[U-Boot] bug, nand, am33xx: nand->ecc.strength not set in board_nand_init()
commit dfe64e2c89731a3f9950d7acd8681b68df2bae03 Author: Sergey Lapin slapin@ossfans.org Date: Mon Jan 14 03:46:50 2013 +0000
mtd: resync with Linux-3.7.1
Introduced runtime bug:
U-Boot 2013.04-00499-g46567df-dirty (Jun 04 2013 - 08:17:08)
I2C: ready DRAM: 512 MiB WARNING: Caches not enabled NAND: BUG: failure at nand_base.c:3214/nand_scan_tail()! BUG! resetting ...
on boards using drivers/mtd/nand/omap_gpmc.c as in board_nand_init() nand->ecc.strength is not set. Fix this!
Signed-off-by: Heiko Schocher hs@denx.de Cc: Sergey Lapin slapin@ossfans.org Cc: Scott Wood scottwood@freescale.com Cc: Tom Rini trini@ti.com --- drivers/mtd/nand/omap_gpmc.c | 2 ++ 1 Datei geändert, 2 Zeilen hinzugefügt(+)
diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index d5f3248..5d08822 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -936,6 +936,7 @@ int board_nand_init(struct nand_chip *nand) nand->ecc.layout = &hw_bch8_nand_oob; nand->ecc.size = CONFIG_SYS_NAND_ECCSIZE; nand->ecc.bytes = CONFIG_SYS_NAND_ECCBYTES; + nand->ecc.strength = 8; nand->ecc.hwctl = omap_enable_ecc_bch; nand->ecc.correct = omap_correct_data_bch; nand->ecc.calculate = omap_calculate_ecc_bch; @@ -954,6 +955,7 @@ int board_nand_init(struct nand_chip *nand) nand->ecc.hwctl = omap_enable_hwecc; nand->ecc.correct = omap_correct_data; nand->ecc.calculate = omap_calculate_ecc; + nand->ecc.strength = 1; omap_hwecc_init(nand); #endif #endif
Thanks, applied to u-boot-nand-flash. We did try to update all the existing drivers to do this. Omap_gpmc did get updated, but it was incomplete, as unlike most drivers, it has two different places where this stuff gets initialized (the actual init, and the ecc switch command).
-Scott
Heiko Schocher
Scott Wood
