[PATCH v2] cmd: mmc: Expand bkops handling
Add more capable "bkops" command which allows enabling and disabling both manual and automatic bkops. The existing 'mmc bkops-enable' subcommand is poorly named to cover all the possibilities, hence the new-ish subcommand. Note that both commands are wrappers around the same common code.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Peng Fan peng.fan@nxp.com --- V2: - Add kerneldoc comment to mmc_set_bkops_enable - Drop ifdef around mmc_set_bkops_enable in mmc.h --- cmd/mmc.c | 49 +++++++++++++++++++++++++++++++++++++++-------- drivers/mmc/mmc.c | 14 +++++++++----- include/mmc.h | 14 +++++++++++--- 3 files changed, 61 insertions(+), 16 deletions(-)
diff --git a/cmd/mmc.c b/cmd/mmc.c index c79d9407986..94deb9a1686 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -1020,16 +1020,12 @@ static int do_mmc_setdsr(struct cmd_tbl *cmdtp, int flag, }
#ifdef CONFIG_CMD_BKOPS_ENABLE -static int do_mmc_bkops_enable(struct cmd_tbl *cmdtp, int flag, - int argc, char *const argv[]) +static int mmc_bkops_common(char *device, bool autobkops, bool enable) { - int dev; struct mmc *mmc; + int dev;
- if (argc != 2) - return CMD_RET_USAGE; - - dev = dectoul(argv[1], NULL); + dev = dectoul(device, NULL);
mmc = init_mmc_device(dev, false); if (!mmc) @@ -1040,7 +1036,41 @@ static int do_mmc_bkops_enable(struct cmd_tbl *cmdtp, int flag, return CMD_RET_FAILURE; }
- return mmc_set_bkops_enable(mmc); + return mmc_set_bkops_enable(mmc, autobkops, enable); +} + +static int do_mmc_bkops(struct cmd_tbl *cmdtp, int flag, + int argc, char * const argv[]) +{ + bool autobkops, enable; + + if (argc != 4) + return CMD_RET_USAGE; + + if (!strcmp(argv[2], "manual")) + autobkops = false; + else if (!strcmp(argv[2], "auto")) + autobkops = true; + else + return CMD_RET_FAILURE; + + if (!strcmp(argv[3], "disable")) + enable = false; + else if (!strcmp(argv[3], "enable")) + enable = true; + else + return CMD_RET_FAILURE; + + return mmc_bkops_common(argv[1], autobkops, enable); +} + +static int do_mmc_bkops_enable(struct cmd_tbl *cmdtp, int flag, + int argc, char * const argv[]) +{ + if (argc != 2) + return CMD_RET_USAGE; + + return mmc_bkops_common(argv[1], false, true); } #endif
@@ -1102,6 +1132,7 @@ static struct cmd_tbl cmd_mmc[] = { U_BOOT_CMD_MKENT(setdsr, 2, 0, do_mmc_setdsr, "", ""), #ifdef CONFIG_CMD_BKOPS_ENABLE U_BOOT_CMD_MKENT(bkops-enable, 2, 0, do_mmc_bkops_enable, "", ""), + U_BOOT_CMD_MKENT(bkops, 4, 0, do_mmc_bkops, "", ""), #endif };
@@ -1188,6 +1219,8 @@ U_BOOT_CMD( #ifdef CONFIG_CMD_BKOPS_ENABLE "mmc bkops-enable <dev> - enable background operations handshake on device\n" " WARNING: This is a write-once setting.\n" + "mmc bkops <dev> [auto|manual] [enable|disable]\n" + " - configure background operations handshake on device\n" #endif );
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 210703ea46b..afbc497b12c 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -3127,9 +3127,10 @@ int mmc_init_device(int num) #endif
#ifdef CONFIG_CMD_BKOPS_ENABLE -int mmc_set_bkops_enable(struct mmc *mmc) +int mmc_set_bkops_enable(struct mmc *mmc, bool autobkops, bool enable) { int err; + u32 bit = autobkops ? BIT(1) : BIT(0); ALLOC_CACHE_ALIGN_BUFFER(u8, ext_csd, MMC_MAX_BLOCK_LEN);
err = mmc_send_ext_csd(mmc, ext_csd); @@ -3143,18 +3144,21 @@ int mmc_set_bkops_enable(struct mmc *mmc) return -EMEDIUMTYPE; }
- if (ext_csd[EXT_CSD_BKOPS_EN] & 0x1) { + if (enable && (ext_csd[EXT_CSD_BKOPS_EN] & bit)) { puts("Background operations already enabled\n"); return 0; }
- err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_BKOPS_EN, 1); + err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_BKOPS_EN, + enable ? bit : 0); if (err) { - puts("Failed to enable manual background operations\n"); + printf("Failed to %sable manual background operations\n", + enable ? "en" : "dis"); return err; }
- puts("Enabled manual background operations\n"); + printf("%sabled %s background operations\n", + enable ? "En" : "Dis", autobkops ? "auto" : "manual");
return 0; } diff --git a/include/mmc.h b/include/mmc.h index 571fa625d02..36dd841d5d1 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -892,9 +892,17 @@ int mmc_rpmb_write(struct mmc *mmc, void *addr, unsigned short blk, int mmc_rpmb_route_frames(struct mmc *mmc, void *req, unsigned long reqlen, void *rsp, unsigned long rsplen);
-#ifdef CONFIG_CMD_BKOPS_ENABLE -int mmc_set_bkops_enable(struct mmc *mmc); -#endif +/** + * mmc_set_bkops_enable() - enable background operations + * @param mmc Pointer to a MMC device struct + * @param autobkops Enable automatic bkops, not manual bkops + * @param enable Enable bkops, not disable + * + * Enable or disable automatic or manual background operation of the eMMC. + * + * Return: 0 on success, <0 on error. + */ +int mmc_set_bkops_enable(struct mmc *mmc, bool autobkops, bool enable);
/** * Start device initialization and return immediately; it does not block on
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- int dev;
- if (argc != 2)
- return mmc_set_bkops_enable(mmc, autobkops, enable);
- bool autobkops, enable;
- if (argc != 4)
- if (!strcmp(argv[2], "manual"))
autobkops = false;
- else if (!strcmp(argv[2], "auto"))
autobkops = true;
- else
- if (!strcmp(argv[3], "disable"))
enable = false;
- else if (!strcmp(argv[3], "enable"))
enable = true;
- else
- return mmc_bkops_common(argv[1], autobkops, enable);
- if (argc != 2)
- return mmc_bkops_common(argv[1], false, true);
} #endif
- U_BOOT_CMD_MKENT(bkops, 4, 0, do_mmc_bkops, "", ""),
#endif };
- "mmc bkops <dev> [auto|manual] [enable|disable]\n"
- " - configure background operations handshake on device\n"
#endif );
- if (enable && (ext_csd[EXT_CSD_BKOPS_EN] & bit)) { puts("Background operations already enabled\n"); return 0; }
if (err) {enable ? bit : 0);
return err; }enable ? "en" : "dis");
- mmc_set_bkops_enable() - enable background operations
- @param mmc Pointer to a MMC device struct
- @param autobkops Enable automatic bkops, not manual bkops
- @param enable Enable bkops, not disable
- Enable or disable automatic or manual background operation of the eMMC.
- Return: 0 on success, <0 on error.
- Start device initialization and return immediately; it does not block on
Jaehoon Chung
