[U-Boot] [PATCH] net: eth-uclass: Remove warning about ROM MAC address
Using a MAC address from ROM storage is the normal case for most ethernet hardware. Why should we warn about this?
Signed-off-by: Soeren Moch smoch@web.de --- Cc: Joe Hershberger joe.hershberger@ni.com Cc: u-boot@lists.denx.de --- net/eth-uclass.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 3bd98b01ad..8b29de37bb 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -538,8 +538,6 @@ static int eth_post_probe(struct udevice *dev) memcpy(pdata->enetaddr, env_enetaddr, ARP_HLEN); } else if (is_valid_ethaddr(pdata->enetaddr)) { eth_env_set_enetaddr_by_index("eth", dev->seq, pdata->enetaddr); - printf("\nWarning: %s using MAC address from ROM\n", - dev->name); } else if (is_zero_ethaddr(pdata->enetaddr) || !is_valid_ethaddr(pdata->enetaddr)) { #ifdef CONFIG_NET_RANDOM_ETHADDR -- 2.17.1
Hi Soeren,
Most hardware that U-Boot runs on is an SoC and the boards rarely have a ROM associated with the Ethernet MAC. Usually the storage for the ethaddr is the U-Boot environment itself. That's the reason it warns.
Cheers, -Joe
2.17.1
Hi Joe,
On 11.10.19 05:06, Joe Hershberger wrote:
Hi Soeren,
Hm, I just converted the tbs2910 board to DM_ETH and now see this misleading warning. This board is based on a i.MX6Q SoC (ARMv7), the ethernet MAC is stored in fuses on this SoC. There is absolutely nothing wrong in using the ROM MAC address. For systems without ROM storage we use the environment to set the MAC, also fine. Also OK if both addresses are set identically. We only should warn the user if addresses are set inconsistently or not set at all.
Regards, Soeren
Cheers, -Joe
2.17.1
Hi Joe,
On Fri, Oct 11, 2019 at 12:06 AM Joe Hershberger joe.hershberger@ni.com wrote:
Hi Soeren,
On i.MX SoCs the MAC usually is stored in fuses via On-Chip OTP Controller (OCOTP).
Should we at least change the message to debug() level instead?
As Soeren says there is nothing wrong with the fact that the MAC addresses are retrieved from fuses and there is nothing the user can do about this warning message.
IMHO it is causing pure noise.
Thanks
Hi Soeren,
dev->name);
I also find this warning misleading:
Reviewed-by: Fabio Estevam festevam@gmail.com
Some months ago I came up with the very same patch and I currently have it in my local fork with the description "Reading the MAC address from ROM is often a standard use case and should not produce a warning".
Therefore I'm supporting Soeren's and Fabio's point of view here and I'm in favor of merging this patch or if preferred, change the printf() to debug().
Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de
} else if (is_zero_ethaddr(pdata->enetaddr) || !is_valid_ethaddr(pdata->enetaddr)) { #ifdef CONFIG_NET_RANDOM_ETHADDRdev->name);
-- 2.17.1
Hi Joe,
On Wed, Dec 11, 2019 at 8:54 AM Schrempf Frieder frieder.schrempf@kontron.de wrote:
Any feedback, please?
Hi Joe,
Ping
On Mon, Jan 6, 2020 at 8:32 PM Fabio Estevam festevam@gmail.com wrote:
Hi Joe,
On Tue, Jan 28, 2020 at 10:33 AM Fabio Estevam festevam@gmail.com wrote:
Hi Joe,
Ping
Hi Joe,
Traditionally the env was the source of truth for the MAC, so using the ROM was a fall-back if the env didn't have one. But times change, I guess. I'll pull this into my next PR.
Fabio Estevam
Joe Hershberger
Schrempf Frieder
Soeren Moch
