[U-Boot] [GIT] Pull request: u-boot-dfu (13.12.2018)
Dear Marek,
The following changes since commit 51b24944fdbfa760aa87a1ad812355e1df9c9355:
usb: musb: Remove legacy CONFIG_USB_DA8XX (2018-12-12 15:23:04 +0100)
git://git.denx.de/u-boot-dfu.git
for you to fetch changes up to 8a3755462f65c032528af70c6582abf89f91b2bc:
configs: am335x_boneblack_vboot: enable DM_USB and RNDIS boot in SPl (2018-12-12 15:35:08 +0100)
---------------------------------------------------------------- Jean-Jacques Hiblot (20): usb: dwc3-generic: make it compatible with "ti, keystone-dwc3" board: ks2_evm: Enable the USB clocks if DM_USB is used ARM: dts: k2g-evm: enable USB0 and USB1 PHY: Add phy driver for the keystone USB PHY usb: host: replace xhci-keystone driver by the generic dwc3 driver configs: k2g_evm: Enable DFU on K2G EVM spl: drivers: Link usb common library to SPL if USB gadget is enabled spl: net: dm: usb: bind the gadget before attempting to load the image phy: omap_usb2: Add support for am437x dwc3-generic: Add support for the am437x board: ti: am43xx: turn on USB clocks dts: Add a u-boot specific dtsi file for the am4372 dts: am4372: Enable USB1 in SPL configs: am43xx_evm: Enable DM_USB and DM_USB_GADGET configs: am43xx: Enable RNDIS support in SPL usb: musb-new: Allow the diver not to use the set_phy_power() callback usb: musb-new: Add support for DM_USB arm: am33xx: Register USB controllers if DM_USB is used but not OF_CONTROL configs: am335x_evm: Do not disable DM_USB in SPL configs: am335x_boneblack_vboot: enable DM_USB and RNDIS boot in SPl
arch/arm/dts/am4372-generic-u-boot.dtsi | 2 + arch/arm/dts/am4372-u-boot.dtsi | 40 ++++++++++++++++++ arch/arm/dts/am437x-gp-evm-u-boot.dtsi | 2 + arch/arm/dts/am437x-idk-evm-u-boot.dtsi | 2 + arch/arm/dts/am437x-sk-evm-u-boot.dtsi | 2 + arch/arm/dts/keystone-k2g-evm.dts | 28 +++++++++++++ arch/arm/dts/keystone-k2g.dtsi | 56 +++++++++++++++++++++++++ arch/arm/include/asm/omap_musb.h | 8 ++++ arch/arm/mach-omap2/am33xx/board.c | 58 ++++++++++++++++++++++---- board/ti/am43xx/board.c | 22 ++++++++++ board/ti/ks2_evm/board.c | 12 ++++++ common/Makefile | 3 ++ common/spl/spl_net.c | 4 +- configs/am335x_boneblack_vboot_defconfig | 10 +++++ configs/am43xx_evm_defconfig | 19 +++++++++ configs/k2e_evm_defconfig | 7 ++++ configs/k2e_hs_evm_defconfig | 7 ++++ configs/k2g_evm_defconfig | 12 ++++++ configs/k2g_hs_evm_defconfig | 12 ++++++ configs/k2hk_evm_defconfig | 7 ++++ configs/k2hk_hs_evm_defconfig | 7 ++++ configs/k2l_evm_defconfig | 7 ++++ configs/k2l_hs_evm_defconfig | 7 ++++ drivers/Makefile | 1 + drivers/phy/Kconfig | 10 +++++ drivers/phy/Makefile | 1 + drivers/phy/keystone-usb-phy.c | 109 +++++++++++++++++++++++++++++++++++++++++++++++++ drivers/phy/omap-usb2-phy.c | 45 +++++++++++++++----- drivers/usb/dwc3/dwc3-generic.c | 2 + drivers/usb/host/Makefile | 1 - drivers/usb/host/xhci-keystone.c | 240 ----------------------------------------------------------------------------------------------------------- drivers/usb/musb-new/am35x.c | 8 ++-- drivers/usb/musb-new/musb_dsps.c | 8 ++-- drivers/usb/musb-new/musb_gadget.c | 11 +++++ drivers/usb/musb-new/musb_uboot.c | 4 +- drivers/usb/musb-new/ti-musb.c | 181 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++--------------------- include/configs/am335x_evm.h | 1 - include/configs/ti_armv7_keystone2.h | 17 +++++--- 38 files changed, 649 insertions(+), 324 deletions(-) create mode 100644 arch/arm/dts/am4372-u-boot.dtsi create mode 100644 drivers/phy/keystone-usb-phy.c delete mode 100644 drivers/usb/host/xhci-keystone.c
Travis-Ci: https://travis-ci.org/lmajewski/u-boot-dfu/builds/467026476
This is the last instalment of patches from Jean-Jacques
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On 12/12/2018 11:58 PM, Lukasz Majewski wrote:
Dear Marek,
This looks quite heavy after RC1 . How thoroughly was this tested ?
Lukasz Majewski
Hi Marek,
Dear Marek,
I've run:
./tools/buildman/buildman.py --branch=HEAD k2 omap am335x am43 dra7 trats2 odroid-xu3 --detail --verbose --show_errors --force-build --count=20 --output-dir=../BUILD/
on it without any issues (DTS warnings were there - as expected).
Nonetheless, this is the second "instalment" of Jean-Jacques work and shall IMHO be treated as a one part with the code already included to main line.
I do not expect so much changes to DFU/UDC tree from now on - hence we can focus on fixes.
Lukasz Majewski
Lukasz Majewski
Hi Marek, Lukasz,
On 13/12/18 1:43 PM, Lukasz Majewski wrote:
Hi Marek,
Dear Marek,
I've run:
FWIW, I did verify 8a3755462f65c032528af70c6582abf89f91b2bc on AM437x-gp evem.
MMC Boot and DFU at u-boot prompt: https://pastebin.ubuntu.com/p/gmT33ksrFC/ USB Host Boot: https://pastebin.ubuntu.com/p/zyn8PNdJ5V/
Thanks and regards, Lokesh
On 12/13/2018 10:06 AM, Lokesh Vutla wrote:
Hi Marek, Lukasz,
Hi Marek,
Dear Marek,
I've run:
Pulled, but I expect only fixes after this one.
Hi Marek,
Hi Marek, Lukasz,
Hi Marek,
Dear Marek,
I've run:
Roger :-)
Lukasz Majewski
Lokesh Vutla
Lukasz Majewski
