[PATCH v1 0/4] Sync StarFive JH7110 clock and reset dt-bindings with Linux
There are differences in clock / reset dt-bindings between U-Boot and Linux. Sync them, so it is feasible to use OF_UPSTREAM for StarFive JH7110 SoC.
Hal Feng (4): dt-bindings: clock: jh7110: Sync with Linux dt-bindings: reset: jh7110: Sync with Linux clk: starfive: jh7110: Sync clock definitions with Linux riscv: dts: jh7110: Sync clock and reset definitions with Linux
.../dts/jh7110-starfive-visionfive-2.dtsi | 6 +- arch/riscv/dts/jh7110-u-boot.dtsi | 2 +- arch/riscv/dts/jh7110.dtsi | 28 +-- drivers/clk/starfive/clk-jh7110-pll.c | 6 +- drivers/clk/starfive/clk-jh7110.c | 44 ++--- .../dt-bindings/clock/starfive,jh7110-crg.h | 180 +++++++++++------- .../dt-bindings/reset/starfive,jh7110-crg.h | 144 ++++++++------ 7 files changed, 243 insertions(+), 167 deletions(-)
base-commit: ea722aa5eb33740ae77e8816aeb72b385e621cd0
Sync JH7110 clock dt-bindings with Linux, which is the same with dts/upstream/include/dt-bindings/clock/starfive,jh7110-crg.h except copyright.
Signed-off-by: Hal Feng hal.feng@starfivetech.com --- .../dt-bindings/clock/starfive,jh7110-crg.h | 180 +++++++++++------- 1 file changed, 112 insertions(+), 68 deletions(-)
diff --git a/include/dt-bindings/clock/starfive,jh7110-crg.h b/include/dt-bindings/clock/starfive,jh7110-crg.h index b51e3829ff..4eabb05473 100644 --- a/include/dt-bindings/clock/starfive,jh7110-crg.h +++ b/include/dt-bindings/clock/starfive,jh7110-crg.h @@ -5,19 +5,21 @@ * Author: Yanhong Wang yanhong.wang@starfivetech.com */
-#ifndef __DT_BINDINGS_CLOCK_STARFIVE_JH7110_H__ -#define __DT_BINDINGS_CLOCK_STARFIVE_JH7110_H__ +#ifndef __DT_BINDINGS_CLOCK_STARFIVE_JH7110_CRG_H__ +#define __DT_BINDINGS_CLOCK_STARFIVE_JH7110_CRG_H__
-#define JH7110_SYSCLK_PLL0_OUT 0 -#define JH7110_SYSCLK_PLL1_OUT 1 -#define JH7110_SYSCLK_PLL2_OUT 2 +/* PLL clocks */ +#define JH7110_PLLCLK_PLL0_OUT 0 +#define JH7110_PLLCLK_PLL1_OUT 1 +#define JH7110_PLLCLK_PLL2_OUT 2 #define JH7110_PLLCLK_END 3
+/* SYSCRG clocks */ #define JH7110_SYSCLK_CPU_ROOT 0 #define JH7110_SYSCLK_CPU_CORE 1 #define JH7110_SYSCLK_CPU_BUS 2 #define JH7110_SYSCLK_GPU_ROOT 3 -#define JH7110_SYSCLK_PERH_ROOT 4 +#define JH7110_SYSCLK_PERH_ROOT 4 #define JH7110_SYSCLK_BUS_ROOT 5 #define JH7110_SYSCLK_NOCSTG_BUS 6 #define JH7110_SYSCLK_AXI_CFG0 7 @@ -26,9 +28,9 @@ #define JH7110_SYSCLK_AHB1 10 #define JH7110_SYSCLK_APB_BUS 11 #define JH7110_SYSCLK_APB0 12 -#define JH7110_SYSCLK_PLL0_DIV2 13 -#define JH7110_SYSCLK_PLL1_DIV2 14 -#define JH7110_SYSCLK_PLL2_DIV2 15 +#define JH7110_SYSCLK_PLL0_DIV2 13 +#define JH7110_SYSCLK_PLL1_DIV2 14 +#define JH7110_SYSCLK_PLL2_DIV2 15 #define JH7110_SYSCLK_AUDIO_ROOT 16 #define JH7110_SYSCLK_MCLK_INNER 17 #define JH7110_SYSCLK_MCLK 18 @@ -50,12 +52,12 @@ #define JH7110_SYSCLK_TRACE2 34 #define JH7110_SYSCLK_TRACE3 35 #define JH7110_SYSCLK_TRACE4 36 -#define JH7110_SYSCLK_TRACE_COM 37 +#define JH7110_SYSCLK_TRACE_COM 37 #define JH7110_SYSCLK_NOC_BUS_CPU_AXI 38 #define JH7110_SYSCLK_NOC_BUS_AXICFG0_AXI 39 #define JH7110_SYSCLK_OSC_DIV2 40 -#define JH7110_SYSCLK_PLL1_DIV4 41 -#define JH7110_SYSCLK_PLL1_DIV8 42 +#define JH7110_SYSCLK_PLL1_DIV4 41 +#define JH7110_SYSCLK_PLL1_DIV8 42 #define JH7110_SYSCLK_DDR_BUS 43 #define JH7110_SYSCLK_DDR_AXI 44 #define JH7110_SYSCLK_GPU_CORE 45 @@ -64,21 +66,21 @@ #define JH7110_SYSCLK_GPU_APB 48 #define JH7110_SYSCLK_GPU_RTC_TOGGLE 49 #define JH7110_SYSCLK_NOC_BUS_GPU_AXI 50 -#define JH7110_SYSCLK_ISP_TOP_CLK_ISPCORE_2X 51 -#define JH7110_SYSCLK_ISP_TOP_CLK_ISP_AXI 52 +#define JH7110_SYSCLK_ISP_TOP_CORE 51 +#define JH7110_SYSCLK_ISP_TOP_AXI 52 #define JH7110_SYSCLK_NOC_BUS_ISP_AXI 53 #define JH7110_SYSCLK_HIFI4_CORE 54 -#define JH7110_SYSCLK_HIFI4_AXI 55 -#define JH7110_SYSCLK_AXI_CFG1_DEC_MAIN 56 -#define JH7110_SYSCLK_AXI_CFG1_DEC_AHB 57 +#define JH7110_SYSCLK_HIFI4_AXI 55 +#define JH7110_SYSCLK_AXI_CFG1_MAIN 56 +#define JH7110_SYSCLK_AXI_CFG1_AHB 57 #define JH7110_SYSCLK_VOUT_SRC 58 #define JH7110_SYSCLK_VOUT_AXI 59 #define JH7110_SYSCLK_NOC_BUS_DISP_AXI 60 -#define JH7110_SYSCLK_VOUT_TOP_CLK_VOUT_AHB 61 -#define JH7110_SYSCLK_VOUT_TOP_CLK_VOUT_AXI 62 -#define JH7110_SYSCLK_VOUT_TOP_CLK_HDMITX0_MCLK 63 -#define JH7110_SYSCLK_VOUT_TOP_CLK_MIPIPHY_REF 64 -#define JH7110_SYSCLK_JPEGC_AXI 65 +#define JH7110_SYSCLK_VOUT_TOP_AHB 61 +#define JH7110_SYSCLK_VOUT_TOP_AXI 62 +#define JH7110_SYSCLK_VOUT_TOP_HDMITX0_MCLK 63 +#define JH7110_SYSCLK_VOUT_TOP_MIPIPHY_REF 64 +#define JH7110_SYSCLK_JPEGC_AXI 65 #define JH7110_SYSCLK_CODAJ12_AXI 66 #define JH7110_SYSCLK_CODAJ12_CORE 67 #define JH7110_SYSCLK_CODAJ12_APB 68 @@ -87,8 +89,8 @@ #define JH7110_SYSCLK_WAVE511_BPU 71 #define JH7110_SYSCLK_WAVE511_VCE 72 #define JH7110_SYSCLK_WAVE511_APB 73 -#define JH7110_SYSCLK_VDEC_JPG_ARB_JPG 74 -#define JH7110_SYSCLK_VDEC_JPG_ARB_MAIN 75 +#define JH7110_SYSCLK_VDEC_JPG 74 +#define JH7110_SYSCLK_VDEC_MAIN 75 #define JH7110_SYSCLK_NOC_BUS_VDEC_AXI 76 #define JH7110_SYSCLK_VENC_AXI 77 #define JH7110_SYSCLK_WAVE420L_AXI 78 @@ -96,37 +98,37 @@ #define JH7110_SYSCLK_WAVE420L_VCE 80 #define JH7110_SYSCLK_WAVE420L_APB 81 #define JH7110_SYSCLK_NOC_BUS_VENC_AXI 82 -#define JH7110_SYSCLK_AXI_CFG0_DEC_MAIN_DIV 83 -#define JH7110_SYSCLK_AXI_CFG0_DEC_MAIN 84 -#define JH7110_SYSCLK_AXI_CFG0_DEC_HIFI4 85 +#define JH7110_SYSCLK_AXI_CFG0_MAIN_DIV 83 +#define JH7110_SYSCLK_AXI_CFG0_MAIN 84 +#define JH7110_SYSCLK_AXI_CFG0_HIFI4 85 #define JH7110_SYSCLK_AXIMEM2_AXI 86 #define JH7110_SYSCLK_QSPI_AHB 87 #define JH7110_SYSCLK_QSPI_APB 88 #define JH7110_SYSCLK_QSPI_REF_SRC 89 #define JH7110_SYSCLK_QSPI_REF 90 -#define JH7110_SYSCLK_SDIO0_AHB 91 -#define JH7110_SYSCLK_SDIO1_AHB 92 +#define JH7110_SYSCLK_SDIO0_AHB 91 +#define JH7110_SYSCLK_SDIO1_AHB 92 #define JH7110_SYSCLK_SDIO0_SDCARD 93 #define JH7110_SYSCLK_SDIO1_SDCARD 94 #define JH7110_SYSCLK_USB_125M 95 #define JH7110_SYSCLK_NOC_BUS_STG_AXI 96 -#define JH7110_SYSCLK_GMAC1_AHB 97 -#define JH7110_SYSCLK_GMAC1_AXI 98 +#define JH7110_SYSCLK_GMAC1_AHB 97 +#define JH7110_SYSCLK_GMAC1_AXI 98 #define JH7110_SYSCLK_GMAC_SRC 99 #define JH7110_SYSCLK_GMAC1_GTXCLK 100 #define JH7110_SYSCLK_GMAC1_RMII_RTX 101 -#define JH7110_SYSCLK_GMAC1_PTP 102 +#define JH7110_SYSCLK_GMAC1_PTP 102 #define JH7110_SYSCLK_GMAC1_RX 103 #define JH7110_SYSCLK_GMAC1_RX_INV 104 #define JH7110_SYSCLK_GMAC1_TX 105 #define JH7110_SYSCLK_GMAC1_TX_INV 106 #define JH7110_SYSCLK_GMAC1_GTXC 107 #define JH7110_SYSCLK_GMAC0_GTXCLK 108 -#define JH7110_SYSCLK_GMAC0_PTP 109 +#define JH7110_SYSCLK_GMAC0_PTP 109 #define JH7110_SYSCLK_GMAC_PHY 110 #define JH7110_SYSCLK_GMAC0_GTXC 111 -#define JH7110_SYSCLK_IOMUX_APB 112 -#define JH7110_SYSCLK_MAILBOX 113 +#define JH7110_SYSCLK_IOMUX_APB 112 +#define JH7110_SYSCLK_MAILBOX_APB 113 #define JH7110_SYSCLK_INT_CTRL_APB 114 #define JH7110_SYSCLK_CAN0_APB 115 #define JH7110_SYSCLK_CAN0_TIMER 116 @@ -137,13 +139,13 @@ #define JH7110_SYSCLK_PWM_APB 121 #define JH7110_SYSCLK_WDT_APB 122 #define JH7110_SYSCLK_WDT_CORE 123 -#define JH7110_SYSCLK_TIMER_APB 124 +#define JH7110_SYSCLK_TIMER_APB 124 #define JH7110_SYSCLK_TIMER0 125 #define JH7110_SYSCLK_TIMER1 126 #define JH7110_SYSCLK_TIMER2 127 #define JH7110_SYSCLK_TIMER3 128 #define JH7110_SYSCLK_TEMP_APB 129 -#define JH7110_SYSCLK_TEMP_CORE 130 +#define JH7110_SYSCLK_TEMP_CORE 130 #define JH7110_SYSCLK_SPI0_APB 131 #define JH7110_SYSCLK_SPI1_APB 132 #define JH7110_SYSCLK_SPI2_APB 133 @@ -158,21 +160,21 @@ #define JH7110_SYSCLK_I2C4_APB 142 #define JH7110_SYSCLK_I2C5_APB 143 #define JH7110_SYSCLK_I2C6_APB 144 -#define JH7110_SYSCLK_UART0_APB 145 +#define JH7110_SYSCLK_UART0_APB 145 #define JH7110_SYSCLK_UART0_CORE 146 -#define JH7110_SYSCLK_UART1_APB 147 +#define JH7110_SYSCLK_UART1_APB 147 #define JH7110_SYSCLK_UART1_CORE 148 -#define JH7110_SYSCLK_UART2_APB 149 +#define JH7110_SYSCLK_UART2_APB 149 #define JH7110_SYSCLK_UART2_CORE 150 -#define JH7110_SYSCLK_UART3_APB 151 +#define JH7110_SYSCLK_UART3_APB 151 #define JH7110_SYSCLK_UART3_CORE 152 -#define JH7110_SYSCLK_UART4_APB 153 +#define JH7110_SYSCLK_UART4_APB 153 #define JH7110_SYSCLK_UART4_CORE 154 -#define JH7110_SYSCLK_UART5_APB 155 +#define JH7110_SYSCLK_UART5_APB 155 #define JH7110_SYSCLK_UART5_CORE 156 #define JH7110_SYSCLK_PWMDAC_APB 157 #define JH7110_SYSCLK_PWMDAC_CORE 158 -#define JH7110_SYSCLK_SPDIF_APB 159 +#define JH7110_SYSCLK_SPDIF_APB 159 #define JH7110_SYSCLK_SPDIF_CORE 160 #define JH7110_SYSCLK_I2STX0_APB 161 #define JH7110_SYSCLK_I2STX0_BCLK_MST 162 @@ -188,7 +190,7 @@ #define JH7110_SYSCLK_I2STX1_BCLK 172 #define JH7110_SYSCLK_I2STX1_BCLK_INV 173 #define JH7110_SYSCLK_I2STX1_LRCK 174 -#define JH7110_SYSCLK_I2SRX_APB 175 +#define JH7110_SYSCLK_I2SRX_APB 175 #define JH7110_SYSCLK_I2SRX_BCLK_MST 176 #define JH7110_SYSCLK_I2SRX_BCLK_MST_INV 177 #define JH7110_SYSCLK_I2SRX_LRCK_MST 178 @@ -200,12 +202,13 @@ #define JH7110_SYSCLK_TDM_AHB 184 #define JH7110_SYSCLK_TDM_APB 185 #define JH7110_SYSCLK_TDM_INTERNAL 186 -#define JH7110_SYSCLK_TDM_CLK_TDM 187 -#define JH7110_SYSCLK_TDM_CLK_TDM_N 188 +#define JH7110_SYSCLK_TDM_TDM 187 +#define JH7110_SYSCLK_TDM_TDM_INV 188 #define JH7110_SYSCLK_JTAG_CERTIFICATION_TRNG 189
#define JH7110_SYSCLK_END 190
+/* AONCRG clocks */ #define JH7110_AONCLK_OSC_DIV4 0 #define JH7110_AONCLK_APB_FUNC 1 #define JH7110_AONCLK_GMAC0_AHB 2 @@ -223,30 +226,31 @@
#define JH7110_AONCLK_END 14
-#define JH7110_STGCLK_HIFI4_CORE 0 -#define JH7110_STGCLK_USB_APB 1 -#define JH7110_STGCLK_USB_UTMI_APB 2 -#define JH7110_STGCLK_USB_AXI 3 -#define JH7110_STGCLK_USB_LPM 4 -#define JH7110_STGCLK_USB_STB 5 -#define JH7110_STGCLK_USB_APP_125 6 -#define JH7110_STGCLK_USB_REFCLK 7 -#define JH7110_STGCLK_PCIE0_AXI 8 +/* STGCRG clocks */ +#define JH7110_STGCLK_HIFI4_CLK_CORE 0 +#define JH7110_STGCLK_USB0_APB 1 +#define JH7110_STGCLK_USB0_UTMI_APB 2 +#define JH7110_STGCLK_USB0_AXI 3 +#define JH7110_STGCLK_USB0_LPM 4 +#define JH7110_STGCLK_USB0_STB 5 +#define JH7110_STGCLK_USB0_APP_125 6 +#define JH7110_STGCLK_USB0_REFCLK 7 +#define JH7110_STGCLK_PCIE0_AXI_MST0 8 #define JH7110_STGCLK_PCIE0_APB 9 #define JH7110_STGCLK_PCIE0_TL 10 -#define JH7110_STGCLK_PCIE1_AXI 11 +#define JH7110_STGCLK_PCIE1_AXI_MST0 11 #define JH7110_STGCLK_PCIE1_APB 12 #define JH7110_STGCLK_PCIE1_TL 13 -#define JH7110_STGCLK_PCIE01_MAIN 14 -#define JH7110_STGCLK_SEC_HCLK 15 -#define JH7110_STGCLK_SEC_MISCAHB 16 -#define JH7110_STGCLK_MTRX_GRP0_MAIN 17 -#define JH7110_STGCLK_MTRX_GRP0_BUS 18 -#define JH7110_STGCLK_MTRX_GRP0_STG 19 -#define JH7110_STGCLK_MTRX_GRP1_MAIN 20 -#define JH7110_STGCLK_MTRX_GRP1_BUS 21 -#define JH7110_STGCLK_MTRX_GRP1_STG 22 -#define JH7110_STGCLK_MTRX_GRP1_HIFI 23 +#define JH7110_STGCLK_PCIE_SLV_MAIN 14 +#define JH7110_STGCLK_SEC_AHB 15 +#define JH7110_STGCLK_SEC_MISC_AHB 16 +#define JH7110_STGCLK_GRP0_MAIN 17 +#define JH7110_STGCLK_GRP0_BUS 18 +#define JH7110_STGCLK_GRP0_STG 19 +#define JH7110_STGCLK_GRP1_MAIN 20 +#define JH7110_STGCLK_GRP1_BUS 21 +#define JH7110_STGCLK_GRP1_STG 22 +#define JH7110_STGCLK_GRP1_HIFI 23 #define JH7110_STGCLK_E2_RTC 24 #define JH7110_STGCLK_E2_CORE 25 #define JH7110_STGCLK_E2_DBG 26 @@ -255,4 +259,44 @@
#define JH7110_STGCLK_END 29
-#endif /* __DT_BINDINGS_CLOCK_STARFIVE_JH7110_H__ */ +/* ISPCRG clocks */ +#define JH7110_ISPCLK_DOM4_APB_FUNC 0 +#define JH7110_ISPCLK_MIPI_RX0_PXL 1 +#define JH7110_ISPCLK_DVP_INV 2 +#define JH7110_ISPCLK_M31DPHY_CFG_IN 3 +#define JH7110_ISPCLK_M31DPHY_REF_IN 4 +#define JH7110_ISPCLK_M31DPHY_TX_ESC_LAN0 5 +#define JH7110_ISPCLK_VIN_APB 6 +#define JH7110_ISPCLK_VIN_SYS 7 +#define JH7110_ISPCLK_VIN_PIXEL_IF0 8 +#define JH7110_ISPCLK_VIN_PIXEL_IF1 9 +#define JH7110_ISPCLK_VIN_PIXEL_IF2 10 +#define JH7110_ISPCLK_VIN_PIXEL_IF3 11 +#define JH7110_ISPCLK_VIN_P_AXI_WR 12 +#define JH7110_ISPCLK_ISPV2_TOP_WRAPPER_C 13 + +#define JH7110_ISPCLK_END 14 + +/* VOUTCRG clocks */ +#define JH7110_VOUTCLK_APB 0 +#define JH7110_VOUTCLK_DC8200_PIX 1 +#define JH7110_VOUTCLK_DSI_SYS 2 +#define JH7110_VOUTCLK_TX_ESC 3 +#define JH7110_VOUTCLK_DC8200_AXI 4 +#define JH7110_VOUTCLK_DC8200_CORE 5 +#define JH7110_VOUTCLK_DC8200_AHB 6 +#define JH7110_VOUTCLK_DC8200_PIX0 7 +#define JH7110_VOUTCLK_DC8200_PIX1 8 +#define JH7110_VOUTCLK_DOM_VOUT_TOP_LCD 9 +#define JH7110_VOUTCLK_DSITX_APB 10 +#define JH7110_VOUTCLK_DSITX_SYS 11 +#define JH7110_VOUTCLK_DSITX_DPI 12 +#define JH7110_VOUTCLK_DSITX_TXESC 13 +#define JH7110_VOUTCLK_MIPITX_DPHY_TXESC 14 +#define JH7110_VOUTCLK_HDMI_TX_MCLK 15 +#define JH7110_VOUTCLK_HDMI_TX_BCLK 16 +#define JH7110_VOUTCLK_HDMI_TX_SYS 17 + +#define JH7110_VOUTCLK_END 18 + +#endif /* __DT_BINDINGS_CLOCK_STARFIVE_JH7110_CRG_H__ */
Sync JH7110 reset dt-bindings with Linux, which is the same with dts/upstream/include/dt-bindings/reset/starfive,jh7110-crg.h except copyright.
Signed-off-by: Hal Feng hal.feng@starfivetech.com --- .../dt-bindings/reset/starfive,jh7110-crg.h | 144 +++++++++++------- 1 file changed, 88 insertions(+), 56 deletions(-)
diff --git a/include/dt-bindings/reset/starfive,jh7110-crg.h b/include/dt-bindings/reset/starfive,jh7110-crg.h index 1d596581da..771b1aecd0 100644 --- a/include/dt-bindings/reset/starfive,jh7110-crg.h +++ b/include/dt-bindings/reset/starfive,jh7110-crg.h @@ -5,13 +5,13 @@ * Author: Yanhong Wang yanhong.wang@starfivetech.com */
-#ifndef __DT_BINDINGS_RESET_STARFIVE_JH7110_H__ -#define __DT_BINDINGS_RESET_STARFIVE_JH7110_H__ +#ifndef __DT_BINDINGS_RESET_STARFIVE_JH7110_CRG_H__ +#define __DT_BINDINGS_RESET_STARFIVE_JH7110_CRG_H__
/* SYSCRG resets */ -#define JH7110_SYSRST_JTAG2APB 0 -#define JH7110_SYSRST_SYSCON 1 -#define JH7110_SYSRST_IOMUX_APB 2 +#define JH7110_SYSRST_JTAG_APB 0 +#define JH7110_SYSRST_SYSCON_APB 1 +#define JH7110_SYSRST_IOMUX_APB 2 #define JH7110_SYSRST_BUS 3 #define JH7110_SYSRST_DEBUG 4 #define JH7110_SYSRST_CORE0 5 @@ -29,10 +29,10 @@ #define JH7110_SYSRST_TRACE2 17 #define JH7110_SYSRST_TRACE3 18 #define JH7110_SYSRST_TRACE4 19 -#define JH7110_SYSRST_TRACE_COM 20 +#define JH7110_SYSRST_TRACE_COM 20 #define JH7110_SYSRST_GPU_APB 21 #define JH7110_SYSRST_GPU_DOMA 22 -#define JH7110_SYSRST_NOC_BUS_APB_BUS 23 +#define JH7110_SYSRST_NOC_BUS_APB 23 #define JH7110_SYSRST_NOC_BUS_AXICFG0_AXI 24 #define JH7110_SYSRST_NOC_BUS_CPU_AXI 25 #define JH7110_SYSRST_NOC_BUS_DISP_AXI 26 @@ -43,17 +43,17 @@ #define JH7110_SYSRST_NOC_BUS_VDEC_AXI 31
#define JH7110_SYSRST_NOC_BUS_VENC_AXI 32 -#define JH7110_SYSRST_AXI_CFG1_DEC_AHB 33 -#define JH7110_SYSRST_AXI_CFG1_DEC_MAIN 34 -#define JH7110_SYSRST_AXI_CFG0_DEC_MAIN 35 -#define JH7110_SYSRST_AXI_CFG0_DEC_MAIN_DIV 36 -#define JH7110_SYSRST_AXI_CFG0_DEC_HIFI4 37 +#define JH7110_SYSRST_AXI_CFG1_AHB 33 +#define JH7110_SYSRST_AXI_CFG1_MAIN 34 +#define JH7110_SYSRST_AXI_CFG0_MAIN 35 +#define JH7110_SYSRST_AXI_CFG0_MAIN_DIV 36 +#define JH7110_SYSRST_AXI_CFG0_HIFI4 37 #define JH7110_SYSRST_DDR_AXI 38 #define JH7110_SYSRST_DDR_OSC 39 #define JH7110_SYSRST_DDR_APB 40 -#define JH7110_SYSRST_DOM_ISP_TOP_N 41 -#define JH7110_SYSRST_DOM_ISP_TOP_AXI 42 -#define JH7110_SYSRST_DOM_VOUT_TOP_SRC 43 +#define JH7110_SYSRST_ISP_TOP 41 +#define JH7110_SYSRST_ISP_TOP_AXI 42 +#define JH7110_SYSRST_VOUT_TOP_SRC 43 #define JH7110_SYSRST_CODAJ12_AXI 44 #define JH7110_SYSRST_CODAJ12_CORE 45 #define JH7110_SYSRST_CODAJ12_APB 46 @@ -61,8 +61,8 @@ #define JH7110_SYSRST_WAVE511_BPU 48 #define JH7110_SYSRST_WAVE511_VCE 49 #define JH7110_SYSRST_WAVE511_APB 50 -#define JH7110_SYSRST_VDEC_JPG_ARB_JPG 51 -#define JH7110_SYSRST_VDEC_JPG_ARB_MAIN 52 +#define JH7110_SYSRST_VDEC_JPG 51 +#define JH7110_SYSRST_VDEC_MAIN 52 #define JH7110_SYSRST_AXIMEM0_AXI 53 #define JH7110_SYSRST_WAVE420L_AXI 54 #define JH7110_SYSRST_WAVE420L_BPU 55 @@ -75,11 +75,11 @@ #define JH7110_SYSRST_QSPI_APB 62 #define JH7110_SYSRST_QSPI_REF 63
-#define JH7110_SYSRST_SDIO0_AHB 64 -#define JH7110_SYSRST_SDIO1_AHB 65 -#define JH7110_SYSRST_GMAC1_AXI 66 -#define JH7110_SYSRST_GMAC1_AHB 67 -#define JH7110_SYSRST_MAILBOX 68 +#define JH7110_SYSRST_SDIO0_AHB 64 +#define JH7110_SYSRST_SDIO1_AHB 65 +#define JH7110_SYSRST_GMAC1_AXI 66 +#define JH7110_SYSRST_GMAC1_AHB 67 +#define JH7110_SYSRST_MAILBOX_APB 68 #define JH7110_SYSRST_SPI0_APB 69 #define JH7110_SYSRST_SPI1_APB 70 #define JH7110_SYSRST_SPI2_APB 71 @@ -94,24 +94,24 @@ #define JH7110_SYSRST_I2C4_APB 80 #define JH7110_SYSRST_I2C5_APB 81 #define JH7110_SYSRST_I2C6_APB 82 -#define JH7110_SYSRST_UART0_APB 83 +#define JH7110_SYSRST_UART0_APB 83 #define JH7110_SYSRST_UART0_CORE 84 -#define JH7110_SYSRST_UART1_APB 85 +#define JH7110_SYSRST_UART1_APB 85 #define JH7110_SYSRST_UART1_CORE 86 -#define JH7110_SYSRST_UART2_APB 87 +#define JH7110_SYSRST_UART2_APB 87 #define JH7110_SYSRST_UART2_CORE 88 -#define JH7110_SYSRST_UART3_APB 89 +#define JH7110_SYSRST_UART3_APB 89 #define JH7110_SYSRST_UART3_CORE 90 -#define JH7110_SYSRST_UART4_APB 91 +#define JH7110_SYSRST_UART4_APB 91 #define JH7110_SYSRST_UART4_CORE 92 -#define JH7110_SYSRST_UART5_APB 93 +#define JH7110_SYSRST_UART5_APB 93 #define JH7110_SYSRST_UART5_CORE 94 -#define JH7110_SYSRST_SPDIF_APB 95 +#define JH7110_SYSRST_SPDIF_APB 95
#define JH7110_SYSRST_PWMDAC_APB 96 #define JH7110_SYSRST_PDM_DMIC 97 #define JH7110_SYSRST_PDM_APB 98 -#define JH7110_SYSRST_I2SRX_APB 99 +#define JH7110_SYSRST_I2SRX_APB 99 #define JH7110_SYSRST_I2SRX_BCLK 100 #define JH7110_SYSRST_I2STX0_APB 101 #define JH7110_SYSRST_I2STX0_BCLK 102 @@ -124,26 +124,26 @@ #define JH7110_SYSRST_WDT_APB 109 #define JH7110_SYSRST_WDT_CORE 110 #define JH7110_SYSRST_CAN0_APB 111 -#define JH7110_SYSRST_CAN0_CORE 112 +#define JH7110_SYSRST_CAN0_CORE 112 #define JH7110_SYSRST_CAN0_TIMER 113 #define JH7110_SYSRST_CAN1_APB 114 -#define JH7110_SYSRST_CAN1_CORE 115 +#define JH7110_SYSRST_CAN1_CORE 115 #define JH7110_SYSRST_CAN1_TIMER 116 -#define JH7110_SYSRST_TIMER_APB 117 +#define JH7110_SYSRST_TIMER_APB 117 #define JH7110_SYSRST_TIMER0 118 #define JH7110_SYSRST_TIMER1 119 #define JH7110_SYSRST_TIMER2 120 #define JH7110_SYSRST_TIMER3 121 #define JH7110_SYSRST_INT_CTRL_APB 122 #define JH7110_SYSRST_TEMP_APB 123 -#define JH7110_SYSRST_TEMP_CORE 124 +#define JH7110_SYSRST_TEMP_CORE 124 #define JH7110_SYSRST_JTAG_CERTIFICATION 125
#define JH7110_SYSRST_END 126
/* AONCRG resets */ -#define JH7110_AONRST_GMAC0_AXI 0 -#define JH7110_AONRST_GMAC0_AHB 1 +#define JH7110_AONRST_GMAC0_AXI 0 +#define JH7110_AONRST_GMAC0_AHB 1 #define JH7110_AONRST_IOMUX 2 #define JH7110_AONRST_PMU_APB 3 #define JH7110_AONRST_PMU_WKUP 4 @@ -154,30 +154,62 @@ #define JH7110_AONRST_END 8
/* STGCRG resets */ -#define JH7110_STGRST_SYSCON_PRESETN 0 +#define JH7110_STGRST_SYSCON 0 #define JH7110_STGRST_HIFI4_CORE 1 -#define JH7110_STGRST_HIFI4_AXI 2 -#define JH7110_STGRST_SEC_TOP_HRESETN 3 +#define JH7110_STGRST_HIFI4_AXI 2 +#define JH7110_STGRST_SEC_AHB 3 #define JH7110_STGRST_E24_CORE 4 -#define JH7110_STGRST_DMA1P_AXI 5 -#define JH7110_STGRST_DMA1P_AHB 6 -#define JH7110_STGRST_USB_AXI 7 -#define JH7110_STGRST_USB_APB 8 -#define JH7110_STGRST_USB_UTMI_APB 9 -#define JH7110_STGRST_USB_PWRUP 10 -#define JH7110_STGRST_PCIE0_MST0 11 -#define JH7110_STGRST_PCIE0_SLV0 12 -#define JH7110_STGRST_PCIE0_SLV 13 -#define JH7110_STGRST_PCIE0_BRG 14 +#define JH7110_STGRST_DMA1P_AXI 5 +#define JH7110_STGRST_DMA1P_AHB 6 +#define JH7110_STGRST_USB0_AXI 7 +#define JH7110_STGRST_USB0_APB 8 +#define JH7110_STGRST_USB0_UTMI_APB 9 +#define JH7110_STGRST_USB0_PWRUP 10 +#define JH7110_STGRST_PCIE0_AXI_MST0 11 +#define JH7110_STGRST_PCIE0_AXI_SLV0 12 +#define JH7110_STGRST_PCIE0_AXI_SLV 13 +#define JH7110_STGRST_PCIE0_BRG 14 #define JH7110_STGRST_PCIE0_CORE 15 -#define JH7110_STGRST_PCIE0_APB 16 -#define JH7110_STGRST_PCIE1_MST0 17 -#define JH7110_STGRST_PCIE1_SLV0 18 -#define JH7110_STGRST_PCIE1_SLV 19 -#define JH7110_STGRST_PCIE1_BRG 20 +#define JH7110_STGRST_PCIE0_APB 16 +#define JH7110_STGRST_PCIE1_AXI_MST0 17 +#define JH7110_STGRST_PCIE1_AXI_SLV0 18 +#define JH7110_STGRST_PCIE1_AXI_SLV 19 +#define JH7110_STGRST_PCIE1_BRG 20 #define JH7110_STGRST_PCIE1_CORE 21 -#define JH7110_STGRST_PCIE1_APB 22 +#define JH7110_STGRST_PCIE1_APB 22
#define JH7110_STGRST_END 23
-#endif /* __DT_BINDINGS_RESET_STARFIVE_JH7110_H__ */ +/* ISPCRG resets */ +#define JH7110_ISPRST_ISPV2_TOP_WRAPPER_P 0 +#define JH7110_ISPRST_ISPV2_TOP_WRAPPER_C 1 +#define JH7110_ISPRST_M31DPHY_HW 2 +#define JH7110_ISPRST_M31DPHY_B09_AON 3 +#define JH7110_ISPRST_VIN_APB 4 +#define JH7110_ISPRST_VIN_PIXEL_IF0 5 +#define JH7110_ISPRST_VIN_PIXEL_IF1 6 +#define JH7110_ISPRST_VIN_PIXEL_IF2 7 +#define JH7110_ISPRST_VIN_PIXEL_IF3 8 +#define JH7110_ISPRST_VIN_SYS 9 +#define JH7110_ISPRST_VIN_P_AXI_RD 10 +#define JH7110_ISPRST_VIN_P_AXI_WR 11 + +#define JH7110_ISPRST_END 12 + +/* VOUTCRG resets */ +#define JH7110_VOUTRST_DC8200_AXI 0 +#define JH7110_VOUTRST_DC8200_AHB 1 +#define JH7110_VOUTRST_DC8200_CORE 2 +#define JH7110_VOUTRST_DSITX_DPI 3 +#define JH7110_VOUTRST_DSITX_APB 4 +#define JH7110_VOUTRST_DSITX_RXESC 5 +#define JH7110_VOUTRST_DSITX_SYS 6 +#define JH7110_VOUTRST_DSITX_TXBYTEHS 7 +#define JH7110_VOUTRST_DSITX_TXESC 8 +#define JH7110_VOUTRST_HDMI_TX_HDMI 9 +#define JH7110_VOUTRST_MIPITX_DPHY_SYS 10 +#define JH7110_VOUTRST_MIPITX_DPHY_TXBYTEHS 11 + +#define JH7110_VOUTRST_END 12 + +#endif /* __DT_BINDINGS_RESET_STARFIVE_JH7110_CRG_H__ */
The JH7110 clock dt-bindings is synchronized with Linux, so update the clock definitions in drivers accordingly.
Signed-off-by: Hal Feng hal.feng@starfivetech.com --- drivers/clk/starfive/clk-jh7110-pll.c | 6 ++-- drivers/clk/starfive/clk-jh7110.c | 44 +++++++++++++-------------- 2 files changed, 25 insertions(+), 25 deletions(-)
diff --git a/drivers/clk/starfive/clk-jh7110-pll.c b/drivers/clk/starfive/clk-jh7110-pll.c index 1568a1f4cd..96beacb4fa 100644 --- a/drivers/clk/starfive/clk-jh7110-pll.c +++ b/drivers/clk/starfive/clk-jh7110-pll.c @@ -375,13 +375,13 @@ static int jh7110_pll_clk_probe(struct udevice *dev) if (sysreg == FDT_ADDR_T_NONE) return -EINVAL;
- clk_dm(JH7110_PLL_ID_TRANS(JH7110_SYSCLK_PLL0_OUT), + clk_dm(JH7110_PLL_ID_TRANS(JH7110_PLLCLK_PLL0_OUT), starfive_jh7110_pll("pll0_out", "oscillator", reg, (void __iomem *)sysreg, &starfive_jh7110_pll0)); - clk_dm(JH7110_PLL_ID_TRANS(JH7110_SYSCLK_PLL1_OUT), + clk_dm(JH7110_PLL_ID_TRANS(JH7110_PLLCLK_PLL1_OUT), starfive_jh7110_pll("pll1_out", "oscillator", reg, (void __iomem *)sysreg, &starfive_jh7110_pll1)); - clk_dm(JH7110_PLL_ID_TRANS(JH7110_SYSCLK_PLL2_OUT), + clk_dm(JH7110_PLL_ID_TRANS(JH7110_PLLCLK_PLL2_OUT), starfive_jh7110_pll("pll2_out", "oscillator", reg, (void __iomem *)sysreg, &starfive_jh7110_pll2));
diff --git a/drivers/clk/starfive/clk-jh7110.c b/drivers/clk/starfive/clk-jh7110.c index a38694809a..523342128e 100644 --- a/drivers/clk/starfive/clk-jh7110.c +++ b/drivers/clk/starfive/clk-jh7110.c @@ -496,37 +496,37 @@ static int jh7110_stgcrg_init(struct udevice *dev) { struct jh7110_clk_priv *priv = dev_get_priv(dev);
- clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB_APB), + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB0_APB), starfive_clk_gate(priv->reg, "usb_apb", "apb_bus", - OFFSET(JH7110_STGCLK_USB_APB))); - clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB_UTMI_APB), + OFFSET(JH7110_STGCLK_USB0_APB))); + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB0_UTMI_APB), starfive_clk_gate(priv->reg, "usb_utmi_apb", "apb_bus", - OFFSET(JH7110_STGCLK_USB_UTMI_APB))); - clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB_AXI), + OFFSET(JH7110_STGCLK_USB0_UTMI_APB))); + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB0_AXI), starfive_clk_gate(priv->reg, "usb_axi", "stg_axiahb", - OFFSET(JH7110_STGCLK_USB_AXI))); - clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB_LPM), + OFFSET(JH7110_STGCLK_USB0_AXI))); + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB0_LPM), starfive_clk_gate_divider(priv->reg, "usb_lpm", "oscillator", - OFFSET(JH7110_STGCLK_USB_LPM), 2)); - clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB_STB), + OFFSET(JH7110_STGCLK_USB0_LPM), 2)); + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB0_STB), starfive_clk_gate_divider(priv->reg, "usb_stb", "oscillator", - OFFSET(JH7110_STGCLK_USB_STB), 3)); - clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB_APP_125), + OFFSET(JH7110_STGCLK_USB0_STB), 3)); + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB0_APP_125), starfive_clk_gate(priv->reg, "usb_app_125", "usb_125m", - OFFSET(JH7110_STGCLK_USB_APP_125))); - clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB_REFCLK), + OFFSET(JH7110_STGCLK_USB0_APP_125))); + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_USB0_REFCLK), starfive_clk_divider(priv->reg, "usb_refclk", "oscillator", - OFFSET(JH7110_STGCLK_USB_REFCLK), 2)); - clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_PCIE0_AXI), + OFFSET(JH7110_STGCLK_USB0_REFCLK), 2)); + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_PCIE0_AXI_MST0), starfive_clk_gate(priv->reg, "pcie0_axi", "stg_axiahb", - OFFSET(JH7110_STGCLK_PCIE0_AXI))); + OFFSET(JH7110_STGCLK_PCIE0_AXI_MST0))); clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_PCIE0_APB), starfive_clk_gate(priv->reg, "pcie0_apb", "apb_bus", @@ -535,10 +535,10 @@ static int jh7110_stgcrg_init(struct udevice *dev) starfive_clk_gate(priv->reg, "pcie0_tl", "stg_axiahb", OFFSET(JH7110_STGCLK_PCIE0_TL))); - clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_PCIE1_AXI), + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_PCIE1_AXI_MST0), starfive_clk_gate(priv->reg, "pcie1_axi", "stg_axiahb", - OFFSET(JH7110_STGCLK_PCIE1_AXI))); + OFFSET(JH7110_STGCLK_PCIE1_AXI_MST0))); clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_PCIE1_APB), starfive_clk_gate(priv->reg, "pcie1_apb", "apb_bus", @@ -549,14 +549,14 @@ static int jh7110_stgcrg_init(struct udevice *dev) OFFSET(JH7110_STGCLK_PCIE1_TL)));
/* Security clocks */ - clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_SEC_HCLK), + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_SEC_AHB), starfive_clk_gate(priv->reg, "sec_ahb", "stg_axiahb", - OFFSET(JH7110_STGCLK_SEC_HCLK))); - clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_SEC_MISCAHB), + OFFSET(JH7110_STGCLK_SEC_AHB))); + clk_dm(JH7110_STG_ID_TRANS(JH7110_STGCLK_SEC_MISC_AHB), starfive_clk_gate(priv->reg, "sec_misc_ahb", "stg_axiahb", - OFFSET(JH7110_STGCLK_SEC_MISCAHB))); + OFFSET(JH7110_STGCLK_SEC_MISC_AHB)));
return 0; }
The JH7110 clock and reset dt-bindings are synchronized with Linux, so update the clock and reset definitions in device tree accordingly.
Signed-off-by: Hal Feng hal.feng@starfivetech.com --- .../dts/jh7110-starfive-visionfive-2.dtsi | 6 ++-- arch/riscv/dts/jh7110-u-boot.dtsi | 2 +- arch/riscv/dts/jh7110.dtsi | 28 +++++++++---------- 3 files changed, 18 insertions(+), 18 deletions(-)
diff --git a/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi b/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi index e11babc1cd..2666fd4696 100644 --- a/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi +++ b/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi @@ -334,9 +334,9 @@ <&syscrg JH7110_SYSCLK_BUS_ROOT>, <&syscrg JH7110_SYSCLK_PERH_ROOT>, <&syscrg JH7110_SYSCLK_QSPI_REF>; - assigned-clock-parents = <&pllclk JH7110_SYSCLK_PLL0_OUT>, - <&pllclk JH7110_SYSCLK_PLL2_OUT>, - <&pllclk JH7110_SYSCLK_PLL2_OUT>, + assigned-clock-parents = <&pllclk JH7110_PLLCLK_PLL0_OUT>, + <&pllclk JH7110_PLLCLK_PLL2_OUT>, + <&pllclk JH7110_PLLCLK_PLL2_OUT>, <&syscrg JH7110_SYSCLK_QSPI_REF_SRC>; assigned-clock-rates = <0>, <0>, <0>, <0>; }; diff --git a/arch/riscv/dts/jh7110-u-boot.dtsi b/arch/riscv/dts/jh7110-u-boot.dtsi index c09d5c9170..56530cf4c2 100644 --- a/arch/riscv/dts/jh7110-u-boot.dtsi +++ b/arch/riscv/dts/jh7110-u-boot.dtsi @@ -62,7 +62,7 @@ <&syscrg JH7110_SYSRST_DDR_OSC>, <&syscrg JH7110_SYSRST_DDR_APB>; reset-names = "axi", "osc", "apb"; - clocks = <&syscrg JH7110_SYSCLK_PLL1_OUT>; + clocks = <&syscrg JH7110_PLLCLK_PLL1_OUT>; clock-names = "pll1_out"; clock-frequency = <2133>; }; diff --git a/arch/riscv/dts/jh7110.dtsi b/arch/riscv/dts/jh7110.dtsi index 2cdc683d49..dbce57c421 100644 --- a/arch/riscv/dts/jh7110.dtsi +++ b/arch/riscv/dts/jh7110.dtsi @@ -503,9 +503,9 @@ <&i2stx_bclk_ext>, <&i2stx_lrck_ext>, <&i2srx_bclk_ext>, <&i2srx_lrck_ext>, <&tdm_ext>, <&mclk_ext>, - <&pllclk JH7110_SYSCLK_PLL0_OUT>, - <&pllclk JH7110_SYSCLK_PLL1_OUT>, - <&pllclk JH7110_SYSCLK_PLL2_OUT>; + <&pllclk JH7110_PLLCLK_PLL0_OUT>, + <&pllclk JH7110_PLLCLK_PLL1_OUT>, + <&pllclk JH7110_PLLCLK_PLL2_OUT>; clock-names = "osc", "gmac1_rmii_refin", "gmac1_rgmii_rxin", "i2stx_bclk_ext", "i2stx_lrck_ext", @@ -646,10 +646,10 @@ rng: rng@1600c000 { compatible = "starfive,jh7110-trng"; reg = <0x0 0x1600C000 0x0 0x4000>; - clocks = <&stgcrg JH7110_STGCLK_SEC_HCLK>, - <&stgcrg JH7110_STGCLK_SEC_MISCAHB>; + clocks = <&stgcrg JH7110_STGCLK_SEC_AHB>, + <&stgcrg JH7110_STGCLK_SEC_MISC_AHB>; clock-names = "hclk", "ahb"; - resets = <&stgcrg JH7110_STGRST_SEC_TOP_HRESETN>; + resets = <&stgcrg JH7110_STGRST_SEC_AHB>; interrupts = <30>; };
@@ -707,12 +707,12 @@ bus-range = <0x0 0xff>; clocks = <&syscrg JH7110_SYSCLK_NOC_BUS_STG_AXI>, <&stgcrg JH7110_STGCLK_PCIE0_TL>, - <&stgcrg JH7110_STGCLK_PCIE0_AXI>, + <&stgcrg JH7110_STGCLK_PCIE0_AXI_MST0>, <&stgcrg JH7110_STGCLK_PCIE0_APB>; clock-names = "noc", "tl", "axi", "apb"; - resets = <&stgcrg JH7110_STGRST_PCIE0_MST0>, - <&stgcrg JH7110_STGRST_PCIE0_SLV0>, - <&stgcrg JH7110_STGRST_PCIE0_SLV>, + resets = <&stgcrg JH7110_STGRST_PCIE0_AXI_MST0>, + <&stgcrg JH7110_STGRST_PCIE0_AXI_SLV0>, + <&stgcrg JH7110_STGRST_PCIE0_AXI_SLV>, <&stgcrg JH7110_STGRST_PCIE0_BRG>, <&stgcrg JH7110_STGRST_PCIE0_CORE>, <&stgcrg JH7110_STGRST_PCIE0_APB>; @@ -744,12 +744,12 @@ bus-range = <0x0 0xff>; clocks = <&syscrg JH7110_SYSCLK_NOC_BUS_STG_AXI>, <&stgcrg JH7110_STGCLK_PCIE1_TL>, - <&stgcrg JH7110_STGCLK_PCIE1_AXI>, + <&stgcrg JH7110_STGCLK_PCIE1_AXI_MST0>, <&stgcrg JH7110_STGCLK_PCIE1_APB>; clock-names = "noc", "tl", "axi", "apb"; - resets = <&stgcrg JH7110_STGRST_PCIE1_MST0>, - <&stgcrg JH7110_STGRST_PCIE1_SLV0>, - <&stgcrg JH7110_STGRST_PCIE1_SLV>, + resets = <&stgcrg JH7110_STGRST_PCIE1_AXI_MST0>, + <&stgcrg JH7110_STGRST_PCIE1_AXI_SLV0>, + <&stgcrg JH7110_STGRST_PCIE1_AXI_SLV>, <&stgcrg JH7110_STGRST_PCIE1_BRG>, <&stgcrg JH7110_STGRST_PCIE1_CORE>, <&stgcrg JH7110_STGRST_PCIE1_APB>;
Hi Hal,
Instead of manual dt-bindings sync can we please adopt OF_UPSTREAM for JH7110 ?
-E
2.43.2
On 04.06.24 04:32, E Shattow wrote: Hi Hal,
Yeah, I will try to do it recently, although I am not sure whether the U-Boot drivers and Linux drivers are compatible so that they can use the same DT.
Best regards, Hal
2.43.2
They must be compatible so that they can use the same DT, U-Boot needs updating if it doesn't match.
Other than the naming, I think they are compatible. IIRC there were some issues where U-Boot originally used different numbers to linux, but this was fixed in commit 9a12e304dd ("dt-bindings: clock: jh7110: Modify clock id to be same with Linux").
On 05.06.24 23:38, Conor Dooley wrote: On Wed, Jun 05, 2024 at 08:35:15AM -0600, Tom Rini wrote:
same DT.
I found the Linux DT of VisionFive 2 can not be applied to U-Boot directly. Some issues need to be fixed such as making drivers compatible with Linux DT, unifying DT names. I am preparing a new patchset. When I finish coding and testing, I will send it out.
Best regards, Hal
Conor Dooley
E Shattow
Hal Feng
