msmc_cache_size: + $ref: "#/definitions/u8" + debug_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + trace_dst_enables: + $ref: "#/definitions/u16" + trace_src_enables: + $ref: "#/definitions/u16" + + sec-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + + processor_acl_list: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + proc_acl_entries: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + processor_id: + $ref: "#/definitions/u8" + proc_access_master: + $ref: "#/definitions/u8" + proc_access_secondary: + type: array + minItems: 3 + maxItems: 3 + items: + $ref: "#/definitions/u8" + host_hierarchy: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + host_hierarchy_entries: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + supervisor_host_id: + $ref: "#/definitions/u8" + + otp_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + otp_entry: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + host_perms: + $ref: "#/definitions/u8" + write_host_id: + $ref: "#/definitions/u8" + + dkek_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + allowed_hosts: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + allow_dkek_export_tisci: + $ref: "#/definitions/u8" + rsvd: + type: array + minItems: 3 + maxItems: 3 + items: + $ref: "#/definitions/u8" + + sa2ul_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + rsvd: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + sec_dbg_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + allow_jtag_unlock: + $ref: "#/definitions/u8" + allow_wildcard_unlock: + $ref: "#/definitions/u8" + allowed_debug_level_rsvd: + $ref: "#/definitions/u8" + rsvd: + $ref: "#/definitions/u8" + min_cert_rev: + $ref: "#/definitions/u32" + jtag_unlock_hosts: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + + + sec_handover_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + handover_msg_sender: + $ref: "#/definitions/u8" + handover_to_host_id: + $ref: "#/definitions/u8" + rsvd: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + + rm-cfg: + type: object + properties: + rm_boardcfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + + host_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + host_cfg_entries: + type: array + minItems: 0 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + allowed_atype: + $ref: "#/definitions/u8" + allowed_qos: + $ref: "#/definitions/u16" + allowed_orderid: + $ref: "#/definitions/u32" + allowed_priority: + $ref: "#/definitions/u16" + allowed_sched_priority: + $ref: "#/definitions/u8" + resasg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + resasg_entries_size: + $ref: "#/definitions/u16" + reserved: + $ref: "#/definitions/u16" + + resasg_entries: + type: array + minItems: 0 + maxItems: 418 + items: + type: object + properties: + start_resource: + $ref: "#/definitions/u16" + num_resource: + $ref: "#/definitions/u16" + type: + $ref: "#/definitions/u16" + host_id: + $ref: "#/definitions/u8" + reserved: + $ref: "#/definitions/u8" diff --git a/board/ti/j721e/config.yaml b/board/ti/j721e/config.yaml new file mode 100644 index 0000000000..710517404f --- /dev/null +++ b/board/ti/j721e/config.yaml @@ -0,0 +1,3162 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for J721E EVM +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + +board-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable: 0x5A + main_isolation_hostid: 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor: 0x1 + scaling_profile: 0x1 + disable_main_nav_secure_proxy: 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size: 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables: 0x00 + trace_src_enables: 0x00 + +sec-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + write_host_id: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci: 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size: 0 + rsvd: [0, 0, 0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock: 0x5A + allow_wildcard_unlock: 0x5A + allowed_debug_level_rsvd: 0 + rsvd: 0 + min_cert_rev: 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender: 0 + handover_to_host_id: 0 + rsvd: [0, 0, 0, 0] + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size: 356 + host_cfg_entries: + - #1 + host_id: 3 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #2 + host_id: 5 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #3 + host_id: 12 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #4 + host_id: 13 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #5 + host_id: 21 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #6 + host_id: 26 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #7 + host_id: 28 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #8 + host_id: 35 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #9 + host_id: 37 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #10 + host_id: 40 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #11 + host_id: 42 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #12 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #13 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #14 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #15 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #16 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #17 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #18 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #19 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #20 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #21 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #22 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #23 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #24 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #25 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #26 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #27 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #28 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #29 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #30 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #31 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #32 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + resasg: + subhdr: + magic: 0x7B25 + size: 8 + resasg_entries_size: 3344 + reserved: 0 + resasg_entries: + - + start_resource: 4 + num_resource: 93 + type: 7744 + host_id: 26 + reserved: 0 + - + start_resource: 4 + num_resource: 93 + type: 7808 + host_id: 28 + reserved: 0 + - + start_resource: 0 + num_resource: 32 + type: 7872 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 32 + type: 8192 + host_id: 3 + reserved: 0 + - + start_resource: 32 + num_resource: 32 + type: 8192 + host_id: 5 + reserved: 0 + - + start_resource: 0 + num_resource: 24 + type: 8320 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 24 + type: 8320 + host_id: 5 + reserved: 0 + - + start_resource: 0 + num_resource: 8 + type: 8384 + host_id: 3 + reserved: 0 + - + start_resource: 8 + num_resource: 8 + type: 8384 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 4 + type: 8384 + host_id: 40 + reserved: 0 + - + start_resource: 20 + num_resource: 4 + type: 8384 + host_id: 42 + reserved: 0 + - + start_resource: 24 + num_resource: 4 + type: 8384 + host_id: 35 + reserved: 0 + - + start_resource: 28 + num_resource: 4 + type: 8384 + host_id: 37 + reserved: 0 + - + start_resource: 32 + num_resource: 4 + type: 8384 + host_id: 26 + reserved: 0 + - + start_resource: 36 + num_resource: 4 + type: 8384 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 12 + type: 8384 + host_id: 12 + reserved: 0 + - + start_resource: 52 + num_resource: 12 + type: 8384 + host_id: 13 + reserved: 0 + - + start_resource: 0 + num_resource: 128 + type: 8576 + host_id: 35 + reserved: 0 + - + start_resource: 128 + num_resource: 128 + type: 8576 + host_id: 37 + reserved: 0 + - + start_resource: 0 + num_resource: 128 + type: 8640 + host_id: 40 + reserved: 0 + - + start_resource: 128 + num_resource: 128 + type: 8640 + host_id: 42 + reserved: 0 + - + start_resource: 0 + num_resource: 48 + type: 8704 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 8 + type: 8768 + host_id: 3 + reserved: 0 + - + start_resource: 8 + num_resource: 8 + type: 8768 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 6 + type: 8768 + host_id: 12 + reserved: 0 + - + start_resource: 22 + num_resource: 6 + type: 8768 + host_id: 13 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 8768 + host_id: 35 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 8768 + host_id: 37 + reserved: 0 + - + start_resource: 0 + num_resource: 64 + type: 13258 + host_id: 128 + reserved: 0 + - + start_resource: 20480 + num_resource: 1024 + type: 13261 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 64 + type: 13322 + host_id: 128 + reserved: 0 + - + start_resource: 22528 + num_resource: 1024 + type: 13325 + host_id: 128 + reserved: 0 + - + start_resource: 38 + num_resource: 86 + type: 13386 + host_id: 12 + reserved: 0 + - + start_resource: 124 + num_resource: 32 + type: 13386 + host_id: 13 + reserved: 0 + - + start_resource: 156 + num_resource: 12 + type: 13386 + host_id: 40 + reserved: 0 + - + start_resource: 168 + num_resource: 12 + type: 13386 + host_id: 42 + reserved: 0 + - + start_resource: 180 + num_resource: 12 + type: 13386 + host_id: 21 + reserved: 0 + - + start_resource: 192 + num_resource: 12 + type: 13386 + host_id: 26 + reserved: 0 + - + start_resource: 204 + num_resource: 12 + type: 13386 + host_id: 28 + reserved: 0 + - + start_resource: 216 + num_resource: 28 + type: 13386 + host_id: 35 + reserved: 0 + - + start_resource: 244 + num_resource: 8 + type: 13386 + host_id: 37 + reserved: 0 + - + start_resource: 252 + num_resource: 4 + type: 13386 + host_id: 128 + reserved: 0 + - + start_resource: 38 + num_resource: 1024 + type: 13389 + host_id: 12 + reserved: 0 + - + start_resource: 1062 + num_resource: 512 + type: 13389 + host_id: 13 + reserved: 0 + - + start_resource: 1574 + num_resource: 32 + type: 13389 + host_id: 3 + reserved: 0 + - + start_resource: 1606 + num_resource: 32 + type: 13389 + host_id: 5 + reserved: 0 + - + start_resource: 1638 + num_resource: 256 + type: 13389 + host_id: 40 + reserved: 0 + - + start_resource: 1894 + num_resource: 256 + type: 13389 + host_id: 42 + reserved: 0 + - + start_resource: 2150 + num_resource: 256 + type: 13389 + host_id: 21 + reserved: 0 + - + start_resource: 2406 + num_resource: 256 + type: 13389 + host_id: 26 + reserved: 0 + - + start_resource: 2662 + num_resource: 256 + type: 13389 + host_id: 28 + reserved: 0 + - + start_resource: 2918 + num_resource: 512 + type: 13389 + host_id: 35 + reserved: 0 + - + start_resource: 3430 + num_resource: 256 + type: 13389 + host_id: 37 + reserved: 0 + - + start_resource: 3686 + num_resource: 922 + type: 13389 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 4 + type: 13440 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13440 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 4 + type: 13440 + host_id: 3 + reserved: 0 + - + start_resource: 12 + num_resource: 4 + type: 13440 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 4 + type: 13440 + host_id: 40 + reserved: 0 + - + start_resource: 20 + num_resource: 4 + type: 13440 + host_id: 42 + reserved: 0 + - + start_resource: 24 + num_resource: 4 + type: 13440 + host_id: 21 + reserved: 0 + - + start_resource: 28 + num_resource: 4 + type: 13440 + host_id: 26 + reserved: 0 + - + start_resource: 32 + num_resource: 4 + type: 13440 + host_id: 28 + reserved: 0 + - + start_resource: 36 + num_resource: 12 + type: 13440 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 4 + type: 13440 + host_id: 37 + reserved: 0 + - + start_resource: 52 + num_resource: 12 + type: 13440 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 13504 + host_id: 128 + reserved: 0 + - + start_resource: 440 + num_resource: 150 + type: 13505 + host_id: 12 + reserved: 0 + - + start_resource: 590 + num_resource: 40 + type: 13505 + host_id: 13 + reserved: 0 + - + start_resource: 630 + num_resource: 6 + type: 13505 + host_id: 3 + reserved: 0 + - + start_resource: 636 + num_resource: 6 + type: 13505 + host_id: 5 + reserved: 0 + - + start_resource: 642 + num_resource: 10 + type: 13505 + host_id: 40 + reserved: 0 + - + start_resource: 652 + num_resource: 10 + type: 13505 + host_id: 42 + reserved: 0 + - + start_resource: 662 + num_resource: 32 + type: 13505 + host_id: 21 + reserved: 0 + - + start_resource: 694 + num_resource: 38 + type: 13505 + host_id: 26 + reserved: 0 + - + start_resource: 732 + num_resource: 12 + type: 13505 + host_id: 28 + reserved: 0 + - + start_resource: 744 + num_resource: 182 + type: 13505 + host_id: 35 + reserved: 0 + - + start_resource: 926 + num_resource: 40 + type: 13505 + host_id: 37 + reserved: 0 + - + start_resource: 966 + num_resource: 8 + type: 13505 + host_id: 128 + reserved: 0 + - + start_resource: 316 + num_resource: 8 + type: 13506 + host_id: 12 + reserved: 0 + - + start_resource: 324 + num_resource: 2 + type: 13506 + host_id: 3 + reserved: 0 + - + start_resource: 324 + num_resource: 0 + type: 13506 + host_id: 13 + reserved: 0 + - + start_resource: 326 + num_resource: 2 + type: 13506 + host_id: 5 + reserved: 0 + - + start_resource: 328 + num_resource: 2 + type: 13506 + host_id: 40 + reserved: 0 + - + start_resource: 330 + num_resource: 2 + type: 13506 + host_id: 42 + reserved: 0 + - + start_resource: 332 + num_resource: 2 + type: 13506 + host_id: 21 + reserved: 0 + - + start_resource: 334 + num_resource: 8 + type: 13506 + host_id: 26 + reserved: 0 + - + start_resource: 342 + num_resource: 2 + type: 13506 + host_id: 28 + reserved: 0 + - + start_resource: 344 + num_resource: 4 + type: 13506 + host_id: 35 + reserved: 0 + - + start_resource: 348 + num_resource: 1 + type: 13506 + host_id: 37 + reserved: 0 + - + start_resource: 349 + num_resource: 28 + type: 13506 + host_id: 12 + reserved: 0 + - + start_resource: 377 + num_resource: 20 + type: 13506 + host_id: 13 + reserved: 0 + - + start_resource: 397 + num_resource: 4 + type: 13506 + host_id: 40 + reserved: 0 + - + start_resource: 401 + num_resource: 4 + type: 13506 + host_id: 42 + reserved: 0 + - + start_resource: 405 + num_resource: 4 + type: 13506 + host_id: 21 + reserved: 0 + - + start_resource: 409 + num_resource: 8 + type: 13506 + host_id: 26 + reserved: 0 + - + start_resource: 417 + num_resource: 6 + type: 13506 + host_id: 28 + reserved: 0 + - + start_resource: 423 + num_resource: 16 + type: 13506 + host_id: 35 + reserved: 0 + - + start_resource: 439 + num_resource: 1 + type: 13506 + host_id: 37 + reserved: 0 + - + start_resource: 16 + num_resource: 8 + type: 13507 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 2 + type: 13507 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 0 + type: 13507 + host_id: 13 + reserved: 0 + - + start_resource: 26 + num_resource: 2 + type: 13507 + host_id: 5 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 13507 + host_id: 40 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 13507 + host_id: 42 + reserved: 0 + - + start_resource: 32 + num_resource: 2 + type: 13507 + host_id: 21 + reserved: 0 + - + start_resource: 34 + num_resource: 8 + type: 13507 + host_id: 26 + reserved: 0 + - + start_resource: 42 + num_resource: 2 + type: 13507 + host_id: 28 + reserved: 0 + - + start_resource: 44 + num_resource: 4 + type: 13507 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 1 + type: 13507 + host_id: 37 + reserved: 0 + - + start_resource: 49 + num_resource: 28 + type: 13507 + host_id: 12 + reserved: 0 + - + start_resource: 77 + num_resource: 20 + type: 13507 + host_id: 13 + reserved: 0 + - + start_resource: 97 + num_resource: 4 + type: 13507 + host_id: 40 + reserved: 0 + - + start_resource: 101 + num_resource: 4 + type: 13507 + host_id: 42 + reserved: 0 + - + start_resource: 105 + num_resource: 4 + type: 13507 + host_id: 21 + reserved: 0 + - + start_resource: 109 + num_resource: 8 + type: 13507 + host_id: 26 + reserved: 0 + - + start_resource: 117 + num_resource: 6 + type: 13507 + host_id: 28 + reserved: 0 + - + start_resource: 123 + num_resource: 10 + type: 13507 + host_id: 35 + reserved: 0 + - + start_resource: 133 + num_resource: 6 + type: 13507 + host_id: 37 + reserved: 0 + - + start_resource: 139 + num_resource: 1 + type: 13507 + host_id: 128 + reserved: 0 + - + start_resource: 140 + num_resource: 16 + type: 13508 + host_id: 21 + reserved: 0 + - + start_resource: 156 + num_resource: 6 + type: 13508 + host_id: 26 + reserved: 0 + - + start_resource: 162 + num_resource: 6 + type: 13508 + host_id: 28 + reserved: 0 + - + start_resource: 168 + num_resource: 2 + type: 13508 + host_id: 35 + reserved: 0 + - + start_resource: 170 + num_resource: 2 + type: 13508 + host_id: 37 + reserved: 0 + - + start_resource: 172 + num_resource: 96 + type: 13508 + host_id: 35 + reserved: 0 + - + start_resource: 268 + num_resource: 32 + type: 13508 + host_id: 37 + reserved: 0 + - + start_resource: 304 + num_resource: 0 + type: 13509 + host_id: 12 + reserved: 0 + - + start_resource: 304 + num_resource: 4 + type: 13509 + host_id: 12 + reserved: 0 + - + start_resource: 304 + num_resource: 0 + type: 13509 + host_id: 35 + reserved: 0 + - + start_resource: 308 + num_resource: 6 + type: 13509 + host_id: 35 + reserved: 0 + - + start_resource: 314 + num_resource: 2 + type: 13509 + host_id: 128 + reserved: 0 + - + start_resource: 300 + num_resource: 0 + type: 13510 + host_id: 12 + reserved: 0 + - + start_resource: 300 + num_resource: 2 + type: 13510 + host_id: 12 + reserved: 0 + - + start_resource: 300 + num_resource: 0 + type: 13510 + host_id: 35 + reserved: 0 + - + start_resource: 302 + num_resource: 2 + type: 13510 + host_id: 35 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13511 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13511 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13511 + host_id: 35 + reserved: 0 + - + start_resource: 8 + num_resource: 6 + type: 13511 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 2 + type: 13511 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13512 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 13512 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13512 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 13512 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 5 + type: 13514 + host_id: 12 + reserved: 0 + - + start_resource: 7 + num_resource: 1 + type: 13514 + host_id: 13 + reserved: 0 + - + start_resource: 0 + num_resource: 3 + type: 13515 + host_id: 12 + reserved: 0 + - + start_resource: 3 + num_resource: 2 + type: 13515 + host_id: 13 + reserved: 0 + - + start_resource: 5 + num_resource: 1 + type: 13515 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 1 + type: 13515 + host_id: 5 + reserved: 0 + - + start_resource: 7 + num_resource: 3 + type: 13515 + host_id: 40 + reserved: 0 + - + start_resource: 10 + num_resource: 3 + type: 13515 + host_id: 42 + reserved: 0 + - + start_resource: 13 + num_resource: 3 + type: 13515 + host_id: 21 + reserved: 0 + - + start_resource: 16 + num_resource: 3 + type: 13515 + host_id: 26 + reserved: 0 + - + start_resource: 19 + num_resource: 3 + type: 13515 + host_id: 28 + reserved: 0 + - + start_resource: 22 + num_resource: 6 + type: 13515 + host_id: 35 + reserved: 0 + - + start_resource: 28 + num_resource: 3 + type: 13515 + host_id: 37 + reserved: 0 + - + start_resource: 31 + num_resource: 1 + type: 13515 + host_id: 128 + reserved: 0 + - + start_resource: 140 + num_resource: 16 + type: 13568 + host_id: 12 + reserved: 0 + - + start_resource: 156 + num_resource: 16 + type: 13568 + host_id: 13 + reserved: 0 + - + start_resource: 172 + num_resource: 128 + type: 13568 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 13569 + host_id: 128 + reserved: 0 + - + start_resource: 49152 + num_resource: 1024 + type: 13570 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 13571 + host_id: 128 + reserved: 0 + - + start_resource: 16 + num_resource: 8 + type: 13578 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 2 + type: 13578 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 0 + type: 13578 + host_id: 13 + reserved: 0 + - + start_resource: 26 + num_resource: 2 + type: 13578 + host_id: 5 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 13578 + host_id: 40 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 13578 + host_id: 42 + reserved: 0 + - + start_resource: 32 + num_resource: 2 + type: 13578 + host_id: 21 + reserved: 0 + - + start_resource: 34 + num_resource: 8 + type: 13578 + host_id: 26 + reserved: 0 + - + start_resource: 42 + num_resource: 2 + type: 13578 + host_id: 28 + reserved: 0 + - + start_resource: 44 + num_resource: 4 + type: 13578 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 1 + type: 13578 + host_id: 37 + reserved: 0 + - + start_resource: 49 + num_resource: 28 + type: 13578 + host_id: 12 + reserved: 0 + - + start_resource: 77 + num_resource: 20 + type: 13578 + host_id: 13 + reserved: 0 + - + start_resource: 97 + num_resource: 4 + type: 13578 + host_id: 40 + reserved: 0 + - + start_resource: 101 + num_resource: 4 + type: 13578 + host_id: 42 + reserved: 0 + - + start_resource: 105 + num_resource: 4 + type: 13578 + host_id: 21 + reserved: 0 + - + start_resource: 109 + num_resource: 8 + type: 13578 + host_id: 26 + reserved: 0 + - + start_resource: 117 + num_resource: 6 + type: 13578 + host_id: 28 + reserved: 0 + - + start_resource: 123 + num_resource: 16 + type: 13578 + host_id: 35 + reserved: 0 + - + start_resource: 139 + num_resource: 1 + type: 13578 + host_id: 37 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13579 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13579 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13579 + host_id: 35 + reserved: 0 + - + start_resource: 8 + num_resource: 6 + type: 13579 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 2 + type: 13579 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13580 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 13580 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13580 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 13580 + host_id: 35 + reserved: 0 + - + start_resource: 16 + num_resource: 8 + type: 13581 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 2 + type: 13581 + host_id: 3 + reserved: 0 + - + start_resource: 24 + num_resource: 0 + type: 13581 + host_id: 13 + reserved: 0 + - + start_resource: 26 + num_resource: 2 + type: 13581 + host_id: 5 + reserved: 0 + - + start_resource: 28 + num_resource: 2 + type: 13581 + host_id: 40 + reserved: 0 + - + start_resource: 30 + num_resource: 2 + type: 13581 + host_id: 42 + reserved: 0 + - + start_resource: 32 + num_resource: 2 + type: 13581 + host_id: 21 + reserved: 0 + - + start_resource: 34 + num_resource: 8 + type: 13581 + host_id: 26 + reserved: 0 + - + start_resource: 42 + num_resource: 2 + type: 13581 + host_id: 28 + reserved: 0 + - + start_resource: 44 + num_resource: 4 + type: 13581 + host_id: 35 + reserved: 0 + - + start_resource: 48 + num_resource: 1 + type: 13581 + host_id: 37 + reserved: 0 + - + start_resource: 49 + num_resource: 28 + type: 13581 + host_id: 12 + reserved: 0 + - + start_resource: 77 + num_resource: 20 + type: 13581 + host_id: 13 + reserved: 0 + - + start_resource: 97 + num_resource: 4 + type: 13581 + host_id: 40 + reserved: 0 + - + start_resource: 101 + num_resource: 4 + type: 13581 + host_id: 42 + reserved: 0 + - + start_resource: 105 + num_resource: 4 + type: 13581 + host_id: 21 + reserved: 0 + - + start_resource: 109 + num_resource: 8 + type: 13581 + host_id: 26 + reserved: 0 + - + start_resource: 117 + num_resource: 6 + type: 13581 + host_id: 28 + reserved: 0 + - + start_resource: 123 + num_resource: 10 + type: 13581 + host_id: 35 + reserved: 0 + - + start_resource: 133 + num_resource: 6 + type: 13581 + host_id: 37 + reserved: 0 + - + start_resource: 139 + num_resource: 1 + type: 13581 + host_id: 128 + reserved: 0 + - + start_resource: 140 + num_resource: 16 + type: 13582 + host_id: 21 + reserved: 0 + - + start_resource: 156 + num_resource: 6 + type: 13582 + host_id: 26 + reserved: 0 + - + start_resource: 162 + num_resource: 6 + type: 13582 + host_id: 28 + reserved: 0 + - + start_resource: 168 + num_resource: 2 + type: 13582 + host_id: 35 + reserved: 0 + - + start_resource: 170 + num_resource: 2 + type: 13582 + host_id: 37 + reserved: 0 + - + start_resource: 172 + num_resource: 96 + type: 13582 + host_id: 35 + reserved: 0 + - + start_resource: 268 + num_resource: 32 + type: 13582 + host_id: 37 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13583 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 4 + type: 13583 + host_id: 12 + reserved: 0 + - + start_resource: 4 + num_resource: 0 + type: 13583 + host_id: 35 + reserved: 0 + - + start_resource: 8 + num_resource: 6 + type: 13583 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 2 + type: 13583 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13584 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 13584 + host_id: 12 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 13584 + host_id: 35 + reserved: 0 + - + start_resource: 2 + num_resource: 2 + type: 13584 + host_id: 35 + reserved: 0 + - + start_resource: 10 + num_resource: 100 + type: 13632 + host_id: 12 + reserved: 0 + - + start_resource: 110 + num_resource: 32 + type: 13632 + host_id: 13 + reserved: 0 + - + start_resource: 142 + num_resource: 46 + type: 13632 + host_id: 21 + reserved: 0 + - + start_resource: 196 + num_resource: 28 + type: 13632 + host_id: 35 + reserved: 0 + - + start_resource: 228 + num_resource: 28 + type: 13632 + host_id: 37 + reserved: 0 + - + start_resource: 260 + num_resource: 28 + type: 13632 + host_id: 40 + reserved: 0 + - + start_resource: 292 + num_resource: 28 + type: 13632 + host_id: 42 + reserved: 0 + - + start_resource: 320 + num_resource: 24 + type: 13632 + host_id: 26 + reserved: 0 + - + start_resource: 352 + num_resource: 24 + type: 13632 + host_id: 28 + reserved: 0 + - + start_resource: 400 + num_resource: 4 + type: 13632 + host_id: 3 + reserved: 0 + - + start_resource: 404 + num_resource: 4 + type: 13632 + host_id: 5 + reserved: 0 + - + start_resource: 16 + num_resource: 32 + type: 14922 + host_id: 12 + reserved: 0 + - + start_resource: 48 + num_resource: 16 + type: 14922 + host_id: 13 + reserved: 0 + - + start_resource: 64 + num_resource: 64 + type: 14922 + host_id: 3 + reserved: 0 + - + start_resource: 128 + num_resource: 4 + type: 14922 + host_id: 5 + reserved: 0 + - + start_resource: 132 + num_resource: 16 + type: 14922 + host_id: 40 + reserved: 0 + - + start_resource: 148 + num_resource: 16 + type: 14922 + host_id: 42 + reserved: 0 + - + start_resource: 164 + num_resource: 8 + type: 14922 + host_id: 21 + reserved: 0 + - + start_resource: 172 + num_resource: 8 + type: 14922 + host_id: 26 + reserved: 0 + - + start_resource: 180 + num_resource: 8 + type: 14922 + host_id: 28 + reserved: 0 + - + start_resource: 188 + num_resource: 24 + type: 14922 + host_id: 35 + reserved: 0 + - + start_resource: 212 + num_resource: 8 + type: 14922 + host_id: 37 + reserved: 0 + - + start_resource: 220 + num_resource: 36 + type: 14922 + host_id: 128 + reserved: 0 + - + start_resource: 16400 + num_resource: 128 + type: 14925 + host_id: 12 + reserved: 0 + - + start_resource: 16528 + num_resource: 128 + type: 14925 + host_id: 13 + reserved: 0 + - + start_resource: 16656 + num_resource: 256 + type: 14925 + host_id: 3 + reserved: 0 + - + start_resource: 16912 + num_resource: 64 + type: 14925 + host_id: 5 + reserved: 0 + - + start_resource: 16976 + num_resource: 128 + type: 14925 + host_id: 40 + reserved: 0 + - + start_resource: 17104 + num_resource: 128 + type: 14925 + host_id: 42 + reserved: 0 + - + start_resource: 17232 + num_resource: 64 + type: 14925 + host_id: 21 + reserved: 0 + - + start_resource: 17296 + num_resource: 64 + type: 14925 + host_id: 26 + reserved: 0 + - + start_resource: 17360 + num_resource: 64 + type: 14925 + host_id: 28 + reserved: 0 + - + start_resource: 17424 + num_resource: 128 + type: 14925 + host_id: 35 + reserved: 0 + - + start_resource: 17552 + num_resource: 128 + type: 14925 + host_id: 37 + reserved: 0 + - + start_resource: 17680 + num_resource: 240 + type: 14925 + host_id: 128 + reserved: 0 + - + start_resource: 1 + num_resource: 4 + type: 14976 + host_id: 12 + reserved: 0 + - + start_resource: 5 + num_resource: 4 + type: 14976 + host_id: 13 + reserved: 0 + - + start_resource: 9 + num_resource: 4 + type: 14976 + host_id: 3 + reserved: 0 + - + start_resource: 13 + num_resource: 4 + type: 14976 + host_id: 5 + reserved: 0 + - + start_resource: 17 + num_resource: 4 + type: 14976 + host_id: 40 + reserved: 0 + - + start_resource: 21 + num_resource: 4 + type: 14976 + host_id: 42 + reserved: 0 + - + start_resource: 25 + num_resource: 4 + type: 14976 + host_id: 21 + reserved: 0 + - + start_resource: 29 + num_resource: 4 + type: 14976 + host_id: 26 + reserved: 0 + - + start_resource: 33 + num_resource: 4 + type: 14976 + host_id: 28 + reserved: 0 + - + start_resource: 37 + num_resource: 16 + type: 14976 + host_id: 35 + reserved: 0 + - + start_resource: 53 + num_resource: 4 + type: 14976 + host_id: 37 + reserved: 0 + - + start_resource: 57 + num_resource: 7 + type: 14976 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 15040 + host_id: 128 + reserved: 0 + - + start_resource: 96 + num_resource: 20 + type: 15041 + host_id: 12 + reserved: 0 + - + start_resource: 116 + num_resource: 8 + type: 15041 + host_id: 13 + reserved: 0 + - + start_resource: 124 + num_resource: 32 + type: 15041 + host_id: 3 + reserved: 0 + - + start_resource: 156 + num_resource: 12 + type: 15041 + host_id: 5 + reserved: 0 + - + start_resource: 168 + num_resource: 8 + type: 15041 + host_id: 40 + reserved: 0 + - + start_resource: 176 + num_resource: 8 + type: 15041 + host_id: 42 + reserved: 0 + - + start_resource: 184 + num_resource: 8 + type: 15041 + host_id: 21 + reserved: 0 + - + start_resource: 192 + num_resource: 8 + type: 15041 + host_id: 26 + reserved: 0 + - + start_resource: 200 + num_resource: 8 + type: 15041 + host_id: 28 + reserved: 0 + - + start_resource: 208 + num_resource: 16 + type: 15041 + host_id: 35 + reserved: 0 + - + start_resource: 224 + num_resource: 8 + type: 15041 + host_id: 37 + reserved: 0 + - + start_resource: 232 + num_resource: 20 + type: 15041 + host_id: 128 + reserved: 0 + - + start_resource: 50 + num_resource: 4 + type: 15042 + host_id: 12 + reserved: 0 + - + start_resource: 54 + num_resource: 2 + type: 15042 + host_id: 3 + reserved: 0 + - + start_resource: 54 + num_resource: 0 + type: 15042 + host_id: 13 + reserved: 0 + - + start_resource: 56 + num_resource: 0 + type: 15042 + host_id: 5 + reserved: 0 + - + start_resource: 56 + num_resource: 1 + type: 15042 + host_id: 40 + reserved: 0 + - + start_resource: 57 + num_resource: 1 + type: 15042 + host_id: 42 + reserved: 0 + - + start_resource: 58 + num_resource: 1 + type: 15042 + host_id: 21 + reserved: 0 + - + start_resource: 59 + num_resource: 1 + type: 15042 + host_id: 26 + reserved: 0 + - + start_resource: 60 + num_resource: 1 + type: 15042 + host_id: 28 + reserved: 0 + - + start_resource: 61 + num_resource: 1 + type: 15042 + host_id: 35 + reserved: 0 + - + start_resource: 62 + num_resource: 1 + type: 15042 + host_id: 37 + reserved: 0 + - + start_resource: 63 + num_resource: 9 + type: 15042 + host_id: 12 + reserved: 0 + - + start_resource: 72 + num_resource: 6 + type: 15042 + host_id: 13 + reserved: 0 + - + start_resource: 78 + num_resource: 3 + type: 15042 + host_id: 3 + reserved: 0 + - + start_resource: 81 + num_resource: 2 + type: 15042 + host_id: 5 + reserved: 0 + - + start_resource: 83 + num_resource: 1 + type: 15042 + host_id: 40 + reserved: 0 + - + start_resource: 84 + num_resource: 1 + type: 15042 + host_id: 42 + reserved: 0 + - + start_resource: 85 + num_resource: 1 + type: 15042 + host_id: 21 + reserved: 0 + - + start_resource: 86 + num_resource: 1 + type: 15042 + host_id: 26 + reserved: 0 + - + start_resource: 87 + num_resource: 1 + type: 15042 + host_id: 28 + reserved: 0 + - + start_resource: 88 + num_resource: 2 + type: 15042 + host_id: 35 + reserved: 0 + - + start_resource: 90 + num_resource: 1 + type: 15042 + host_id: 37 + reserved: 0 + - + start_resource: 91 + num_resource: 2 + type: 15042 + host_id: 128 + reserved: 0 + - + start_resource: 2 + num_resource: 4 + type: 15043 + host_id: 12 + reserved: 0 + - + start_resource: 6 + num_resource: 2 + type: 15043 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 0 + type: 15043 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 0 + type: 15043 + host_id: 5 + reserved: 0 + - + start_resource: 8 + num_resource: 1 + type: 15043 + host_id: 40 + reserved: 0 + - + start_resource: 9 + num_resource: 1 + type: 15043 + host_id: 42 + reserved: 0 + - + start_resource: 10 + num_resource: 1 + type: 15043 + host_id: 21 + reserved: 0 + - + start_resource: 11 + num_resource: 1 + type: 15043 + host_id: 26 + reserved: 0 + - + start_resource: 12 + num_resource: 1 + type: 15043 + host_id: 28 + reserved: 0 + - + start_resource: 13 + num_resource: 1 + type: 15043 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 1 + type: 15043 + host_id: 37 + reserved: 0 + - + start_resource: 15 + num_resource: 9 + type: 15043 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 6 + type: 15043 + host_id: 13 + reserved: 0 + - + start_resource: 30 + num_resource: 3 + type: 15043 + host_id: 3 + reserved: 0 + - + start_resource: 33 + num_resource: 2 + type: 15043 + host_id: 5 + reserved: 0 + - + start_resource: 35 + num_resource: 1 + type: 15043 + host_id: 40 + reserved: 0 + - + start_resource: 36 + num_resource: 1 + type: 15043 + host_id: 42 + reserved: 0 + - + start_resource: 37 + num_resource: 1 + type: 15043 + host_id: 21 + reserved: 0 + - + start_resource: 38 + num_resource: 1 + type: 15043 + host_id: 26 + reserved: 0 + - + start_resource: 39 + num_resource: 1 + type: 15043 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 2 + type: 15043 + host_id: 35 + reserved: 0 + - + start_resource: 42 + num_resource: 1 + type: 15043 + host_id: 37 + reserved: 0 + - + start_resource: 43 + num_resource: 3 + type: 15043 + host_id: 128 + reserved: 0 + - + start_resource: 48 + num_resource: 0 + type: 15045 + host_id: 3 + reserved: 0 + - + start_resource: 48 + num_resource: 2 + type: 15045 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 15047 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 15047 + host_id: 3 + reserved: 0 + - + start_resource: 2 + num_resource: 5 + type: 15050 + host_id: 12 + reserved: 0 + - + start_resource: 7 + num_resource: 1 + type: 15050 + host_id: 13 + reserved: 0 + - + start_resource: 0 + num_resource: 3 + type: 15051 + host_id: 12 + reserved: 0 + - + start_resource: 3 + num_resource: 2 + type: 15051 + host_id: 13 + reserved: 0 + - + start_resource: 5 + num_resource: 3 + type: 15051 + host_id: 3 + reserved: 0 + - + start_resource: 8 + num_resource: 3 + type: 15051 + host_id: 5 + reserved: 0 + - + start_resource: 11 + num_resource: 3 + type: 15051 + host_id: 40 + reserved: 0 + - + start_resource: 14 + num_resource: 3 + type: 15051 + host_id: 42 + reserved: 0 + - + start_resource: 17 + num_resource: 3 + type: 15051 + host_id: 21 + reserved: 0 + - + start_resource: 20 + num_resource: 3 + type: 15051 + host_id: 26 + reserved: 0 + - + start_resource: 23 + num_resource: 3 + type: 15051 + host_id: 28 + reserved: 0 + - + start_resource: 26 + num_resource: 3 + type: 15051 + host_id: 35 + reserved: 0 + - + start_resource: 29 + num_resource: 3 + type: 15051 + host_id: 37 + reserved: 0 + - + start_resource: 48 + num_resource: 8 + type: 15104 + host_id: 12 + reserved: 0 + - + start_resource: 56 + num_resource: 4 + type: 15104 + host_id: 13 + reserved: 0 + - + start_resource: 60 + num_resource: 8 + type: 15104 + host_id: 3 + reserved: 0 + - + start_resource: 68 + num_resource: 4 + type: 15104 + host_id: 5 + reserved: 0 + - + start_resource: 72 + num_resource: 4 + type: 15104 + host_id: 40 + reserved: 0 + - + start_resource: 76 + num_resource: 4 + type: 15104 + host_id: 42 + reserved: 0 + - + start_resource: 80 + num_resource: 8 + type: 15104 + host_id: 35 + reserved: 0 + - + start_resource: 88 + num_resource: 4 + type: 15104 + host_id: 37 + reserved: 0 + - + start_resource: 92 + num_resource: 4 + type: 15104 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 15105 + host_id: 128 + reserved: 0 + - + start_resource: 56320 + num_resource: 256 + type: 15106 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 1 + type: 15107 + host_id: 128 + reserved: 0 + - + start_resource: 2 + num_resource: 4 + type: 15114 + host_id: 12 + reserved: 0 + - + start_resource: 6 + num_resource: 2 + type: 15114 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 0 + type: 15114 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 0 + type: 15114 + host_id: 5 + reserved: 0 + - + start_resource: 8 + num_resource: 1 + type: 15114 + host_id: 40 + reserved: 0 + - + start_resource: 9 + num_resource: 1 + type: 15114 + host_id: 42 + reserved: 0 + - + start_resource: 10 + num_resource: 1 + type: 15114 + host_id: 21 + reserved: 0 + - + start_resource: 11 + num_resource: 1 + type: 15114 + host_id: 26 + reserved: 0 + - + start_resource: 12 + num_resource: 1 + type: 15114 + host_id: 28 + reserved: 0 + - + start_resource: 13 + num_resource: 1 + type: 15114 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 1 + type: 15114 + host_id: 37 + reserved: 0 + - + start_resource: 15 + num_resource: 9 + type: 15114 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 6 + type: 15114 + host_id: 13 + reserved: 0 + - + start_resource: 30 + num_resource: 3 + type: 15114 + host_id: 3 + reserved: 0 + - + start_resource: 33 + num_resource: 2 + type: 15114 + host_id: 5 + reserved: 0 + - + start_resource: 35 + num_resource: 1 + type: 15114 + host_id: 40 + reserved: 0 + - + start_resource: 36 + num_resource: 1 + type: 15114 + host_id: 42 + reserved: 0 + - + start_resource: 37 + num_resource: 1 + type: 15114 + host_id: 21 + reserved: 0 + - + start_resource: 38 + num_resource: 1 + type: 15114 + host_id: 26 + reserved: 0 + - + start_resource: 39 + num_resource: 1 + type: 15114 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 2 + type: 15114 + host_id: 35 + reserved: 0 + - + start_resource: 42 + num_resource: 1 + type: 15114 + host_id: 37 + reserved: 0 + - + start_resource: 43 + num_resource: 2 + type: 15114 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 15115 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 15115 + host_id: 3 + reserved: 0 + - + start_resource: 2 + num_resource: 4 + type: 15117 + host_id: 12 + reserved: 0 + - + start_resource: 6 + num_resource: 2 + type: 15117 + host_id: 3 + reserved: 0 + - + start_resource: 6 + num_resource: 0 + type: 15117 + host_id: 13 + reserved: 0 + - + start_resource: 8 + num_resource: 0 + type: 15117 + host_id: 5 + reserved: 0 + - + start_resource: 8 + num_resource: 1 + type: 15117 + host_id: 40 + reserved: 0 + - + start_resource: 9 + num_resource: 1 + type: 15117 + host_id: 42 + reserved: 0 + - + start_resource: 10 + num_resource: 1 + type: 15117 + host_id: 21 + reserved: 0 + - + start_resource: 11 + num_resource: 1 + type: 15117 + host_id: 26 + reserved: 0 + - + start_resource: 12 + num_resource: 1 + type: 15117 + host_id: 28 + reserved: 0 + - + start_resource: 13 + num_resource: 1 + type: 15117 + host_id: 35 + reserved: 0 + - + start_resource: 14 + num_resource: 1 + type: 15117 + host_id: 37 + reserved: 0 + - + start_resource: 15 + num_resource: 9 + type: 15117 + host_id: 12 + reserved: 0 + - + start_resource: 24 + num_resource: 6 + type: 15117 + host_id: 13 + reserved: 0 + - + start_resource: 30 + num_resource: 3 + type: 15117 + host_id: 3 + reserved: 0 + - + start_resource: 33 + num_resource: 2 + type: 15117 + host_id: 5 + reserved: 0 + - + start_resource: 35 + num_resource: 1 + type: 15117 + host_id: 40 + reserved: 0 + - + start_resource: 36 + num_resource: 1 + type: 15117 + host_id: 42 + reserved: 0 + - + start_resource: 37 + num_resource: 1 + type: 15117 + host_id: 21 + reserved: 0 + - + start_resource: 38 + num_resource: 1 + type: 15117 + host_id: 26 + reserved: 0 + - + start_resource: 39 + num_resource: 1 + type: 15117 + host_id: 28 + reserved: 0 + - + start_resource: 40 + num_resource: 2 + type: 15117 + host_id: 35 + reserved: 0 + - + start_resource: 42 + num_resource: 1 + type: 15117 + host_id: 37 + reserved: 0 + - + start_resource: 43 + num_resource: 3 + type: 15117 + host_id: 128 + reserved: 0 + - + start_resource: 0 + num_resource: 0 + type: 15119 + host_id: 3 + reserved: 0 + - + start_resource: 0 + num_resource: 2 + type: 15119 + host_id: 3 + reserved: 0 + - + start_resource: 12 + num_resource: 20 + type: 15168 + host_id: 3 + reserved: 0 + - + start_resource: 36 + num_resource: 28 + type: 15168 + host_id: 5 + reserved: 0
For validating config files and generating binary config artifacts, here board specific config class is added.
Add function cfgBinaryGen() in tibcfg_gen.py. It uses TIBoardConfig class to load given schema and config files in YAML, validate them and generate binaries.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: prepared patch for upstreaming] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- test/py/requirements.txt | 1 + tools/tibcfg_gen.py | 114 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 115 insertions(+) create mode 100644 tools/tibcfg_gen.py
diff --git a/test/py/requirements.txt b/test/py/requirements.txt index 33c5c0bbc4..a91ba64563 100644 --- a/test/py/requirements.txt +++ b/test/py/requirements.txt @@ -4,6 +4,7 @@ coverage==4.5.4 extras==1.0.0 fixtures==3.0.0 importlib-metadata==0.23 +jsonschema==4.0.0 linecache2==1.0.0 more-itertools==7.2.0 packaging==19.2 diff --git a/tools/tibcfg_gen.py b/tools/tibcfg_gen.py new file mode 100644 index 0000000000..e5fa2690c8 --- /dev/null +++ b/tools/tibcfg_gen.py @@ -0,0 +1,114 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# TI Board Configuration Class for Schema Validation and Binary Generation +# + +import os +import getopt +import sys + +import yaml + +from jsonschema import validate + + +class TIBoardConfig: + + """ Texas Instruments Board Configuration File""" + + def __init__(self, file, schema, data_rules=""): + """Load a YAML configuration file and YAML schema + + Validation of the config file against the schema is also done.""" + with open(file, 'r') as f: + self.file_yaml = yaml.safe_load(f) + with open(schema, 'r') as sch: + self.schema_yaml = yaml.safe_load(sch) + self.data_rules = data_rules + try: + validate(self.file_yaml, self.schema_yaml) + except Exception as e: + print(e) + + def _convert_to_byte_chunk(self, val, data_type): + """Convert value into byte array""" + size = 0 + if(data_type == "#/definitions/u8"): + size = 1 + elif(data_type == "#/definitions/u16"): + size = 2 + elif(data_type == "#/definitions/u32"): + size = 4 + else: + raise Exception("Data type not present in definitions") + if type(val) == int: + br = val.to_bytes(size, byteorder="little") + return br + + def _compile_yaml(self, schema_yaml, file_yaml): + """Convert YAML file into byte array based on YAML schema""" + br = bytearray() + for key in file_yaml.keys(): + node = file_yaml[key] + node_schema = schema_yaml['properties'][key] + node_type = node_schema.get('type') + if not 'type' in node_schema: + br += self._convert_to_byte_chunk(node, + node_schema.get('$ref')) + elif node_type == 'object': + br += self._compile_yaml(node_schema, node) + elif node_type == 'array': + for item in node: + if not isinstance(item, dict): + br += self._convert_to_byte_chunk( + item, schema_yaml['properties'][key]['items']["$ref"]) + else: + br += self._compile_yaml(node_schema.get('items'), item) + return br + + def generate_binaries(self, out_path=""): + """Generate config binary artifacts from the loaded YAML configuration file""" + if not os.path.isdir(out_path): + os.mkdir(out_path) + for key in self.file_yaml.keys(): + node = self.file_yaml[key] + node_schema = self.schema_yaml['properties'][key] + br = self._compile_yaml(node_schema, node) + path = os.path.join(out_path, key + ".bin") + with open(path, 'wb') as cfg: + cfg.write(br) + + def delete_binaries(self, out_path=""): + """Delete generated binaries""" + if os.path.isdir(out_path): + for key in self.file_yaml.keys(): + path = os.path.join(out_path, key + ".bin") + if os.path.isfile(path): + os.remove(path) + + +def cfgBinaryGen(): + """Generate config binaries from YAML config file and YAML schema + Arguments: + - config_yaml: board config file in YAML + - schema_yaml: schema file in YAML to validate config_yaml against + - output_dir: output directory where generated binaries can be populated + Pass the arguments along with the filename in the Makefile. + """ + opts, args = getopt.getopt(sys.argv[1:], "c:s:o") + for opt, val in opts: + if opt == "-c": + config_yaml = val + elif opt == "-s": + schema_yaml = val + elif opt == "-o": + output_dir = os.path.abspath(val) + try: + tibcfg = TIBoardConfig(config_yaml, schema_yaml) + tibcfg.generate_binaries(output_dir) + except: + raise ValueError("Could not find config files!") + + +cfgBinaryGen()
For K3 devices that require a sysfw image, add entry for SYSFW. It can contain system firmware image that can be packaged into sysfw.itb by binman.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: added tests for addition of etype] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- Makefile | 1 + tools/binman/entries.rst | 11 +++++++++++ tools/binman/etype/ti_sysfw.py | 28 ++++++++++++++++++++++++++++ tools/binman/ftest.py | 7 +++++++ tools/binman/test/232_ti_sysfw.dts | 13 +++++++++++++ 5 files changed, 60 insertions(+) create mode 100644 tools/binman/etype/ti_sysfw.py create mode 100644 tools/binman/test/232_ti_sysfw.dts
diff --git a/Makefile b/Makefile index 4b347d3603..581fbba4c3 100644 --- a/Makefile +++ b/Makefile @@ -1338,6 +1338,7 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ -a opensbi-path=${OPENSBI} \ -a default-dt=$(default_dt) \ -a scp-path=$(SCP) \ + -a ti-sysfw-path=$(SYSFW) \ -a spl-bss-pad=$(if $(CONFIG_SPL_SEPARATE_BSS),,1) \ -a tpl-bss-pad=$(if $(CONFIG_TPL_SEPARATE_BSS),,1) \ -a spl-dtb=$(CONFIG_SPL_OF_REAL) \ diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index ae4305c99e..6c0f03b34f 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1203,6 +1203,17 @@ This entry holds firmware for an external platform-specific coprocessor.
+Entry: sysfw: Texas Instruments System Firmware (SYSFW) blob +------------------------------------------------------------ + +Properties / Entry arguments: + - ti-sysfw-path: Filename of file to read into the entry, typically sysfw.bin + +This entry contains system firmware necessary for booting of K3 architecture +devices. + + + Entry: section: Entry that contains other entries -------------------------------------------------
diff --git a/tools/binman/etype/ti_sysfw.py b/tools/binman/etype/ti_sysfw.py new file mode 100644 index 0000000000..5b5b307030 --- /dev/null +++ b/tools/binman/etype/ti_sysfw.py @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Entry type module for TI SYSFW binary blob +# + +import os +import struct +import sys +import zlib + +from binman.etype.blob_named_by_arg import Entry_blob_named_by_arg +from dtoc import fdt_util +from patman import tools + + +class Entry_ti_sysfw(Entry_blob_named_by_arg): + """Entry containing Texas Instruments System Firmware (SYSFW) blob + + Properties / Entry arguments: + - ti-sysfw-path: Filename of file to read into the entry, typically sysfw.bin + + This entry contains system firmware necessary for booting of K3 architecture devices. + """ + + def __init__(self, section, etype, node): + super().__init__(section, etype, node, 'ti-sysfw') + self.external = True diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 4ce181a066..ec408de334 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -87,6 +87,7 @@ ATF_BL31_DATA = b'bl31' TEE_OS_DATA = b'this is some tee OS data' ATF_BL2U_DATA = b'bl2u' OPENSBI_DATA = b'opensbi' +TI_SYSFW_DATA = b'sysfw' SCP_DATA = b'scp' TEST_FDT1_DATA = b'fdt1' TEST_FDT2_DATA = b'test-fdt2' @@ -195,6 +196,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('tee-pager.bin', TEE_OS_DATA) TestFunctional._MakeInputFile('bl2u.bin', ATF_BL2U_DATA) TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) + TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA)
# Add a few .dtb files for testing @@ -5522,6 +5524,11 @@ fdt fdtmap Extract the devicetree blob from the fdtmap """Test an image with a pre-load header with an invalid key""" with self.assertRaises(ValueError) as e: data = self._DoReadFile('231_pre_load_invalid_key.dts') + + def testPackTiSysfw(self): + """Test that an image with a SYSFW binary can be created""" + data = self._DoReadFile('232_ti_sysfw.dts') + self.assertEqual(TI_SYSFW_DATA, data[:len(TI_SYSFW_DATA)])
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/232_ti_sysfw.dts b/tools/binman/test/232_ti_sysfw.dts new file mode 100644 index 0000000000..9e66cbe77b --- /dev/null +++ b/tools/binman/test/232_ti_sysfw.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + binman { + ti-sysfw { + filename = "sysfw.bin"; + }; + }; +};
'can' or 'should'?
For binman, 'sysfw' and 'dm' (added in patch 4) are just binary blobs. correct? Why can't you just use blob entry type?
cheers, -roger
-a spl-bss-pad=$(if $(CONFIG_SPL_SEPARATE_BSS),,1) \ -a tpl-bss-pad=$(if $(CONFIG_TPL_SEPARATE_BSS),,1) \ -a spl-dtb=$(CONFIG_SPL_OF_REAL) \-a ti-sysfw-path=$(SYSFW) \
- """Entry containing Texas Instruments System Firmware (SYSFW) blob
- Properties / Entry arguments:
- This entry contains system firmware necessary for booting of K3 architecture devices.
- def __init__(self, section, etype, node):
TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA) # Add a few .dtb files for testing
- def testPackTiSysfw(self):
+/dts-v1/;
- #address-cells = <1>;
- #size-cells = <1>;
- binman {
ti-sysfw {
Hi Roger,
'can' or 'should'?
This was suggested so that there is space for changes that will be required when scaling to High Security devices as well.
cheers, -roger
+/dts-v1/;
- binman {
ti-sysfw {
Hi Roger,
On 01/06/22 11:28, Neha Malcom Francis wrote:
Hi Roger,
'can' or 'should'?
Also to add, this also enables us to take files given in "SYSFW" and "DM" arguments since it is an Entry_blob_named_by_arg. Similar to the use of etype/scp.py
cheers, -roger
diff --git a/Makefile b/Makefile index 4b347d3603..581fbba4c3 100644 --- a/Makefile +++ b/Makefile @@ -1338,6 +1338,7 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ -a opensbi-path=${OPENSBI} \ -a default-dt=$(default_dt) \ -a scp-path=$(SCP) \ + -a ti-sysfw-path=$(SYSFW) \ -a spl-bss-pad=$(if $(CONFIG_SPL_SEPARATE_BSS),,1) \ -a tpl-bss-pad=$(if $(CONFIG_TPL_SEPARATE_BSS),,1) \ -a spl-dtb=$(CONFIG_SPL_OF_REAL) \ diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index ae4305c99e..6c0f03b34f 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1203,6 +1203,17 @@ This entry holds firmware for an external platform-specific coprocessor. +Entry: sysfw: Texas Instruments System Firmware (SYSFW) blob +------------------------------------------------------------
Entry: section: Entry that contains other entries ------------------------------------------------- diff --git a/tools/binman/etype/ti_sysfw.py b/tools/binman/etype/ti_sysfw.py new file mode 100644 index 0000000000..5b5b307030 --- /dev/null +++ b/tools/binman/etype/ti_sysfw.py @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Entry type module for TI SYSFW binary blob +#
+ def __init__(self, section, etype, node): + super().__init__(section, etype, node, 'ti-sysfw') + self.external = True diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 4ce181a066..ec408de334 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -87,6 +87,7 @@ ATF_BL31_DATA = b'bl31' TEE_OS_DATA = b'this is some tee OS data' ATF_BL2U_DATA = b'bl2u' OPENSBI_DATA = b'opensbi' +TI_SYSFW_DATA = b'sysfw' SCP_DATA = b'scp' TEST_FDT1_DATA = b'fdt1' TEST_FDT2_DATA = b'test-fdt2' @@ -195,6 +196,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('tee-pager.bin', TEE_OS_DATA) TestFunctional._MakeInputFile('bl2u.bin', ATF_BL2U_DATA) TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) + TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA) # Add a few .dtb files for testing @@ -5522,6 +5524,11 @@ fdt fdtmap Extract the devicetree blob from the fdtmap """Test an image with a pre-load header with an invalid key""" with self.assertRaises(ValueError) as e: data = self._DoReadFile('231_pre_load_invalid_key.dts')
+ def testPackTiSysfw(self): + """Test that an image with a SYSFW binary can be created""" + data = self._DoReadFile('232_ti_sysfw.dts') + self.assertEqual(TI_SYSFW_DATA, data[:len(TI_SYSFW_DATA)]) if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/232_ti_sysfw.dts b/tools/binman/test/232_ti_sysfw.dts new file mode 100644 index 0000000000..9e66cbe77b --- /dev/null +++ b/tools/binman/test/232_ti_sysfw.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+
+/dts-v1/;
On 01/06/2022 08:58, Neha Malcom Francis wrote:
Hi Roger,
'can' or 'should'?
How will these change for High Security devices?
cheers, -roger
cheers, -roger
+/dts-v1/;
K3 devices introduces the concept of centralized power, resource and security management to System Firmware. This is to overcome challenges by the traditional approach that implements system control functions on each of the processing units.
The software interface for System Firmware is split into TIFS and DM. DM (Device Manager) is responsible for resource and power management from secure and non-secure hosts. This additional binary is necessary for specific platforms' ROM boot images and is to be packaged into tispl.bin
Add an entry for DM. The entry can be used for the packaging of tispl.bin by binman along with ATF and TEE.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- Makefile | 1 + tools/binman/entries.rst | 10 ++++++++++ tools/binman/etype/ti_dm.py | 23 +++++++++++++++++++++++ tools/binman/ftest.py | 7 +++++++ tools/binman/test/225_ti_dm.dts | 13 +++++++++++++ 5 files changed, 54 insertions(+) create mode 100644 tools/binman/etype/ti_dm.py create mode 100644 tools/binman/test/225_ti_dm.dts
diff --git a/Makefile b/Makefile index 581fbba4c3..7e9c8272c3 100644 --- a/Makefile +++ b/Makefile @@ -1335,6 +1335,7 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ $(foreach f,$(BINMAN_INDIRS),-I $(f)) \ -a atf-bl31-path=${BL31} \ -a tee-os-path=${TEE} \ + -a ti-dm-path=${DM} \ -a opensbi-path=${OPENSBI} \ -a default-dt=$(default_dt) \ -a scp-path=$(SCP) \ diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index 6c0f03b34f..0c6d82fce8 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1214,6 +1214,16 @@ devices.
+Entry: ti-dm: Texas Instruments Device Manager (DM) blob +----------------------------------------------------------------- + +Properties / Entry arguments: + - ti-dm-path: Filename of file to read into the entry, typically dm.bin + +This entry holds the device manager responsible for resource and power management in K3 devices. + + + Entry: section: Entry that contains other entries -------------------------------------------------
diff --git a/tools/binman/etype/ti_dm.py b/tools/binman/etype/ti_dm.py new file mode 100644 index 0000000000..4203fff36e --- /dev/null +++ b/tools/binman/etype/ti_dm.py @@ -0,0 +1,23 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Entry type for TI Device Manager + +import os + +from binman.etype.blob_named_by_arg import Entry_blob_named_by_arg + + +class Entry_ti_dm(Entry_blob_named_by_arg): + """Entry containing a Texas Instruments Device Manager (DM) + + Properties / Entry arguments: + - ti-dm-path: Filename of file to read into the entry, typically dm.bin + + This entry holds the device manager responsible for resource and power management + in K3 devices. + """ + + def __init__(self, section, etype, node): + super().__init__(section, etype, node, 'ti-dm') + self.external = True diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index ec408de334..5ff294a386 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -85,6 +85,7 @@ FSP_S_DATA = b'fsp_s' FSP_T_DATA = b'fsp_t' ATF_BL31_DATA = b'bl31' TEE_OS_DATA = b'this is some tee OS data' +TI_DM_DATA = b'tidmtidm' ATF_BL2U_DATA = b'bl2u' OPENSBI_DATA = b'opensbi' TI_SYSFW_DATA = b'sysfw' @@ -194,6 +195,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('compress_big', COMPRESS_DATA_BIG) TestFunctional._MakeInputFile('bl31.bin', ATF_BL31_DATA) TestFunctional._MakeInputFile('tee-pager.bin', TEE_OS_DATA) + TestFunctional._MakeInputFile('dm.bin', TI_DM_DATA) TestFunctional._MakeInputFile('bl2u.bin', ATF_BL2U_DATA) TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA) @@ -5300,6 +5302,11 @@ fdt fdtmap Extract the devicetree blob from the fdtmap data = self._DoReadFile('222_tee_os.dts') self.assertEqual(TEE_OS_DATA, data[:len(TEE_OS_DATA)])
+ def testPackTiDm(self): + """Test that an image with a TI DM binary can be created""" + data = self._DoReadFile('225_ti_dm.dts') + self.assertEqual(TI_DM_DATA, data[:len(TI_DM_DATA)]) + def testFitFdtOper(self): """Check handling of a specified FIT operation""" entry_args = { diff --git a/tools/binman/test/225_ti_dm.dts b/tools/binman/test/225_ti_dm.dts new file mode 100644 index 0000000000..3ab754131e --- /dev/null +++ b/tools/binman/test/225_ti_dm.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + binman { + ti-dm { + filename = "dm.bin"; + }; + }; +};
K3 devices x509 certificate added to certain binaries that allows ROM to validate the integrity of the image. Etype that generates an x509 certificate depending on boot flow added.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- tools/binman/entries.rst | 15 ++ tools/binman/etype/x509_cert.py | 248 ++++++++++++++++++++++++++++ tools/binman/ftest.py | 7 + tools/binman/test/232_x509_cert.dts | 18 ++ tools/k3_gen_x509_cert.sh | 10 +- 5 files changed, 293 insertions(+), 5 deletions(-) create mode 100644 tools/binman/etype/x509_cert.py create mode 100644 tools/binman/test/232_x509_cert.dts
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index 0c6d82fce8..dfa281e49f 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1890,6 +1890,21 @@ and kernel are genuine.
+Entry: x509cert: x509 certificate for K3 devices +------------------------------------------------ + +Properties / Entry arguments: + - content: Phandle of binary to sign + - output: Name of the final output file + - key_file: File with key inside it. If not provided, script generates RSA degenerate key + - core: Target core ID on which image would be running + - load: Target load address of the binary in hex + + Output files: + - certificate.bin: Signed certificate binary + + + Entry: x86-reset16: x86 16-bit reset code for U-Boot ----------------------------------------------------
diff --git a/tools/binman/etype/x509_cert.py b/tools/binman/etype/x509_cert.py new file mode 100644 index 0000000000..0009973155 --- /dev/null +++ b/tools/binman/etype/x509_cert.py @@ -0,0 +1,248 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2018 Google, Inc +# Written by Simon Glass sjg@chromium.org +# + +# Support for a x509 certificate for signing K3 devices + +import os +from collections import OrderedDict +from subprocess import Popen, PIPE +from sys import stderr, stdout + +import asn1 +from Crypto.PublicKey import RSA +from cryptography.hazmat.backends import default_backend +from cryptography.hazmat.primitives import serialization + +from binman.etype.collection import Entry_collection +from dtoc import fdt_util +from patman import tools + +temp_x509 = "x509-temp.cert" +cert = "certificate.bin" +rand_key = "eckey.pem" +bootcore_opts = 0 +bootcore = 0 +debug_type = 0 + + +class Entry_x509_cert(Entry_collection): + """ An entry which contains a x509 certificate + + Properties / Entry arguments: + - content: Phandle of binary to sign + - key_file: File with key inside it. If not provided, script generates RSA degenerate key + - core: Target core ID on which image would be running + - load: Target load address of the binary in hex + + Output files: + - certificate.bin: Signed certificate binary""" + + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.key_file = fdt_util.GetString(self._node, 'key-file', "") + self.core = fdt_util.GetInt(self._node, 'core', 0) + self.load_addr = fdt_util.GetInt(self._node, 'load', 0x41c00000) + + def ReadNode(self): + super().ReadNode() + if self.key_file == "": + self.degen_key = True + else: + self.degen_key = False + + def _CreateCertificate(self): + """Create certificate for legacy boot flow""" + if self.degen_key == True: + gen_degen_key() + self.key_file = rand_key + + sha_val = get_sha_val("intermediate-sysfw.bin") + bin_size = get_file_size("intermediate-sysfw.bin") + addr = "%08x" % self.load_addr + if self.core == 0: + cert_type = 2 + elif self.core == 16: + cert_type = 1 + else: + cert_type = 2 + debug_type = 0 + + gen_template() + gen_cert(bin_size, sha_val, cert_type, bootcore_opts, + self.core, addr, debug_type, self.key_file) + + return tools.read_file("certificate.bin") + + def ObtainContents(self): + self.image = self.GetContents(False) + if self.image is None: + return False + f = open("intermediate-sysfw.bin", "wb") + f.write(self.image) + f.close() + self.SetContents(self._CreateCertificate()) + return True + + def ProcessContents(self): + data = self._CreateCertificate() + return self.ProcessContentsUpdate(data) + + +def get_sha_val(binary_file): + process = Popen(['openssl', 'dgst', '-sha512', '-hex', + binary_file], stdout=PIPE, stderr=PIPE) + stdout, stderr = process.communicate() + sha_val = stdout.split()[1] + return sha_val + + +def get_file_size(binary_file): + return os.path.getsize(binary_file) + + +def gen_degen_template(): + with open("degen-template.txt", 'w+', encoding='utf-8') as f: + degen_temp = """ +asn1=SEQUENCE:rsa_key + +[rsa_key] +version=INTEGER:0 +modulus=INTEGER:0xDEGEN_MODULUS +pubExp=INTEGER:1 +privExp=INTEGER:1 +p=INTEGER:0xDEGEN_P +q=INTEGER:0xDEGEN_Q +e1=INTEGER:1 +e2=INTEGER:1 +coeff=INTEGER:0xDEGEN_COEFF""" + f.write(degen_temp) + + +def gen_template(): + """Generate x509 Template""" + with open("x509-template.txt", "w+", encoding='utf-8') as f: + x509template = """ +[ req ] +distinguished_name = req_distinguished_name +x509_extensions = v3_ca +prompt = no +dirstring_type = nobmp + +[ req_distinguished_name ] +C = US +ST = TX +L = Dallas +O = Texas Instruments Incorporated +OU = Processors +CN = TI support +emailAddress = support@ti.com + +[ v3_ca ] +basicConstraints = CA:true +1.3.6.1.4.1.294.1.1 = ASN1:SEQUENCE:boot_seq +1.3.6.1.4.1.294.1.2 = ASN1:SEQUENCE:image_integrity +1.3.6.1.4.1.294.1.3 = ASN1:SEQUENCE:swrv +# 1.3.6.1.4.1.294.1.4 = ASN1:SEQUENCE:encryption +1.3.6.1.4.1.294.1.8 = ASN1:SEQUENCE:debug + +[ boot_seq ] +certType = INTEGER:TEST_CERT_TYPE +bootCore = INTEGER:TEST_BOOT_CORE +bootCoreOpts = INTEGER:TEST_BOOT_CORE_OPTS +destAddr = FORMAT:HEX,OCT:TEST_BOOT_ADDR +imageSize = INTEGER:TEST_IMAGE_LENGTH + +[ image_integrity ] +shaType = OID:2.16.840.1.101.3.4.2.3 +shaValue = FORMAT:HEX,OCT:TEST_IMAGE_SHA_VAL + +[ swrv ] +swrv = INTEGER:0 + +# [ encryption ] +# initalVector = FORMAT:HEX,OCT:TEST_IMAGE_ENC_IV +# randomString = FORMAT:HEX,OCT:TEST_IMAGE_ENC_RS +# iterationCnt = INTEGER:TEST_IMAGE_KEY_DERIVE_INDEX +# salt = FORMAT:HEX,OCT:TEST_IMAGE_KEY_DERIVE_SALT + +[ debug ] +debugUID = FORMAT:HEX,OCT:0000000000000000000000000000000000000000000000000000000000000000 +debugType = INTEGER:TEST_DEBUG_TYPE +coreDbgEn = INTEGER:0 +coreDbgSecEn = INTEGER:0""" + f.write(x509template) + + +def parse_key(inp_key, section): + parsed_key = "" + section_true = False + with open(inp_key, 'r') as file: + for line in file: + if section in line: + section_true = True + elif section_true: + if " " not in line: + break + else: + parsed_key += line.replace(":", "").replace(" ", "") + return parsed_key.replace("\n", "") + + +def gen_degen_key(): + """Generate a 4096 bit RSA key""" + try: + # generates 1024 bit PEM encoded RSA key in PKCS#1 format + private_key = RSA.generate(1024) + f = open('key.pem', 'wb') + f.write(private_key.exportKey('PEM')) + f.close() + except: + raise(Exception) + + try: + process = Popen(['openssl', 'rsa', '-in', 'key.pem', + '-text', '-out', 'key.txt'], stdout=PIPE, stderr=PIPE) + stdout, stderr = process.communicate() + except: + raise(stderr) + + DEGEN_MODULUS = parse_key("key.txt", "modulus") + DEGEN_P = parse_key("key.txt", "prime1") + DEGEN_Q = parse_key("key.txt", "prime2") + DEGEN_COEFF = parse_key("key.txt", "coefficient") + + gen_degen_template() + + with open("degen-template.txt", 'r') as file_input: + with open("degenerateKey.txt", 'w') as file_output: + for line in file_input: + s = line.replace("DEGEN_MODULUS", DEGEN_MODULUS).replace( + "DEGEN_P", DEGEN_P).replace("DEGEN_Q", DEGEN_Q).replace("DEGEN_COEFF", DEGEN_COEFF) + file_output.write(s) + + try: + process = Popen(['openssl', 'asn1parse', '-genconf', 'degenerateKey.txt', + '-out', 'degenerateKey.der'], stdout=PIPE, stderr=PIPE) + stdout, stderr = process.communicate() + except: + raise(stderr) + + try: + process = Popen(['openssl', 'rsa', '-in', 'degenerateKey.der', + '-inform', 'DER', '-outform', 'PEM', '-out', rand_key]) + stdout, stderr = process.communicate() + except: + raise(stderr) + + +def gen_cert(bin_size, sha_val, cert_type, bootcore_opts, bootcore, addr, debug_type, key): + with open(temp_x509, "w") as output_file: + with open("x509-template.txt", "r") as input_file: + for line in input_file: + output_file.write(line.replace("TEST_IMAGE_LENGTH", str(bin_size)).replace("TEST_IMAGE_SHA_VAL", sha_val.decode("utf-8")).replace("TEST_CERT_TYPE", str(cert_type)).replace( + "TEST_BOOT_CORE_OPTS", str(bootcore_opts)).replace("TEST_BOOT_CORE", str(bootcore)).replace("TEST_BOOT_ADDR", str(addr)).replace("TEST_DEBUG_TYPE", str(debug_type))) + process = Popen(['openssl', 'req', '-new', '-x509', '-key', key, '-nodes', '-outform', + 'DER', '-out', cert, '-config', temp_x509, '-sha512'], stdout=PIPE, stderr=PIPE) + stdout, stderr = process.communicate() diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 5ff294a386..d8ee592250 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -96,6 +96,7 @@ ENV_DATA = b'var1=1\nvar2="2"' PRE_LOAD_MAGIC = b'UBSH' PRE_LOAD_VERSION = 0x11223344.to_bytes(4, 'big') PRE_LOAD_HDR_SIZE = 0x00001000.to_bytes(4, 'big') +X509_DATA = b'filetobesigned'
# Subdirectory of the input dir to use to put test FDTs TEST_FDT_SUBDIR = 'fdts' @@ -200,6 +201,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA) + TestFunctional._MakeInputFile('tosign.bin', X509_DATA)
# Add a few .dtb files for testing TestFunctional._MakeInputFile('%s/test-fdt1.dtb' % TEST_FDT_SUBDIR, @@ -5537,5 +5539,10 @@ fdt fdtmap Extract the devicetree blob from the fdtmap data = self._DoReadFile('232_ti_sysfw.dts') self.assertEqual(TI_SYSFW_DATA, data[:len(TI_SYSFW_DATA)])
+ def testX509Cert(self): + """Test an image with the default x509 certificate header""" + data = self._DoReadFile('232_x509_cert.dts') + self.assertEqual(X509_DATA, data[938:938 + len(X509_DATA)]) + if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/232_x509_cert.dts b/tools/binman/test/232_x509_cert.dts new file mode 100644 index 0000000000..f768568ca7 --- /dev/null +++ b/tools/binman/test/232_x509_cert.dts @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + x509-cert { + content = <&image>; + }; + + image: blob-ext { + filename = "tosign.bin"; + }; + }; +}; diff --git a/tools/k3_gen_x509_cert.sh b/tools/k3_gen_x509_cert.sh index 298cec1313..b6ef5a2de3 100755 --- a/tools/k3_gen_x509_cert.sh +++ b/tools/k3_gen_x509_cert.sh @@ -109,7 +109,7 @@ gen_degen_key() { openssl asn1parse -genconf degenerateKey.txt -out degenerateKey.der >>/dev/null 2>&1 openssl rsa -in degenerateKey.der -inform DER -outform PEM -out $RAND_KEY >>/dev/null 2>&1 KEY=$RAND_KEY - rm key.pem key.txt degen-template.txt degenerateKey.txt degenerateKey.der + #rm key.pem key.txt degen-template.txt degenerateKey.txt degenerateKey.der }
declare -A options_help @@ -246,7 +246,7 @@ gen_cert cat $CERT $BIN > $OUTPUT
# Remove all intermediate files -rm $TEMP_X509 $CERT x509-template.txt -if [ "$KEY" == "$RAND_KEY" ]; then - rm $RAND_KEY -fi +#rm $TEMP_X509 $CERT x509-template.txt +#if [ "$KEY" == "$RAND_KEY" ]; then +# rm $RAND_KEY +#fi
what binaries?
Could you please explain in more detail as to what exactly is happening here.
What do you mean by "depending on boot flow"?
x509 is a generic standard. Can this be made usable by other vendors as well or is it very specific to TI? If this is TI specific then I'd suggest a "ti-" prefix to the entry name.
why do you need output property?
- Output files:
- """ An entry which contains a x509 certificate
- Output files:
- def ReadNode(self):
super().ReadNode()
else:
- def _CreateCertificate(self):
gen_degen_key()
if self.core == 0:
cert_type = 2
cert_type = 1
else:
cert_type = 2
debug_type = 0
gen_template()
- def ObtainContents(self):
return False
f.write(self.image)
f.close()
return True
- def ProcessContents(self):
Why do you need _CreateCertificate() and ProcessContents()? Just have one ObtainContents() and try to get rid of all the intermediate files.
- process = Popen(['openssl', 'dgst', '-sha512', '-hex',
- stdout, stderr = process.communicate()
- sha_val = stdout.split()[1]
- return sha_val
- return os.path.getsize(binary_file)
- with open("degen-template.txt", 'w+', encoding='utf-8') as f:
degen_temp = """
f.write(degen_temp)
- """Generate x509 Template"""
- with open("x509-template.txt", "w+", encoding='utf-8') as f:
x509template = """
- parsed_key = ""
- section_true = False
- with open(inp_key, 'r') as file:
for line in file:
if section in line:
section_true = True
elif section_true:
if " " not in line:
break
else:
- return parsed_key.replace("\n", "")
- """Generate a 4096 bit RSA key"""
- try:
f.close()
- except:
raise(Exception)
- try:
- except:
raise(stderr)
- DEGEN_MODULUS = parse_key("key.txt", "modulus")
- DEGEN_P = parse_key("key.txt", "prime1")
- DEGEN_Q = parse_key("key.txt", "prime2")
- DEGEN_COEFF = parse_key("key.txt", "coefficient")
- gen_degen_template()
- with open("degen-template.txt", 'r') as file_input:
- try:
- except:
raise(stderr)
- try:
- except:
raise(stderr)
- with open(temp_x509, "w") as output_file:
- process = Popen(['openssl', 'req', '-new', '-x509', '-key', key, '-nodes', '-outform',
TestFunctional._MakeInputFile('tosign.bin', X509_DATA) # Add a few .dtb files for testing TestFunctional._MakeInputFile('%s/test-fdt1.dtb' % TEST_FDT_SUBDIR,
- def testX509Cert(self):
what is 938?
Isn't it easier to just assert that _DoReadFile('232_x509_cert.dts') is greater than len(X509_DATA)?
+/dts-v1/;
- binman {
x509-cert {
content = <&image>;
image: blob-ext {
- #rm key.pem key.txt degen-template.txt degenerateKey.txt degenerateKey.der
- rm $RAND_KEY
Why these changes? Maybe you should include them within "ifndef CONFIG_BINMAN ... endif" to avoid breaking platforms not using BINMAN.
cheers, -roger
Hi Roger,
what binaries?
I will reformat the commit messages accordingly.
That is not required, I had later changed it to always using certificate.bin. Will make the necessary changes.
- Output files:
- Output files:
super().ReadNode()
else:
gen_degen_key()
if self.core == 0:
cert_type = 2
cert_type = 1
else:
cert_type = 2
debug_type = 0
gen_template()
return False
f.write(self.image)
f.close()
return True
I used etype/vblock.py as a reference. I will clean up this etype further.
- return sha_val
degen_temp = """
f.write(degen_temp)
x509template = """
- parsed_key = ""
for line in file:
if section in line:
section_true = True
elif section_true:
if " " not in line:
break
else:
- try:
f.close()
- except:
raise(Exception)
- try:
- except:
raise(stderr)
- try:
- except:
raise(stderr)
- try:
- except:
raise(stderr)
what is 938?
- if __name__ == "__main__": unittest.main()
+/dts-v1/;
- binman {
x509-cert {
content = <&image>;
image: blob-ext {
- rm $RAND_KEY
cheers, -roger
On 01/06/2022 09:02, Neha Malcom Francis wrote:
Hi Roger,
what binaries?
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index 0c6d82fce8..dfa281e49f 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1890,6 +1890,21 @@ and kernel are genuine. +Entry: x509cert: x509 certificate for K3 devices +------------------------------------------------
Entry: x86-reset16: x86 16-bit reset code for U-Boot ---------------------------------------------------- diff --git a/tools/binman/etype/x509_cert.py b/tools/binman/etype/x509_cert.py new file mode 100644 index 0000000000..0009973155 --- /dev/null +++ b/tools/binman/etype/x509_cert.py @@ -0,0 +1,248 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2018 Google, Inc +# Written by Simon Glass sjg@chromium.org +#
There were some more comments below, in case you missed them.
+def gen_cert(bin_size, sha_val, cert_type, bootcore_opts, bootcore, addr, debug_type, key): + with open(temp_x509, "w") as output_file: + with open("x509-template.txt", "r") as input_file: + for line in input_file: + output_file.write(line.replace("TEST_IMAGE_LENGTH", str(bin_size)).replace("TEST_IMAGE_SHA_VAL", sha_val.decode("utf-8")).replace("TEST_CERT_TYPE", str(cert_type)).replace( + "TEST_BOOT_CORE_OPTS", str(bootcore_opts)).replace("TEST_BOOT_CORE", str(bootcore)).replace("TEST_BOOT_ADDR", str(addr)).replace("TEST_DEBUG_TYPE", str(debug_type))) + process = Popen(['openssl', 'req', '-new', '-x509', '-key', key, '-nodes', '-outform', + 'DER', '-out', cert, '-config', temp_x509, '-sha512'], stdout=PIPE, stderr=PIPE) + stdout, stderr = process.communicate() diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 5ff294a386..d8ee592250 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -96,6 +96,7 @@ ENV_DATA = b'var1=1\nvar2="2"' PRE_LOAD_MAGIC = b'UBSH' PRE_LOAD_VERSION = 0x11223344.to_bytes(4, 'big') PRE_LOAD_HDR_SIZE = 0x00001000.to_bytes(4, 'big') +X509_DATA = b'filetobesigned' # Subdirectory of the input dir to use to put test FDTs TEST_FDT_SUBDIR = 'fdts' @@ -200,6 +201,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) TestFunctional._MakeInputFile('sysfw.bin', TI_SYSFW_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA) + TestFunctional._MakeInputFile('tosign.bin', X509_DATA) # Add a few .dtb files for testing TestFunctional._MakeInputFile('%s/test-fdt1.dtb' % TEST_FDT_SUBDIR, @@ -5537,5 +5539,10 @@ fdt fdtmap Extract the devicetree blob from the fdtmap data = self._DoReadFile('232_ti_sysfw.dts') self.assertEqual(TI_SYSFW_DATA, data[:len(TI_SYSFW_DATA)]) + def testX509Cert(self): + """Test an image with the default x509 certificate header""" + data = self._DoReadFile('232_x509_cert.dts') + self.assertEqual(X509_DATA, data[938:938 + len(X509_DATA)])
what is 938?
+/dts-v1/;
+ image: blob-ext { + filename = "tosign.bin"; + }; + }; +}; diff --git a/tools/k3_gen_x509_cert.sh b/tools/k3_gen_x509_cert.sh index 298cec1313..b6ef5a2de3 100755 --- a/tools/k3_gen_x509_cert.sh +++ b/tools/k3_gen_x509_cert.sh @@ -109,7 +109,7 @@ gen_degen_key() { openssl asn1parse -genconf degenerateKey.txt -out degenerateKey.der >>/dev/null 2>&1 openssl rsa -in degenerateKey.der -inform DER -outform PEM -out $RAND_KEY >>/dev/null 2>&1 KEY=$RAND_KEY - rm key.pem key.txt degen-template.txt degenerateKey.txt degenerateKey.der + #rm key.pem key.txt degen-template.txt degenerateKey.txt degenerateKey.der } declare -A options_help @@ -246,7 +246,7 @@ gen_cert cat $CERT $BIN > $OUTPUT # Remove all intermediate files -rm $TEMP_X509 $CERT x509-template.txt -if [ "$KEY" == "$RAND_KEY" ]; then - rm $RAND_KEY -fi +#rm $TEMP_X509 $CERT x509-template.txt +#if [ "$KEY" == "$RAND_KEY" ]; then +# rm $RAND_KEY +#fi
cheers, -roger
cheers, -roger
Hi Roger,
Hi Roger,
what binaries?
Thanks!
what is 938?
938 was the size of the expected x509 certificate to which the data is appended.
Would that test ensure the proper creation of certificate.bin?
+/dts-v1/;
These file changes (k3_gen_x509_cert.sh) were not intended to be present in the patch series, sorry for that.
cheers, -roger
cheers, -roger
Neha,
On 01/06/2022 12:48, Neha Malcom Francis wrote:
Hi Roger,
Hi Roger,
what binaries?
Thanks!
what is 938?
And that is not exepected to change anytime in future? If not, then you can use a macro define for that. If yes, then this solution is not good.
No but it would just tell you that something was appended or not and will not break if certificate size changes.
Your above check was not checking certificate contents either.
+/dts-v1/;
cheers, -roger
Hi Roger,
On 01/06/22 16:18, Roger Quadros wrote:
Neha,
Hi Roger,
Hi Roger,
what binaries?
Thanks!
what is 938?
Right, I'll make changes to the testing.
I'm not sure about where to draw the line to test the contents of the certificate, I'll ask around about that. If you have any suggestions please let me know. I will definitely add that test to check whether anything was appended or not for now.
+/dts-v1/;
cheers, -roger
For devices that require sysfw.itb, board config binary artifacts must be populated in the R5 output directory. These can be used by binman to package sysfw.itb.
config.mk for mach-k3 updated to generate the required binaries using tibcfg_gen.py.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/mach-k3/config.mk | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index da458bcfb2..e6c13c1800 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -28,6 +28,24 @@ else KEY=$(patsubst "%",$(srctree)/%,$(CONFIG_SYS_K3_KEY)) endif
+# Board config binary artifacts necessary for packaging of tiboot3.bin +# and sysfw.itb by binman, currently for general purpose devices and +# devices that require sysfw.itb in ROM boot image. Currently set up +# for J721E +ifneq ($(CONFIG_SOC_K3_J721E), ) +ifneq ($(CONFIG_TI_SECURE_DEVICE), y) + +CONFIG_YAML = $(srctree)/board/ti/$(BOARD)/config.yaml +SCHEMA_YAML = $(srctree)/board/ti/common/schema.yaml +board-cfg.bin pm-cfg.bin rm-cfg.bin sec-cfg.bin: + $(PYTHON3) $(srctree)/tools/tibcfg_gen.py -c $(CONFIG_YAML) -s $(SCHEMA_YAML) -o $(O) +INPUTS-y += board-cfg.bin +INPUTS-y += pm-cfg.bin +INPUTS-y += rm-cfg.bin +INPUTS-y += sec-cfg.bin +endif +endif + # tiboot3.bin is mandated by ROM and ROM only supports R5 boot. # So restrict tiboot3.bin creation for CPU_V7R. ifdef CONFIG_CPU_V7R
Intention of patch is to move the signing and packaging of tiboot3.bin image to binman, thus removing target from makefile.
Also deleting k3_gen_x509_cert.sh which was earlier used to sign a binary associated with K3 devices with x509 certificate. This functionality has been replicated in binman with the etype x509_cert.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/mach-k3/config.mk | 19 ------------------- 1 file changed, 19 deletions(-)
diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index e6c13c1800..49f80ae79b 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -46,25 +46,6 @@ INPUTS-y += sec-cfg.bin endif endif
-# tiboot3.bin is mandated by ROM and ROM only supports R5 boot. -# So restrict tiboot3.bin creation for CPU_V7R. -ifdef CONFIG_CPU_V7R -image_check: $(obj)/u-boot-spl.bin FORCE - @if [ $(IMAGE_SIZE) -gt $(MAX_SIZE) ]; then \ - echo "===============================================" >&2; \ - echo "ERROR: Final Image too big. " >&2; \ - echo "$< size = $(IMAGE_SIZE), max size = $(MAX_SIZE)" >&2; \ - echo "===============================================" >&2; \ - exit 1; \ - fi - -tiboot3.bin: image_check FORCE - $(srctree)/tools/k3_gen_x509_cert.sh -c 16 -b $(obj)/u-boot-spl.bin \ - -o $@ -l $(CONFIG_SPL_TEXT_BASE) -k $(KEY) - -INPUTS-y += tiboot3.bin -endif - ifdef CONFIG_ARM64
ifeq ($(CONFIG_SOC_K3_J721E),)
exit 1; \
- fi
Instead of removing it unconditionally and breaking build for all this must be placed under
#ifndef CONFIG_BINMAN ... #endif
ifdef CONFIG_ARM64
cheers, -roger
As tispl.bin is to be packaged (with ATF, OPTEE, DM and A72 SPL) using binman, the shell script k3_fit_atf.sh is no longer needed. Removing this file.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- tools/k3_fit_atf.sh | 123 -------------------------------------------- 1 file changed, 123 deletions(-) delete mode 100755 tools/k3_fit_atf.sh
diff --git a/tools/k3_fit_atf.sh b/tools/k3_fit_atf.sh deleted file mode 100755 index 7bc07ad074..0000000000 --- a/tools/k3_fit_atf.sh +++ /dev/null @@ -1,123 +0,0 @@ -#!/bin/sh -# SPDX-License-Identifier: GPL-2.0+ -# -# script to generate FIT image source for K3 Family boards with -# ATF, OPTEE, SPL and multiple device trees (given on the command line). -# Inspired from board/sunxi/mksunxi_fit_atf.sh -# -# usage: $0 <atf_load_addr> <dt_name> [<dt_name> [<dt_name] ...] - -[ -z "$ATF" ] && ATF="bl31.bin" - -if [ ! -f $ATF ]; then - echo "WARNING ATF file $ATF NOT found, resulting binary is non-functional" >&2 - ATF=/dev/null -fi - -[ -z "$TEE" ] && TEE="bl32.bin" - -if [ ! -f $TEE ]; then - echo "WARNING OPTEE file $TEE NOT found, resulting might be non-functional" >&2 - TEE=/dev/null -fi - -[ -z "$DM" ] && DM="dm.bin" - -if [ ! -e $DM ]; then - echo "WARNING DM file $DM NOT found, resulting might be non-functional" >&2 - DM=/dev/null -fi - -if [ ! -z "$IS_HS" ]; then - HS_APPEND=_HS -fi - -cat << __HEADER_EOF -/dts-v1/; - -/ { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - - images { - atf { - description = "ARM Trusted Firmware"; - data = /incbin/("$ATF"); - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <$1>; - entry = <$1>; - }; - tee { - description = "OPTEE"; - data = /incbin/("$TEE"); - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - }; - dm { - description = "DM binary"; - data = /incbin/("$DM"); - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; - }; - spl { - description = "SPL (64-bit)"; - data = /incbin/("spl/u-boot-spl-nodtb.bin$HS_APPEND"); - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <0x80080000>; - entry = <0x80080000>; - }; -__HEADER_EOF - -# shift through ATF load address in the command line arguments -shift - -for dtname in $* -do - cat << __FDT_IMAGE_EOF - $(basename $dtname) { - description = "$(basename $dtname .dtb)"; - data = /incbin/("$dtname$HS_APPEND"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - }; -__FDT_IMAGE_EOF -done - -cat << __CONF_HEADER_EOF - }; - configurations { - default = "$(basename $1)"; - -__CONF_HEADER_EOF - -for dtname in $* -do - cat << __CONF_SECTION_EOF - $(basename $dtname) { - description = "$(basename $dtname .dtb)"; - firmware = "atf"; - loadables = "tee", "dm", "spl"; - fdt = "$(basename $dtname)"; - }; -__CONF_SECTION_EOF -done - -cat << __ITS_EOF - }; -}; -__ITS_EOF
This is not true until you have migrated all K3 platforms to use binman. So let's leave this script here for now.
this file.
cheers, -roger
- ATF=/dev/null
-fi
- TEE=/dev/null
-fi
- DM=/dev/null
-fi
- HS_APPEND=_HS
-fi
- images {
atf {
type = "firmware";
arch = "arm64";
load = <$1>;
entry = <$1>;
tee {
type = "tee";
arch = "arm64";
os = "tee";
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
-__HEADER_EOF
type = "flat_dt";
arch = "arm";
- configurations {
-__CONF_HEADER_EOF
firmware = "atf";
-cat << __ITS_EOF
-}; -__ITS_EOF
Earlier the k3_gen_x509_cert.sh was used for signing binaries with the x509 certificate for Texas Instruments K3 architecture devices. Since the signing process is handled by x509 etype now, there is no more requirement for this script, hence removing it.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- tools/k3_gen_x509_cert.sh | 252 -------------------------------------- 1 file changed, 252 deletions(-) delete mode 100755 tools/k3_gen_x509_cert.sh
diff --git a/tools/k3_gen_x509_cert.sh b/tools/k3_gen_x509_cert.sh deleted file mode 100755 index b6ef5a2de3..0000000000 --- a/tools/k3_gen_x509_cert.sh +++ /dev/null @@ -1,252 +0,0 @@ -#!/bin/bash -# SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause -# -# Script to add K3 specific x509 cetificate to a binary. -# - -# Variables -OUTPUT=tiboot3.bin -TEMP_X509=x509-temp.cert -CERT=certificate.bin -RAND_KEY=eckey.pem -LOADADDR=0x41c00000 -BOOTCORE_OPTS=0 -BOOTCORE=16 -DEBUG_TYPE=0 - -gen_degen_template() { -cat << 'EOF' > degen-template.txt - -asn1=SEQUENCE:rsa_key - -[rsa_key] -version=INTEGER:0 -modulus=INTEGER:0xDEGEN_MODULUS -pubExp=INTEGER:1 -privExp=INTEGER:1 -p=INTEGER:0xDEGEN_P -q=INTEGER:0xDEGEN_Q -e1=INTEGER:1 -e2=INTEGER:1 -coeff=INTEGER:0xDEGEN_COEFF -EOF -} - -# Generate x509 Template -gen_template() { -cat << 'EOF' > x509-template.txt - [ req ] - distinguished_name = req_distinguished_name - x509_extensions = v3_ca - prompt = no - dirstring_type = nobmp - - [ req_distinguished_name ] - C = US - ST = TX - L = Dallas - O = Texas Instruments Incorporated - OU = Processors - CN = TI support - emailAddress = support@ti.com - - [ v3_ca ] - basicConstraints = CA:true - 1.3.6.1.4.1.294.1.1 = ASN1:SEQUENCE:boot_seq - 1.3.6.1.4.1.294.1.2 = ASN1:SEQUENCE:image_integrity - 1.3.6.1.4.1.294.1.3 = ASN1:SEQUENCE:swrv -# 1.3.6.1.4.1.294.1.4 = ASN1:SEQUENCE:encryption - 1.3.6.1.4.1.294.1.8 = ASN1:SEQUENCE:debug - - [ boot_seq ] - certType = INTEGER:TEST_CERT_TYPE - bootCore = INTEGER:TEST_BOOT_CORE - bootCoreOpts = INTEGER:TEST_BOOT_CORE_OPTS - destAddr = FORMAT:HEX,OCT:TEST_BOOT_ADDR - imageSize = INTEGER:TEST_IMAGE_LENGTH - - [ image_integrity ] - shaType = OID:2.16.840.1.101.3.4.2.3 - shaValue = FORMAT:HEX,OCT:TEST_IMAGE_SHA_VAL - - [ swrv ] - swrv = INTEGER:0 - -# [ encryption ] -# initalVector = FORMAT:HEX,OCT:TEST_IMAGE_ENC_IV -# randomString = FORMAT:HEX,OCT:TEST_IMAGE_ENC_RS -# iterationCnt = INTEGER:TEST_IMAGE_KEY_DERIVE_INDEX -# salt = FORMAT:HEX,OCT:TEST_IMAGE_KEY_DERIVE_SALT - - [ debug ] - debugUID = FORMAT:HEX,OCT:0000000000000000000000000000000000000000000000000000000000000000 - debugType = INTEGER:TEST_DEBUG_TYPE - coreDbgEn = INTEGER:0 - coreDbgSecEn = INTEGER:0 -EOF -} - -parse_key() { - sed '/\ \ \ \ /s/://g' key.txt | awk '!/\ \ \ \ / {printf("\n%s\n", $0)}; /\ \ \ \ / {printf("%s", $0)}' | sed 's/\ \ \ \ //g' | awk "/$1:/{getline; print}" -} - -gen_degen_key() { -# Generate a 4096 bit RSA Key - openssl genrsa -out key.pem 1024 >>/dev/null 2>&1 - openssl rsa -in key.pem -text -out key.txt >>/dev/null 2>&1 - DEGEN_MODULUS=$( parse_key 'modulus' ) - DEGEN_P=$( parse_key 'prime1' ) - DEGEN_Q=$( parse_key 'prime2' ) - DEGEN_COEFF=$( parse_key 'coefficient' ) - gen_degen_template - - sed -e "s/DEGEN_MODULUS/$DEGEN_MODULUS/"\ - -e "s/DEGEN_P/$DEGEN_P/" \ - -e "s/DEGEN_Q/$DEGEN_Q/" \ - -e "s/DEGEN_COEFF/$DEGEN_COEFF/" \ - degen-template.txt > degenerateKey.txt - - openssl asn1parse -genconf degenerateKey.txt -out degenerateKey.der >>/dev/null 2>&1 - openssl rsa -in degenerateKey.der -inform DER -outform PEM -out $RAND_KEY >>/dev/null 2>&1 - KEY=$RAND_KEY - #rm key.pem key.txt degen-template.txt degenerateKey.txt degenerateKey.der -} - -declare -A options_help -usage() { - if [ -n "$*" ]; then - echo "ERROR: $*" - fi - echo -n "Usage: $0 " - for option in "${!options_help[@]}" - do - arg=`echo ${options_help[$option]}|cut -d ':' -f1` - if [ -n "$arg" ]; then - arg=" $arg" - fi - echo -n "[-$option$arg] " - done - echo - echo -e "\nWhere:" - for option in "${!options_help[@]}" - do - arg=`echo ${options_help[$option]}|cut -d ':' -f1` - txt=`echo ${options_help[$option]}|cut -d ':' -f2` - tb="\t\t\t" - if [ -n "$arg" ]; then - arg=" $arg" - tb="\t" - fi - echo -e " -$option$arg:$tb$txt" - done - echo - echo "Examples of usage:-" - echo "# Example of signing the SYSFW binary with rsa degenerate key" - echo " $0 -c 0 -b ti-sci-firmware-am6x.bin -o sysfw.bin -l 0x40000" - echo "# Example of signing the SPL binary with rsa degenerate key" - echo " $0 -c 16 -b spl/u-boot-spl.bin -o tiboot3.bin -l 0x41c00000" -} - -options_help[b]="bin_file:Bin file that needs to be signed" -options_help[k]="key_file:file with key inside it. If not provided script generates a rsa degenerate key." -options_help[o]="output_file:Name of the final output file. default to $OUTPUT" -options_help[c]="core_id:target core id on which the image would be running. Default to $BOOTCORE" -options_help[l]="loadaddr: Target load address of the binary in hex. Default to $LOADADDR" -options_help[d]="debug_type: Debug type, set to 4 to enable early JTAG. Default to $DEBUG_TYPE" - -while getopts "b:k:o:c:l:d:h" opt -do - case $opt in - b) - BIN=$OPTARG - ;; - k) - KEY=$OPTARG - ;; - o) - OUTPUT=$OPTARG - ;; - l) - LOADADDR=$OPTARG - ;; - c) - BOOTCORE=$OPTARG - ;; - d) - DEBUG_TYPE=$OPTARG - ;; - h) - usage - exit 0 - ;; - ?) - usage "Invalid Option '-$OPTARG'" - exit 1 - ;; - :) - usage "Option '-$OPTARG' Needs an argument." - exit 1 - ;; - esac -done - -if [ "$#" -eq 0 ]; then - usage "Arguments missing" - exit 1 -fi - -if [ -z "$BIN" ]; then - usage "Bin file missing in arguments" - exit 1 -fi - -# Generate rsa degenerate key if user doesn't provide a key -if [ -z "$KEY" ]; then - gen_degen_key -fi - -if [ $BOOTCORE == 0 ]; then # BOOTCORE M3, loaded by ROM - CERTTYPE=2 -elif [ $BOOTCORE == 16 ]; then # BOOTCORE R5, loaded by ROM - CERTTYPE=1 -else # Non BOOTCORE, loaded by SYSFW - BOOTCORE_OPTS_VER=$(printf "%01x" 1) - # Add input args option for SET and CLR flags. - BOOTCORE_OPTS_SETFLAG=$(printf "%08x" 0) - BOOTCORE_OPTS_CLRFLAG=$(printf "%08x" 0x100) # Clear FLAG_ARMV8_AARCH32 - BOOTCORE_OPTS="0x$BOOTCORE_OPTS_VER$BOOTCORE_OPTS_SETFLAG$BOOTCORE_OPTS_CLRFLAG" - # Set the cert type to zero. - # We are not using public/private key store now - CERTTYPE=$(printf "0x%08x" 0) -fi - -SHA_VAL=`openssl dgst -sha512 -hex $BIN | sed -e "s/^.*= //g"` -BIN_SIZE=`cat $BIN | wc -c` -ADDR=`printf "%08x" $LOADADDR` - -gen_cert() { - #echo "Certificate being generated :" - #echo " LOADADDR = 0x$ADDR" - #echo " IMAGE_SIZE = $BIN_SIZE" - #echo " CERT_TYPE = $CERTTYPE" - #echo " DEBUG_TYPE = $DEBUG_TYPE" - sed -e "s/TEST_IMAGE_LENGTH/$BIN_SIZE/" \ - -e "s/TEST_IMAGE_SHA_VAL/$SHA_VAL/" \ - -e "s/TEST_CERT_TYPE/$CERTTYPE/" \ - -e "s/TEST_BOOT_CORE_OPTS/$BOOTCORE_OPTS/" \ - -e "s/TEST_BOOT_CORE/$BOOTCORE/" \ - -e "s/TEST_BOOT_ADDR/$ADDR/" \ - -e "s/TEST_DEBUG_TYPE/$DEBUG_TYPE/" \ - x509-template.txt > $TEMP_X509 - openssl req -new -x509 -key $KEY -nodes -outform DER -out $CERT -config $TEMP_X509 -sha512 -} - -gen_template -gen_cert -cat $CERT $BIN > $OUTPUT - -# Remove all intermediate files -#rm $TEMP_X509 $CERT x509-template.txt -#if [ "$KEY" == "$RAND_KEY" ]; then -# rm $RAND_KEY -#fi
Are you sure this script is not required for any Keystone platforms? If not, let's just leave it there.
cheers, -roger
- [ req ]
- prompt = no
- C = US
- ST = TX
- L = Dallas
- OU = Processors
- CN = TI support
- [ v3_ca ]
- [ boot_seq ]
- [ swrv ]
- swrv = INTEGER:0
- [ debug ]
-EOF -}
-parse_key() {
- KEY=$RAND_KEY
echo "ERROR: $*"
- fi
- do
arg=" $arg"
fi
- done
- echo
- do
tb="\t\t\t"
arg=" $arg"
tb="\t"
fi
- done
- echo
- case $opt in
- b)
BIN=$OPTARG
- k)
KEY=$OPTARG
- o)
OUTPUT=$OPTARG
- l)
LOADADDR=$OPTARG
- c)
BOOTCORE=$OPTARG
- d)
DEBUG_TYPE=$OPTARG
- h)
usage
exit 0
exit 1
exit 1
- esac
-done
- exit 1
-fi
- exit 1
-fi
- gen_degen_key
-fi
- CERTTYPE=2
- CERTTYPE=1
-fi
-gen_cert() {
By providing entries in the binman node of the device tree, binman will be able to find and package board config binary artifacts generated by TIBoardConfig with sysfw.bin and generate the final image sysfw.itb.
k3-j721e-r5-binman.dtsi has been introduced for R5 specific binman node. It can be then be include by files that require it like k3-j721e-r5-common-proc-board-u-boot.dtsi.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: prepared patch for upstreaming] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-j721e-r5-binman.dtsi | 88 +++++++++++++++++++ .../k3-j721e-r5-common-proc-board-u-boot.dtsi | 1 + board/ti/j721e/Kconfig | 1 + 3 files changed, 90 insertions(+) create mode 100644 arch/arm/dts/k3-j721e-r5-binman.dtsi
diff --git a/arch/arm/dts/k3-j721e-r5-binman.dtsi b/arch/arm/dts/k3-j721e-r5-binman.dtsi new file mode 100644 index 0000000000..cf5b5bfdf6 --- /dev/null +++ b/arch/arm/dts/k3-j721e-r5-binman.dtsi @@ -0,0 +1,88 @@ +// SPDX-License-Identifier: GPL-2.0+ +// Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + +#include <config.h> + +/ { + binman: binman { + multiple-images; + }; +}; + +&binman { + tiboot3 { + filename = "tiboot3.bin"; + x509-cert { + content = <&image1>; + core = <16>; + load = <CONFIG_SPL_TEXT_BASE>; + }; + image1: u-boot-spl { + no-expanded; + }; + }; + binary { + filename = "sysfw.bin"; + x509-cert { + content = <&image2>; + core = <0>; + load = <0x0040000>; + }; + image2: ti-sysfw { + }; + }; + itb { + filename = "sysfw.itb"; + fit { + description = "SYSFW and Config Fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob { + filename = "sysfw.bin"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "board-cfg.bin"; + }; + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "pm-cfg.bin"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "rm-cfg.bin"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sec-cfg.bin"; + }; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi index 48c6ddf672..75ec722e89 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include "k3-j721e-common-proc-board-u-boot.dtsi" +#include "k3-j721e-r5-binman.dtsi"
/ { chosen { diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index c28752a658..a3a9d504ae 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -24,6 +24,7 @@ config TARGET_J721E_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Explicit make commands were earlier used to generate tispl.bin image, now it is replaced using binman.
Binman picks up and packages entries according to the description of entries given in the binman node in the device tree. The make commands that were earlier responsible for generating tispl.bin has been removed.
k3-j721e-a72-binman.dtsi has been introduced for A72 specific binman node. It can be included in files that require it like k3-j721e-common-proc-board-u-boot.dtsi.
Note that make commands for secure devices has also been removed as focus is on general purpose devices at present time.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: prepared patch for upstreaming] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-j721e-a72-binman.dtsi | 86 +++++++++++++++++++ .../k3-j721e-common-proc-board-u-boot.dtsi | 1 + arch/arm/mach-k3/config.mk | 33 ------- board/ti/j721e/Kconfig | 1 + scripts/Makefile.spl | 4 - 5 files changed, 88 insertions(+), 37 deletions(-) create mode 100644 arch/arm/dts/k3-j721e-a72-binman.dtsi
diff --git a/arch/arm/dts/k3-j721e-a72-binman.dtsi b/arch/arm/dts/k3-j721e-a72-binman.dtsi new file mode 100644 index 0000000000..beb3424bb9 --- /dev/null +++ b/arch/arm/dts/k3-j721e-a72-binman.dtsi @@ -0,0 +1,86 @@ +// SPDX-License-Identifier: GPL-2.0+ +// Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + +#include <config.h> + +#ifdef CONFIG_ARM64 +/ { + binman: binman { + multiple-images; + }; +}; + +&binman { + tispl { + filename = "tispl.bin"; + fit { + description = "FIT IMAGE"; + #address-cells = <1>; + images { + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + ti-dm { + }; + }; + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + u-boot-spl-nodtb { + }; + }; + k3-j721e-common-proc-board.dtb { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "spl/dts/k3-j721e-common-proc-board.dtb"; + }; + }; + }; + configurations { + default = "conf"; + conf { + description = "k3-j721e-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "k3-j721e-common-proc-board.dtb"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index 677a72d2a2..6490d71f7e 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include <dt-bindings/net/ti-dp83867.h> +#include "k3-j721e-a72-binman.dtsi"
/ { chosen { diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index 49f80ae79b..e0d9ea97c9 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -52,38 +52,5 @@ ifeq ($(CONFIG_SOC_K3_J721E),) export DM := /dev/null endif
-ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -SPL_ITS := u-boot-spl-k3_HS.its -$(SPL_ITS): export IS_HS=1 -INPUTS-y += tispl.bin_HS -else -SPL_ITS := u-boot-spl-k3.its -INPUTS-y += tispl.bin -endif - -ifeq ($(CONFIG_SPL_OF_LIST),) -LIST_OF_DTB := $(CONFIG_DEFAULT_DEVICE_TREE) -else -LIST_OF_DTB := $(CONFIG_SPL_OF_LIST) endif - -quiet_cmd_k3_mkits = MKITS $@ -cmd_k3_mkits = \ - $(srctree)/tools/k3_fit_atf.sh \ - $(CONFIG_K3_ATF_LOAD_ADDR) \ - $(patsubst %,$(obj)/dts/%.dtb,$(subst ",,$(LIST_OF_DTB))) > $@ - -$(SPL_ITS): FORCE - $(call cmd,k3_mkits) endif - -else - -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -INPUTS-y += u-boot.img_HS -else -INPUTS-y += u-boot.img -endif -endif - -include $(srctree)/arch/arm/mach-k3/config_secure.mk diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index a3a9d504ae..3cf05f0d3b 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -14,6 +14,7 @@ config TARGET_J721E_A72_EVM select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS + select BINMAN
config TARGET_J721E_R5_EVM bool "TI K3 based J721E EVM running on R5" diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 6ad82cecfb..5f8a8487c5 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -577,7 +577,3 @@ $(obj)/$(SPL_BIN).multidtb.fit.gz: $(obj)/$(SPL_BIN).multidtb.fit $(obj)/$(SPL_BIN).multidtb.fit.lzo: $(obj)/$(SPL_BIN).multidtb.fit @lzop -f9 $< > $@
-ifdef CONFIG_ARCH_K3 -tispl.bin: $(obj)/u-boot-spl-nodtb.bin $(SHRUNK_ARCH_DTB) $(SPL_ITS) FORCE - $(call if_changed,mkfitimage) -endif
- binman: binman {
multiple-images;
+&binman {
- tispl {
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
ti-dm {
spl {
os = "U-Boot";
arch = "arm64";
u-boot-spl-nodtb {
type = "flat_dt";
arch = "arm";
blob-ext {
configurations {
default = "conf";
conf {
firmware = "atf";
-$(SPL_ITS): FORCE
endif
-else
You can't yet remove these as all K3 platforms are not converted to use binman. Please include them under #ifndef CONFIG_BINMAN...#endif
One more question I have is that how are _HS binaries being created with binman?
- select BINMAN
-endif
Please don't remove this but include it under #ifndef CONFIG_BINMAN...#endif
cheers, -roger
Hi Roger,
- binman: binman {
multiple-images;
+&binman {
- tispl {
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
ti-dm {
spl {
os = "U-Boot";
arch = "arm64";
u-boot-spl-nodtb {
type = "flat_dt";
arch = "arm";
blob-ext {
configurations {
default = "conf";
conf {
firmware = "atf";
-$(SPL_ITS): FORCE
-else
I will make the changes accordingly that do not affect any of the other builds. _HS binaries are not being created with binman in this series.
But there is a patch series that does create HS images (tispl.bin and u-boot.img) using binman for AM64x: https://patchwork.ozlabs.org/project/uboot/patch/20220509072936.12899-4-roge...
select BINMAN
-endif
cheers, -roger
On 01/06/2022 09:08, Neha Malcom Francis wrote:
Hi Roger,
+&binman { + tispl { + filename = "tispl.bin"; + fit { + description = "FIT IMAGE"; + #address-cells = <1>; + images { + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + ti-dm { + }; + }; + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + u-boot-spl-nodtb { + }; + }; + k3-j721e-common-proc-board.dtb { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "spl/dts/k3-j721e-common-proc-board.dtb"; + }; + }; + }; + configurations { + default = "conf"; + conf { + description = "k3-j721e-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "k3-j721e-common-proc-board.dtb"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index 677a72d2a2..6490d71f7e 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -4,6 +4,7 @@ */ #include <dt-bindings/net/ti-dp83867.h> +#include "k3-j721e-a72-binman.dtsi" / { chosen { diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk index 49f80ae79b..e0d9ea97c9 100644 --- a/arch/arm/mach-k3/config.mk +++ b/arch/arm/mach-k3/config.mk @@ -52,38 +52,5 @@ ifeq ($(CONFIG_SOC_K3_J721E),) export DM := /dev/null endif -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -SPL_ITS := u-boot-spl-k3_HS.its -$(SPL_ITS): export IS_HS=1 -INPUTS-y += tispl.bin_HS -else -SPL_ITS := u-boot-spl-k3.its -INPUTS-y += tispl.bin -endif
-else
That series still depends on "TI_SECURE_DEV_PKG//scripts/secure-binary-image.sh" to sign the image.
Funny thing is that I'm no longer able to download the above package from ti.com to see what it is doing. Any pointers on how to get it?
cheers, -roger
diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index a3a9d504ae..3cf05f0d3b 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -14,6 +14,7 @@ config TARGET_J721E_A72_EVM select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS + select BINMAN config TARGET_J721E_R5_EVM bool "TI K3 based J721E EVM running on R5" diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 6ad82cecfb..5f8a8487c5 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -577,7 +577,3 @@ $(obj)/$(SPL_BIN).multidtb.fit.gz: $(obj)/$(SPL_BIN).multidtb.fit $(obj)/$(SPL_BIN).multidtb.fit.lzo: $(obj)/$(SPL_BIN).multidtb.fit @lzop -f9 $< > $@ -ifdef CONFIG_ARCH_K3 -tispl.bin: $(obj)/u-boot-spl-nodtb.bin $(SHRUNK_ARCH_DTB) $(SPL_ITS) FORCE - $(call if_changed,mkfitimage) -endif
cheers, -roger
Hi Roger,
Hi Roger,
-else
cheers, -roger
Did you try to access using the browser using https link?
I am able to access the script by cloning git://git.ti.com/security-development-tools/core-secdev-k3.git
cheers, -roger
On 01/06/2022 13:42, Neha Malcom Francis wrote:
Hi Roger,
Hi Roger,
-else
cheers, -roger
Aha! sure I can access that. But according to doc/README.ti-secure I should be getting it from http://www.ti.com/mysecuresoftware And I couldn't get anything there.
Looks like we need to update the doc to point to the git repo instead?
cheers, -roger
cheers, -roger
Hi Roger,
Hi Roger,
-else
cheers, -roger
The mysecuresoftware is for the AM335x-AM57x class devices, that is still the place to get the tools for those. For K3 forward the git.ti.com is the right spot. We can add a new doc for K3 devices.
Andrew
cheers, -roger
cheers, -roger
Hi Roger,
Hi Roger,
On 06/05/2022 07:37, Neha Malcom Francis wrote: > Explicit make commands were earlier used to generate tispl.bin image, > now it is replaced using binman. > > Binman picks up and packages entries according to the description of > entries given in the binman node in the device tree. The make commands > that were earlier responsible for generating tispl.bin has been removed. > > k3-j721e-a72-binman.dtsi has been introduced for A72 specific binman node. > It can be included in files that require it like > k3-j721e-common-proc-board-u-boot.dtsi. > > Note that make commands for secure devices has also been removed as > focus is on general purpose devices at present time. > > Signed-off-by: Tarun Sahu t-sahu@ti.com > [n-francis@ti.com: prepared patch for upstreaming] > Signed-off-by: Neha Malcom Francis n-francis@ti.com > --- > arch/arm/dts/k3-j721e-a72-binman.dtsi | 86 +++++++++++++++++++ > .../k3-j721e-common-proc-board-u-boot.dtsi | 1 + > arch/arm/mach-k3/config.mk | 33 ------- > board/ti/j721e/Kconfig | 1 + > scripts/Makefile.spl | 4 - > 5 files changed, 88 insertions(+), 37 deletions(-) > create mode 100644 arch/arm/dts/k3-j721e-a72-binman.dtsi > > diff --git a/arch/arm/dts/k3-j721e-a72-binman.dtsi b/arch/arm/dts/k3-j721e-a72-binman.dtsi > new file mode 100644 > index 0000000000..beb3424bb9 > --- /dev/null > +++ b/arch/arm/dts/k3-j721e-a72-binman.dtsi > @@ -0,0 +1,86 @@ > +// SPDX-License-Identifier: GPL-2.0+ > +// Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ > + > +#include <config.h> > + > +#ifdef CONFIG_ARM64 > +/ { > + binman: binman { > + multiple-images; > + }; > +}; > + > +&binman { > + tispl { > + filename = "tispl.bin"; > + fit { > + description = "FIT IMAGE"; > + #address-cells = <1>; > + images { > + atf { > + description = "ARM Trusted Firmware"; > + type = "firmware"; > + arch = "arm64"; > + compression = "none"; > + os = "arm-trusted-firmware"; > + load = <CONFIG_K3_ATF_LOAD_ADDR>; > + entry = <CONFIG_K3_ATF_LOAD_ADDR>; > + atf-bl31 { > + }; > + }; > + tee { > + description = "OPTEE"; > + type = "tee"; > + arch = "arm64"; > + compression = "none"; > + os = "tee"; > + load = <0x9e800000>; > + entry = <0x9e800000>; > + tee-os { > + }; > + }; > + dm { > + description = "DM binary"; > + type = "firmware"; > + arch = "arm32"; > + compression = "none"; > + os = "DM"; > + load = <0x89000000>; > + entry = <0x89000000>; > + ti-dm { > + }; > + }; > + spl { > + description = "SPL (64-bit)"; > + type = "standalone"; > + os = "U-Boot"; > + arch = "arm64"; > + compression = "none"; > + load = <CONFIG_SPL_TEXT_BASE>; > + entry = <CONFIG_SPL_TEXT_BASE>; > + u-boot-spl-nodtb { > + }; > + }; > + k3-j721e-common-proc-board.dtb { > + description = "k3-j721e-common-proc-board"; > + type = "flat_dt"; > + arch = "arm"; > + compression = "none"; > + blob-ext { > + filename = "spl/dts/k3-j721e-common-proc-board.dtb"; > + }; > + }; > + }; > + configurations { > + default = "conf"; > + conf { > + description = "k3-j721e-common-proc-board"; > + firmware = "atf"; > + loadables = "tee", "dm", "spl"; > + fdt = "k3-j721e-common-proc-board.dtb"; > + }; > + }; > + }; > + }; > +}; > +#endif > diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi > index 677a72d2a2..6490d71f7e 100644 > --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi > +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi > @@ -4,6 +4,7 @@ > */ > #include <dt-bindings/net/ti-dp83867.h> > +#include "k3-j721e-a72-binman.dtsi" > / { > chosen { > diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk > index 49f80ae79b..e0d9ea97c9 100644 > --- a/arch/arm/mach-k3/config.mk > +++ b/arch/arm/mach-k3/config.mk > @@ -52,38 +52,5 @@ ifeq ($(CONFIG_SOC_K3_J721E),) > export DM := /dev/null > endif > -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) > -SPL_ITS := u-boot-spl-k3_HS.its > -$(SPL_ITS): export IS_HS=1 > -INPUTS-y += tispl.bin_HS > -else > -SPL_ITS := u-boot-spl-k3.its > -INPUTS-y += tispl.bin > -endif > - > -ifeq ($(CONFIG_SPL_OF_LIST),) > -LIST_OF_DTB := $(CONFIG_DEFAULT_DEVICE_TREE) > -else > -LIST_OF_DTB := $(CONFIG_SPL_OF_LIST) > endif > - > -quiet_cmd_k3_mkits = MKITS $@ > -cmd_k3_mkits = \ > - $(srctree)/tools/k3_fit_atf.sh \ > - $(CONFIG_K3_ATF_LOAD_ADDR) \ > - $(patsubst %,$(obj)/dts/%.dtb,$(subst ",,$(LIST_OF_DTB))) > $@ > - > -$(SPL_ITS): FORCE > - $(call cmd,k3_mkits) > endif > - > -else > - > -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) > -INPUTS-y += u-boot.img_HS > -else > -INPUTS-y += u-boot.img > -endif > -endif > - > -include $(srctree)/arch/arm/mach-k3/config_secure.mk
cheers, -roger
Understood now. Thanks for the clarification.
cheers, -roger
On Fri, May 06, 2022 at 10:07:48AM +0530, Neha Malcom Francis wrote:
Devices that belong to the K3 architecture require SYSFW which is a FIT image consisting of a signed system firmware image and board config binaries.
Board config binaries are needed to bring up SYSFW during U-Boot SPL startup. The board config data is given in YAML as input. These board configs contain board-specific information such as resource management, power management and security.
The following series intends to plumb the system firmware generation into U-Boot using binman for packaging. Thus it will eliminate the need for additional custom repositories for SYSFW generation and also moves t owards the community standard build flow. We use binman to package tiboot3.bin and sysfw.itb images.
These images also require x509 certificates which are created using the etype x509-cert.
The series also plumbs the generation of tispl.bin into the build flow. This image is required for loading u-boot in K3 devices. The image is packaged using ATF, OPTEE and DM (Device Manager).
Please note that the following series has implemented the above for J721E general purpose board. The board configs and device trees added are specific to J721E GP devices.
Also note the introduction of three new etypes: ti-sysfw, ti-dm and x509-cert.
On running CI tests on Github, errors were produced during world builds of keystone2_keystone3 and siemens (I0T2050 which is based on AM65x). This patch series is intended for only J721E and future work is to expand to the remaining K3 devices as well. The errors that come are mainly due to the boards other than J721E trying to generate tispl.bin.
v2:
- Added etype x509-cert for creating x509 Texas Instruments certificate binary
- Added packaging of tiboot3.bin
- Packaging of tiboot3.bin and sysfw.itb using new etype x509
- sysfw --> ti-sysfw
- Reformatted and re-arranged patches
- Removed k3_fit_atf.sh and k3_gen_x509_cert.sh as their functionality is provided by binman now
Neha Malcom Francis (11): j721e_evm: schema: yaml: Add general schema and J721E board config files ti: tools: config: Add board config class to generate config binaries ti: etype: sysfw: Add entry type for sysfw ti: etype: dm: Add entry type for TI DM ti: etype: x509: Add etype for x509 certificate for K3 devices ti: sysfw: Add support for packaging sysfw.itb ti: tiboot3.bin: Remove tiboot3.bin target from makefile ti: tispl.bin: Removed script that packages tispl.bin ti: x509: Remove shell script used for signing ti: dtsi: j721e: Use binman to package sysfw.itb and tiboot3.bin ti: dtsi: j721e: Use binman to package tispl.bin
Makefile | 2 + arch/arm/dts/k3-j721e-a72-binman.dtsi | 86 + .../k3-j721e-common-proc-board-u-boot.dtsi | 1 + arch/arm/dts/k3-j721e-r5-binman.dtsi | 88 + .../k3-j721e-r5-common-proc-board-u-boot.dtsi | 1 + arch/arm/mach-k3/config.mk | 64 +- board/ti/common/schema.yaml | 355 ++ board/ti/j721e/Kconfig | 2 + board/ti/j721e/config.yaml | 3162 +++++++++++++++++ scripts/Makefile.spl | 4 - test/py/requirements.txt | 1 + tools/binman/entries.rst | 36 + tools/binman/etype/ti_dm.py | 23 + tools/binman/etype/ti_sysfw.py | 28 + tools/binman/etype/x509_cert.py | 248 ++ tools/binman/ftest.py | 21 + tools/binman/test/225_ti_dm.dts | 13 + tools/binman/test/232_ti_sysfw.dts | 13 + tools/binman/test/232_x509_cert.dts | 18 + tools/k3_fit_atf.sh | 123 - tools/k3_gen_x509_cert.sh | 252 -- tools/tibcfg_gen.py | 114 + 22 files changed, 4227 insertions(+), 428 deletions(-) create mode 100644 arch/arm/dts/k3-j721e-a72-binman.dtsi create mode 100644 arch/arm/dts/k3-j721e-r5-binman.dtsi create mode 100644 board/ti/common/schema.yaml create mode 100644 board/ti/j721e/config.yaml create mode 100644 tools/binman/etype/ti_dm.py create mode 100644 tools/binman/etype/ti_sysfw.py create mode 100644 tools/binman/etype/x509_cert.py create mode 100644 tools/binman/test/225_ti_dm.dts create mode 100644 tools/binman/test/232_ti_sysfw.dts create mode 100644 tools/binman/test/232_x509_cert.dts delete mode 100755 tools/k3_fit_atf.sh delete mode 100755 tools/k3_gen_x509_cert.sh create mode 100644 tools/tibcfg_gen.py
Adding the other binman maintainer..
Thanks. I haven't been able to focus on anything for a while. I'll try to review the few series that have accumulated, maybe can manage this week or so if things go well. Just wanted to send an update.
You will have to implement it such that none of the existing board build/functionality breaks. Otherwise it will be impossible to get this merged.
Is this series tested for High-Security (HS) J721E as well?
cheers, -roger
v2:
Hi Roger,
cheers, -roger
I've noted this and the other comments you've mentioned in the rest of the series regarding not breaking any of the existing board functionalities. I'll make the necessary changes and send across a new patch for the same.
No this series is intended for only General Purpose J721E devices.
v2:
participants (5)
Alper Nebi Yasak
Andrew Davis
Neha Malcom Francis
Roger Quadros
