[PATCH] net: use a more deterministic approach to get the active ethernet device
If the environment variable "ethact" is not set, the first device in the uclass is returned. This depends on the probing order of the ethernet devices. Moreover it is not not configurable at all.
Try to return the ethernet device with sequence id 0 first which then can be configured by the aliases in a device tree. Fall back to the old mechanism in case of an error.
Signed-off-by: Michael Walle michael@walle.cc --- net/eth-uclass.c | 17 ++++++++++++----- 1 file changed, 12 insertions(+), 5 deletions(-)
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 34ca731d1e..0b4260dc5b 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -69,8 +69,11 @@ void eth_set_current_to_next(void) /* * Typically this will simply return the active device. * In the case where the most recent active device was unset, this will attempt - * to return the first device. If that device doesn't exist or fails to probe, - * this function will return NULL. + * to return the device with sequence id 0 (which can be configured by the + * device tree). If this fails, fall back to just getting the first device. + * The latter is non-deterministic and depends on the order of the probing. + * If that device doesn't exist or fails to probe, this function will return + * NULL. */ struct udevice *eth_get_dev(void) { @@ -80,9 +83,13 @@ struct udevice *eth_get_dev(void) if (!uc_priv) return NULL;
- if (!uc_priv->current) - eth_errno = uclass_first_device(UCLASS_ETH, - &uc_priv->current); + if (!uc_priv->current) { + eth_errno = uclass_get_device_by_seq(UCLASS_ETH, 0, + &uc_priv->current); + if (eth_errno) + eth_errno = uclass_first_device(UCLASS_ETH, + &uc_priv->current); + } return uc_priv->current; }
Am 2021-02-24 17:30, schrieb Michael Walle:
any news?
-michael
- Typically this will simply return the active device.
- In the case where the most recent active device was unset, this will attempt
- to return the first device. If that device doesn't exist or fails to probe,
- this function will return NULL.
- to return the device with sequence id 0 (which can be configured by the
- device tree). If this fails, fall back to just getting the first device.
- The latter is non-deterministic and depends on the order of the probing.
- If that device doesn't exist or fails to probe, this function will return
- NULL.
&uc_priv->current);
&uc_priv->current);
if (eth_errno)
&uc_priv->current);
-- 2.20.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
- NULL.
&uc_priv->current);
&uc_priv->current);
if (eth_errno)
&uc_priv->current);
-- 2.20.1
Applied to u-boot-net/master, thanks!
Best regards, Ramon Fried
Michael Walle
Ramon Fried
