[U-Boot] [PATCH] test/py: fix anchors in HTML status report
The current code wraps a pre tag inside an a tag. For some reason, this causes at least Firefox to attempt to drag the pre section content when using a mouse drag to select text. Re-order the tags so that the text can be selected using the mouse, at least if you start the drag outside the text (after the end of the line, for example).
Signed-off-by: Stephen Warren swarren@nvidia.com --- test/py/multiplexed_log.py | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/test/py/multiplexed_log.py b/test/py/multiplexed_log.py index bf926c3e7762..5bc1bc49d4de 100644 --- a/test/py/multiplexed_log.py +++ b/test/py/multiplexed_log.py @@ -365,13 +365,13 @@ $(document).ready(function () {
self._terminate_stream() self.f.write('<div class="' + note_type + '">\n') - if anchor: - self.f.write('<a href="#%s">\n' % anchor) self.f.write('<pre>') + if anchor: + self.f.write('<a href="#%s">' % anchor) self.f.write(self._escape(msg)) - self.f.write('\n</pre>\n') if anchor: - self.f.write('</a>\n') + self.f.write('</a>') + self.f.write('\n</pre>\n') self.f.write('</div>\n')
def start_section(self, marker, anchor=None):
Stephen Warren
