[PATCH 1/5] tools: relocate-rela: adjust le64_to_cpu -> le32_to_cpu in decode_elf32()
The sh_addr/sh_offset/sh_size fields in Elf32_Shdr are 32-bits wide, so use le32_to_cpu() instead of the 64-bit variant.
Fixes: 5e0e1a86d327 ("tools: relocate-rela: Fix ELF decoding on big-endian hosts") Signed-off-by: Ovidiu Panait ovpanait@gmail.com ---
tools/relocate-rela.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/tools/relocate-rela.c b/tools/relocate-rela.c index 2d2a2ed277..689e2d4655 100644 --- a/tools/relocate-rela.c +++ b/tools/relocate-rela.c @@ -316,9 +316,9 @@ static int decode_elf32(FILE *felf, char **argv)
debug("%s\n", sh_name);
- sh_addr = le64_to_cpu(sh_table[i].sh_addr); - sh_offset = le64_to_cpu(sh_table[i].sh_offset); - sh_size = le64_to_cpu(sh_table[i].sh_size); + sh_addr = le32_to_cpu(sh_table[i].sh_addr); + sh_offset = le32_to_cpu(sh_table[i].sh_offset); + sh_size = le32_to_cpu(sh_table[i].sh_size);
if (!strcmp(".rela.dyn", sh_name)) { debug("Found section\t".rela_dyn"\n");
Add elf16_to_cpu() and elf32_to_cpu() functions that allow to read data in both big-endian and little-endian formats.
tools/relocate-rela.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/tools/relocate-rela.c b/tools/relocate-rela.c index 689e2d4655..84531b23a6 100644 --- a/tools/relocate-rela.c +++ b/tools/relocate-rela.c @@ -45,6 +45,7 @@ #endif
static int ei_class; +static int ei_data;
static uint64_t rela_start, rela_end, text_base, dyn_start;
@@ -61,6 +62,22 @@ static void debug(const char *fmt, ...) } }
+static uint16_t elf16_to_cpu(uint16_t data) +{ + if (ei_data == 0x01) + return le16_to_cpu(data); + + return be16_to_cpu(data); +} + +static uint32_t elf32_to_cpu(uint32_t data) +{ + if (ei_data == 0x01) + return le32_to_cpu(data); + + return be32_to_cpu(data); +} + static bool supported_rela(Elf64_Rela *rela) { uint64_t mask = 0xffffffffULL; /* would be different on 32-bit */ @@ -384,6 +401,9 @@ static int decode_elf(char **argv) ei_class = e_ident[4]; debug("EI_CLASS(1=32bit, 2=64bit) %d\n", ei_class);
+ ei_data = e_ident[5]; + debug("EI_DATA(1=little endian, 2=big endian) %d\n", ei_data); + if (ei_class == 2) return decode_elf64(felf, argv);
- if (ei_data == 0x01)
Can we used macros instead of hardcoding value?
/* e_ident[] data encoding */ #define ELFDATANONE 0 /* invalid */ #define ELFDATA2LSB 1 /* Little-Endian */ #define ELFDATA2MSB 2 /* Big-Endian */ #define ELFDATANUM 3 /* number of data encode defines */
M
Currently, a microblaze build with CONFIG_SYS_BIG_ENDIAN=y and CONFIG_STATIC_RELA=y fails with: tools/relocate-rela: Not supported machine type ELF decoding failed make[2]: *** [u-boot/Makefile:1306: u-boot-nodtb.bin] Error 1
To fix this, convert the 32-bit codepath to use the previously added elf{16,32}_to_cpu() functions. The aarch64 codepath is left untouched.
This commit ensures that CI doesn't fail for the next patches which enable runtime relocation by default for microblaze.
tools/relocate-rela.c | 32 ++++++++++++++++---------------- 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/tools/relocate-rela.c b/tools/relocate-rela.c index 84531b23a6..2bc46a12d7 100644 --- a/tools/relocate-rela.c +++ b/tools/relocate-rela.c @@ -251,7 +251,7 @@ static int decode_elf32(FILE *felf, char **argv) return 25; }
- machine = le16_to_cpu(header.e_machine); + machine = elf16_to_cpu(header.e_machine); debug("Machine %d\n", machine);
if (machine != EM_MICROBLAZE) { @@ -259,10 +259,10 @@ static int decode_elf32(FILE *felf, char **argv) return 30; }
- text_base = le32_to_cpu(header.e_entry); - section_header_base = le32_to_cpu(header.e_shoff); - section_header_size = le16_to_cpu(header.e_shentsize) * - le16_to_cpu(header.e_shnum); + text_base = elf32_to_cpu(header.e_entry); + section_header_base = elf32_to_cpu(header.e_shoff); + section_header_size = elf16_to_cpu(header.e_shentsize) * + elf16_to_cpu(header.e_shnum);
sh_table = malloc(section_header_size); if (!sh_table) { @@ -290,8 +290,8 @@ static int decode_elf32(FILE *felf, char **argv) return 27; }
- sh_index = le16_to_cpu(header.e_shstrndx); - sh_size = le32_to_cpu(sh_table[sh_index].sh_size); + sh_index = elf16_to_cpu(header.e_shstrndx); + sh_size = elf32_to_cpu(sh_table[sh_index].sh_size); debug("e_shstrndx %x, sh_size %lx\n", sh_index, sh_size);
sh_str = malloc(sh_size); @@ -306,8 +306,8 @@ static int decode_elf32(FILE *felf, char **argv) * Specifies the byte offset from the beginning of the file * to the first byte in the section. */ - sh_offset = le32_to_cpu(sh_table[sh_index].sh_offset); - sh_num = le16_to_cpu(header.e_shnum); + sh_offset = elf32_to_cpu(sh_table[sh_index].sh_offset); + sh_num = elf16_to_cpu(header.e_shnum);
ret = fseek(felf, sh_offset, SEEK_SET); if (ret) { @@ -329,13 +329,13 @@ static int decode_elf32(FILE *felf, char **argv) }
for (i = 0; i < sh_num; i++) { - char *sh_name = sh_str + le32_to_cpu(sh_table[i].sh_name); + char *sh_name = sh_str + elf32_to_cpu(sh_table[i].sh_name);
- sh_addr = le32_to_cpu(sh_table[i].sh_addr); - sh_offset = le32_to_cpu(sh_table[i].sh_offset); - sh_size = le32_to_cpu(sh_table[i].sh_size); + sh_addr = elf32_to_cpu(sh_table[i].sh_addr); + sh_offset = elf32_to_cpu(sh_table[i].sh_offset); + sh_size = elf32_to_cpu(sh_table[i].sh_size);
if (!strcmp(".rela.dyn", sh_name)) { debug("Found section\t".rela_dyn"\n"); @@ -540,9 +540,9 @@ static int rela_elf32(char **argv, FILE *f) PRIu32 " r_addend:\t%" PRIx32 "\n", rela.r_offset, rela.r_info, rela.r_addend);
- swrela.r_offset = le32_to_cpu(rela.r_offset); - swrela.r_info = le32_to_cpu(rela.r_info); - swrela.r_addend = le32_to_cpu(rela.r_addend); + swrela.r_offset = elf32_to_cpu(rela.r_offset); + swrela.r_info = elf32_to_cpu(rela.r_info); + swrela.r_addend = elf32_to_cpu(rela.r_addend);
debug("SWRela:\toffset:\t%" PRIx32 " r_info:\t%" PRIu32 " r_addend:\t%" PRIx32 "\n",
Reviewed-by: Michal Simek michal.simek@amd.com
Thanks, Michal
Microblaze and m68k are the only remaining architectures that still enable CONFIG_NEEDS_MANUAL_RELOC by default.
Microblaze has had runtime relocation support using CONFIG_STATIC_RELA for quite some time, since commit d58c007498 ("microblaze: Add support for run time relocation"). Drop support for CONFIG_NEEDS_MANUAL_RELOC and make runtime relocation the default, as the rest of the architectures do.
arch/microblaze/Kconfig | 13 +------------ 1 file changed, 1 insertion(+), 12 deletions(-)
diff --git a/arch/microblaze/Kconfig b/arch/microblaze/Kconfig index ce157a79cc..e38c9f6d71 100644 --- a/arch/microblaze/Kconfig +++ b/arch/microblaze/Kconfig @@ -4,19 +4,8 @@ menu "MicroBlaze architecture" config SYS_ARCH default "microblaze"
-config NEEDS_MANUAL_RELOC - bool "Disable position-independent pre-relocation code" - default y - help - U-Boot expects to be linked to a specific hard-coded address, and to - be loaded to and run from that address. This option lifts that - restriction, thus allowing the code to be loaded to and executed from - almost any 4K aligned address. This logic relies on the relocation - information that is embedded in the binary to support U-Boot - relocating itself to the top-of-RAM later during execution. - config STATIC_RELA - def_bool y if !NEEDS_MANUAL_RELOC + def_bool y
choice prompt "Target select"
- default y
- help
def_bool y
Thanks, Michal
Runtime relocation has been made the default for microblaze, so do the following cleanups: - drop all manual reloc codepaths in start.S - drop all STATIC_RELA ifdefs, as it is now enabled unconditionally in Kconfig
arch/microblaze/config.mk | 4 ---- arch/microblaze/cpu/Makefile | 3 +-- arch/microblaze/cpu/start.S | 28 ---------------------------- 3 files changed, 1 insertion(+), 34 deletions(-)
diff --git a/arch/microblaze/config.mk b/arch/microblaze/config.mk index 467c5ca1b1..64c3f31319 100644 --- a/arch/microblaze/config.mk +++ b/arch/microblaze/config.mk @@ -13,10 +13,6 @@ LDFLAGS_FINAL += --gc-sections
ifeq ($(CONFIG_SPL_BUILD),) PLATFORM_CPPFLAGS += -fPIC -endif - -ifeq ($(CONFIG_STATIC_RELA),y) -PLATFORM_CPPFLAGS += -fPIC LDFLAGS_u-boot += -pic endif
diff --git a/arch/microblaze/cpu/Makefile b/arch/microblaze/cpu/Makefile index 1c586a7de0..b8c1dcbe14 100644 --- a/arch/microblaze/cpu/Makefile +++ b/arch/microblaze/cpu/Makefile @@ -5,7 +5,6 @@
extra-y = start.o obj-y = irq.o -obj-y += interrupts.o cache.o exception.o cpuinfo.o -obj-$(CONFIG_STATIC_RELA) += relocate.o +obj-y += interrupts.o cache.o exception.o cpuinfo.o relocate.o obj-$(CONFIG_XILINX_MICROBLAZE0_PVR) += pvr.o obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/arch/microblaze/cpu/start.S b/arch/microblaze/cpu/start.S index 7079d9e170..c1e0fcda0a 100644 --- a/arch/microblaze/cpu/start.S +++ b/arch/microblaze/cpu/start.S @@ -10,16 +10,11 @@ #include <asm-offsets.h> #include <config.h>
-#if defined(CONFIG_STATIC_RELA) #define SYM_ADDR(reg, reg_add, symbol) \ mfs r20, rpc; \ addik r20, r20, _GLOBAL_OFFSET_TABLE_ + 8; \ lwi reg, r20, symbol@GOT; \ addk reg, reg reg_add; -#else -#define SYM_ADDR(reg, reg_add, symbol) \ - addi reg, reg_add, symbol -#endif
.text .global _start @@ -35,7 +30,6 @@ _start: addi r1, r0, CONFIG_SPL_STACK #else add r1, r0, r20 -#if defined(CONFIG_STATIC_RELA) bri 1f
/* Force alignment for easier ASM code below */ @@ -67,7 +61,6 @@ uboot_sym_start:
brlid r15, mb_fix_rela nop -#endif #endif
addi r1, r1, -4 /* Decrement SP to top of memory */ @@ -310,7 +303,6 @@ relocate_code: brlid r15, __setup_exceptions nop
-#if defined(CONFIG_STATIC_RELA) /* reloc_offset is current location */ SYM_ADDR(r10, r0, _start)
@@ -331,27 +323,7 @@ relocate_code: add r9, r9, r5 brlid r15, mb_fix_rela nop - /* end of code which does relocation */ -#else - /* Check if GOT exist */ - addik r21, r23, _got_start - addik r22, r23, _got_end - cmpu r12, r21, r22 - beqi r12, 2f /* No GOT table - jump over */ - - /* Skip last 3 entries plus 1 because of loop boundary below */ - addik r22, r22, -0x10 - - /* Relocate the GOT. */ -3: lw r12, r21, r0 /* Load entry */ - addk r12, r12, r23 /* Add reloc offset */ - sw r12, r21, r0 /* Save entry back */ - - cmpu r12, r21, r22 /* Check if this cross boundary */ - bneid r12, 3b - addik r21. r21, 4 -#endif
/* Flush caches to ensure consistency */ brlid r15, flush_cache_all
Kconfig
-#endif
-#else
- bneid r12, 3b
- addik r21. r21, 4
-#endif
Thanks, Michal
Thanks, Michal
Michal Simek
Ovidiu Panait
