[U-Boot] [PATCH] kirkwood_spi: small fixes
- use proper defines for the control register - deactivate CS properly - instead of polling the IRQ status bit use SPI status bit directly - add comments
Signed-off-by: Michael Walle michael@walle.cc Cc: Prafulla Wadaskar prafulla@marvell.com --- drivers/spi/kirkwood_spi.c | 14 +++++++------- 1 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c index db8ba8b..60f3f09 100644 --- a/drivers/spi/kirkwood_spi.c +++ b/drivers/spi/kirkwood_spi.c @@ -55,7 +55,8 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, slave->bus = bus; slave->cs = cs;
- writel(~KWSPI_CSN_ACT | KWSPI_SMEMRDY, &spireg->ctrl); + /* make sure cs is deactivated */ + writel(0, &spireg->ctrl);
/* calculate spi clock prescaller using max_hz */ data = ((CONFIG_SYS_TCLK / 2) / max_hz) & KWSPI_CLKPRESCL_MASK; @@ -63,9 +64,9 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs,
/* program spi clock prescaller using max_hz */ writel(KWSPI_ADRLEN_3BYTE | data, &spireg->cfg); - debug("data = 0x%08x \n", data); + debug("data = 0x%08x\n", data);
- writel(KWSPI_SMEMRDIRQ, &spireg->irq_cause); + /* mask interrupt */ writel(KWSPI_IRQMASK, &spireg->irq_mask);
/* program mpp registers to select SPI_CSn */ @@ -113,12 +114,12 @@ void spi_init(void)
void spi_cs_activate(struct spi_slave *slave) { - writel(readl(&spireg->ctrl) | KWSPI_IRQUNMASK, &spireg->ctrl); + writel(readl(&spireg->ctrl) | KWSPI_CSN_ACT, &spireg->ctrl); }
void spi_cs_deactivate(struct spi_slave *slave) { - writel(readl(&spireg->ctrl) & KWSPI_IRQMASK, &spireg->ctrl); + writel(readl(&spireg->ctrl) & ~KWSPI_CSN_ACT, &spireg->ctrl); }
int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, @@ -148,7 +149,6 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, if (dout) tmpdout = *(u32 *) dout & 0x0ff;
- writel(~KWSPI_SMEMRDIRQ, &spireg->irq_cause); writel(tmpdout, &spireg->dout); /* Write the data out */ debug("*** spi_xfer: ... %08x written, bitlen %d\n", tmpdout, bitlen); @@ -159,7 +159,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, * The NE event must be read and cleared first */ for (tm = 0, isread = 0; tm < KWSPI_TIMEOUT; ++tm) { - if (readl(&spireg->irq_cause) & KWSPI_SMEMRDIRQ) { + if (readl(&spireg->ctrl) & KWSPI_SMEMRDY) { isread = 1; tmpdin = readl(&spireg->din); debug
Michael Walle
