[PATCH] scsi: Forceably finish migration to DM_SCSI
The migration deadline for moving to DM_SCSI was v2023.04. A further reminder was sent out in August 2023 to the remaining platforms that had not migrated already, and that a few more over the line (or configs deleted).
With this commit we: - Rename CONFIG_DM_SCSI to CONFIG_SCSI. - Remove all of the non-DM SCSI code. This includes removing other legacy symbols and code and removes some legacy non-DM AHCI code. - Some platforms that had previously been DM_SCSI=y && SCSI=n are now fully migrated to DM_SCSI as a few corner cases in the code assumed DM_SCSI=y meant SCSI=y.
Signed-off-by: Tom Rini trini@konsulko.com --- I'm cc'ing the maintainers of the last few platforms which did not yet switch over and might need further updates or dts resyncs or something: configs/controlcenterdc_defconfig configs/highbank_defconfig configs/ls1021atsn_qspi_defconfig configs/ls1021atsn_sdcard_defconfig configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig
Cc: Mario Six mario.six@gdsys.cc (maintainer:A38X BOARD) Cc: Andre Przywara andre.przywara@arm.com (maintainer:HIGHBANK BOARD) Cc: Vladimir Oltean olteanv@gmail.com (maintainer:NXP LS1021A-TSN Board) Cc: Alison Wang alison.wang@nxp.com (maintainer:LS1021ATWR BOARD) --- Makefile | 1 - api/api_storage.c | 7 - arch/Kconfig | 2 +- arch/arm/Kconfig | 4 +- arch/arm/mach-imx/mx6/Kconfig | 2 +- arch/arm/mach-mvebu/cpu.c | 9 -- arch/arm/mach-omap2/Makefile | 7 - arch/arm/mach-omap2/boot-common.c | 7 - arch/arm/mach-omap2/omap5/hw_data.c | 12 -- arch/arm/mach-omap2/pipe3-phy.c | 231 ---------------------------- arch/arm/mach-omap2/pipe3-phy.h | 35 ----- arch/arm/mach-omap2/sata.c | 72 --------- board/emulation/qemu-riscv/Kconfig | 1 - board/highbank/highbank.c | 13 -- cmd/scsi.c | 3 - common/board_r.c | 15 -- configs/apalis_imx6_defconfig | 3 +- configs/dh_imx6_defconfig | 3 +- configs/edison_defconfig | 1 + configs/efi-x86_app32_defconfig | 1 + configs/efi-x86_app64_defconfig | 1 + configs/galileo_defconfig | 1 + configs/mvebu_ac5_rd_defconfig | 3 +- configs/novena_defconfig | 1 + configs/udoo_defconfig | 3 +- configs/wandboard_defconfig | 3 +- configs/x240_defconfig | 3 +- drivers/ata/Kconfig | 18 +-- drivers/ata/Makefile | 1 - drivers/ata/ahci.c | 172 +-------------------- drivers/ata/sata.c | 58 ------- drivers/ata/sata_sandbox.c | 33 ---- drivers/scsi/Kconfig | 43 +----- drivers/scsi/Makefile | 17 +- drivers/scsi/scsi.c | 151 ------------------ drivers/ufs/Kconfig | 2 +- include/ahci.h | 3 - include/configs/ls1021aiot.h | 7 - include/configs/ls1028ardb.h | 5 - include/configs/ls1043ardb.h | 7 - include/sata.h | 16 -- include/scsi.h | 9 -- 42 files changed, 34 insertions(+), 952 deletions(-) delete mode 100644 arch/arm/mach-omap2/pipe3-phy.c delete mode 100644 arch/arm/mach-omap2/pipe3-phy.h delete mode 100644 arch/arm/mach-omap2/sata.c delete mode 100644 drivers/ata/sata_sandbox.c
diff --git a/Makefile b/Makefile index 8a04dfcf3638..a88cbe8c1185 100644 --- a/Makefile +++ b/Makefile @@ -1153,7 +1153,6 @@ endif @# is enable to tell 'deprecated' that one of these symbols exists $(call deprecated,CONFIG_TIMER,Timer drivers,v2023.01,$(if $(strip $(CFG_SYS_TIMER_RATE)$(CFG_SYS_TIMER_COUNTER)),x)) $(call deprecated,CONFIG_DM_SERIAL,Serial drivers,v2023.04,$(CONFIG_SERIAL)) - $(call deprecated,CONFIG_DM_SCSI,SCSI drivers,v2023.04,$(CONFIG_SCSI)) @# Check that this build does not override OF_HAS_PRIOR_STAGE by @# disabling OF_BOARD. $(call cmd,ofcheck,$(KCONFIG_CONFIG)) diff --git a/api/api_storage.c b/api/api_storage.c index 997e8727a965..78becbe39fb6 100644 --- a/api/api_storage.c +++ b/api/api_storage.c @@ -67,13 +67,6 @@ void dev_stor_init(void) specs[ENUM_SATA].type = DEV_TYP_STOR | DT_STOR_SATA; specs[ENUM_SATA].name = "sata"; #endif -#if defined(CONFIG_SCSI) - specs[ENUM_SCSI].max_dev = SCSI_MAX_DEVICE; - specs[ENUM_SCSI].enum_started = 0; - specs[ENUM_SCSI].enum_ended = 0; - specs[ENUM_SCSI].type = DEV_TYP_STOR | DT_STOR_SCSI; - specs[ENUM_SCSI].name = "scsi"; -#endif #if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) specs[ENUM_USB].max_dev = USB_MAX_STOR_DEV; specs[ENUM_USB].enum_started = 0; diff --git a/arch/Kconfig b/arch/Kconfig index 4f5b75129f34..edd3ad09e54c 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -248,7 +248,7 @@ config X86 imply DM_KEYBOARD imply DM_MMC imply DM_RTC - imply DM_SCSI + imply SCSI imply DM_SERIAL imply DM_SPI imply DM_SPI_FLASH diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d812685c9842..6009b7d46dc9 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1133,7 +1133,6 @@ config ARCH_SUNXI select DM_SPI_FLASH if SPI select DM_KEYBOARD select DM_MMC if MMC - select DM_SCSI if SCSI select DM_SERIAL select OF_BOARD_SETUP select OF_CONTROL @@ -1838,7 +1837,7 @@ config TARGET_SL28 select PCI select DM_RNG select DM_RTC - select DM_SCSI + select SCSI select DM_SERIAL select DM_SPI select GPIO_EXTRA_HEADER @@ -2053,7 +2052,6 @@ config TARGET_POMELO select PCI select DM_PCI select SCSI - select DM_SCSI select DM_SERIAL imply CMD_PCI help diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 7529b311f80e..50a9c3e4203d 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -246,7 +246,7 @@ config TARGET_KOSAGI_NOVENA select DM_GPIO select DM_MMC select PCI - select DM_SCSI + select SCSI select VIDEO select OF_CONTROL select SUPPORT_SPL diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 6deffb818362..8e0de9353858 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -589,15 +589,6 @@ int board_ahci_enable(void) return 0; }
-#ifdef CONFIG_SCSI_AHCI_PLAT -void scsi_init(void) -{ - printf("MVEBU SATA INIT\n"); - board_ahci_enable(); - ahci_init((void __iomem *)MVEBU_SATA0_BASE); -} -#endif - #ifdef CONFIG_USB_XHCI_MVEBU #define USB3_MAX_WINDOWS 4 #define USB3_WIN_CTRL(w) (0x0 + ((w) * 8)) diff --git a/arch/arm/mach-omap2/Makefile b/arch/arm/mach-omap2/Makefile index bb01eab80e67..8c10c694dffb 100644 --- a/arch/arm/mach-omap2/Makefile +++ b/arch/arm/mach-omap2/Makefile @@ -27,13 +27,6 @@ obj-y += vc.o obj-y += abb.o endif
-ifneq ($(CONFIG_OMAP54XX),) -ifeq ($(CONFIG_DM_SCSI),) -obj-y += pipe3-phy.o -obj-$(CONFIG_SCSI_AHCI_PLAT) += sata.o -endif -endif - ifeq ($(CONFIG_$(SPL_TPL_)SYS_DCACHE_OFF),) obj-y += omap-cache.o endif diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index a2dd5f6df01e..5e4d29910c97 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -309,13 +309,6 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) } #endif
-#ifdef CONFIG_SCSI_AHCI_PLAT -void arch_preboot_os(void) -{ - ahci_reset((void __iomem *)DWC_AHSATA_BASE); -} -#endif - #ifdef CONFIG_TI_SECURE_DEVICE void board_fit_image_post_process(const void *fit, int node, void **p_image, size_t *p_size) diff --git a/arch/arm/mach-omap2/omap5/hw_data.c b/arch/arm/mach-omap2/omap5/hw_data.c index e6bee48dfcb3..b39132222ee5 100644 --- a/arch/arm/mach-omap2/omap5/hw_data.c +++ b/arch/arm/mach-omap2/omap5/hw_data.c @@ -485,9 +485,6 @@ void enable_basic_clocks(void) (*prcm)->cm_l4per_gpio6_clkctrl, (*prcm)->cm_l4per_gpio7_clkctrl, (*prcm)->cm_l4per_gpio8_clkctrl, -#ifdef CONFIG_SCSI_AHCI_PLAT - (*prcm)->cm_l3init_ocp2scp3_clkctrl, -#endif 0 };
@@ -506,9 +503,6 @@ void enable_basic_clocks(void)
#ifdef CONFIG_TI_QSPI (*prcm)->cm_l4per_qspi_clkctrl, -#endif -#ifdef CONFIG_SCSI_AHCI_PLAT - (*prcm)->cm_l3init_sata_clkctrl, #endif 0 }; @@ -542,12 +536,6 @@ void enable_basic_clocks(void) setbits_le32((*prcm)->cm_l4per_qspi_clkctrl, (1<<24)); #endif
-#ifdef CONFIG_SCSI_AHCI_PLAT - /* Enable optional functional clock for SATA */ - setbits_le32((*prcm)->cm_l3init_sata_clkctrl, - SATA_CLKCTRL_OPTFCLKEN_MASK); -#endif - /* Enable SCRM OPT clocks for PER and CORE dpll */ setbits_le32((*prcm)->cm_wkupaon_scrm_clkctrl, OPTFCLKEN_SCRM_PER_MASK); diff --git a/arch/arm/mach-omap2/pipe3-phy.c b/arch/arm/mach-omap2/pipe3-phy.c deleted file mode 100644 index 3dfb184c4308..000000000000 --- a/arch/arm/mach-omap2/pipe3-phy.c +++ /dev/null @@ -1,231 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * TI PIPE3 PHY - * - * (C) Copyright 2013 - * Texas Instruments, <www.ti.com> - */ - -#include <common.h> -#include <sata.h> -#include <asm/arch/clock.h> -#include <asm/arch/sys_proto.h> -#include <asm/io.h> -#include <linux/bitops.h> -#include <linux/delay.h> -#include <linux/errno.h> -#include "pipe3-phy.h" - -/* PLLCTRL Registers */ -#define PLL_STATUS 0x00000004 -#define PLL_GO 0x00000008 -#define PLL_CONFIGURATION1 0x0000000C -#define PLL_CONFIGURATION2 0x00000010 -#define PLL_CONFIGURATION3 0x00000014 -#define PLL_CONFIGURATION4 0x00000020 - -#define PLL_REGM_MASK 0x001FFE00 -#define PLL_REGM_SHIFT 9 -#define PLL_REGM_F_MASK 0x0003FFFF -#define PLL_REGM_F_SHIFT 0 -#define PLL_REGN_MASK 0x000001FE -#define PLL_REGN_SHIFT 1 -#define PLL_SELFREQDCO_MASK 0x0000000E -#define PLL_SELFREQDCO_SHIFT 1 -#define PLL_SD_MASK 0x0003FC00 -#define PLL_SD_SHIFT 10 -#define SET_PLL_GO 0x1 -#define PLL_TICOPWDN BIT(16) -#define PLL_LDOPWDN BIT(15) -#define PLL_LOCK 0x2 -#define PLL_IDLE 0x1 - -/* PHY POWER CONTROL Register */ -#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_MASK 0x003FC000 -#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_SHIFT 0xE - -#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_MASK 0xFFC00000 -#define OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_SHIFT 0x16 - -#define OMAP_CTRL_PIPE3_PHY_TX_RX_POWERON 0x3 -#define OMAP_CTRL_PIPE3_PHY_TX_RX_POWEROFF 0x0 - - -#define PLL_IDLE_TIME 100 /* in milliseconds */ -#define PLL_LOCK_TIME 100 /* in milliseconds */ - -static inline u32 omap_pipe3_readl(void __iomem *addr, unsigned offset) -{ - return __raw_readl(addr + offset); -} - -static inline void omap_pipe3_writel(void __iomem *addr, unsigned offset, - u32 data) -{ - __raw_writel(data, addr + offset); -} - -static struct pipe3_dpll_params *omap_pipe3_get_dpll_params(struct omap_pipe3 - *pipe3) -{ - u32 rate; - struct pipe3_dpll_map *dpll_map = pipe3->dpll_map; - - rate = get_sys_clk_freq(); - - for (; dpll_map->rate; dpll_map++) { - if (rate == dpll_map->rate) - return &dpll_map->params; - } - - printf("%s: No DPLL configuration for %u Hz SYS CLK\n", - __func__, rate); - return NULL; -} - - -static int omap_pipe3_wait_lock(struct omap_pipe3 *phy) -{ - u32 val; - int timeout = PLL_LOCK_TIME; - - do { - mdelay(1); - val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_STATUS); - if (val & PLL_LOCK) - break; - } while (--timeout); - - if (!(val & PLL_LOCK)) { - printf("%s: DPLL failed to lock\n", __func__); - return -EBUSY; - } - - return 0; -} - -static int omap_pipe3_dpll_program(struct omap_pipe3 *phy) -{ - u32 val; - struct pipe3_dpll_params *dpll_params; - - dpll_params = omap_pipe3_get_dpll_params(phy); - if (!dpll_params) { - printf("%s: Invalid DPLL parameters\n", __func__); - return -EINVAL; - } - - val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION1); - val &= ~PLL_REGN_MASK; - val |= dpll_params->n << PLL_REGN_SHIFT; - omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION1, val); - - val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION2); - val &= ~PLL_SELFREQDCO_MASK; - val |= dpll_params->freq << PLL_SELFREQDCO_SHIFT; - omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION2, val); - - val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION1); - val &= ~PLL_REGM_MASK; - val |= dpll_params->m << PLL_REGM_SHIFT; - omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION1, val); - - val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION4); - val &= ~PLL_REGM_F_MASK; - val |= dpll_params->mf << PLL_REGM_F_SHIFT; - omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION4, val); - - val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION3); - val &= ~PLL_SD_MASK; - val |= dpll_params->sd << PLL_SD_SHIFT; - omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION3, val); - - omap_pipe3_writel(phy->pll_ctrl_base, PLL_GO, SET_PLL_GO); - - return omap_pipe3_wait_lock(phy); -} - -static void omap_control_phy_power(struct omap_pipe3 *phy, int on) -{ - u32 val, rate; - - val = readl(phy->power_reg); - - rate = get_sys_clk_freq(); - rate = rate/1000000; - - if (on) { - val &= ~(OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_MASK | - OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_MASK); - val |= OMAP_CTRL_PIPE3_PHY_TX_RX_POWERON << - OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_SHIFT; - val |= rate << - OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_FREQ_SHIFT; - } else { - val &= ~OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_MASK; - val |= OMAP_CTRL_PIPE3_PHY_TX_RX_POWEROFF << - OMAP_CTRL_PIPE3_PHY_PWRCTL_CLK_CMD_SHIFT; - } - - writel(val, phy->power_reg); -} - -int phy_pipe3_power_on(struct omap_pipe3 *phy) -{ - int ret; - u32 val; - - /* Program the DPLL only if not locked */ - val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_STATUS); - if (!(val & PLL_LOCK)) { - ret = omap_pipe3_dpll_program(phy); - if (ret) - return ret; - } else { - /* else just bring it out of IDLE mode */ - val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION2); - if (val & PLL_IDLE) { - val &= ~PLL_IDLE; - omap_pipe3_writel(phy->pll_ctrl_base, - PLL_CONFIGURATION2, val); - ret = omap_pipe3_wait_lock(phy); - if (ret) - return ret; - } - } - - /* Power up the PHY */ - omap_control_phy_power(phy, 1); - - return 0; -} - -int phy_pipe3_power_off(struct omap_pipe3 *phy) -{ - u32 val; - int timeout = PLL_IDLE_TIME; - - /* Power down the PHY */ - omap_control_phy_power(phy, 0); - - /* Put DPLL in IDLE mode */ - val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_CONFIGURATION2); - val |= PLL_IDLE; - omap_pipe3_writel(phy->pll_ctrl_base, PLL_CONFIGURATION2, val); - - /* wait for LDO and Oscillator to power down */ - do { - mdelay(1); - val = omap_pipe3_readl(phy->pll_ctrl_base, PLL_STATUS); - if ((val & PLL_TICOPWDN) && (val & PLL_LDOPWDN)) - break; - } while (--timeout); - - if (!(val & PLL_TICOPWDN) || !(val & PLL_LDOPWDN)) { - printf("%s: Failed to power down DPLL: PLL_STATUS 0x%x\n", - __func__, val); - return -EBUSY; - } - - return 0; -} diff --git a/arch/arm/mach-omap2/pipe3-phy.h b/arch/arm/mach-omap2/pipe3-phy.h deleted file mode 100644 index 182bdcd4c81f..000000000000 --- a/arch/arm/mach-omap2/pipe3-phy.h +++ /dev/null @@ -1,35 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * TI PIPE3 PHY - * - * (C) Copyright 2013 - * Texas Instruments, <www.ti.com> - */ - -#ifndef __OMAP_PIPE3_PHY_H -#define __OMAP_PIPE3_PHY_H - -struct pipe3_dpll_params { - u16 m; - u8 n; - u8 freq:3; - u8 sd; - u32 mf; -}; - -struct pipe3_dpll_map { - unsigned long rate; - struct pipe3_dpll_params params; -}; - -struct omap_pipe3 { - void __iomem *pll_ctrl_base; - void __iomem *power_reg; - struct pipe3_dpll_map *dpll_map; -}; - - -int phy_pipe3_power_on(struct omap_pipe3 *phy); -int phy_pipe3_power_off(struct omap_pipe3 *pipe3); - -#endif /* __OMAP_PIPE3_PHY_H */ diff --git a/arch/arm/mach-omap2/sata.c b/arch/arm/mach-omap2/sata.c deleted file mode 100644 index 53c39ce1fb68..000000000000 --- a/arch/arm/mach-omap2/sata.c +++ /dev/null @@ -1,72 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * TI SATA platform driver - * - * (C) Copyright 2013 - * Texas Instruments, <www.ti.com> - */ - -#include <common.h> -#include <ahci.h> -#include <scsi.h> -#include <asm/arch/clock.h> -#include <asm/arch/sata.h> -#include <sata.h> -#include <asm/io.h> -#include <asm/omap_common.h> -#include "pipe3-phy.h" - -static struct pipe3_dpll_map dpll_map_sata[] = { - {12000000, {1000, 7, 4, 6, 0} }, /* 12 MHz */ - {16800000, {714, 7, 4, 6, 0} }, /* 16.8 MHz */ - {19200000, {625, 7, 4, 6, 0} }, /* 19.2 MHz */ - {20000000, {600, 7, 4, 6, 0} }, /* 20 MHz */ - {26000000, {461, 7, 4, 6, 0} }, /* 26 MHz */ - {38400000, {312, 7, 4, 6, 0} }, /* 38.4 MHz */ - { }, /* Terminator */ -}; - -struct omap_pipe3 sata_phy = { - .pll_ctrl_base = (void __iomem *)TI_SATA_PLLCTRL_BASE, - /* .power_reg is updated at runtime */ - .dpll_map = dpll_map_sata, -}; - -int init_sata(int dev) -{ - int ret; - u32 val; - - sata_phy.power_reg = (void __iomem *)(*ctrl)->control_phy_power_sata; - - /* Power up the PHY */ - phy_pipe3_power_on(&sata_phy); - - /* Enable SATA module, No Idle, No Standby */ - val = TI_SATA_IDLE_NO | TI_SATA_STANDBY_NO; - writel(val, TI_SATA_WRAPPER_BASE + TI_SATA_SYSCONFIG); - - ret = ahci_init((void __iomem *)DWC_AHSATA_BASE); - - return ret; -} - -int reset_sata(int dev) -{ - return 0; -} - -/* On OMAP platforms SATA provides the SCSI subsystem */ -void scsi_init(void) -{ - init_sata(0); - scsi_scan(1); -} - -int scsi_bus_reset(struct udevice *dev) -{ - ahci_reset((void __iomem *)DWC_AHSATA_BASE); - ahci_init((void __iomem *)DWC_AHSATA_BASE); - - return 0; -} diff --git a/board/emulation/qemu-riscv/Kconfig b/board/emulation/qemu-riscv/Kconfig index d56b4b5bc1ed..108e9fdb00a9 100644 --- a/board/emulation/qemu-riscv/Kconfig +++ b/board/emulation/qemu-riscv/Kconfig @@ -59,7 +59,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply PCIE_ECAM_GENERIC imply DM_RNG imply SCSI - imply DM_SCSI imply SYS_NS16550 imply SIFIVE_SERIAL imply HTIF_CONSOLE if 64BIT diff --git a/board/highbank/highbank.c b/board/highbank/highbank.c index b5fa5101e881..7f67d1e45308 100644 --- a/board/highbank/highbank.c +++ b/board/highbank/highbank.c @@ -52,19 +52,6 @@ int board_init(void) return 0; }
-#ifdef CONFIG_SCSI_AHCI_PLAT -void scsi_init(void) -{ - u32 reg = readl(HB_SREG_A9_PWRDOM_STAT); - - cphy_disable_overrides(); - if (reg & PWRDOM_STAT_SATA) { - ahci_init((void __iomem *)HB_AHCI_BASE); - scsi_scan(true); - } -} -#endif - #ifdef CONFIG_MISC_INIT_R int misc_init_r(void) { diff --git a/cmd/scsi.c b/cmd/scsi.c index 4549995ba73c..c501d7f456d7 100644 --- a/cmd/scsi.c +++ b/cmd/scsi.c @@ -34,9 +34,6 @@ static int do_scsi(struct cmd_tbl *cmdtp, int flag, int argc, if (argc == 2) { if (strncmp(argv[1], "res", 3) == 0) { printf("\nReset SCSI\n"); -#ifndef CONFIG_DM_SCSI - scsi_bus_reset(NULL); -#endif ret = scsi_scan(true); if (ret) return CMD_RET_FAILURE; diff --git a/common/board_r.c b/common/board_r.c index a7967849dc0c..da0b80f24ff0 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -472,17 +472,6 @@ static int initr_status_led(void) } #endif
-#if defined(CONFIG_SCSI) && !defined(CONFIG_DM_SCSI) -static int initr_scsi(void) -{ - puts("SCSI: "); - scsi_init(); - puts("\n"); - - return 0; -} -#endif - #ifdef CONFIG_CMD_NET static int initr_net(void) { @@ -732,10 +721,6 @@ static init_fnc_t init_sequence_r[] = { #ifdef CONFIG_BOARD_LATE_INIT board_late_init, #endif -#if defined(CONFIG_SCSI) && !defined(CONFIG_DM_SCSI) - INIT_FUNC_WATCHDOG_RESET - initr_scsi, -#endif #ifdef CONFIG_BITBANGMII bb_miiphy_init, #endif diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index aa9cf77960bb..cf2af5797f3e 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -59,6 +59,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y +# CONFIG_CMD_SCSI is not set CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y @@ -105,7 +106,7 @@ CONFIG_DM_PMIC_PFUZE100=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_SCSI=y +CONFIG_SCSI=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 5a83b6a08a26..154131e62e09 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -52,6 +52,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_SATA=y +# CONFIG_CMD_SCSI is not set CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_WDT=y @@ -99,7 +100,7 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_SCSI=y +CONFIG_SCSI=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y diff --git a/configs/edison_defconfig b/configs/edison_defconfig index f134680e4122..db2e35f388b7 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y +# CONFIG_CMD_SCSI is not set CONFIG_CMD_TIMER=y CONFIG_CMD_HASH=y CONFIG_CMD_EXT4=y diff --git a/configs/efi-x86_app32_defconfig b/configs/efi-x86_app32_defconfig index dfc315774a50..682ba5b89576 100644 --- a/configs/efi-x86_app32_defconfig +++ b/configs/efi-x86_app32_defconfig @@ -20,6 +20,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=532 CONFIG_CMD_BOOTZ=y CONFIG_CMD_PART=y +# CONFIG_CMD_SCSI is not set # CONFIG_CMD_NET is not set CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y diff --git a/configs/efi-x86_app64_defconfig b/configs/efi-x86_app64_defconfig index e0cfe3ee243a..d6b6c3d82995 100644 --- a/configs/efi-x86_app64_defconfig +++ b/configs/efi-x86_app64_defconfig @@ -21,6 +21,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=532 CONFIG_CMD_BOOTZ=y CONFIG_CMD_PART=y +# CONFIG_CMD_SCSI is not set # CONFIG_CMD_NET is not set CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 3eb1917454d5..35f7fb77e634 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_CPU=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y +# CONFIG_CMD_SCSI is not set CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/mvebu_ac5_rd_defconfig b/configs/mvebu_ac5_rd_defconfig index e8fa22b648be..0a9adcc03999 100644 --- a/configs/mvebu_ac5_rd_defconfig +++ b/configs/mvebu_ac5_rd_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y +# CONFIG_CMD_SCSI is not set CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set @@ -72,7 +73,7 @@ CONFIG_PINCTRL_ARMADA_8K=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RTC=y -CONFIG_DM_SCSI=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_MVEBU_A3700_SPI=y CONFIG_DM_THERMAL=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 278e3fd8adb1..238999118826 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SATA=y +# CONFIG_CMD_SCSI is not set CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index e128a62cd005..f89b163ddf56 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_SATA=y +# CONFIG_CMD_SCSI is not set CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y @@ -54,7 +55,7 @@ CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y -CONFIG_DM_SCSI=y +CONFIG_SCSI=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_DM_THERMAL=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 7c1727f8b12b..c9ec962201b4 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_SATA=y +# CONFIG_CMD_SCSI is not set CONFIG_CMD_USB=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y @@ -71,7 +72,7 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC=y CONFIG_DM_PMIC_PFUZE100=y -CONFIG_DM_SCSI=y +CONFIG_SCSI=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_DM_THERMAL=y diff --git a/configs/x240_defconfig b/configs/x240_defconfig index 4b1a761a9086..152413de0e50 100644 --- a/configs/x240_defconfig +++ b/configs/x240_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MTD=y CONFIG_CMD_PCI=y +# CONFIG_CMD_SCSI is not set CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set @@ -68,7 +69,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RTC=y CONFIG_RTC_MAX313XX=y -CONFIG_DM_SCSI=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_MVEBU_A3700_SPI=y CONFIG_DM_THERMAL=y diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index 049f7efd10b8..9bc5283c2688 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -20,14 +20,6 @@ config SATA
See also CMD_SATA which provides command-line support.
-config SYS_SATA_MAX_PORTS - int "Maximum supported SATA ports" - depends on SCSI_AHCI && !DM_SCSI - default 1 - help - Sets the maximum number of ports to scan when looking for devices. - Ports from 0 to (this value - 1) are scanned. - config LIBATA bool help @@ -44,7 +36,7 @@ menu "SATA/SCSI device support" config AHCI_PCI bool "Support for PCI-based AHCI controller" depends on PCI - depends on DM_SCSI + depends on SCSI depends on SCSI_AHCI help Enables support for the PCI-based AHCI controller. @@ -55,13 +47,13 @@ config SPL_AHCI_PCI bool "Support for PCI-based AHCI controller for SPL" depends on SPL depends on SPL_PCI - depends on SPL_SATA && DM_SCSI + depends on SPL_SATA && SCSI
config DWC_AHCI bool "Enable Synopsys DWC AHCI driver support" select SCSI_AHCI select PHY - depends on DM_SCSI + depends on SCSI help Enable this driver to support Sata devices through Synopsys DWC AHCI module. @@ -91,7 +83,7 @@ config AHCI_MVEBU bool "Marvell EBU AHCI SATA support" depends on ARCH_MVEBU || ARCH_OCTEON select SCSI_AHCI - select DM_SCSI + select SCSI help This option enables support for the Marvell EBU SoC's onboard AHCI SATA. @@ -112,7 +104,7 @@ if SATA config SATA_CEVA bool "Ceva Sata controller" depends on AHCI - depends on DM_SCSI + depends on SCSI help This option enables Ceva Sata controller hard IP available on Xilinx ZynqMP. Support up to 2 external devices. Compliant with SATA 3.1 and diff --git a/drivers/ata/Makefile b/drivers/ata/Makefile index 0b6f91098a39..af6f0bf2780c 100644 --- a/drivers/ata/Makefile +++ b/drivers/ata/Makefile @@ -14,7 +14,6 @@ obj-$(CONFIG_SATA) += sata.o sata_bootdev.o obj-$(CONFIG_SATA_CEVA) += sata_ceva.o obj-$(CONFIG_SATA_MV) += sata_mv.o obj-$(CONFIG_SATA_SIL) += sata_sil.o -obj-$(CONFIG_SANDBOX) += sata_sandbox.o obj-$(CONFIG_AHCI_MVEBU) += ahci_mvebu.o obj-$(CONFIG_SUNXI_AHCI) += ahci_sunxi.o obj-$(CONFIG_MTK_AHCI) += mtk_ahci.o diff --git a/drivers/ata/ahci.c b/drivers/ata/ahci.c index cb2c648a91fd..04ddc3394648 100644 --- a/drivers/ata/ahci.c +++ b/drivers/ata/ahci.c @@ -33,10 +33,6 @@
static int ata_io_flush(struct ahci_uc_priv *uc_priv, u8 port);
-#ifndef CONFIG_DM_SCSI -struct ahci_uc_priv *probe_ent = NULL; -#endif - #define writel_with_flush(a,b) do { writel(a,b); readl(b); } while (0)
/* @@ -169,11 +165,6 @@ int ahci_reset(void __iomem *base)
static int ahci_host_init(struct ahci_uc_priv *uc_priv) { -#if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SCSI) - struct udevice *dev = uc_priv->dev; - struct pci_child_plat *pplat = dev_get_parent_plat(dev); - u16 tmp16; -#endif void __iomem *mmio = uc_priv->mmio_base; u32 tmp, cap_save, cmd; int i, j, ret; @@ -194,14 +185,6 @@ static int ahci_host_init(struct ahci_uc_priv *uc_priv) writel(cap_save, mmio + HOST_CAP); writel_with_flush(0xf, mmio + HOST_PORTS_IMPL);
-#if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SCSI) - if (pplat->vendor == PCI_VENDOR_ID_INTEL) { - u16 tmp16; - - dm_pci_read_config16(dev, 0x92, &tmp16); - dm_pci_write_config16(dev, 0x92, tmp16 | 0xf); - } -#endif uc_priv->cap = readl(mmio + HOST_CAP); uc_priv->port_map = readl(mmio + HOST_PORTS_IMPL); port_map = uc_priv->port_map; @@ -210,11 +193,6 @@ static int ahci_host_init(struct ahci_uc_priv *uc_priv) debug("cap 0x%x port_map 0x%x n_ports %d\n", uc_priv->cap, uc_priv->port_map, uc_priv->n_ports);
-#if !defined(CONFIG_DM_SCSI) - if (uc_priv->n_ports > CONFIG_SYS_SATA_MAX_PORTS) - uc_priv->n_ports = CONFIG_SYS_SATA_MAX_PORTS; -#endif - for (i = 0; i < uc_priv->n_ports; i++) { if (!(port_map & (1 << i))) continue; @@ -313,23 +291,12 @@ static int ahci_host_init(struct ahci_uc_priv *uc_priv) writel(tmp | HOST_IRQ_EN, mmio + HOST_CTL); tmp = readl(mmio + HOST_CTL); debug("HOST_CTL 0x%x\n", tmp); -#if !defined(CONFIG_DM_SCSI) -#ifndef CONFIG_SCSI_AHCI_PLAT - dm_pci_read_config16(dev, PCI_COMMAND, &tmp16); - tmp |= PCI_COMMAND_MASTER; - dm_pci_write_config16(dev, PCI_COMMAND, tmp16); -#endif -#endif return 0; }
static void ahci_print_info(struct ahci_uc_priv *uc_priv) { -#if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SCSI) - struct udevice *dev = uc_priv->dev; - u16 cc; -#endif void __iomem *mmio = uc_priv->mmio_base; u32 vers, cap, cap2, impl, speed; const char *speed_s; @@ -350,19 +317,7 @@ static void ahci_print_info(struct ahci_uc_priv *uc_priv) else speed_s = "?";
-#if defined(CONFIG_SCSI_AHCI_PLAT) || defined(CONFIG_DM_SCSI) scc_s = "SATA"; -#else - dm_pci_read_config16(dev, 0x0a, &cc); - if (cc == 0x0101) - scc_s = "IDE"; - else if (cc == 0x0106) - scc_s = "SATA"; - else if (cc == 0x0104) - scc_s = "RAID"; - else - scc_s = "unknown"; -#endif printf("AHCI %02x%02x.%02x%02x " "%u slots %u ports %s Gbps 0x%x impl %s mode\n", (vers >> 24) & 0xff, @@ -397,12 +352,8 @@ static void ahci_print_info(struct ahci_uc_priv *uc_priv) cap2 & (1 << 0) ? "boh " : ""); }
-#if defined(CONFIG_DM_SCSI) || !defined(CONFIG_SCSI_AHCI_PLAT) static int ahci_init_one(struct ahci_uc_priv *uc_priv, struct udevice *dev) { -#if !defined(CONFIG_DM_SCSI) - u16 vendor; -#endif int rc;
uc_priv->dev = dev; @@ -415,21 +366,8 @@ static int ahci_init_one(struct ahci_uc_priv *uc_priv, struct udevice *dev) uc_priv->pio_mask = 0x1f; uc_priv->udma_mask = 0x7f; /*Fixme,assume to support UDMA6 */
-#if !defined(CONFIG_DM_SCSI) - uc_priv->mmio_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_5, 0, 0, - PCI_REGION_TYPE, PCI_REGION_MEM); - - /* Take from kernel: - * JMicron-specific fixup: - * make sure we're in AHCI mode - */ - dm_pci_read_config16(dev, PCI_VENDOR_ID, &vendor); - if (vendor == 0x197b) - dm_pci_write_config8(dev, 0x41, 0xa1); -#else struct scsi_plat *plat = dev_get_uclass_plat(dev); uc_priv->mmio_base = (void *)plat->base; -#endif
debug("ahci mmio_base=0x%p\n", uc_priv->mmio_base); /* initialize adapter */ @@ -444,7 +382,6 @@ static int ahci_init_one(struct ahci_uc_priv *uc_priv, struct udevice *dev) err_out: return rc; } -#endif
#define MAX_DATA_BYTE_COUNT (4*1024*1024)
@@ -893,12 +830,7 @@ static int ata_scsiop_test_unit_ready(struct ahci_uc_priv *uc_priv,
static int ahci_scsi_exec(struct udevice *dev, struct scsi_cmd *pccb) { - struct ahci_uc_priv *uc_priv; -#ifdef CONFIG_DM_SCSI - uc_priv = dev_get_uclass_priv(dev->parent); -#else - uc_priv = probe_ent; -#endif + struct ahci_uc_priv *uc_priv = dev_get_uclass_priv(dev->parent); int ret;
switch (pccb->cmd[0]) { @@ -953,41 +885,12 @@ static int ahci_start_ports(struct ahci_uc_priv *uc_priv) return 0; }
-#ifndef CONFIG_DM_SCSI -void scsi_low_level_init(int busdevfunc) -{ - struct ahci_uc_priv *uc_priv; - -#ifndef CONFIG_SCSI_AHCI_PLAT - probe_ent = calloc(1, sizeof(struct ahci_uc_priv)); - if (!probe_ent) { - printf("%s: No memory for uc_priv\n", __func__); - return; - } - uc_priv = probe_ent; - struct udevice *dev; - int ret; - - ret = dm_pci_bus_find_bdf(busdevfunc, &dev); - if (ret) - return; - ahci_init_one(uc_priv, dev); -#else - uc_priv = probe_ent; -#endif - - ahci_start_ports(uc_priv); -} -#endif - -#ifndef CONFIG_SCSI_AHCI_PLAT int ahci_init_one_dm(struct udevice *dev) { struct ahci_uc_priv *uc_priv = dev_get_uclass_priv(dev);
return ahci_init_one(uc_priv, dev); } -#endif
int ahci_start_ports_dm(struct udevice *dev) { @@ -996,65 +899,6 @@ int ahci_start_ports_dm(struct udevice *dev) return ahci_start_ports(uc_priv); }
-#ifdef CONFIG_SCSI_AHCI_PLAT -static int ahci_init_common(struct ahci_uc_priv *uc_priv, void __iomem *base) -{ - int rc; - - uc_priv->host_flags = ATA_FLAG_SATA - | ATA_FLAG_NO_LEGACY - | ATA_FLAG_MMIO - | ATA_FLAG_PIO_DMA - | ATA_FLAG_NO_ATAPI; - uc_priv->pio_mask = 0x1f; - uc_priv->udma_mask = 0x7f; /*Fixme,assume to support UDMA6 */ - - uc_priv->mmio_base = base; - - /* initialize adapter */ - rc = ahci_host_init(uc_priv); - if (rc) - goto err_out; - - ahci_print_info(uc_priv); - - rc = ahci_start_ports(uc_priv); - -err_out: - return rc; -} - -#ifndef CONFIG_DM_SCSI -int ahci_init(void __iomem *base) -{ - struct ahci_uc_priv *uc_priv; - - probe_ent = malloc(sizeof(struct ahci_uc_priv)); - if (!probe_ent) { - printf("%s: No memory for uc_priv\n", __func__); - return -ENOMEM; - } - - uc_priv = probe_ent; - memset(uc_priv, 0, sizeof(struct ahci_uc_priv)); - - return ahci_init_common(uc_priv, base); -} -#endif - -int ahci_init_dm(struct udevice *dev, void __iomem *base) -{ - struct ahci_uc_priv *uc_priv = dev_get_uclass_priv(dev); - - return ahci_init_common(uc_priv, base); -} - -void __weak scsi_init(void) -{ -} - -#endif /* CONFIG_SCSI_AHCI_PLAT */ - /* * In the general case of generic rotating media it makes sense to have a * flush capability. It probably even makes sense in the case of SSDs because @@ -1098,7 +942,6 @@ static int ahci_scsi_bus_reset(struct udevice *dev) return 0; }
-#ifdef CONFIG_DM_SCSI int ahci_bind_scsi(struct udevice *ahci_dev, struct udevice **devp) { struct udevice *dev; @@ -1190,16 +1033,3 @@ U_BOOT_DRIVER(ahci_scsi) = { .id = UCLASS_SCSI, .ops = &scsi_ops, }; -#else -int scsi_exec(struct udevice *dev, struct scsi_cmd *pccb) -{ - return ahci_scsi_exec(dev, pccb); -} - -__weak int scsi_bus_reset(struct udevice *dev) -{ - return ahci_scsi_bus_reset(dev); - - return 0; -} -#endif diff --git a/drivers/ata/sata.c b/drivers/ata/sata.c index dcb5fcf476b5..be1ee01b296f 100644 --- a/drivers/ata/sata.c +++ b/drivers/ata/sata.c @@ -18,10 +18,6 @@ #include <dm/device-internal.h> #include <dm/uclass-internal.h>
-#ifndef CONFIG_AHCI -struct blk_desc sata_dev_desc[CONFIG_SYS_SATA_MAX_DEVICE]; -#endif - int sata_reset(struct udevice *dev) { struct ahci_ops *ops = ahci_get_ops(dev); @@ -88,15 +84,6 @@ int sata_rescan(bool verbose) return ret; }
-#ifndef CONFIG_AHCI -#ifdef CONFIG_PARTITIONS -struct blk_desc *sata_get_dev(int dev) -{ - return (dev < CONFIG_SYS_SATA_MAX_DEVICE) ? &sata_dev_desc[dev] : NULL; -} -#endif -#endif - static unsigned long sata_bread(struct udevice *dev, lbaint_t start, lbaint_t blkcnt, void *dst) { @@ -109,51 +96,6 @@ static unsigned long sata_bwrite(struct udevice *dev, lbaint_t start, return -ENOSYS; }
-#ifndef CONFIG_AHCI -int __sata_initialize(void) -{ - int rc, ret = -1; - int i; - - for (i = 0; i < CONFIG_SYS_SATA_MAX_DEVICE; i++) { - memset(&sata_dev_desc[i], 0, sizeof(struct blk_desc)); - sata_dev_desc[i].uclass_id = UCLASS_AHCI; - sata_dev_desc[i].devnum = i; - sata_dev_desc[i].part_type = PART_TYPE_UNKNOWN; - sata_dev_desc[i].type = DEV_TYPE_HARDDISK; - sata_dev_desc[i].lba = 0; - sata_dev_desc[i].blksz = 512; - sata_dev_desc[i].log2blksz = LOG2(sata_dev_desc[i].blksz); - rc = init_sata(i); - if (!rc) { - rc = scan_sata(i); - if (!rc && sata_dev_desc[i].lba > 0 && - sata_dev_desc[i].blksz > 0) { - part_init(&sata_dev_desc[i]); - ret = i; - } - } - } - - return ret; -} -int sata_initialize(void) __attribute__((weak, alias("__sata_initialize"))); - -__weak int __sata_stop(void) -{ - int i, err = 0; - - for (i = 0; i < CONFIG_SYS_SATA_MAX_DEVICE; i++) - err |= reset_sata(i); - - if (err) - printf("Could not reset some SATA devices\n"); - - return err; -} -int sata_stop(void) __attribute__((weak, alias("__sata_stop"))); -#endif - static const struct blk_ops sata_blk_ops = { .read = sata_bread, .write = sata_bwrite, diff --git a/drivers/ata/sata_sandbox.c b/drivers/ata/sata_sandbox.c deleted file mode 100644 index e64cc4a5c10c..000000000000 --- a/drivers/ata/sata_sandbox.c +++ /dev/null @@ -1,33 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2015 Google, Inc - * Written by Simon Glass sjg@chromium.org - */ - -#include <common.h> -#include <blk.h> - -int init_sata(int dev) -{ - return 0; -} - -int reset_sata(int dev) -{ - return 0; -} - -int scan_sata(int dev) -{ - return 0; -} - -ulong sata_read(int dev, ulong blknr, lbaint_t blkcnt, void *buffer) -{ - return 0; -} - -ulong sata_write(int dev, ulong blknr, lbaint_t blkcnt, const void *buffer) -{ - return 0; -} diff --git a/drivers/scsi/Kconfig b/drivers/scsi/Kconfig index a8014129d335..7e21c4ae2bb8 100644 --- a/drivers/scsi/Kconfig +++ b/drivers/scsi/Kconfig @@ -1,46 +1,9 @@ config SCSI - bool "Support SCSI controllers" + bool "Support SCSI controllers with driver model" help This enables support for SCSI (Small Computer System Interface), a parallel interface widely used with storage peripherals such as hard drives and optical drives. The SCSI standards define physical interfaces as well as protocols for controlling devices and - tranferring data. - -config DM_SCSI - bool "Support SCSI controllers with driver model" - help - This option enables the SCSI (Small Computer System Interface) uclass - which supports SCSI and SATA HDDs. For every device configuration - (IDs/LUNs) a block device is created with RAW read/write and - filesystem support. - -if SCSI && !DM_SCSI - -config SCSI_AHCI_PLAT - bool "Platform-specific init of AHCI" - help - This enables a way for boards to set up an AHCI device manually, by - called ahci_init() and providing an ahci_reset() mechanism. - - This is deprecated. An AHCI driver should be provided instead. - -config SYS_SCSI_MAX_SCSI_ID - int "Maximum supported SCSI ID" - default 1 - help - Sets the maximum number of SCSI IDs to scan when looking for devices. - IDs from 0 to (this value - 1) are scanned. - - This is deprecated and is not needed when BLK is enabled. - -config SYS_SCSI_MAX_LUN - int "Maximum support SCSI LUN" - default 1 - help - Sets the maximum number of SCSI Logical Unit Numbers (LUNs) to scan on - devices. LUNs from 0 to (this value - 1) are scanned. - - This is deprecated and is not needed when CONFIG_DM_SCSI is enabled. - -endif + tranferring data. For every device configuration (IDs/LUNs) a block + device is created with RAW read/write and filesystem support. diff --git a/drivers/scsi/Makefile b/drivers/scsi/Makefile index d8d6de59090d..628be4c89fba 100644 --- a/drivers/scsi/Makefile +++ b/drivers/scsi/Makefile @@ -4,25 +4,16 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
ifndef CONFIG_SPL_BUILD -obj-$(CONFIG_DM_SCSI) += scsi-uclass.o -obj-$(CONFIG_SCSI) += scsi.o - +obj-$(CONFIG_SCSI) += scsi.o scsi-uclass.o ifdef CONFIG_SCSI -ifdef CONFIG_DM_SCSI obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += scsi_bootdev.o +obj-$(CONFIG_SANDBOX) += sandbox_scsi.o +obj-$(CONFIG_SANDBOX) += scsi_emul.o endif endif
-endif - ifdef CONFIG_SPL_BUILD ifdef CONFIG_SPL_SATA -obj-$(CONFIG_DM_SCSI) += scsi-uclass.o -obj-$(CONFIG_SCSI) += scsi.o +obj-$(CONFIG_SCSI) += scsi.o scsi-uclass.o endif endif - -ifdef CONFIG_SCSI -obj-$(CONFIG_SANDBOX) += sandbox_scsi.o -obj-$(CONFIG_SANDBOX) += scsi_emul.o -endif diff --git a/drivers/scsi/scsi.c b/drivers/scsi/scsi.c index 779a34bd2f1c..363047d0f72c 100644 --- a/drivers/scsi/scsi.c +++ b/drivers/scsi/scsi.c @@ -21,38 +21,10 @@ #include <dm/device-internal.h> #include <dm/uclass-internal.h>
-#if !defined(CONFIG_DM_SCSI) -# ifdef CFG_SCSI_DEV_LIST -# define SCSI_DEV_LIST CFG_SCSI_DEV_LIST -# else -# ifdef CONFIG_SATA_ULI5288 - -# define SCSI_VEND_ID 0x10b9 -# define SCSI_DEV_ID 0x5288 - -# elif !defined(CONFIG_SCSI_AHCI_PLAT) -# error no scsi device defined -# endif -# define SCSI_DEV_LIST {SCSI_VEND_ID, SCSI_DEV_ID} -# endif -#endif - -#if defined(CONFIG_PCI) && !defined(CONFIG_SCSI_AHCI_PLAT) && \ - !defined(CONFIG_DM_SCSI) -const struct pci_device_id scsi_device_list[] = { SCSI_DEV_LIST }; -#endif static struct scsi_cmd tempccb; /* temporary scsi command buffer */
DEFINE_CACHE_ALIGN_BUFFER(u8, tempbuff, 512); /* temporary data buffer */
-#if !defined(CONFIG_DM_SCSI) -static int scsi_max_devs; /* number of highest available scsi device */ - -static int scsi_curr_dev; /* current device */ - -static struct blk_desc scsi_dev_desc[SCSI_MAX_DEVICE]; -#endif - /* almost the maximum amount of the scsi_ext command.. */ #define SCSI_MAX_BLK 0xFFFF #define SCSI_LBA48_READ 0xFFFFFFF @@ -107,7 +79,6 @@ static void scsi_setup_inquiry(struct scsi_cmd *pccb) pccb->msgout[0] = SCSI_IDENTIFY; /* NOT USED */ }
-#ifdef CONFIG_BLK static void scsi_setup_read_ext(struct scsi_cmd *pccb, lbaint_t start, unsigned short blocks) { @@ -286,59 +257,6 @@ static int scsi_buffer_aligned(struct udevice *dev, struct bounce_buffer *state) return 1; } #endif /* CONFIG_BOUNCE_BUFFER */ -#endif - -#if defined(CONFIG_PCI) && !defined(CONFIG_SCSI_AHCI_PLAT) && \ - !defined(CONFIG_DM_SCSI) -void scsi_init(void) -{ - int busdevfunc = -1; - int i; - /* - * Find a device from the list, this driver will support a single - * controller. - */ - for (i = 0; i < ARRAY_SIZE(scsi_device_list); i++) { - /* get PCI Device ID */ - struct udevice *dev; - int ret; - - ret = dm_pci_find_device(scsi_device_list[i].vendor, - scsi_device_list[i].device, 0, &dev); - if (!ret) { - busdevfunc = dm_pci_get_bdf(dev); - break; - } - if (busdevfunc != -1) - break; - } - - if (busdevfunc == -1) { - printf("Error: SCSI Controller(s) "); - for (i = 0; i < ARRAY_SIZE(scsi_device_list); i++) { - printf("%04X:%04X ", - scsi_device_list[i].vendor, - scsi_device_list[i].device); - } - printf("not found\n"); - return; - } -#ifdef DEBUG - else { - printf("SCSI Controller (%04X,%04X) found (%d:%d:%d)\n", - scsi_device_list[i].vendor, - scsi_device_list[i].device, - (busdevfunc >> 16) & 0xFF, - (busdevfunc >> 11) & 0x1F, - (busdevfunc >> 8) & 0x7); - } -#endif - bootstage_start(BOOTSTAGE_ID_ACCUM_SCSI, "ahci"); - scsi_low_level_init(busdevfunc); - scsi_scan(true); - bootstage_accum(BOOTSTAGE_ID_ACCUM_SCSI); -} -#endif
/* copy src to dest, skipping leading and trailing blanks * and null terminate the string @@ -464,25 +382,6 @@ static void scsi_init_dev_desc_priv(struct blk_desc *dev_desc) #endif /* CONFIG_BOUNCE_BUFFER */ }
-#if !defined(CONFIG_DM_SCSI) -/** - * scsi_init_dev_desc - initialize all SCSI specific blk_desc properties - * - * @dev_desc: Block device description pointer - * @devnum: Device number - */ -static void scsi_init_dev_desc(struct blk_desc *dev_desc, int devnum) -{ - dev_desc->lba = 0; - dev_desc->blksz = 0; - dev_desc->uclass_id = UCLASS_SCSI; - dev_desc->devnum = devnum; - dev_desc->part_type = PART_TYPE_UNKNOWN; - - scsi_init_dev_desc_priv(dev_desc); -} -#endif - /** * scsi_detect_dev - Detect scsi device * @@ -570,7 +469,6 @@ removable: * (re)-scan the scsi bus and reports scsi device info * to the user if mode = 1 */ -#if defined(CONFIG_DM_SCSI) static int do_scsi_scan_one(struct udevice *dev, int id, int lun, bool verbose) { int ret; @@ -691,48 +589,7 @@ int scsi_scan(bool verbose)
return 0; } -#else -int scsi_scan(bool verbose) -{ - unsigned char i, lun; - int ret; - - if (verbose) - printf("scanning bus for devices...\n"); - for (i = 0; i < SCSI_MAX_DEVICE; i++) - scsi_init_dev_desc(&scsi_dev_desc[i], i); - - scsi_max_devs = 0; - for (i = 0; i < CONFIG_SYS_SCSI_MAX_SCSI_ID; i++) { - for (lun = 0; lun < CONFIG_SYS_SCSI_MAX_LUN; lun++) { - struct blk_desc *bdesc = &scsi_dev_desc[scsi_max_devs]; - - ret = scsi_detect_dev(NULL, i, lun, bdesc); - if (ret) - continue; - part_init(bdesc); - - if (verbose) { - printf(" Device %d: ", bdesc->devnum); - dev_print(bdesc); - } - scsi_max_devs++; - } /* next LUN */ - } - if (scsi_max_devs > 0) - scsi_curr_dev = 0; - else - scsi_curr_dev = -1; - - printf("Found %d device(s).\n", scsi_max_devs); -#ifndef CONFIG_SPL_BUILD - env_set_ulong("scsidevs", scsi_max_devs); -#endif - return 0; -} -#endif
-#ifdef CONFIG_BLK static const struct blk_ops scsi_blk_ops = { .read = scsi_read, .write = scsi_write, @@ -746,11 +603,3 @@ U_BOOT_DRIVER(scsi_blk) = { .id = UCLASS_BLK, .ops = &scsi_blk_ops, }; -#else -U_BOOT_LEGACY_BLK(scsi) = { - .uclass_idname = "scsi", - .uclass_id = UCLASS_SCSI, - .max_devs = SCSI_MAX_DEVICE, - .desc = scsi_dev_desc, -}; -#endif diff --git a/drivers/ufs/Kconfig b/drivers/ufs/Kconfig index 0e0cc58e3d64..ee021c7d549d 100644 --- a/drivers/ufs/Kconfig +++ b/drivers/ufs/Kconfig @@ -2,7 +2,7 @@ menu "UFS Host Controller Support"
config UFS bool "Support UFS controllers" - depends on DM_SCSI + depends on SCSI select CHARSET help This selects support for Universal Flash Subsystem (UFS). diff --git a/include/ahci.h b/include/ahci.h index d7f951c3883b..d4f0f3ce0e71 100644 --- a/include/ahci.h +++ b/include/ahci.h @@ -223,9 +223,6 @@ int sata_dm_port_status(struct udevice *dev, int port); */ int sata_scan(struct udevice *dev);
-int ahci_init(void __iomem *base); -int ahci_reset(void __iomem *base); - /** * ahci_init_one_dm() - set up a single AHCI port * diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 83ab94ec444c..971a393817a3 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -57,13 +57,6 @@ * MMC */
-/* SATA */ -#ifndef PCI_DEVICE_ID_FREESCALE_AHCI -#define PCI_DEVICE_ID_FREESCALE_AHCI 0x0440 -#endif -#define CFG_SCSI_DEV_LIST {PCI_VENDOR_ID_FREESCALE, \ - PCI_DEVICE_ID_FREESCALE_AHCI} - /* SPI */
#define FSL_PCIE_COMPAT "fsl,ls1021a-pcie" diff --git a/include/configs/ls1028ardb.h b/include/configs/ls1028ardb.h index ee4f885c5341..0f591e3c4ab5 100644 --- a/include/configs/ls1028ardb.h +++ b/include/configs/ls1028ardb.h @@ -49,11 +49,6 @@ CSOR_NOR_TRHZ_80) #endif
-/* SATA */ -#define SCSI_VEND_ID 0x1b4b -#define SCSI_DEV_ID 0x9170 -#define CFG_SCSI_DEV_LIST {SCSI_VEND_ID, SCSI_DEV_ID} - /* Initial environment variables */ #ifndef SPL_NO_ENV #undef CFG_EXTRA_ENV_SETTINGS diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 60362b6a4d07..ef8fdc1912bd 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -199,13 +199,6 @@ #endif #endif
-/* SATA */ -#ifndef SPL_NO_SATA -#define SCSI_VEND_ID 0x1b4b -#define SCSI_DEV_ID 0x9170 -#define CFG_SCSI_DEV_LIST {SCSI_VEND_ID, SCSI_DEV_ID} -#endif - #include <asm/fsl_secure_boot.h>
#endif /* __LS1043ARDB_H__ */ diff --git a/include/sata.h b/include/sata.h index 6111cf65d9d1..8414e77e42ba 100644 --- a/include/sata.h +++ b/include/sata.h @@ -2,22 +2,6 @@ #define __SATA_H__ #include <part.h>
-#if !defined(CONFIG_DM_SCSI) && !defined(CONFIG_AHCI) -int init_sata(int dev); -int reset_sata(int dev); -int scan_sata(int dev); -ulong sata_read(int dev, ulong blknr, lbaint_t blkcnt, void *buffer); -ulong sata_write(int dev, ulong blknr, lbaint_t blkcnt, const void *buffer); - -int sata_initialize(void); -int __sata_initialize(void); -int sata_stop(void); -int __sata_stop(void); -int sata_port_status(int dev, int port); - -extern struct blk_desc sata_dev_desc[]; -#endif - int sata_probe(int devnum); int sata_remove(int devnum);
diff --git a/include/scsi.h b/include/scsi.h index ee9d622680d6..cf756aa62e16 100644 --- a/include/scsi.h +++ b/include/scsi.h @@ -10,10 +10,6 @@ #include <bouncebuf.h> #include <linux/dma-direction.h>
-/* Fix this to the maximum */ -#define SCSI_MAX_DEVICE \ - (CONFIG_SYS_SCSI_MAX_SCSI_ID * CONFIG_SYS_SCSI_MAX_LUN) - struct udevice;
/** @@ -355,11 +351,6 @@ int scsi_scan(bool verbose); */ int scsi_scan_dev(struct udevice *dev, bool verbose);
-#ifndef CONFIG_DM_SCSI -void scsi_low_level_init(int busdevfunc); -void scsi_init(void); -#endif - #define SCSI_IDENTIFY 0xC0 /* not used */
/* Hardware errors */
