[U-Boot] mx7: ums command does not mount SD card partitions
Hi Peng/Ye Li,
We are trying the 'ums' command on a mx7d sabresd board running the latest U-Boot code from u-boot-imx tree:
=> ums 0 mmc 0
This should make the content of the SD card to be mounted on the host PC and the two SD card partition should pop up in the screen.
We do see the two partitions icons to appear on the host, but the two SD card partitions are not mounted automatically.
We see this behavior on a mx7d sabresd and also mx7s warp boards.
In other mx6 boards the partitions are correctly mounted.
We also tested the following command in the kernel on a mx7d sabresd:
modprobe g_mass_storage file=/dev/mmcblk0
and the SD card partitions are always automatically mounted.
Any ideas as to why U-boot ums do not mount the SD card partitions automatically?
Thanks,
Fabio Estevam
Hi Fabio,
I just tried 'ums' on mx7d sabresd with latest u-boot-imx codes. It works well on my board. I don't see your issue. My SD card has a FAT partition. I can access it from my host after running the "ums 0 mmc 0".
Best regards, Ye Li -----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Fabio Estevam Sent: Saturday, August 20, 2016 12:46 AM To: Peng Fan; Ye Li Cc: Marek VaĊĦut; U-Boot-Denx; Vanessa Maegima Subject: [U-Boot] mx7: ums command does not mount SD card partitions
Hi Peng/Ye Li,
=> ums 0 mmc 0
Thanks,
Fabio Estevam _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Ye Li,
On Thu, Aug 25, 2016 at 3:25 AM, Ye Li ye.li@nxp.com wrote:
Hi Fabio,
Thanks for trying it on your side.
Could you please try "ums 0 mmc 0" several times in a row?
I notice that sometimes the partitions mount automatically, sometimes not.
Thanks
Hi Fabio,
On 8/25/2016 8:18 PM, Fabio Estevam wrote:
Hi Ye Li,
Hi Fabio,
Thanks
I tried with 20 times, no issue found. Could you change a USB cable and try again.
Ye Li
Hi Ye Li,
Thanks for testing.
Just want to make sure we are using the same method to test this.
When I run "ums 0 mmc 0" on mx7d sabresd I do see the "/dev/sdb1" to appear every time. I am using Ubuntu on my host PC and the two USB stick icons (one for each partition) do appear in the left column.
However, the two partitions do not automount all the time:
$ ls -al /media/fabio/dff160a2-b8d2-4964-babe-a7d4f47e5c4e/ ls: cannot access /media/fabio/dff160a2-b8d2-4964-babe-a7d4f47e5c4e/: No such file or directory
$ ls -al /media/fabio/Boot\ imx7d-/ ls: cannot access /media/fabio/Boot imx7d-/: No such file or directory
On mx6 I see the partitions to mount automatically every time, so I don't think it would be a USB cable problem.
Thanks
Fabio Estevam
Ye Li
