[U-Boot] [PATCH v5 1/8] nand: mxc: Prepare to add support for i.MX5
Add some abstraction to NFC defitnitions so that some parts of the current code can also be used for future i.MX5 code.
Clean up a few things by the way.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v5: None Changes in v4: None Changes in v3: - Separate code reformatting from behavioral changes.
Changes in v2: - Fix warning for unused tmp variable in board_nand_init() for NFC V1.
drivers/mtd/nand/mxc_nand.c | 92 +++++++++++++++++++++--------------------- include/fsl_nfc.h | 72 ++++++++++++--------------------- nand_spl/nand_boot_fsl_nfc.c | 47 +++++++++++---------- 3 files changed, 97 insertions(+), 114 deletions(-)
diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index d0ded48..045df49 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -150,7 +150,7 @@ static uint32_t *mxc_nand_memcpy32(uint32_t *dest, uint32_t *source, size_t size
/* * This function polls the NANDFC to wait for the basic operation to - * complete by checking the INT bit of config2 register. + * complete by checking the INT bit. */ static void wait_op_done(struct mxc_nand_host *host, int max_retries, uint16_t param) @@ -158,10 +158,10 @@ static void wait_op_done(struct mxc_nand_host *host, int max_retries, uint32_t tmp;
while (max_retries-- > 0) { - if (readw(&host->regs->config2) & NFC_INT) { - tmp = readw(&host->regs->config2); - tmp &= ~NFC_INT; - writew(tmp, &host->regs->config2); + tmp = readnfc(&host->regs->config2); + if (tmp & NFC_V1_V2_CONFIG2_INT) { + tmp &= ~NFC_V1_V2_CONFIG2_INT; + writenfc(tmp, &host->regs->config2); break; } udelay(1); @@ -180,8 +180,8 @@ static void send_cmd(struct mxc_nand_host *host, uint16_t cmd) { MTDDEBUG(MTD_DEBUG_LEVEL3, "send_cmd(host, 0x%x)\n", cmd);
- writew(cmd, &host->regs->flash_cmd); - writew(NFC_CMD, &host->regs->config2); + writenfc(cmd, &host->regs->flash_cmd); + writenfc(NFC_CMD, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, cmd); @@ -196,8 +196,8 @@ static void send_addr(struct mxc_nand_host *host, uint16_t addr) { MTDDEBUG(MTD_DEBUG_LEVEL3, "send_addr(host, 0x%x)\n", addr);
- writew(addr, &host->regs->flash_addr); - writew(NFC_ADDR, &host->regs->config2); + writenfc(addr, &host->regs->flash_addr); + writenfc(NFC_ADDR, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, addr); @@ -229,19 +229,19 @@ static void send_prog_page(struct mxc_nand_host *host, uint8_t buf_id, } }
- writew(buf_id, &host->regs->buf_addr); + writenfc(buf_id, &host->regs->buf_addr);
/* Configure spare or page+spare access */ if (!host->pagesize_2k) { - uint16_t config1 = readw(&host->regs->config1); + uint16_t config1 = readnfc(&host->regs->config1); if (spare_only) - config1 |= NFC_SP_EN; + config1 |= NFC_CONFIG1_SP_EN; else - config1 &= ~NFC_SP_EN; - writew(config1, &host->regs->config1); + config1 &= ~NFC_CONFIG1_SP_EN; + writenfc(config1, &host->regs->config1); }
- writew(NFC_INPUT, &host->regs->config2); + writenfc(NFC_INPUT, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, spare_only); @@ -256,19 +256,19 @@ static void send_read_page(struct mxc_nand_host *host, uint8_t buf_id, { MTDDEBUG(MTD_DEBUG_LEVEL3, "send_read_page (%d)\n", spare_only);
/* Configure spare or page+spare access */ if (!host->pagesize_2k) { - uint32_t config1 = readw(&host->regs->config1); + uint32_t config1 = readnfc(&host->regs->config1); if (spare_only) - config1 |= NFC_SP_EN; + config1 |= NFC_CONFIG1_SP_EN; else - config1 &= ~NFC_SP_EN; - writew(config1, &host->regs->config1); + config1 &= ~NFC_CONFIG1_SP_EN; + writenfc(config1, &host->regs->config1); }
- writew(NFC_OUTPUT, &host->regs->config2); + writenfc(NFC_OUTPUT, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, spare_only); @@ -296,14 +296,14 @@ static void send_read_id(struct mxc_nand_host *host) uint16_t tmp;
/* NANDFC buffer 0 is used for device ID output */ - writew(0x0, &host->regs->buf_addr); + writenfc(0x0, &host->regs->buf_addr);
/* Read ID into main buffer */ - tmp = readw(&host->regs->config1); - tmp &= ~NFC_SP_EN; - writew(tmp, &host->regs->config1); + tmp = readnfc(&host->regs->config1); + tmp &= ~NFC_CONFIG1_SP_EN; + writenfc(tmp, &host->regs->config1);
- writew(NFC_ID, &host->regs->config2); + writenfc(NFC_ID, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, 0); @@ -323,14 +323,14 @@ static uint16_t get_dev_status(struct mxc_nand_host *host) /* store the main area1 first word, later do recovery */ store = readl(main_buf); /* NANDFC buffer 1 is used for device status */ - writew(1, &host->regs->buf_addr); + writenfc(1, &host->regs->buf_addr);
/* Read status into main buffer */ - tmp = readw(&host->regs->config1); - tmp &= ~NFC_SP_EN; - writew(tmp, &host->regs->config1); + tmp = readnfc(&host->regs->config1); + tmp &= ~NFC_CONFIG1_SP_EN; + writenfc(tmp, &host->regs->config1);
- writew(NFC_STATUS, &host->regs->config2); + writenfc(NFC_STATUS, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, 0); @@ -359,13 +359,13 @@ static void _mxc_nand_enable_hwecc(struct mtd_info *mtd, int on) { struct nand_chip *nand_chip = mtd->priv; struct mxc_nand_host *host = nand_chip->priv; - uint16_t tmp = readw(&host->regs->config1); + uint16_t tmp = readnfc(&host->regs->config1);
if (on) - tmp |= NFC_ECC_EN; + tmp |= NFC_V1_V2_CONFIG1_ECC_EN; else - tmp &= ~NFC_ECC_EN; - writew(tmp, &host->regs->config1); + tmp &= ~NFC_V1_V2_CONFIG1_ECC_EN; + writenfc(tmp, &host->regs->config1); }
#ifdef CONFIG_MXC_NAND_HWECC @@ -698,7 +698,7 @@ static int mxc_nand_correct_data(struct mtd_info *mtd, u_char *dat, * additional correction. 2-Bit errors cannot be corrected by * HW ECC, so we need to return failure */ - uint16_t ecc_status = readw(&host->regs->ecc_status_result); + uint16_t ecc_status = readnfc(&host->regs->ecc_status_result);
if (((ecc_status & 0x3) == 2) || ((ecc_status >> 2) == 2)) { MTDDEBUG(MTD_DEBUG_LEVEL0, @@ -1241,24 +1241,24 @@ int board_nand_init(struct nand_chip *this) #endif
#ifdef MXC_NFC_V2_1 - tmp = readw(&host->regs->config1); - tmp |= NFC_ONE_CYCLE; - tmp |= NFC_4_8N_ECC; - writew(tmp, &host->regs->config1); + tmp = readnfc(&host->regs->config1); + tmp |= NFC_V2_CONFIG1_ONE_CYCLE; + tmp |= NFC_V2_CONFIG1_ECC_MODE_4; + writenfc(tmp, &host->regs->config1); if (host->pagesize_2k) - writew(64/2, &host->regs->spare_area_size); + writenfc(64/2, &host->regs->spare_area_size); else - writew(16/2, &host->regs->spare_area_size); + writenfc(16/2, &host->regs->spare_area_size); #endif
/* * preset operation * Unlock the internal RAM Buffer */ - writew(0x2, &host->regs->config); + writenfc(0x2, &host->regs->config);
/* Blocks to be unlocked */ - writew(0x0, &host->regs->unlockstart_blkaddr); + writenfc(0x0, &host->regs->unlockstart_blkaddr); /* Originally (Freescale LTIB 2.6.21) 0x4000 was written to the * unlockend_blkaddr, but the magic 0x4000 does not always work * when writing more than some 32 megabytes (on 2k page nands) @@ -1270,10 +1270,10 @@ int board_nand_init(struct nand_chip *this) * This might be NAND chip specific and the i.MX31 datasheet is * extremely vague about the semantics of this register. */ - writew(0xFFFF, &host->regs->unlockend_blkaddr); + writenfc(0xFFFF, &host->regs->unlockend_blkaddr);
/* Unlock Block Command for given address range */ - writew(0x4, &host->regs->wrprot); + writenfc(0x4, &host->regs->wrprot);
return 0; } diff --git a/include/fsl_nfc.h b/include/fsl_nfc.h index ff537b4..013e9e2 100644 --- a/include/fsl_nfc.h +++ b/include/fsl_nfc.h @@ -113,58 +113,38 @@ struct fsl_nfc_regs { #endif };
-/* - * Set INT to 0, FCMD to 1, rest to 0 in NFC_CONFIG2 Register for Command - * operation - */ -#define NFC_CMD 0x1 +/* Set FCMD to 1, rest to 0 for Command operation */ +#define NFC_CMD 0x1
-/* - * Set INT to 0, FADD to 1, rest to 0 in NFC_CONFIG2 Register for Address - * operation - */ -#define NFC_ADDR 0x2 +/* Set FADD to 1, rest to 0 for Address operation */ +#define NFC_ADDR 0x2
-/* - * Set INT to 0, FDI to 1, rest to 0 in NFC_CONFIG2 Register for Input - * operation - */ -#define NFC_INPUT 0x4 +/* Set FDI to 1, rest to 0 for Input operation */ +#define NFC_INPUT 0x4
-/* - * Set INT to 0, FDO to 001, rest to 0 in NFC_CONFIG2 Register for Data - * Output operation - */ -#define NFC_OUTPUT 0x8 +/* Set FDO to 001, rest to 0 for Data Output operation */ +#define NFC_OUTPUT 0x8
-/* - * Set INT to 0, FD0 to 010, rest to 0 in NFC_CONFIG2 Register for Read ID - * operation - */ -#define NFC_ID 0x10 +/* Set FDO to 010, rest to 0 for Read ID operation */ +#define NFC_ID 0x10
-/* - * Set INT to 0, FDO to 100, rest to 0 in NFC_CONFIG2 Register for Read - * Status operation - */ -#define NFC_STATUS 0x20 +/* Set FDO to 100, rest to 0 for Read Status operation */ +#define NFC_STATUS 0x20
-/* - * Set INT to 1, rest to 0 in NFC_CONFIG2 Register for Read Status - * operation - */ -#define NFC_INT 0x8000 +#define NFC_CONFIG1_SP_EN (1 << 2) +#define NFC_CONFIG1_RST (1 << 6) +#define NFC_CONFIG1_CE (1 << 7) +#define NFC_V1_V2_CONFIG1_ECC_EN (1 << 3) +#define NFC_V1_V2_CONFIG1_INT_MSK (1 << 4) +#define NFC_V1_V2_CONFIG1_BIG (1 << 5) +#define NFC_V2_CONFIG1_ECC_MODE_4 (1 << 0) +#define NFC_V2_CONFIG1_ONE_CYCLE (1 << 8) +#define NFC_V2_CONFIG1_FP_INT (1 << 11)
-#ifdef MXC_NFC_V2_1 -#define NFC_4_8N_ECC (1 << 0) -#endif -#define NFC_SP_EN (1 << 2) -#define NFC_ECC_EN (1 << 3) -#define NFC_INT_MSK (1 << 4) -#define NFC_BIG (1 << 5) -#define NFC_RST (1 << 6) -#define NFC_CE (1 << 7) -#define NFC_ONE_CYCLE (1 << 8) -#define NFC_FP_INT (1 << 11) +#define NFC_V1_V2_CONFIG2_INT (1 << 15) + +#define operation config2 +#define readnfc readw +#define writenfc writew
#endif /* __FSL_NFC_H */ diff --git a/nand_spl/nand_boot_fsl_nfc.c b/nand_spl/nand_boot_fsl_nfc.c index a40c998..615e820 100644 --- a/nand_spl/nand_boot_fsl_nfc.c +++ b/nand_spl/nand_boot_fsl_nfc.c @@ -36,13 +36,13 @@ static void nfc_wait_ready(void) { uint32_t tmp;
- while (!(readw(&nfc->config2) & NFC_INT)) + while (!(readnfc(&nfc->config2) & NFC_V1_V2_CONFIG2_INT)) ;
/* Reset interrupt flag */ - tmp = readw(&nfc->config2); - tmp &= ~NFC_INT; - writew(tmp, &nfc->config2); + tmp = readnfc(&nfc->config2); + tmp &= ~NFC_V1_V2_CONFIG2_INT; + writenfc(tmp, &nfc->config2); }
static void nfc_nand_init(void) @@ -51,43 +51,45 @@ static void nfc_nand_init(void) int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; int config1;
- writew(CONFIG_SYS_NAND_SPARE_SIZE / 2, &nfc->spare_area_size); + writenfc(CONFIG_SYS_NAND_SPARE_SIZE / 2, &nfc->spare_area_size);
/* unlocking RAM Buff */ - writew(0x2, &nfc->config); + writenfc(0x2, &nfc->config);
/* hardware ECC checking and correct */ - config1 = readw(&nfc->config1) | NFC_ECC_EN | NFC_INT_MSK | - NFC_ONE_CYCLE | NFC_FP_INT; + config1 = readnfc(&nfc->config1) | NFC_V1_V2_CONFIG1_ECC_EN | + NFC_V1_V2_CONFIG1_INT_MSK | NFC_V2_CONFIG1_ONE_CYCLE | + NFC_V2_CONFIG1_FP_INT; /* * if spare size is larger that 16 bytes per 512 byte hunk * then use 8 symbol correction instead of 4 */ if (CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16) - config1 &= ~NFC_4_8N_ECC; + config1 &= ~NFC_V2_CONFIG1_ECC_MODE_4; else - config1 |= NFC_4_8N_ECC; - writew(config1, &nfc->config1); + config1 |= NFC_V2_CONFIG1_ECC_MODE_4; + writenfc(config1, &nfc->config1); #elif defined(MXC_NFC_V1) /* unlocking RAM Buff */ - writew(0x2, &nfc->config); + writenfc(0x2, &nfc->config);
/* hardware ECC checking and correct */ - writew(NFC_ECC_EN | NFC_INT_MSK, &nfc->config1); + writenfc(NFC_V1_V2_CONFIG1_ECC_EN | NFC_V1_V2_CONFIG1_INT_MSK, + &nfc->config1); #endif }
static void nfc_nand_command(unsigned short command) { - writew(command, &nfc->flash_cmd); - writew(NFC_CMD, &nfc->config2); + writenfc(command, &nfc->flash_cmd); + writenfc(NFC_CMD, &nfc->operation); nfc_wait_ready(); }
static void nfc_nand_address(unsigned short address) { - writew(address, &nfc->flash_addr); - writew(NFC_ADDR, &nfc->config2); + writenfc(address, &nfc->flash_addr); + writenfc(NFC_ADDR, &nfc->operation); nfc_wait_ready(); }
@@ -121,8 +123,8 @@ static void nfc_nand_data_output(void) int i; #endif
- writew(0, &nfc->buf_addr); - writew(NFC_OUTPUT, &nfc->config2); + writenfc(0, &nfc->buf_addr); + writenfc(NFC_OUTPUT, &nfc->operation); nfc_wait_ready(); #ifdef NAND_MXC_2K_MULTI_CYCLE /* @@ -130,8 +132,8 @@ static void nfc_nand_data_output(void) * for pages larger than 512 bytes. */ for (i = 1; i < CONFIG_SYS_NAND_PAGE_SIZE / 512; i++) { - writew(i, &nfc->buf_addr); - writew(NFC_OUTPUT, &nfc->config2); + writenfc(i, &nfc->buf_addr); + writenfc(NFC_OUTPUT, &nfc->operation); nfc_wait_ready(); } #endif @@ -160,7 +162,8 @@ static int nfc_nand_check_ecc(void)
static void nfc_nand_read_page(unsigned int page_address) { - writew(0, &nfc->buf_addr); /* read in first 0 buffer */ + /* read in first 0 buffer */ + writenfc(0, &nfc->buf_addr); nfc_nand_command(NAND_CMD_READ0); nfc_nand_page_address(page_address);
Changes in v2: None
arch/arm/include/asm/arch-mx5/imx-regs.h | 9 +++ drivers/mtd/nand/mxc_nand.c | 129 +++++++++++++++++++++++++++--- include/fsl_nfc.h | 79 +++++++++++++++++- nand_spl/nand_boot_fsl_nfc.c | 67 +++++++++++++++- 4 files changed, 269 insertions(+), 15 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 249d15a..9aa0c6a 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -224,6 +224,15 @@ #define CS0_32M_CS1_32M_CS2_32M_CS3_32M 3
/* + * SRC register definitions + */ +#if defined(CONFIG_MX51) +#define SRC_SBMR_NF16B (1 << 2) +#elif defined(CONFIG_MX53) +#define SRC_SBMR_NF16B (1 << 13) +#endif + +/* * CSPI register definitions */ #define MXC_ECSPI diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index 045df49..cead757 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -22,7 +22,8 @@ #include <nand.h> #include <linux/err.h> #include <asm/io.h> -#if defined(CONFIG_MX25) || defined(CONFIG_MX27) || defined(CONFIG_MX35) +#if defined(CONFIG_MX25) || defined(CONFIG_MX27) || defined(CONFIG_MX35) || \ + defined(CONFIG_MX51) || defined(CONFIG_MX53) #include <asm/arch/imx-regs.h> #endif #include <fsl_nfc.h> @@ -36,6 +37,9 @@ struct mxc_nand_host { struct nand_chip *nand;
struct fsl_nfc_regs __iomem *regs; +#ifdef MXC_NFC_V3_2 + struct fsl_nfc_ip_regs __iomem *ip_regs; +#endif int spare_only; int status_request; int pagesize_2k; @@ -77,7 +81,7 @@ static struct nand_ecclayout nand_hw_eccoob2k = { .oobfree = { {2, 4}, {11, 11}, {27, 11}, {43, 11}, {59, 5} }, }; #endif -#elif defined(MXC_NFC_V2_1) +#elif defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) #ifndef CONFIG_SYS_NAND_LARGEPAGE static struct nand_ecclayout nand_hw_eccoob = { .eccbytes = 9, @@ -130,6 +134,16 @@ static int is_16bit_nand(void) else return 0; } +#elif defined(CONFIG_MX51) || defined(CONFIG_MX53) +static int is_16bit_nand(void) +{ + struct src *src = (struct src *)SRC_BASE_ADDR; + + if (readl(&src->sbmr) & SRC_SBMR_NF16B) + return 1; + else + return 0; +} #else #warning "8/16 bit NAND autodetection not supported" static int is_16bit_nand(void) @@ -158,10 +172,17 @@ static void wait_op_done(struct mxc_nand_host *host, int max_retries, uint32_t tmp;
while (max_retries-- > 0) { +#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) tmp = readnfc(&host->regs->config2); if (tmp & NFC_V1_V2_CONFIG2_INT) { tmp &= ~NFC_V1_V2_CONFIG2_INT; writenfc(tmp, &host->regs->config2); +#elif defined(MXC_NFC_V3_2) + tmp = readnfc(&host->ip_regs->ipc); + if (tmp & NFC_V3_IPC_INT) { + tmp &= ~NFC_V3_IPC_INT; + writenfc(tmp, &host->ip_regs->ipc); +#endif break; } udelay(1); @@ -213,7 +234,7 @@ static void send_prog_page(struct mxc_nand_host *host, uint8_t buf_id, if (spare_only) MTDDEBUG(MTD_DEBUG_LEVEL1, "send_prog_page (%d)\n", spare_only);
- if (is_mxc_nfc_21()) { + if (is_mxc_nfc_21() || is_mxc_nfc_32()) { int i; /* * The controller copies the 64 bytes of spare data from @@ -229,11 +250,18 @@ static void send_prog_page(struct mxc_nand_host *host, uint8_t buf_id, } }
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) writenfc(buf_id, &host->regs->buf_addr); +#elif defined(MXC_NFC_V3_2) + uint32_t tmp = readnfc(&host->regs->config1); + tmp &= ~NFC_V3_CONFIG1_RBA_MASK; + tmp |= NFC_V3_CONFIG1_RBA(buf_id); + writenfc(tmp, &host->regs->config1); +#endif
/* Configure spare or page+spare access */ if (!host->pagesize_2k) { - uint16_t config1 = readnfc(&host->regs->config1); + uint32_t config1 = readnfc(&host->regs->config1); if (spare_only) config1 |= NFC_CONFIG1_SP_EN; else @@ -256,7 +284,14 @@ static void send_read_page(struct mxc_nand_host *host, uint8_t buf_id, { MTDDEBUG(MTD_DEBUG_LEVEL3, "send_read_page (%d)\n", spare_only);
/* Configure spare or page+spare access */ if (!host->pagesize_2k) { @@ -273,7 +308,7 @@ static void send_read_page(struct mxc_nand_host *host, uint8_t buf_id, /* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, spare_only);
/* @@ -293,10 +328,16 @@ static void send_read_page(struct mxc_nand_host *host, uint8_t buf_id, /* Request the NANDFC to perform a read of the NAND device ID. */ static void send_read_id(struct mxc_nand_host *host) { - uint16_t tmp; + uint32_t tmp;
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) /* NANDFC buffer 0 is used for device ID output */ writenfc(0x0, &host->regs->buf_addr); +#elif defined(MXC_NFC_V3_2) + tmp = readnfc(&host->regs->config1); + tmp &= ~NFC_V3_CONFIG1_RBA_MASK; + writenfc(tmp, &host->regs->config1); +#endif
/* Read ID into main buffer */ tmp = readnfc(&host->regs->config1); @@ -315,15 +356,19 @@ static void send_read_id(struct mxc_nand_host *host) */ static uint16_t get_dev_status(struct mxc_nand_host *host) { +#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) void __iomem *main_buf = host->regs->main_area[1]; uint32_t store; - uint16_t ret, tmp; +#endif + uint32_t ret, tmp; /* Issue status request to NAND device */
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) /* store the main area1 first word, later do recovery */ store = readl(main_buf); /* NANDFC buffer 1 is used for device status */ writenfc(1, &host->regs->buf_addr); +#endif
/* Read status into main buffer */ tmp = readnfc(&host->regs->config1); @@ -335,12 +380,16 @@ static uint16_t get_dev_status(struct mxc_nand_host *host) /* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, 0);
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) /* * Status is placed in first word of main buffer * get status, then recovery area 1 data */ ret = readw(main_buf); writel(store, main_buf); +#elif defined(MXC_NFC_V3_2) + ret = readnfc(&host->regs->config1) >> 16; +#endif
return ret; } @@ -359,6 +408,7 @@ static void _mxc_nand_enable_hwecc(struct mtd_info *mtd, int on) { struct nand_chip *nand_chip = mtd->priv; struct mxc_nand_host *host = nand_chip->priv; +#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) uint16_t tmp = readnfc(&host->regs->config1);
if (on) @@ -366,6 +416,15 @@ static void _mxc_nand_enable_hwecc(struct mtd_info *mtd, int on) else tmp &= ~NFC_V1_V2_CONFIG1_ECC_EN; writenfc(tmp, &host->regs->config1); +#elif defined(MXC_NFC_V3_2) + uint32_t tmp = readnfc(&host->ip_regs->config2); + + if (on) + tmp |= NFC_V3_CONFIG2_ECC_EN; + else + tmp &= ~NFC_V3_CONFIG2_ECC_EN; + writenfc(tmp, &host->ip_regs->config2); +#endif }
#ifdef CONFIG_MXC_NAND_HWECC @@ -377,7 +436,7 @@ static void mxc_nand_enable_hwecc(struct mtd_info *mtd, int mode) */ }
-#ifdef MXC_NFC_V2_1 +#if defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) static int mxc_nand_read_oob_syndrome(struct mtd_info *mtd, struct nand_chip *chip, int page, int sndcmd) @@ -1167,8 +1226,8 @@ static struct nand_bbt_descr bbt_mirror_descr = { int board_nand_init(struct nand_chip *this) { struct mtd_info *mtd; -#ifdef MXC_NFC_V2_1 - uint16_t tmp; +#if defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) + uint32_t tmp; #endif
#ifdef CONFIG_SYS_NAND_USE_FLASH_BBT @@ -1196,13 +1255,17 @@ int board_nand_init(struct nand_chip *this) this->verify_buf = mxc_nand_verify_buf;
host->regs = (struct fsl_nfc_regs __iomem *)CONFIG_MXC_NAND_REGS_BASE; +#ifdef MXC_NFC_V3_2 + host->ip_regs = + (struct fsl_nfc_ip_regs __iomem *)CONFIG_MXC_NAND_IP_REGS_BASE; +#endif host->clk_act = 1;
#ifdef CONFIG_MXC_NAND_HWECC this->ecc.calculate = mxc_nand_calculate_ecc; this->ecc.hwctl = mxc_nand_enable_hwecc; this->ecc.correct = mxc_nand_correct_data; - if (is_mxc_nfc_21()) { + if (is_mxc_nfc_21() || is_mxc_nfc_32()) { this->ecc.mode = NAND_ECC_HW_SYNDROME; this->ecc.read_page = mxc_nand_read_page_syndrome; this->ecc.read_page_raw = mxc_nand_read_page_raw_syndrome; @@ -1240,6 +1303,7 @@ int board_nand_init(struct nand_chip *this) this->ecc.layout = &nand_hw_eccoob; #endif
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) #ifdef MXC_NFC_V2_1 tmp = readnfc(&host->regs->config1); tmp |= NFC_V2_CONFIG1_ONE_CYCLE; @@ -1274,6 +1338,49 @@ int board_nand_init(struct nand_chip *this)
/* Unlock Block Command for given address range */ writenfc(0x4, &host->regs->wrprot); +#elif defined(MXC_NFC_V3_2) + writenfc(NFC_V3_CONFIG1_RBA(0), &host->regs->config1); + writenfc(NFC_V3_IPC_CREQ, &host->ip_regs->ipc); + + /* Unlock the internal RAM Buffer */ + writenfc(NFC_V3_WRPROT_BLS_UNLOCK | NFC_V3_WRPROT_UNLOCK, + &host->ip_regs->wrprot); + + /* Blocks to be unlocked */ + for (tmp = 0; tmp < CONFIG_SYS_NAND_MAX_CHIPS; tmp++) + writenfc(0x0 | 0xFFFF << 16, + &host->ip_regs->wrprot_unlock_blkaddr[tmp]); + + writenfc(0, &host->ip_regs->ipc); + + tmp = readnfc(&host->ip_regs->config2); + tmp &= ~(NFC_V3_CONFIG2_SPAS_MASK | NFC_V3_CONFIG2_EDC_MASK | + NFC_V3_CONFIG2_ECC_MODE_8 | NFC_V3_CONFIG2_PS_MASK); + tmp |= NFC_V3_CONFIG2_ONE_CYCLE; + + if (host->pagesize_2k) { + tmp |= NFC_V3_CONFIG2_SPAS(64/2); + tmp |= NFC_V3_CONFIG2_PS_2048; + } else { + tmp |= NFC_V3_CONFIG2_SPAS(16/2); + tmp |= NFC_V3_CONFIG2_PS_512; + } + + writenfc(tmp, &host->ip_regs->config2); + + tmp = NFC_V3_CONFIG3_NUM_OF_DEVS(0) | + NFC_V3_CONFIG3_NO_SDMA | + NFC_V3_CONFIG3_RBB_MODE | + NFC_V3_CONFIG3_SBB(6) | /* Reset default */ + NFC_V3_CONFIG3_ADD_OP(0); + + if (!(this->options & NAND_BUSWIDTH_16)) + tmp |= NFC_V3_CONFIG3_FW8; + + writenfc(tmp, &host->ip_regs->config3); + + writenfc(0, &host->ip_regs->delay_line); +#endif
return 0; } diff --git a/include/fsl_nfc.h b/include/fsl_nfc.h index 013e9e2..48a6448 100644 --- a/include/fsl_nfc.h +++ b/include/fsl_nfc.h @@ -33,7 +33,8 @@ * to support up to 2K byte pagesize nand. * Reading or writing a 2K page requires 4 FDI/FDO cycles. * - * MX25 and MX35 have version 2.1, which has: + * MX25 and MX35 have version 2.1, and MX51 and MX53 have version 3.2, which + * have: * 8 512-byte main buffers and * 8 64-byte spare buffers * to support up to 4K byte pagesize nand. @@ -44,20 +45,29 @@ #define MXC_NFC_V1 #define is_mxc_nfc_1() 1 #define is_mxc_nfc_21() 0 +#define is_mxc_nfc_32() 0 #elif defined(CONFIG_MX25) || defined(CONFIG_MX35) #define MXC_NFC_V2_1 #define is_mxc_nfc_1() 0 #define is_mxc_nfc_21() 1 +#define is_mxc_nfc_32() 0 +#elif defined(CONFIG_MX51) || defined(CONFIG_MX53) +#define MXC_NFC_V3 +#define MXC_NFC_V3_2 +#define is_mxc_nfc_1() 0 +#define is_mxc_nfc_21() 0 +#define is_mxc_nfc_32() 1 #else #error "MXC NFC implementation not supported" #endif +#define is_mxc_nfc_3() is_mxc_nfc_32()
#if defined(MXC_NFC_V1) #define NAND_MXC_NR_BUFS 4 #define NAND_MXC_SPARE_BUF_SIZE 16 #define NAND_MXC_REG_OFFSET 0xe00 #define NAND_MXC_2K_MULTI_CYCLE -#elif defined(MXC_NFC_V2_1) +#elif defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) #define NAND_MXC_NR_BUFS 8 #define NAND_MXC_SPARE_BUF_SIZE 64 #define NAND_MXC_REG_OFFSET 0x1e00 @@ -110,9 +120,28 @@ struct fsl_nfc_regs { u16 unlockend_blkaddr2; u16 unlockstart_blkaddr3; u16 unlockend_blkaddr3; +#elif defined(MXC_NFC_V3_2) + u32 flash_cmd; + u32 flash_addr[12]; + u32 config1; + u32 ecc_status_result; + u32 status_sum; + u32 launch; #endif };
+#ifdef MXC_NFC_V3_2 +struct fsl_nfc_ip_regs { + u32 wrprot; + u32 wrprot_unlock_blkaddr[8]; + u32 config2; + u32 config3; + u32 ipc; + u32 err_addr; + u32 delay_line; +}; +#endif + /* Set FCMD to 1, rest to 0 for Command operation */ #define NFC_CMD 0x1
@@ -131,20 +160,66 @@ struct fsl_nfc_regs { /* Set FDO to 100, rest to 0 for Read Status operation */ #define NFC_STATUS 0x20
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) #define NFC_CONFIG1_SP_EN (1 << 2) #define NFC_CONFIG1_RST (1 << 6) #define NFC_CONFIG1_CE (1 << 7) +#elif defined(MXC_NFC_V3_2) +#define NFC_CONFIG1_SP_EN (1 << 0) +#define NFC_CONFIG1_CE (1 << 1) +#define NFC_CONFIG1_RST (1 << 2) +#endif #define NFC_V1_V2_CONFIG1_ECC_EN (1 << 3) #define NFC_V1_V2_CONFIG1_INT_MSK (1 << 4) #define NFC_V1_V2_CONFIG1_BIG (1 << 5) #define NFC_V2_CONFIG1_ECC_MODE_4 (1 << 0) #define NFC_V2_CONFIG1_ONE_CYCLE (1 << 8) #define NFC_V2_CONFIG1_FP_INT (1 << 11) +#define NFC_V3_CONFIG1_RBA_MASK (0x7 << 4) +#define NFC_V3_CONFIG1_RBA(x) (((x) & 0x7) << 4)
#define NFC_V1_V2_CONFIG2_INT (1 << 15) +#define NFC_V3_CONFIG2_PS_MASK (0x3 << 0) +#define NFC_V3_CONFIG2_PS_512 (0 << 0) +#define NFC_V3_CONFIG2_PS_2048 (1 << 0) +#define NFC_V3_CONFIG2_PS_4096 (2 << 0) +#define NFC_V3_CONFIG2_ONE_CYCLE (1 << 2) +#define NFC_V3_CONFIG2_ECC_EN (1 << 3) +#define NFC_V3_CONFIG2_2CMD_PHASES (1 << 4) +#define NFC_V3_CONFIG2_NUM_ADDR_PH0 (1 << 5) +#define NFC_V3_CONFIG2_ECC_MODE_8 (1 << 6) +#define NFC_V3_CONFIG2_PPB_MASK (0x3 << 7) +#define NFC_V3_CONFIG2_PPB(x) (((x) & 0x3) << 7) +#define NFC_V3_CONFIG2_EDC_MASK (0x7 << 9) +#define NFC_V3_CONFIG2_EDC(x) (((x) & 0x7) << 9) +#define NFC_V3_CONFIG2_NUM_ADDR_PH1(x) (((x) & 0x3) << 12) +#define NFC_V3_CONFIG2_INT_MSK (1 << 15) +#define NFC_V3_CONFIG2_SPAS_MASK (0xff << 16) +#define NFC_V3_CONFIG2_SPAS(x) (((x) & 0xff) << 16) +#define NFC_V3_CONFIG2_ST_CMD_MASK (0xff << 24) +#define NFC_V3_CONFIG2_ST_CMD(x) (((x) & 0xff) << 24) + +#define NFC_V3_CONFIG3_ADD_OP(x) (((x) & 0x3) << 0) +#define NFC_V3_CONFIG3_FW8 (1 << 3) +#define NFC_V3_CONFIG3_SBB(x) (((x) & 0x7) << 8) +#define NFC_V3_CONFIG3_NUM_OF_DEVS(x) (((x) & 0x7) << 12) +#define NFC_V3_CONFIG3_RBB_MODE (1 << 15) +#define NFC_V3_CONFIG3_NO_SDMA (1 << 20)
+#define NFC_V3_WRPROT_UNLOCK (1 << 2) +#define NFC_V3_WRPROT_BLS_UNLOCK (2 << 6) + +#define NFC_V3_IPC_CREQ (1 << 0) +#define NFC_V3_IPC_INT (1 << 31) + +#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) #define operation config2 #define readnfc readw #define writenfc writew +#elif defined(MXC_NFC_V3_2) +#define operation launch +#define readnfc readl +#define writenfc writel +#endif
#endif /* __FSL_NFC_H */ diff --git a/nand_spl/nand_boot_fsl_nfc.c b/nand_spl/nand_boot_fsl_nfc.c index 615e820..1096727 100644 --- a/nand_spl/nand_boot_fsl_nfc.c +++ b/nand_spl/nand_boot_fsl_nfc.c @@ -30,12 +30,18 @@ #include <asm/io.h> #include <fsl_nfc.h>
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) static struct fsl_nfc_regs *const nfc = (void *)NFC_BASE_ADDR; +#elif defined(MXC_NFC_V3_2) +static struct fsl_nfc_regs *const nfc = (void *)NFC_BASE_ADDR_AXI; +static struct fsl_nfc_ip_regs *const nfc_ip = (void *)NFC_BASE_ADDR; +#endif
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) while (!(readnfc(&nfc->config2) & NFC_V1_V2_CONFIG2_INT)) ;
@@ -43,11 +49,56 @@ static void nfc_wait_ready(void) tmp = readnfc(&nfc->config2); tmp &= ~NFC_V1_V2_CONFIG2_INT; writenfc(tmp, &nfc->config2); +#elif defined(MXC_NFC_V3_2) + while (!(readnfc(&nfc_ip->ipc) & NFC_V3_IPC_INT)) + ; + + /* Reset interrupt flag */ + tmp = readnfc(&nfc_ip->ipc); + tmp &= ~NFC_V3_IPC_INT; + writenfc(tmp, &nfc_ip->ipc); +#endif }
static void nfc_nand_init(void) { -#if defined(MXC_NFC_V2_1) +#if defined(MXC_NFC_V3_2) + int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; + int tmp; + + tmp = (readnfc(&nfc_ip->config2) & ~(NFC_V3_CONFIG2_SPAS_MASK | + NFC_V3_CONFIG2_EDC_MASK | NFC_V3_CONFIG2_PS_MASK)) | + NFC_V3_CONFIG2_SPAS(CONFIG_SYS_NAND_SPARE_SIZE / 2) | + NFC_V3_CONFIG2_INT_MSK | NFC_V3_CONFIG2_ECC_EN | + NFC_V3_CONFIG2_ONE_CYCLE; + if (CONFIG_SYS_NAND_PAGE_SIZE == 4096) + tmp |= NFC_V3_CONFIG2_PS_4096; + else if (CONFIG_SYS_NAND_PAGE_SIZE == 2048) + tmp |= NFC_V3_CONFIG2_PS_2048; + else if (CONFIG_SYS_NAND_PAGE_SIZE == 512) + tmp |= NFC_V3_CONFIG2_PS_512; + /* + * if spare size is larger that 16 bytes per 512 byte hunk + * then use 8 symbol correction instead of 4 + */ + if (CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16) + tmp |= NFC_V3_CONFIG2_ECC_MODE_8; + else + tmp &= ~NFC_V3_CONFIG2_ECC_MODE_8; + writenfc(tmp, &nfc_ip->config2); + + tmp = NFC_V3_CONFIG3_NUM_OF_DEVS(0) | + NFC_V3_CONFIG3_NO_SDMA | + NFC_V3_CONFIG3_RBB_MODE | + NFC_V3_CONFIG3_SBB(6) | /* Reset default */ + NFC_V3_CONFIG3_ADD_OP(0); +#ifndef CONFIG_SYS_NAND_BUSWIDTH_16 + tmp |= NFC_V3_CONFIG3_FW8; +#endif + writenfc(tmp, &nfc_ip->config3); + + writenfc(0, &nfc_ip->delay_line); +#elif defined(MXC_NFC_V2_1) int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; int config1;
@@ -123,7 +174,13 @@ static void nfc_nand_data_output(void) int i; #endif
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) writenfc(0, &nfc->buf_addr); +#elif defined(MXC_NFC_V3_2) + int config1 = readnfc(&nfc->config1); + config1 &= ~NFC_V3_CONFIG1_RBA_MASK; + writenfc(config1, &nfc->config1); +#endif writenfc(NFC_OUTPUT, &nfc->operation); nfc_wait_ready(); #ifdef NAND_MXC_2K_MULTI_CYCLE @@ -144,7 +201,7 @@ static int nfc_nand_check_ecc(void) #if defined(MXC_NFC_V1) u16 ecc_status = readw(&nfc->ecc_status_result); return (ecc_status & 0x3) == 2 || (ecc_status >> 2) == 2; -#elif defined(MXC_NFC_V2_1) +#elif defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) u32 ecc_status = readl(&nfc->ecc_status_result); int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; int err_limit = CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16 ? 8 : 4; @@ -163,7 +220,13 @@ static int nfc_nand_check_ecc(void) static void nfc_nand_read_page(unsigned int page_address) { /* read in first 0 buffer */ +#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) writenfc(0, &nfc->buf_addr); +#elif defined(MXC_NFC_V3_2) + int config1 = readnfc(&nfc->config1); + config1 &= ~NFC_V3_CONFIG1_RBA_MASK; + writenfc(config1, &nfc->config1); +#endif nfc_nand_command(NAND_CMD_READ0); nfc_nand_page_address(page_address);
Don't use several instructions to build constant values.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Acked-by: Stefano Babic sbabic@denx.de --- Changes in v5: None Changes in v4: None Changes in v3: - New patch.
Changes in v2: None
arch/arm/cpu/armv7/mx5/lowlevel_init.S | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx5/lowlevel_init.S b/arch/arm/cpu/armv7/mx5/lowlevel_init.S index 6d9396a..dfce0ca 100644 --- a/arch/arm/cpu/armv7/mx5/lowlevel_init.S +++ b/arch/arm/cpu/armv7/mx5/lowlevel_init.S @@ -309,8 +309,7 @@ setup_pll_func: ldr r0, =CCM_BASE_ADDR ldr r1, =0x00015154 str r1, [r0, #CLKCTL_CBCMR] - ldr r1, =0x02888945 - orr r1, r1, #(1 << 16) + ldr r1, =0x02898945 str r1, [r0, #CLKCTL_CBCDR] /* make sure change is effective */ 1: ldr r1, [r0, #CLKCTL_CDHIPR] @@ -321,10 +320,7 @@ setup_pll_func:
/* Switch peripheral to PLL2 */ ldr r0, =CCM_BASE_ADDR - ldr r1, =0x00808145 - orr r1, r1, #(2 << 10) - orr r1, r1, #(0 << 16) - orr r1, r1, #(1 << 19) + ldr r1, =0x00888945 str r1, [r0, #CLKCTL_CBCDR]
ldr r1, =0x00016154
Add support for the Samsung K9LAG08U0M NAND Flash (2-GiB MLC NAND Flash, 2-kiB pages, 256-kiB blocks, 30-ns R/W cycles, 1 CS) on mx53ard.
eNFC_CLK_ROOT is set up with a cycle time of 37.5 ns (400 MHz / 3 / 5) for this board, which satisfies the 30-ns NF R/W cycle requirement.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v5: None Changes in v4: None Changes in v3: - New patch.
Changes in v2: None
board/freescale/mx53ard/mx53ard.c | 18 ++++++++++++++++++ include/configs/mx53ard.h | 10 ++++++++++ 2 files changed, 28 insertions(+)
diff --git a/board/freescale/mx53ard/mx53ard.c b/board/freescale/mx53ard/mx53ard.c index 2fc8570..8907388 100644 --- a/board/freescale/mx53ard/mx53ard.c +++ b/board/freescale/mx53ard/mx53ard.c @@ -58,6 +58,23 @@ void dram_init_banksize(void) gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; }
+#ifdef CONFIG_NAND_MXC +static void setup_iomux_nand(void) +{ + mxc_request_iomux(MX53_PIN_NANDF_CLE, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_NANDF_ALE, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_NANDF_CS0, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_NANDF_RE_B, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_NANDF_WE_B, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_NANDF_WP_B, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_NANDF_RB0, IOMUX_CONFIG_ALT0); +} +#else +static void setup_iomux_nand(void) +{ +} +#endif + static void setup_iomux_uart(void) { /* UART1 RXD */ @@ -277,6 +294,7 @@ static void weim_cs1_settings(void)
int board_early_init_f(void) { + setup_iomux_nand(); setup_iomux_uart(); return 0; } diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 62cb42b..148f7a2 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -41,6 +41,16 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MXC_GPIO
+#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR_AXI +#define CONFIG_NAND_MXC +#define CONFIG_MXC_NAND_REGS_BASE NFC_BASE_ADDR_AXI +#define CONFIG_MXC_NAND_IP_REGS_BASE NFC_BASE_ADDR +#define CONFIG_SYS_NAND_LARGEPAGE +#define CONFIG_MXC_NAND_HWECC +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_CMD_NAND + #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE
The page number indicated in the debug trace of mxc_nand_read_oob_syndrome() did not match the page being worked on.
By the way, replace the GCC-specific __FUNCTION__ with __func__.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v5: - Replace __FUNCTION__ with __func__.
Changes in v4: - New patch.
drivers/mtd/nand/mxc_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index cead757..249328e 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -450,7 +450,7 @@ static int mxc_nand_read_oob_syndrome(struct mtd_info *mtd,
MTDDEBUG(MTD_DEBUG_LEVEL0, "%s: Reading OOB area of page %u to oob %p\n", - __FUNCTION__, host->page_addr, buf); + __func__, page, buf);
chip->cmdfunc(mtd, NAND_CMD_READOOB, mtd->writesize, page); for (i = 0; i < chip->ecc.steps; i++) {
The syndrome functions should use the page number passed as argument instead of the page number saved upon NAND_CMD_READ0.
This does not make any difference if the NAND_NO_AUTOINCR option is set, but otherwise this fixes accesses to the wrong pages.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v5: None Changes in v4: - New patch.
drivers/mtd/nand/mxc_nand.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index 249328e..001c2c0 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -504,7 +504,7 @@ static int mxc_nand_read_page_raw_syndrome(struct mtd_info *mtd, int n;
_mxc_nand_enable_hwecc(mtd, 0); - chip->cmdfunc(mtd, NAND_CMD_READ0, 0x00, host->page_addr); + chip->cmdfunc(mtd, NAND_CMD_READ0, 0x00, page);
for (n = 0, steps = chip->ecc.steps; steps > 0; n++, steps--) { host->col_addr = n * eccsize; @@ -548,7 +548,7 @@ static int mxc_nand_read_page_syndrome(struct mtd_info *mtd, uint8_t *oob = chip->oob_poi;
MTDDEBUG(MTD_DEBUG_LEVEL1, "Reading page %u to buf %p oob %p\n", - host->page_addr, buf, oob); + page, buf, oob);
/* first read the data area and the available portion of OOB */ for (n = 0; eccsteps; n++, eccsteps--, p += eccsize) { @@ -586,7 +586,7 @@ static int mxc_nand_read_page_syndrome(struct mtd_info *mtd,
/* Then switch ECC off and read the OOB area to get the ECC code */ _mxc_nand_enable_hwecc(mtd, 0); - chip->cmdfunc(mtd, NAND_CMD_READOOB, mtd->writesize, host->page_addr); + chip->cmdfunc(mtd, NAND_CMD_READOOB, mtd->writesize, page); eccsteps = chip->ecc.steps; oob = chip->oob_poi + chip->ecc.prepad; for (n = 0; eccsteps; n++, eccsteps--, p += eccsize) {
PAD_TO is not a generic SPL configuration option, so use CONFIG_SPL_MAX_SIZE instead.
Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index f4a9b33..d28e608 100644 --- a/Makefile +++ b/Makefile @@ -486,7 +486,7 @@ $(obj)u-boot.dis: $(obj)u-boot $(OBJDUMP) -d $< > $@
$(obj)u-boot-with-spl.bin: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin - $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $(obj)spl/u-boot-spl $(obj)spl/u-boot-spl-pad.bin + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(CONFIG_SPL_MAX_SIZE) -O binary $(obj)spl/u-boot-spl $(obj)spl/u-boot-spl-pad.bin cat $(obj)spl/u-boot-spl-pad.bin $(obj)u-boot.bin > $@ rm $(obj)spl/u-boot-spl-pad.bin
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v5: - Remove spaces between function name and open parenthesis. - Fix mx31pdk and tx25 Makefile-s and SPL linker scripts. - Remove the useless definition of CONFIG_SPL_LDSCRIPT. - Fix the call to nand_boot().
Makefile | 3 + arch/arm/cpu/arm1136/config.mk | 3 - arch/arm/cpu/arm1136/start.S | 2 - arch/arm/cpu/arm926ejs/start.S | 9 +- board/freescale/mx31pdk/Makefile | 4 + board/freescale/mx31pdk/config.mk | 5 -- .../freescale/mx31pdk/u-boot-spl.lds | 20 +++-- board/karo/tx25/Makefile | 5 +- board/karo/tx25/config.mk | 5 -- .../u-boot.lds => board/karo/tx25/u-boot-spl.lds | 16 ++-- boards.cfg | 2 +- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/mxc_nand.c | 10 +-- include/fsl_nfc.h => drivers/mtd/nand/mxc_nand.h | 10 +-- .../mtd/nand/mxc_nand_spl.c | 26 +++--- include/common.h | 6 +- include/configs/mx31pdk.h | 10 ++- include/configs/tx25.h | 13 ++- include/configs/woodburn_sd.h | 1 + nand_spl/board/freescale/mx31pdk/Makefile | 68 --------------- nand_spl/board/karo/tx25/Makefile | 89 -------------------- nand_spl/board/karo/tx25/config.mk | 1 - 22 files changed, 87 insertions(+), 222 deletions(-) delete mode 100644 board/freescale/mx31pdk/config.mk rename nand_spl/board/karo/tx25/u-boot.lds => board/freescale/mx31pdk/u-boot-spl.lds (86%) delete mode 100644 board/karo/tx25/config.mk rename nand_spl/board/freescale/mx31pdk/u-boot.lds => board/karo/tx25/u-boot-spl.lds (89%) rename include/fsl_nfc.h => drivers/mtd/nand/mxc_nand.h (98%) rename nand_spl/nand_boot_fsl_nfc.c => drivers/mtd/nand/mxc_nand_spl.c (92%) delete mode 100644 nand_spl/board/freescale/mx31pdk/Makefile delete mode 100644 nand_spl/board/karo/tx25/Makefile delete mode 100644 nand_spl/board/karo/tx25/config.mk
diff --git a/Makefile b/Makefile index d28e608..cc2298a 100644 --- a/Makefile +++ b/Makefile @@ -470,6 +470,9 @@ $(obj)u-boot.img: $(obj)u-boot.bin $(OBJTREE)/u-boot.imx : $(obj)u-boot.bin $(SUBDIR_TOOLS) depend $(MAKE) -C $(SRCTREE)/arch/arm/imx-common $@
+$(OBJTREE)/SPL : $(obj)spl/u-boot-spl.bin depend + $(MAKE) -C $(SRCTREE)/arch/arm/imx-common $@ + $(obj)u-boot.kwb: $(obj)u-boot.bin $(obj)tools/mkimage -n $(CONFIG_SYS_KWD_CONFIG) -T kwbimage \ -a $(CONFIG_SYS_TEXT_BASE) -e $(CONFIG_SYS_TEXT_BASE) -d $< $@ diff --git a/arch/arm/cpu/arm1136/config.mk b/arch/arm/cpu/arm1136/config.mk index 9092d91..efee0d1 100644 --- a/arch/arm/cpu/arm1136/config.mk +++ b/arch/arm/cpu/arm1136/config.mk @@ -31,6 +31,3 @@ PLATFORM_CPPFLAGS += -march=armv5 # ========================================================================= PF_RELFLAGS_SLB_AT := $(call cc-option,-mshort-load-bytes,$(call cc-option,-malignment-traps,)) PLATFORM_RELFLAGS += $(PF_RELFLAGS_SLB_AT) -ifdef CONFIG_SPL_BUILD -ALL-y += $(OBJTREE)/SPL -endif diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index a067b8a..3818768 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -235,8 +235,6 @@ fixnext: add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 blo fixloop - bx lr - #endif
relocate_done: diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 66a8b65..dee45f7 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -140,6 +140,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.global _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -196,7 +200,6 @@ reset:
-#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_NAND_SPL) /* * void relocate_code (addr_sp, gd, addr_moni) * @@ -216,7 +219,7 @@ relocate_code: moveq r9, #0 /* no relocation. offset(r9) = 0 */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: @@ -270,6 +273,8 @@ relocate_done:
bx lr
+#ifndef CONFIG_SPL_BUILD + _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: diff --git a/board/freescale/mx31pdk/Makefile b/board/freescale/mx31pdk/Makefile index 5b7cafd..a1e01f0 100644 --- a/board/freescale/mx31pdk/Makefile +++ b/board/freescale/mx31pdk/Makefile @@ -27,7 +27,11 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
+ifdef CONFIG_SPL_BUILD +SOBJS := lowlevel_init.o +else COBJS := mx31pdk.o +endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/mx31pdk/config.mk b/board/freescale/mx31pdk/config.mk deleted file mode 100644 index de2c642..0000000 --- a/board/freescale/mx31pdk/config.mk +++ /dev/null @@ -1,5 +0,0 @@ -ifdef CONFIG_NAND_SPL -CONFIG_SYS_TEXT_BASE = 0x87ec0000 -else -CONFIG_SYS_TEXT_BASE = 0x87f00000 -endif diff --git a/nand_spl/board/karo/tx25/u-boot.lds b/board/freescale/mx31pdk/u-boot-spl.lds similarity index 86% rename from nand_spl/board/karo/tx25/u-boot.lds rename to board/freescale/mx31pdk/u-boot-spl.lds index ee36131..96e04ce 100644 --- a/nand_spl/board/karo/tx25/u-boot.lds +++ b/board/freescale/mx31pdk/u-boot-spl.lds @@ -30,30 +30,32 @@ SECTIONS . = ALIGN(4); .text : { - start.o (.text) - lowlevel_init.o (.text) - nand_boot_fsl_nfc.o (.text) - *(.text) + arch/arm/cpu/arm1136/start.o (.text*) + board/freescale/mx31pdk/libmx31pdk.o (.text*) + drivers/mtd/nand/libnand.o (.text*) + *(.text*) . = 2K; }
. = ALIGN(4); - .rodata : { *(.rodata) } + .rodata : { *(.rodata*) }
. = ALIGN(4); .data : { - *(.data) + *(.data*) }
. = ALIGN(4);
. = ALIGN(4); .u_boot_list : { - #include <u-boot.lst> + #include <u-boot.lst> }
. = ALIGN(4);
+ __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*) @@ -62,14 +64,14 @@ SECTIONS
.dynsym : { __dynsym_start = .; - *(.dynsym) + *(.dynsym*) }
_end = .;
.bss __rel_dyn_start (OVERLAY) : { __bss_start = .; - *(.bss) + *(.bss*) . = ALIGN(4); __bss_end__ = .; } diff --git a/board/karo/tx25/Makefile b/board/karo/tx25/Makefile index 9617fa5..cf83a6b 100644 --- a/board/karo/tx25/Makefile +++ b/board/karo/tx25/Makefile @@ -25,8 +25,11 @@ include $(TOPDIR)/config.mk
-COBJS := tx25.o +ifdef CONFIG_SPL_BUILD SOBJS := lowlevel_init.o +else +COBJS := tx25.o +endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/karo/tx25/config.mk b/board/karo/tx25/config.mk deleted file mode 100644 index 18b2883..0000000 --- a/board/karo/tx25/config.mk +++ /dev/null @@ -1,5 +0,0 @@ -ifdef CONFIG_NAND_SPL -CONFIG_SYS_TEXT_BASE = 0x810c0000 -else -CONFIG_SYS_TEXT_BASE = 0x81200000 -endif diff --git a/nand_spl/board/freescale/mx31pdk/u-boot.lds b/board/karo/tx25/u-boot-spl.lds similarity index 89% rename from nand_spl/board/freescale/mx31pdk/u-boot.lds rename to board/karo/tx25/u-boot-spl.lds index a26110f..0d7f140 100644 --- a/nand_spl/board/freescale/mx31pdk/u-boot.lds +++ b/board/karo/tx25/u-boot-spl.lds @@ -30,19 +30,19 @@ SECTIONS . = ALIGN(4); .text : { - start.o (.text) - lowlevel_init.o (.text) - nand_boot_fsl_nfc.o (.text) - *(.text) + arch/arm/cpu/arm926ejs/start.o (.text*) + board/karo/tx25/libtx25.o (.text*) + drivers/mtd/nand/libnand.o (.text*) + *(.text*) . = 2K; }
. = ALIGN(4); @@ -64,14 +64,14 @@ SECTIONS
_end = .;
.bss __rel_dyn_start (OVERLAY) : { __bss_start = .; - *(.bss) + *(.bss*) . = ALIGN(4); __bss_end__ = .; } diff --git a/boards.cfg b/boards.cfg index 7d03620..2649c88 100644 --- a/boards.cfg +++ b/boards.cfg @@ -45,7 +45,7 @@ imx31_phycore arm arm1136 - - imx31_phycore_eet arm arm1136 imx31_phycore - mx31 imx31_phycore:IMX31_PHYCORE_EET qong arm arm1136 - davedenx mx31 mx31ads arm arm1136 - freescale mx31 -mx31pdk arm arm1136 - freescale mx31 mx31pdk:NAND_U_BOOT +mx31pdk arm arm1136 - freescale mx31 tt01 arm arm1136 - hale mx31 imx31_litekit arm arm1136 - logicpd mx31 flea3 arm arm1136 - CarMediaLab mx35 diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index c77c0c4..bcb7161 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -82,6 +82,7 @@ COBJS-$(CONFIG_NAND_PLAT) += nand_plat.o else # minimal SPL drivers
COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_spl.o +COBJS-$(CONFIG_NAND_MXC) += mxc_nand_spl.o
endif # drivers endif # nand diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index 001c2c0..159e3b4 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -26,7 +26,7 @@ defined(CONFIG_MX51) || defined(CONFIG_MX53) #include <asm/arch/imx-regs.h> #endif -#include <fsl_nfc.h> +#include "mxc_nand.h"
#define DRIVER_NAME "mxc_nand"
@@ -36,9 +36,9 @@ struct mxc_nand_host { struct mtd_info mtd; struct nand_chip *nand;
- struct fsl_nfc_regs __iomem *regs; + struct mxc_nand_regs __iomem *regs; #ifdef MXC_NFC_V3_2 - struct fsl_nfc_ip_regs __iomem *ip_regs; + struct mxc_nand_ip_regs __iomem *ip_regs; #endif int spare_only; int status_request; @@ -1254,10 +1254,10 @@ int board_nand_init(struct nand_chip *this) this->read_buf = mxc_nand_read_buf; this->verify_buf = mxc_nand_verify_buf;
- host->regs = (struct fsl_nfc_regs __iomem *)CONFIG_MXC_NAND_REGS_BASE; + host->regs = (struct mxc_nand_regs __iomem *)CONFIG_MXC_NAND_REGS_BASE; #ifdef MXC_NFC_V3_2 host->ip_regs = - (struct fsl_nfc_ip_regs __iomem *)CONFIG_MXC_NAND_IP_REGS_BASE; + (struct mxc_nand_ip_regs __iomem *)CONFIG_MXC_NAND_IP_REGS_BASE; #endif host->clk_act = 1;
diff --git a/include/fsl_nfc.h b/drivers/mtd/nand/mxc_nand.h similarity index 98% rename from include/fsl_nfc.h rename to drivers/mtd/nand/mxc_nand.h index 48a6448..308ff8d 100644 --- a/include/fsl_nfc.h +++ b/drivers/mtd/nand/mxc_nand.h @@ -20,8 +20,8 @@ * MA 02111-1307 USA */
-#ifndef __FSL_NFC_H -#define __FSL_NFC_H +#ifndef __MXC_NAND_H +#define __MXC_NAND_H
/* * Register map and bit definitions for the Freescale NAND Flash Controller @@ -73,7 +73,7 @@ #define NAND_MXC_REG_OFFSET 0x1e00 #endif
-struct fsl_nfc_regs { +struct mxc_nand_regs { u8 main_area[NAND_MXC_NR_BUFS][0x200]; u8 spare_area[NAND_MXC_NR_BUFS][NAND_MXC_SPARE_BUF_SIZE]; /* @@ -131,7 +131,7 @@ struct fsl_nfc_regs { };
#ifdef MXC_NFC_V3_2 -struct fsl_nfc_ip_regs { +struct mxc_nand_ip_regs { u32 wrprot; u32 wrprot_unlock_blkaddr[8]; u32 config2; @@ -222,4 +222,4 @@ struct fsl_nfc_ip_regs { #define writenfc writel #endif
-#endif /* __FSL_NFC_H */ +#endif /* __MXC_NAND_H */ diff --git a/nand_spl/nand_boot_fsl_nfc.c b/drivers/mtd/nand/mxc_nand_spl.c similarity index 92% rename from nand_spl/nand_boot_fsl_nfc.c rename to drivers/mtd/nand/mxc_nand_spl.c index 1096727..5f7108d 100644 --- a/nand_spl/nand_boot_fsl_nfc.c +++ b/drivers/mtd/nand/mxc_nand_spl.c @@ -28,13 +28,13 @@ #include <nand.h> #include <asm/arch/imx-regs.h> #include <asm/io.h> -#include <fsl_nfc.h> +#include "mxc_nand.h"
#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) -static struct fsl_nfc_regs *const nfc = (void *)NFC_BASE_ADDR; +static struct mxc_nand_regs *const nfc = (void *)NFC_BASE_ADDR; #elif defined(MXC_NFC_V3_2) -static struct fsl_nfc_regs *const nfc = (void *)NFC_BASE_ADDR_AXI; -static struct fsl_nfc_ip_regs *const nfc_ip = (void *)NFC_BASE_ADDR; +static struct mxc_nand_regs *const nfc = (void *)NFC_BASE_ADDR_AXI; +static struct mxc_nand_ip_regs *const nfc_ip = (void *)NFC_BASE_ADDR; #endif
static void nfc_wait_ready(void) @@ -68,7 +68,7 @@ static void nfc_nand_init(void)
tmp = (readnfc(&nfc_ip->config2) & ~(NFC_V3_CONFIG2_SPAS_MASK | NFC_V3_CONFIG2_EDC_MASK | NFC_V3_CONFIG2_PS_MASK)) | - NFC_V3_CONFIG2_SPAS(CONFIG_SYS_NAND_SPARE_SIZE / 2) | + NFC_V3_CONFIG2_SPAS(CONFIG_SYS_NAND_OOBSIZE / 2) | NFC_V3_CONFIG2_INT_MSK | NFC_V3_CONFIG2_ECC_EN | NFC_V3_CONFIG2_ONE_CYCLE; if (CONFIG_SYS_NAND_PAGE_SIZE == 4096) @@ -81,7 +81,7 @@ static void nfc_nand_init(void) * if spare size is larger that 16 bytes per 512 byte hunk * then use 8 symbol correction instead of 4 */ - if (CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16) + if (CONFIG_SYS_NAND_OOBSIZE / ecc_per_page > 16) tmp |= NFC_V3_CONFIG2_ECC_MODE_8; else tmp &= ~NFC_V3_CONFIG2_ECC_MODE_8; @@ -102,7 +102,7 @@ static void nfc_nand_init(void) int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; int config1;
- writenfc(CONFIG_SYS_NAND_SPARE_SIZE / 2, &nfc->spare_area_size); + writenfc(CONFIG_SYS_NAND_OOBSIZE / 2, &nfc->spare_area_size);
/* unlocking RAM Buff */ writenfc(0x2, &nfc->config); @@ -115,7 +115,7 @@ static void nfc_nand_init(void) * if spare size is larger that 16 bytes per 512 byte hunk * then use 8 symbol correction instead of 4 */ - if (CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16) + if (CONFIG_SYS_NAND_OOBSIZE / ecc_per_page > 16) config1 &= ~NFC_V2_CONFIG1_ECC_MODE_4; else config1 |= NFC_V2_CONFIG1_ECC_MODE_4; @@ -204,7 +204,7 @@ static int nfc_nand_check_ecc(void) #elif defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) u32 ecc_status = readl(&nfc->ecc_status_result); int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; - int err_limit = CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16 ? 8 : 4; + int err_limit = CONFIG_SYS_NAND_OOBSIZE / ecc_per_page > 16 ? 8 : 4; int subpages = CONFIG_SYS_NAND_PAGE_SIZE / 512;
do { @@ -333,10 +333,12 @@ static int nand_load(unsigned int from, unsigned int size, unsigned char *buf) }
#if defined(CONFIG_ARM) -void board_init_f (ulong bootflag) +void board_init_f(ulong bootflag) { - relocate_code (CONFIG_SYS_TEXT_BASE - TOTAL_MALLOC_LEN, NULL, - CONFIG_SYS_TEXT_BASE); + relocate_code(CONFIG_SPL_TEXT_BASE - TOTAL_MALLOC_LEN, NULL, + CONFIG_SPL_TEXT_BASE); + + asm volatile("ldr pc, =nand_boot\n"); } #endif
diff --git a/include/common.h b/include/common.h index 4ad17ea..43a5ee4 100644 --- a/include/common.h +++ b/include/common.h @@ -515,7 +515,11 @@ int dcache_status (void); void dcache_enable (void); void dcache_disable(void); void mmu_disable(void); -void relocate_code (ulong, gd_t *, ulong) __attribute__ ((noreturn)); +void relocate_code (ulong, gd_t *, ulong) +#if !defined(CONFIG_ARM) +__attribute__ ((noreturn)) +#endif +; ulong get_endaddr (void); void trap_init (ulong); #if defined (CONFIG_4xx) || \ diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 34e4295..8892e89 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -45,7 +45,15 @@
#define CONFIG_MACH_TYPE MACH_TYPE_MX31_3DS
-#if defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) +#define CONFIG_SPL +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_MAX_SIZE 2048 +#define CONFIG_SPL_NAND_SUPPORT + +#define CONFIG_SPL_TEXT_BASE 0x87ec0000 +#define CONFIG_SYS_TEXT_BASE 0x87f00000 + +#ifndef CONFIG_SPL_BUILD #define CONFIG_SKIP_LOWLEVEL_INIT #endif
diff --git a/include/configs/tx25.h b/include/configs/tx25.h index 80194d8..e362fe9 100644 --- a/include/configs/tx25.h +++ b/include/configs/tx25.h @@ -31,8 +31,13 @@
#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* 256 kB for U-Boot */
-/* NAND BOOT is the only boot method */ -#define CONFIG_NAND_U_BOOT +#define CONFIG_SPL +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_MAX_SIZE 2048 +#define CONFIG_SPL_NAND_SUPPORT + +#define CONFIG_SPL_TEXT_BASE 0x810c0000 +#define CONFIG_SYS_TEXT_BASE 0x81200000
#ifndef MACH_TYPE_TX25 #define MACH_TYPE_TX25 2177 @@ -40,7 +45,7 @@
#define CONFIG_MACH_TYPE MACH_TYPE_TX25
-#ifdef CONFIG_NAND_SPL +#ifdef CONFIG_SPL_BUILD /* Start copying real U-boot from the second page */ #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x800 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x30000 @@ -49,7 +54,7 @@ #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST
#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_SPARE_SIZE 64 +#define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_SIZE (128 * 1024 * 1024) diff --git a/include/configs/woodburn_sd.h b/include/configs/woodburn_sd.h index 63185c5..1cc0e95 100644 --- a/include/configs/woodburn_sd.h +++ b/include/configs/woodburn_sd.h @@ -38,6 +38,7 @@ #define CONFIG_SPL #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm1136/u-boot-spl.lds" +#define CONFIG_SPL_TARGET "SPL" #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT #define CONFIG_SPL_LIBDISK_SUPPORT diff --git a/nand_spl/board/freescale/mx31pdk/Makefile b/nand_spl/board/freescale/mx31pdk/Makefile deleted file mode 100644 index fd0dfc1..0000000 --- a/nand_spl/board/freescale/mx31pdk/Makefile +++ /dev/null @@ -1,68 +0,0 @@ -CONFIG_NAND_SPL = y -PAD_TO := 2048 - -include $(TOPDIR)/config.mk - -nandobj := $(OBJTREE)/nand_spl/ - -LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds -LSTSCRIPT= $(nandobj)/board/$(BOARDDIR)/u-boot.lst -LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ - $(LDFLAGS_FINAL) -AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL -CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL - -SOBJS = start.o crt0.o lowlevel_init.o -COBJS = nand_boot_fsl_nfc.o - -SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c -SRCS += $(SRCTREE)/arch/arm/cpu/arm1136/start.S -SRCS += $(SRCTREE)/arch/arm/lib/crt0.S -SRCS += $(SRCTREE)/board/freescale/mx31pdk/lowlevel_init.S -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -__OBJS := $(SOBJS) $(COBJS) -LNDIR := $(nandobj)board/$(BOARDDIR) - -ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin - -all: $(obj).depend $(ALL) - -$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ - -$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ - -$(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot.lds - cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ - -Map $(nandobj)u-boot-spl.map \ - -o $@ - -# The following line expands into whole rule which generates $(LSTSCRIPT), -# the file containing u-boots LG-array linker section. This is included into -# $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. -$(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) -$(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ - -ansi -D__ASSEMBLY__ -P - <$< >$@ - -######################################################################### - -$(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm1136/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/arch/arm/lib/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/board/freescale/mx31pdk/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/nand_spl/%.c - $(CC) $(CFLAGS) -c -o $@ $< - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/nand_spl/board/karo/tx25/Makefile b/nand_spl/board/karo/tx25/Makefile deleted file mode 100644 index 82489d2..0000000 --- a/nand_spl/board/karo/tx25/Makefile +++ /dev/null @@ -1,89 +0,0 @@ -# -# (C) Copyright 2009 DENX Software Engineering -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundatio; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -CONFIG_NAND_SPL = y - -include $(TOPDIR)/config.mk -include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk - -nandobj := $(OBJTREE)/nand_spl/ - -LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds -LSTSCRIPT= $(nandobj)/board/$(BOARDDIR)/u-boot.lst -LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ - $(LDFLAGS_FINAL) -AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL -CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL - -SOBJS = start.o crt0.o lowlevel_init.o -COBJS = nand_boot_fsl_nfc.o - -SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c -SRCS += $(SRCTREE)/arch/arm/cpu/arm926ejs/start.S -SRCS += $(SRCTREE)/arch/arm/lib/crt0.S -SRCS += $(SRCTREE)/board/karo/tx25/lowlevel_init.S -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -__OBJS := $(SOBJS) $(COBJS) -LNDIR := $(nandobj)board/$(BOARDDIR) - -ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin - -all: $(obj).depend $(ALL) - -$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ - -$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ - -$(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot.lds - cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ - -Map $(nandobj)u-boot-spl.map \ - -o $@ - -# The following line expands into whole rule which generates $(LSTSCRIPT), -# the file containing u-boots LG-array linker section. This is included into -# $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. -$(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) -$(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ - -ansi -D__ASSEMBLY__ -P - <$< >$@ - -######################################################################### - -$(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm926ejs/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/arch/arm/lib/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/board/karo/tx25/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/nand_spl/%.c - $(CC) $(CFLAGS) -c -o $@ $< - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/nand_spl/board/karo/tx25/config.mk b/nand_spl/board/karo/tx25/config.mk deleted file mode 100644 index 68afbf1..0000000 --- a/nand_spl/board/karo/tx25/config.mk +++ /dev/null @@ -1 +0,0 @@ -PAD_TO := 2048
On Friday, February 8, 2013 11:49:27 PM, Benoît Thébaudeau wrote:
Subject: [PATCH v5 8/8] nand: mxc: Switch NAND SPL to generic SPL
Changes in v5:
Changes in v4:
- New patch.
This is now supposed to be working and compile-tested.
Custodians, please review and advise.
Board maintainers, please test.
Tell me if I should split away some stuff.
Should doc/README.arm-relocation be updated, and how since tx25 no longer uses NAND SPL, which is also deprecated?
Note that mx31pdk and tx25 had been broken by commit e05e5de7fae5bec79617e113916dac6631251156. After this commit, for those boards, _main called board_init_f, which called relocate_code, which unexpectedly (for their users) returned to nowhere in ctr0.S instead of calling nand_boot. Also, crt0.S calls nand_boot if CONFIG_SPL_BUILD is not defined but CONFIG_NAND_SPL is, which is not normal for NAND SPL. Other NAND SPL boards may be broken too, but that's not too much of an issue since they are supposed to migrate to generic SPL.
Best regards, Benoît
Changes in v5:
Changes in v4:
- New patch.
I am also wondering if board_init_f should not be moved out of mxc_nand_spl.c to either <board>/lowlevel_init.S or <board>/<board>.c. That would make mxc_nand_spl.c more generic if for some reason a board needs to do specific things. Any opinion?
For the start.S files, since it's not possible to know from CONFIG_SPL_BUILD and CONFIG_NAND_SPL if relocate_code is needed or not, I see the following choices: 1) Let it defined in all cases. It's quite small, so it won't hurt much. 2) Create a specific SPL #define (e.g. CONFIG_SPL_RELOCATE_CODE) to define it for generic SPL only if needed. 3) Just create a specific linker section for it so that it's automatically garbage-collected if unneeded. Any opinion?
Changes in v5:
Changes in v4:
- New patch.
- Let it defined in all cases. It's quite small, so it won't hurt much.
- Create a specific SPL #define (e.g. CONFIG_SPL_RELOCATE_CODE) to define it for generic SPL only if needed.
- Just create a specific linker section for it so that it's automatically garbage-collected if unneeded.
Any opinion?
I'm also considering to factorize relocate_code to crt0.S. There's not really a good reason for it to be depending on each ARM processor. Any opinion?
Dear Benoît Thébaudeau,
Changes in v5:
Changes in v4:
- New patch.
define it
automatically
Any opinion?
How much of start.S can be actually rewritten in pure-C ?
Best regards, Marek Vasut
Dear Marek Vasut,
Changes in v5:
Changes in v4:
- New patch.
define it
automatically
Any opinion?
I would say only relocate_code(). Apart from this function, start.S only deals with preprocessor register accesses and IRQ / exception handling that require assembly.
As to relocate_code(), it would still be tricky in pure C because it mixes absolute addresses with position-independent code and data accesses, so one would have to be very careful about the C coding of this function in order to avoid a dependency on compiler choices. Having it written in assembly guarantees a correct result and emphasizes the absolute/relative access constraints for easier maintenance.
But this is only my opinion.
On Sunday, February 10, 2013 1:02:58 AM, Benoît Thébaudeau wrote:
Dear Marek Vasut,
Changes in v5:
Changes in v4:
- New patch.
automatically
Any opinion?
s/preprocessor/coprocessor/
Hi Stefano,
Changes in v5:
Changes in v4:
- New patch.
FYI, I will post soon a v6 with a lot of cleanup.
On 12/02/2013 14:45, Benoît Thébaudeau wrote:
Hi Stefano,
Ok, thanks. Stefano
Benoît Thébaudeau
Stefano Babic
