[U-Boot] [PATCH ] board: ls2080a: Add "mcinitcmd" env for MC & DPL deployment
From: Pratiyush Mohan Srivastava pratiyush.srivastava@nxp.com
Environment variable mcinitcmd is defined to initiate MC and DPL deployment from the location where it is stored(NOR, NAND, SD, SATA, USB)during u-boot booting.If this variable is not defined then macro MC_BOOT_ENV_VAR will be null and MC will not be booted and DPL will not be applied during U-boot booting.
Signed-off-by: Pratiyush Mohan Srivastava pratiyush.srivastava@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/README.lsch3 | 29 ++++++++++++++++++++++++++ board/freescale/ls2080aqds/eth.c | 5 +++++ board/freescale/ls2080ardb/eth_ls2080rdb.c | 5 +++++ 3 files changed, 39 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/README.lsch3 b/arch/arm/cpu/armv8/fsl-layerscape/README.lsch3 index f9323c1..da5e052 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/README.lsch3 +++ b/arch/arm/cpu/armv8/fsl-layerscape/README.lsch3 @@ -121,6 +121,35 @@ mcboottimeout: MC boot timeout in milliseconds. If this variable is not defined mcmemsize: MC DRAM block size. If this variable is not defined, the value CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE will be assumed.
+mcinitcmd: This environment variable is defined to initiate MC and DPL deployment + from the location where it is stored(NOR, NAND, SD, SATA, USB)during + u-boot booting.If this variable is not defined then MC_BOOT_ENV_VAR + will be null and MC will not be booted and DPL will not be applied + during U-boot booting.However the MC, DPC and DPL can be applied from + console independently. + The variable needs to be set from the console once and then on + rebooting the parameters set in the varible will automatically be + executed. The commmand is demostrated taking an example of mc boot + using NOR Flash i.e. MC, DPL, and DPC is stored in the NOR flash: + + cp.b 0xa0000000 0x580300000 $filesize + cp.b 0x80000000 0x580800000 $filesize + cp.b 0x90000000 0x580700000 $filesize + + setenv mcinitcmd 'fsl_mc start mc 0x580300000 0x580800000' + + If only linux is to be booted then the mcinitcmd environment should be set as + + setenv mcinitcmd 'fsl_mc start mc 0x580300000 0x580800000;fsl_mc apply DPL 0x580700000' + + Here the addresses 0xa0000000, 0x80000000, 0x80000000 are of DDR to where + MC binary, DPC binary and DPL binary are stored and 0x580300000, 0x580800000 + and 0x580700000 are addresses in NOR where these are copied. It is to be + noted that these addresses in 'fsl_mc start mc 0x580300000 0x580800000;fsl_mc apply DPL 0x580700000' + can be replaced with the addresses of DDR to + which these will be copied in case of these binaries being stored in other + devices like SATA, USB, NAND, SD etc. + Booting from NAND ------------------- Booting from NAND requires two images, RCW and u-boot-with-spl.bin. diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index 5b9c2d1..db9de77 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -20,6 +20,7 @@
#include "ls2080aqds_qixis.h"
+#define MC_BOOT_ENV_VAR "mcinitcmd"
#ifdef CONFIG_FSL_MC_ENET /* - In LS2080A there are only 16 SERDES lanes, spread across 2 SERDES banks. @@ -714,6 +715,7 @@ void ls2080a_handle_phy_interface_xsgmii(int i) int board_eth_init(bd_t *bis) { int error; + char *mc_boot_env_var; #ifdef CONFIG_FSL_MC_ENET struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; int serdes1_prtcl = (in_le32(&gur->rcwsr[28]) & @@ -781,6 +783,9 @@ int board_eth_init(bd_t *bis) } }
+ mc_boot_env_var = getenv(MC_BOOT_ENV_VAR); + if (mc_boot_env_var) + run_command_list(mc_boot_env_var, -1, 0); error = cpu_eth_init(bis);
if (hwconfig_f("xqsgmii", env_hwconfig)) { diff --git a/board/freescale/ls2080ardb/eth_ls2080rdb.c b/board/freescale/ls2080ardb/eth_ls2080rdb.c index 58ea746..758bb3d 100644 --- a/board/freescale/ls2080ardb/eth_ls2080rdb.c +++ b/board/freescale/ls2080ardb/eth_ls2080rdb.c @@ -20,9 +20,11 @@
DECLARE_GLOBAL_DATA_PTR;
+#define MC_BOOT_ENV_VAR "mcinitcmd" int board_eth_init(bd_t *bis) { #if defined(CONFIG_FSL_MC_ENET) + char *mc_boot_env_var; int i, interface; struct memac_mdio_info mdio_info; struct mii_dev *dev; @@ -89,6 +91,9 @@ int board_eth_init(bd_t *bis) } }
+ mc_boot_env_var = getenv(MC_BOOT_ENV_VAR); + if (mc_boot_env_var) + run_command_list(mc_boot_env_var, -1, 0); cpu_eth_init(bis); #endif /* CONFIG_FMAN_ENET */
<snip>
- char *mc_boot_env_var;
- mc_boot_env_var = getenv(MC_BOOT_ENV_VAR);
- if (mc_boot_env_var)
error = cpu_eth_init(bis);run_command_list(mc_boot_env_var, -1, 0);
Why not put the code into cpu_eth_init()?
York
-----Original Message----- From: york sun Sent: Wednesday, January 20, 2016 9:32 PM To: Pratiyush Mohan Srivastava pratiyush.srivastava@freescale.com; u-boot@lists.denx.de Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Pratiyush Srivastava pratiyush.srivastava@nxp.com Subject: Re: [PATCH ] board: ls2080a: Add "mcinitcmd" env for MC & DPL deployment
<snip>
Ans: While deciding on the location of the command "run_command_list" I could not find any prior usage in arch/arm folder. Hence I decided that the run_command_list command be kept just before calling cpu_eth_init inside board folder.
York
Applied to fsl-qoriq master. Awaiting upstream. Thanks.
York
York Sun
york sun
