Pull request: u-boot-spi/master
Hi Tom,
Please pull this PR.
Summary: - new GigaDevice flash ids - fixes for imx, nxp_spi drivers
GitLab CI: https://gitlab.denx.de/u-boot/custodians/u-boot-spi/-/pipelines/6528
The following changes since commit c28d5d704d3347fcbe5e49ab561973c00bf9337f:
Merge branch '2021-02-25-remove-platforms' (2021-02-25 13:18:27 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-spi master
for you to fetch changes up to 783a15b35131abc599ec6deca55cf841d2e7c208:
mtd: nand: spi: Support GigaDevice GD5F1GQ5UExxG (2021-02-26 16:01:37 +0530)
---------------------------------------------------------------- Adam Ford (1): spi: nxp_fspi: Fix error reporting
Alper Nebi Yasak (1): mtd: spi-nor-ids: Add Gigadevice GD25LQ64C
Bin Meng (1): mtd: spi-nor.h: Change spaces to tabs
Hauke Mehrtens (1): mtd: nand: spi: Only one dummy byte in QUADIO
Marek Vasut (1): spi: imx: Implement set_speed
Reto Schneider (1): mtd: nand: spi: Support GigaDevice GD5F1GQ5UExxG
Sean Anderson (3): cmd: sf: Display errno on erase failure cmd: sf: Print error on test failure mtd: spi-nor-core: Fix typo in documentation
Su Baocheng (1): mtd: spi-nor-ids: Add support of flash protection to w25q128
cmd/sf.c | 29 ++++++++------ drivers/mtd/nand/spi/gigadevice.c | 79 ++++++++++++++++++++++++++++++++++----- drivers/mtd/spi/spi-nor-ids.c | 10 ++++- drivers/spi/mxc_spi.c | 5 ++- drivers/spi/nxp_fspi.c | 4 +- include/linux/mtd/spi-nor.h | 22 +++++------ 6 files changed, 113 insertions(+), 36 deletions(-)
On Fri, Feb 26, 2021 at 10:52:12PM +0530, Jagan Teki wrote:
Hi Tom,
Summary:
Jagan Teki
