[U-Boot] [PATCH] sunxi: Fix H3 DRAM impedance calibration on rev. A chips
H3 seems to have a silicon bug breaking the impedance calibration. This is currently worked around in software by multiple steps combining the results to replace the wrong values.
Revision A chips need a different workaround, which is present in the vendor bootloader too, but got overlooked in lack of information and affected boards till now. This commit adds a simplified version without correction factor, which would be 1.00 for all known boards anyway.
Signed-off-by: Jens Kuske jenskuske@gmail.com ---
This has been tested by an Armbian user: http://forum.armbian.com/index.php/topic/872-beelink-x2-with-armbian-possibl...
It looks like only few boards have revision A chips, probably only non-development boards, otherwise we would have found this earlier. The idea that these are different chip revision is based on: https://github.com/igorpecovnik/linux/blob/sun8i/arch/arm/mach-sunxi/sunxi-c...
Regards, Jens
--- arch/arm/mach-sunxi/dram_sun8i_h3.c | 64 +++++++++++++++++++++++++------------ 1 file changed, 43 insertions(+), 21 deletions(-)
diff --git a/arch/arm/mach-sunxi/dram_sun8i_h3.c b/arch/arm/mach-sunxi/dram_sun8i_h3.c index 2020d75..b08b8e6 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_h3.c +++ b/arch/arm/mach-sunxi/dram_sun8i_h3.c @@ -217,35 +217,57 @@ static void mctl_zq_calibration(struct dram_para *para) struct sunxi_mctl_ctl_reg * const mctl_ctl = (struct sunxi_mctl_ctl_reg *)SUNXI_DRAM_CTL0_BASE;
- int i; - u16 zq_val[6]; - u8 val; + if ((readl(SUNXI_SRAMC_BASE + 0x24) & 0xff) == 0 && + (readl(SUNXI_SRAMC_BASE + 0xf0) & 0x1) == 0) { + u32 reg_val;
- writel(0x0a0a0a0a, &mctl_ctl->zqdr[2]); - - for (i = 0; i < 6; i++) { - u8 zq = (CONFIG_DRAM_ZQ >> (i * 4)) & 0xf; - - writel((zq << 20) | (zq << 16) | (zq << 12) | - (zq << 8) | (zq << 4) | (zq << 0), - &mctl_ctl->zqcr); + clrsetbits_le32(&mctl_ctl->zqcr, 0xffff, + CONFIG_DRAM_ZQ & 0xffff);
writel(PIR_CLRSR, &mctl_ctl->pir); mctl_phy_init(PIR_ZCAL);
- zq_val[i] = readl(&mctl_ctl->zqdr[0]) & 0xff; - writel(REPEAT_BYTE(zq_val[i]), &mctl_ctl->zqdr[2]); + reg_val = readl(&mctl_ctl->zqdr[0]); + reg_val &= (0x1f << 16) | (0x1f << 0); + reg_val |= reg_val << 8; + writel(reg_val, &mctl_ctl->zqdr[0]);
- writel(PIR_CLRSR, &mctl_ctl->pir); - mctl_phy_init(PIR_ZCAL); + reg_val = readl(&mctl_ctl->zqdr[1]); + reg_val &= (0x1f << 16) | (0x1f << 0); + reg_val |= reg_val << 8; + writel(reg_val, &mctl_ctl->zqdr[1]); + writel(reg_val, &mctl_ctl->zqdr[2]); + } else { + int i; + u16 zq_val[6]; + u8 val;
- val = readl(&mctl_ctl->zqdr[0]) >> 24; - zq_val[i] |= bin_to_mgray(mgray_to_bin(val) - 1) << 8; - } + writel(0x0a0a0a0a, &mctl_ctl->zqdr[2]); + + for (i = 0; i < 6; i++) { + u8 zq = (CONFIG_DRAM_ZQ >> (i * 4)) & 0xf; + + writel((zq << 20) | (zq << 16) | (zq << 12) | + (zq << 8) | (zq << 4) | (zq << 0), + &mctl_ctl->zqcr);
- writel((zq_val[1] << 16) | zq_val[0], &mctl_ctl->zqdr[0]); - writel((zq_val[3] << 16) | zq_val[2], &mctl_ctl->zqdr[1]); - writel((zq_val[5] << 16) | zq_val[4], &mctl_ctl->zqdr[2]); + writel(PIR_CLRSR, &mctl_ctl->pir); + mctl_phy_init(PIR_ZCAL); + + zq_val[i] = readl(&mctl_ctl->zqdr[0]) & 0xff; + writel(REPEAT_BYTE(zq_val[i]), &mctl_ctl->zqdr[2]); + + writel(PIR_CLRSR, &mctl_ctl->pir); + mctl_phy_init(PIR_ZCAL); + + val = readl(&mctl_ctl->zqdr[0]) >> 24; + zq_val[i] |= bin_to_mgray(mgray_to_bin(val) - 1) << 8; + } + + writel((zq_val[1] << 16) | zq_val[0], &mctl_ctl->zqdr[0]); + writel((zq_val[3] << 16) | zq_val[2], &mctl_ctl->zqdr[1]); + writel((zq_val[5] << 16) | zq_val[4], &mctl_ctl->zqdr[2]); + } }
static void mctl_set_cr(struct dram_para *para)
Regards, Jens
int i;
u16 zq_val[6];
u8 val;
I think we can unlock before reading the sram version, do you think so? and lock same after.
u32 reg_val;
&mctl_ctl->zqcr);
CONFIG_DRAM_ZQ & 0xffff); writel(PIR_CLRSR, &mctl_ctl->pir); mctl_phy_init(PIR_ZCAL);
Was this write call for zqdr[2] true?
thanks!
Regards, Jens
int i;
u16 zq_val[6];
u8 val;
We don't have to unlock to read this field, it's even documented in the datasheet. Only to read the full version in bits 31:16 it has to be unlocked. Or what did you mean?
u32 reg_val;
&mctl_ctl->zqcr);
Yes, it is correct, calibration for zqdr[2] doesn't work at all, so zqdr[1] gets copied. Both are for the data lanes, so this is reasonable.
thanks!
Regards, Jens
int i;
u16 zq_val[6];
u8 val;
This code is detecting H3 rev.A chip, correct? I'm thinking we need to detect the H3(0x1680) first and check for rev.A for safety. Can you point me where it documented, unable to find the same.
thanks!
Regards, Jens
int i;
u16 zq_val[6];
u8 val;
All code in this file must only be run on H3, otherwise everything else will fail too. So we don't have extra checks for that anywhere, the SoC version is a compiletime option for all sunxi code.
H3 Datasheet v1.2 page 152 (VER_BITS), but only the 0x24, 0xf0 is from https://github.com/igorpecovnik/linux/blob/sun8i/arch/arm/mach-sunxi/sunxi-c...
thanks!
Regards, Jens
int i;
u16 zq_val[6];
u8 val;
OK.
Thanks.
Reviewed-by: Jagan Teki jteki@openedev.com
Thank you for the patch. I've applied this patch to my local tree and it will be part of the pull-request I'm about to send out.
Regards,
Hans
Regards, Jens
- int i;
- u16 zq_val[6];
- u8 val;
- if ((readl(SUNXI_SRAMC_BASE + 0x24) & 0xff) == 0 &&
u32 reg_val;
&mctl_ctl->zqcr);
- } else {
int i;
u16 zq_val[6];
u8 val;
&mctl_ctl->zqcr);
Hans de Goede
Jagan Teki
Jens Kuske
