[U-Boot] [PATCH] net: ne2000: Divided a function of NE2000 driver
get_prom function was used __attriute__ , but it is not enable. ax88796.o does not do link besides ne2000.o. When ld is carried out, get_prom function of ax88796.c is ignored. This problem is a thing by specifications of ld. I checked and test this patch on SuperH and MIPS.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com --- drivers/net/Makefile | 6 +- drivers/net/ax88796.c | 2 +- drivers/net/ne2000.c | 719 +-------------------------------------------- drivers/net/ne2000_base.h | 36 ++- 4 files changed, 40 insertions(+), 723 deletions(-)
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index bcf31cb..734e058 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -42,10 +42,8 @@ COBJS-$(CONFIG_DRIVER_LAN91C96) += lan91c96.o COBJS-$(CONFIG_MACB) += macb.o COBJS-$(CONFIG_MCFFEC) += mcffec.o COBJS-$(CONFIG_NATSEMI) += natsemi.o -ifeq ($(CONFIG_DRIVER_NE2000),y) -COBJS-y += ne2000.o -COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o -endif +COBJS-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o +COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o COBJS-$(CONFIG_DRIVER_NETARMETH) += netarm_eth.o COBJS-$(CONFIG_NETCONSOLE) += netconsole.o COBJS-$(CONFIG_DRIVER_NS7520_ETHERNET) += ns7520_eth.o diff --git a/drivers/net/ax88796.c b/drivers/net/ax88796.c index 39cd101..2089141 100644 --- a/drivers/net/ax88796.c +++ b/drivers/net/ax88796.c @@ -143,7 +143,7 @@ static void ax88796_mac_read(u8 *buff) } }
-int get_prom(u8* mac_addr) +int get_prom(u8* mac_addr, u8* base_addr) { u8 prom[32]; int i; diff --git a/drivers/net/ne2000.c b/drivers/net/ne2000.c index ec92485..ab5eec7 100644 --- a/drivers/net/ne2000.c +++ b/drivers/net/ne2000.c @@ -74,600 +74,11 @@ Add SNMP
#include <common.h> #include <command.h> -#include <net.h> -#include <malloc.h> - -#define mdelay(n) udelay((n)*1000) -/* forward definition of function used for the uboot interface */ -void uboot_push_packet_len(int len); -void uboot_push_tx_done(int key, int val); - -/* - * Debugging details - * - * Set to perms of: - * 0 disables all debug output - * 1 for process debug output - * 2 for added data IO output: get_reg, put_reg - * 4 for packet allocation/free output - * 8 for only startup status, so we can tell we're installed OK - */ -#if 0 -#define DEBUG 0xf -#else -#define DEBUG 0 -#endif - -#if DEBUG & 1 -#define DEBUG_FUNCTION() do { printf("%s\n", __FUNCTION__); } while (0) -#define DEBUG_LINE() do { printf("%d\n", __LINE__); } while (0) -#define PRINTK(args...) printf(args) -#else -#define DEBUG_FUNCTION() do {} while(0) -#define DEBUG_LINE() do {} while(0) -#define PRINTK(args...) -#endif
/* NE2000 base header file */ #include "ne2000_base.h"
-#if defined(CONFIG_DRIVER_AX88796L) -/* AX88796L support */ -#include "ax88796.h" -#else -/* Basic NE2000 chip support */ -#include "ne2000.h" -#endif - -static dp83902a_priv_data_t nic; /* just one instance of the card supported */ - -static bool -dp83902a_init(void) -{ - dp83902a_priv_data_t *dp = &nic; - u8* base; -#if defined(NE2000_BASIC_INIT) - int i; -#endif - - DEBUG_FUNCTION(); - - base = dp->base; - if (!base) - return false; /* No device found */ - - DEBUG_LINE(); - -#if defined(NE2000_BASIC_INIT) - /* AX88796L doesn't need */ - /* Prepare ESA */ - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1); /* Select page 1 */ - /* Use the address from the serial EEPROM */ - for (i = 0; i < 6; i++) - DP_IN(base, DP_P1_PAR0+i, dp->esa[i]); - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0); /* Select page 0 */ - - printf("NE2000 - %s ESA: %02x:%02x:%02x:%02x:%02x:%02x\n", - "eeprom", - dp->esa[0], - dp->esa[1], - dp->esa[2], - dp->esa[3], - dp->esa[4], - dp->esa[5] ); - -#endif /* NE2000_BASIC_INIT */ - return true; -} - -static void -dp83902a_stop(void) -{ - dp83902a_priv_data_t *dp = &nic; - u8 *base = dp->base; - - DEBUG_FUNCTION(); - - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ - DP_OUT(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ - DP_OUT(base, DP_IMR, 0x00); /* Disable all interrupts */ - - dp->running = false; -} - -/* - * This function is called to "start up" the interface. It may be called - * multiple times, even when the hardware is already running. It will be - * called whenever something "hardware oriented" changes and should leave - * the hardware ready to send/receive packets. - */ -static void -dp83902a_start(u8 * enaddr) -{ - dp83902a_priv_data_t *dp = &nic; - u8 *base = dp->base; - int i; - - DEBUG_FUNCTION(); - - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ - DP_OUT(base, DP_DCR, DP_DCR_INIT); - DP_OUT(base, DP_RBCH, 0); /* Remote byte count */ - DP_OUT(base, DP_RBCL, 0); - DP_OUT(base, DP_RCR, DP_RCR_MON); /* Accept no packets */ - DP_OUT(base, DP_TCR, DP_TCR_LOCAL); /* Transmitter [virtually] off */ - DP_OUT(base, DP_TPSR, dp->tx_buf1); /* Transmitter start page */ - dp->tx1 = dp->tx2 = 0; - dp->tx_next = dp->tx_buf1; - dp->tx_started = false; - dp->running = true; - DP_OUT(base, DP_PSTART, dp->rx_buf_start); /* Receive ring start page */ - DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); /* Receive ring boundary */ - DP_OUT(base, DP_PSTOP, dp->rx_buf_end); /* Receive ring end page */ - dp->rx_next = dp->rx_buf_start - 1; - dp->running = true; - DP_OUT(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ - DP_OUT(base, DP_IMR, DP_IMR_All); /* Enable all interrupts */ - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1 | DP_CR_STOP); /* Select page 1 */ - DP_OUT(base, DP_P1_CURP, dp->rx_buf_start); /* Current page - next free page for Rx */ - dp->running = true; - for (i = 0; i < ETHER_ADDR_LEN; i++) { - /* FIXME */ - /*((vu_short*)( base + ((DP_P1_PAR0 + i) * 2) + - * 0x1400)) = enaddr[i];*/ - DP_OUT(base, DP_P1_PAR0+i, enaddr[i]); - } - /* Enable and start device */ - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_OUT(base, DP_TCR, DP_TCR_NORMAL); /* Normal transmit operations */ - DP_OUT(base, DP_RCR, DP_RCR_AB); /* Accept broadcast, no errors, no multicast */ - dp->running = true; -} - -/* - * This routine is called to start the transmitter. It is split out from the - * data handling routine so it may be called either when data becomes first - * available or when an Tx interrupt occurs - */ - -static void -dp83902a_start_xmit(int start_page, int len) -{ - dp83902a_priv_data_t *dp = (dp83902a_priv_data_t *) &nic; - u8 *base = dp->base; - - DEBUG_FUNCTION(); - -#if DEBUG & 1 - printf("Tx pkt %d len %d\n", start_page, len); - if (dp->tx_started) - printf("TX already started?!?\n"); -#endif - - DP_OUT(base, DP_ISR, (DP_ISR_TxP | DP_ISR_TxE)); - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_OUT(base, DP_TBCL, len & 0xFF); - DP_OUT(base, DP_TBCH, len >> 8); - DP_OUT(base, DP_TPSR, start_page); - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_TXPKT | DP_CR_START); - - dp->tx_started = true; -} - -/* - * This routine is called to send data to the hardware. It is known a-priori - * that there is free buffer space (dp->tx_next). - */ -static void -dp83902a_send(u8 *data, int total_len, u32 key) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - int len, start_page, pkt_len, i, isr; -#if DEBUG & 4 - int dx; -#endif - - DEBUG_FUNCTION(); - - len = pkt_len = total_len; - if (pkt_len < IEEE_8023_MIN_FRAME) - pkt_len = IEEE_8023_MIN_FRAME; - - start_page = dp->tx_next; - if (dp->tx_next == dp->tx_buf1) { - dp->tx1 = start_page; - dp->tx1_len = pkt_len; - dp->tx1_key = key; - dp->tx_next = dp->tx_buf2; - } else { - dp->tx2 = start_page; - dp->tx2_len = pkt_len; - dp->tx2_key = key; - dp->tx_next = dp->tx_buf1; - } - -#if DEBUG & 5 - printf("TX prep page %d len %d\n", start_page, pkt_len); -#endif - - DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ - { - /* - * Dummy read. The manual sez something slightly different, - * but the code is extended a bit to do what Hitachi's monitor - * does (i.e., also read data). - */ - - u16 tmp; - int len = 1; - - DP_OUT(base, DP_RSAL, 0x100 - len); - DP_OUT(base, DP_RSAH, (start_page - 1) & 0xff); - DP_OUT(base, DP_RBCL, len); - DP_OUT(base, DP_RBCH, 0); - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_RDMA | DP_CR_START); - DP_IN_DATA(dp->data, tmp); - } - -#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA - /* - * Stall for a bit before continuing to work around random data - * corruption problems on some platforms. - */ - CYGACC_CALL_IF_DELAY_US(1); -#endif - - /* Send data to device buffer(s) */ - DP_OUT(base, DP_RSAL, 0); - DP_OUT(base, DP_RSAH, start_page); - DP_OUT(base, DP_RBCL, pkt_len & 0xFF); - DP_OUT(base, DP_RBCH, pkt_len >> 8); - DP_OUT(base, DP_CR, DP_CR_WDMA | DP_CR_START); - - /* Put data into buffer */ -#if DEBUG & 4 - printf(" sg buf %08lx len %08x\n ", (u32)data, len); - dx = 0; -#endif - while (len > 0) { -#if DEBUG & 4 - printf(" %02x", *data); - if (0 == (++dx % 16)) printf("\n "); -#endif - - DP_OUT_DATA(dp->data, *data++); - len--; - } -#if DEBUG & 4 - printf("\n"); -#endif - if (total_len < pkt_len) { -#if DEBUG & 4 - printf(" + %d bytes of padding\n", pkt_len - total_len); -#endif - /* Padding to 802.3 length was required */ - for (i = total_len; i < pkt_len;) { - i++; - DP_OUT_DATA(dp->data, 0); - } - } - -#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA - /* - * After last data write, delay for a bit before accessing the - * device again, or we may get random data corruption in the last - * datum (on some platforms). - */ - CYGACC_CALL_IF_DELAY_US(1); -#endif - - /* Wait for DMA to complete */ - do { - DP_IN(base, DP_ISR, isr); - } while ((isr & DP_ISR_RDC) == 0); - - /* Then disable DMA */ - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - - /* Start transmit if not already going */ - if (!dp->tx_started) { - if (start_page == dp->tx1) { - dp->tx_int = 1; /* Expecting interrupt from BUF1 */ - } else { - dp->tx_int = 2; /* Expecting interrupt from BUF2 */ - } - dp83902a_start_xmit(start_page, pkt_len); - } -} - -/* - * This function is called when a packet has been received. It's job is - * to prepare to unload the packet from the hardware. Once the length of - * the packet is known, the upper layer of the driver can be told. When - * the upper layer is ready to unload the packet, the internal function - * 'dp83902a_recv' will be called to actually fetch it from the hardware. - */ -static void -dp83902a_RxEvent(void) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - u8 rsr; - u8 rcv_hdr[4]; - int i, len, pkt, cur; - - DEBUG_FUNCTION(); - - DP_IN(base, DP_RSR, rsr); - while (true) { - /* Read incoming packet header */ - DP_OUT(base, DP_CR, DP_CR_PAGE1 | DP_CR_NODMA | DP_CR_START); - DP_IN(base, DP_P1_CURP, cur); - DP_OUT(base, DP_P1_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_IN(base, DP_BNDRY, pkt); - - pkt += 1; - if (pkt == dp->rx_buf_end) - pkt = dp->rx_buf_start; - - if (pkt == cur) { - break; - } - DP_OUT(base, DP_RBCL, sizeof(rcv_hdr)); - DP_OUT(base, DP_RBCH, 0); - DP_OUT(base, DP_RSAL, 0); - DP_OUT(base, DP_RSAH, pkt); - if (dp->rx_next == pkt) { - if (cur == dp->rx_buf_start) - DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); - else - DP_OUT(base, DP_BNDRY, cur - 1); /* Update pointer */ - return; - } - dp->rx_next = pkt; - DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ - DP_OUT(base, DP_CR, DP_CR_RDMA | DP_CR_START); -#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_RX_DMA - CYGACC_CALL_IF_DELAY_US(10); -#endif - - /* read header (get data size)*/ - for (i = 0; i < sizeof(rcv_hdr);) { - DP_IN_DATA(dp->data, rcv_hdr[i++]); - } - -#if DEBUG & 5 - printf("rx hdr %02x %02x %02x %02x\n", - rcv_hdr[0], rcv_hdr[1], rcv_hdr[2], rcv_hdr[3]); -#endif - len = ((rcv_hdr[3] << 8) | rcv_hdr[2]) - sizeof(rcv_hdr); - - /* data read */ - uboot_push_packet_len(len); - - if (rcv_hdr[1] == dp->rx_buf_start) - DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); - else - DP_OUT(base, DP_BNDRY, rcv_hdr[1] - 1); /* Update pointer */ - } -} - -/* - * This function is called as a result of the "eth_drv_recv()" call above. - * It's job is to actually fetch data for a packet from the hardware once - * memory buffers have been allocated for the packet. Note that the buffers - * may come in pieces, using a scatter-gather list. This allows for more - * efficient processing in the upper layers of the stack. - */ -static void -dp83902a_recv(u8 *data, int len) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - int i, mlen; - u8 saved_char = 0; - bool saved; -#if DEBUG & 4 - int dx; -#endif - - DEBUG_FUNCTION(); - -#if DEBUG & 5 - printf("Rx packet %d length %d\n", dp->rx_next, len); -#endif - - /* Read incoming packet data */ - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_OUT(base, DP_RBCL, len & 0xFF); - DP_OUT(base, DP_RBCH, len >> 8); - DP_OUT(base, DP_RSAL, 4); /* Past header */ - DP_OUT(base, DP_RSAH, dp->rx_next); - DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ - DP_OUT(base, DP_CR, DP_CR_RDMA | DP_CR_START); -#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_RX_DMA - CYGACC_CALL_IF_DELAY_US(10); -#endif - - saved = false; - for (i = 0; i < 1; i++) { - if (data) { - mlen = len; -#if DEBUG & 4 - printf(" sg buf %08lx len %08x \n", (u32) data, mlen); - dx = 0; -#endif - while (0 < mlen) { - /* Saved byte from previous loop? */ - if (saved) { - *data++ = saved_char; - mlen--; - saved = false; - continue; - } - - { - u8 tmp; - DP_IN_DATA(dp->data, tmp); -#if DEBUG & 4 - printf(" %02x", tmp); - if (0 == (++dx % 16)) printf("\n "); -#endif - *data++ = tmp;; - mlen--; - } - } -#if DEBUG & 4 - printf("\n"); -#endif - } - } -} - -static void -dp83902a_TxEvent(void) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - u8 tsr; - u32 key; - - DEBUG_FUNCTION(); - - DP_IN(base, DP_TSR, tsr); - if (dp->tx_int == 1) { - key = dp->tx1_key; - dp->tx1 = 0; - } else { - key = dp->tx2_key; - dp->tx2 = 0; - } - /* Start next packet if one is ready */ - dp->tx_started = false; - if (dp->tx1) { - dp83902a_start_xmit(dp->tx1, dp->tx1_len); - dp->tx_int = 1; - } else if (dp->tx2) { - dp83902a_start_xmit(dp->tx2, dp->tx2_len); - dp->tx_int = 2; - } else { - dp->tx_int = 0; - } - /* Tell higher level we sent this packet */ - uboot_push_tx_done(key, 0); -} - -/* - * Read the tally counters to clear them. Called in response to a CNT - * interrupt. - */ -static void -dp83902a_ClearCounters(void) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - u8 cnt1, cnt2, cnt3; - - DP_IN(base, DP_FER, cnt1); - DP_IN(base, DP_CER, cnt2); - DP_IN(base, DP_MISSED, cnt3); - DP_OUT(base, DP_ISR, DP_ISR_CNT); -} - -/* - * Deal with an overflow condition. This code follows the procedure set - * out in section 7.0 of the datasheet. - */ -static void -dp83902a_Overflow(void) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *)&nic; - u8 *base = dp->base; - u8 isr; - - /* Issue a stop command and wait 1.6ms for it to complete. */ - DP_OUT(base, DP_CR, DP_CR_STOP | DP_CR_NODMA); - CYGACC_CALL_IF_DELAY_US(1600); - - /* Clear the remote byte counter registers. */ - DP_OUT(base, DP_RBCL, 0); - DP_OUT(base, DP_RBCH, 0); - - /* Enter loopback mode while we clear the buffer. */ - DP_OUT(base, DP_TCR, DP_TCR_LOCAL); - DP_OUT(base, DP_CR, DP_CR_START | DP_CR_NODMA); - - /* - * Read in as many packets as we can and acknowledge any and receive - * interrupts. Since the buffer has overflowed, a receive event of - * some kind will have occured. - */ - dp83902a_RxEvent(); - DP_OUT(base, DP_ISR, DP_ISR_RxP|DP_ISR_RxE); - - /* Clear the overflow condition and leave loopback mode. */ - DP_OUT(base, DP_ISR, DP_ISR_OFLW); - DP_OUT(base, DP_TCR, DP_TCR_NORMAL); - - /* - * If a transmit command was issued, but no transmit event has occured, - * restart it here. - */ - DP_IN(base, DP_ISR, isr); - if (dp->tx_started && !(isr & (DP_ISR_TxP|DP_ISR_TxE))) { - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_TXPKT | DP_CR_START); - } -} - -static void -dp83902a_poll(void) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - u8 isr; - - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0 | DP_CR_START); - DP_IN(base, DP_ISR, isr); - while (0 != isr) { - /* - * The CNT interrupt triggers when the MSB of one of the error - * counters is set. We don't much care about these counters, but - * we should read their values to reset them. - */ - if (isr & DP_ISR_CNT) { - dp83902a_ClearCounters(); - } - /* - * Check for overflow. It's a special case, since there's a - * particular procedure that must be followed to get back into - * a running state.a - */ - if (isr & DP_ISR_OFLW) { - dp83902a_Overflow(); - } else { - /* - * Other kinds of interrupts can be acknowledged simply by - * clearing the relevant bits of the ISR. Do that now, then - * handle the interrupts we care about. - */ - DP_OUT(base, DP_ISR, isr); /* Clear set bits */ - if (!dp->running) break; /* Is this necessary? */ - /* - * Check for tx_started on TX event since these may happen - * spuriously it seems. - */ - if (isr & (DP_ISR_TxP|DP_ISR_TxE) && dp->tx_started) { - dp83902a_TxEvent(); - } - if (isr & (DP_ISR_RxP|DP_ISR_RxE)) { - dp83902a_RxEvent(); - } - } - DP_IN(base, DP_ISR, isr); - } -} - +#define mdelay(n) udelay((n)*1000) /* find prom (taken from pc_net_cs.c from Linux) */
#include "8390.h" @@ -763,18 +174,16 @@ static hw_info_t hw_info[] = { #define PCNET_RESET 0x1f /* Issue a read to reset, a write to clear. */ #define PCNET_MISC 0x18 /* For IBM CCAE and Socket EA cards */
-static void pcnet_reset_8390(void) +static void pcnet_reset_8390(u8* addr) { int i, r;
- PRINTK("nic base is %lx\n", nic.base); - n2k_outb(E8390_NODMA + E8390_PAGE0+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", nic.base + E8390_CMD, n2k_inb(E8390_CMD)); + PRINTK("cmd (at %lx) is %x\n", addr + E8390_CMD, n2k_inb(E8390_CMD)); n2k_outb(E8390_NODMA+E8390_PAGE1+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", nic.base + E8390_CMD, n2k_inb(E8390_CMD)); + PRINTK("cmd (at %lx) is %x\n", addr + E8390_CMD, n2k_inb(E8390_CMD)); n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", nic.base + E8390_CMD, n2k_inb(E8390_CMD)); + PRINTK("cmd (at %lx) is %x\n", addr + E8390_CMD, n2k_inb(E8390_CMD)); n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD);
n2k_outb(n2k_inb(PCNET_RESET), PCNET_RESET); @@ -791,8 +200,7 @@ static void pcnet_reset_8390(void) printf("pcnet_reset_8390() did not complete.\n"); } /* pcnet_reset_8390 */
-int get_prom(u8* mac_addr) __attribute__ ((weak, alias ("__get_prom"))); -int __get_prom(u8* mac_addr) +int get_prom(u8* mac_addr, u8* base_addr) { u8 prom[32]; int i, j; @@ -816,7 +224,7 @@ int __get_prom(u8* mac_addr)
PRINTK ("trying to get MAC via prom reading\n");
- pcnet_reset_8390 (); + pcnet_reset_8390 (base_addr);
mdelay (10);
@@ -849,116 +257,3 @@ int __get_prom(u8* mac_addr) } return 0; } - -/* U-boot specific routines */ -static u8 *pbuf = NULL; - -static int pkey = -1; -static int initialized = 0; - -void uboot_push_packet_len(int len) { - PRINTK("pushed len = %d\n", len); - if (len >= 2000) { - printf("NE2000: packet too big\n"); - return; - } - dp83902a_recv(&pbuf[0], len); - - /*Just pass it to the upper layer*/ - NetReceive(&pbuf[0], len); -} - -void uboot_push_tx_done(int key, int val) { - PRINTK("pushed key = %d\n", key); - pkey = key; -} - -int eth_init(bd_t *bd) { - int r; - u8 dev_addr[6]; - char ethaddr[20]; - - PRINTK("### eth_init\n"); - - if (!pbuf) { - pbuf = malloc(2000); - if (!pbuf) { - printf("Cannot allocate rx buffer\n"); - return -1; - } - } - -#ifdef CONFIG_DRIVER_NE2000_CCR - { - vu_char *p = (vu_char *) CONFIG_DRIVER_NE2000_CCR; - - PRINTK("CCR before is %x\n", *p); - *p = CONFIG_DRIVER_NE2000_VAL; - PRINTK("CCR after is %x\n", *p); - } -#endif - - nic.base = (u8 *) CONFIG_DRIVER_NE2000_BASE; - - r = get_prom(dev_addr); - if (!r) - return -1; - - sprintf (ethaddr, "%02X:%02X:%02X:%02X:%02X:%02X", - dev_addr[0], dev_addr[1], - dev_addr[2], dev_addr[3], - dev_addr[4], dev_addr[5]) ; - PRINTK("Set environment from HW MAC addr = "%s"\n", ethaddr); - setenv ("ethaddr", ethaddr); - - nic.data = nic.base + DP_DATA; - nic.tx_buf1 = START_PG; - nic.tx_buf2 = START_PG2; - nic.rx_buf_start = RX_START; - nic.rx_buf_end = RX_END; - - if (dp83902a_init() == false) - return -1; - - dp83902a_start(dev_addr); - initialized = 1; - - return 0; -} - -void eth_halt() { - - PRINTK("### eth_halt\n"); - if(initialized) - dp83902a_stop(); - initialized = 0; -} - -int eth_rx() { - dp83902a_poll(); - return 1; -} - -int eth_send(volatile void *packet, int length) { - int tmo; - - PRINTK("### eth_send\n"); - - pkey = -1; - - dp83902a_send((u8 *) packet, length, 666); - tmo = get_timer (0) + TOUT * CFG_HZ; - while(1) { - dp83902a_poll(); - if (pkey != -1) { - PRINTK("Packet sucesfully sent\n"); - return 0; - } - if (get_timer (0) >= tmo) { - printf("transmission error (timoeut)\n"); - return 0; - } - - } - return 0; -} diff --git a/drivers/net/ne2000_base.h b/drivers/net/ne2000_base.h index 948b290..5446de4 100644 --- a/drivers/net/ne2000_base.h +++ b/drivers/net/ne2000_base.h @@ -80,10 +80,35 @@ are GPL, so this is, of course, GPL. #define __NE2000_BASE_H__
#define bool int - #define false 0 #define true 1
+/* + * Debugging details + * + * Set to perms of: + * 0 disables all debug output + * 1 for process debug output + * 2 for added data IO output: get_reg, put_reg + * 4 for packet allocation/free output + * 8 for only startup status, so we can tell we're installed OK + */ +#if 0 +#define DEBUG 0xf +#else +#define DEBUG 0 +#endif + +#if DEBUG & 1 +#define DEBUG_FUNCTION() do { printf("%s\n", __FUNCTION__); } while (0) +#define DEBUG_LINE() do { printf("%d\n", __LINE__); } while (0) +#define PRINTK(args...) printf(args) +#else +#define DEBUG_FUNCTION() do {} while(0) +#define DEBUG_LINE() do {} while(0) +#define PRINTK(args...) +#endif + /* timeout for tx/rx in s */ #define TOUT 5 /* Ether MAC address size */ @@ -119,11 +144,6 @@ typedef struct dp83902a_priv_data { int rx_buf_start, rx_buf_end; } dp83902a_priv_data_t;
-/* - * Some forward declarations - */ -static void dp83902a_poll(void); - /* ------------------------------------------------------------------------ */ /* Register offsets */
@@ -281,4 +301,8 @@ static void dp83902a_poll(void);
#define IEEE_8023_MAX_FRAME 1518 /* Largest possible ethernet frame */ #define IEEE_8023_MIN_FRAME 64 /* Smallest possible ethernet frame */ + +/* Functions */ +int get_prom(u8* mac_addr, u8* base_addr); + #endif /* __NE2000_BASE_H__ */
Dear Ben,
I think this patch was not added, nor was any feedback sent?
Please comment.
Wolfgang Denk wrote:
Dear Ben,
Please comment.
There's been commentary about v2 of this patch within the last couple of weeks. I'm not crazy about it but no better ideas have shown up. I'll pull it in ASAP.
regards, Ben
Ben Warren
Nobuhiro Iwamatsu
