[U-Boot] [PATCH 0/3][v2] sf: Update spi-nor framework
SPI-NOR framework currently supports- - (1-1-1, 1-1-2, 1-1-4) read protocols - read latency(dummy bytes) are hardcoded with the assumption that the flash would support it. - No support of mode bits. - No support of flash size above 128Mib
This patch set add support of 1-2-2, 1-4-4 read protocols. It ports Linux commits "mtd: spi-nor: add a stateless method to support memory size above 128Mib" and "mtd: spi-nor: parse Serial Flash Discoverable Parameters (SFDP) tables". It enables 4byte address opcode and run time flash parameters discovery including dummy cycle and mode cycle.
Prabhakar Kushwaha (3): sf: Add support of 1-2-2, 1-4-4 IO READ protocols sf: add method to support memory size above 128Mib sf: parse Serial Flash Discoverable Parameters (SFDP) tables
Changes for v2: Incorporated Cyrille Pitchen's comments
drivers/mtd/spi/sf_internal.h | 231 ++++++++++++++++- drivers/mtd/spi/spi_flash.c | 589 +++++++++++++++++++++++++++++++++++++++++- include/spi_flash.h | 2 + 3 files changed, 808 insertions(+), 14 deletions(-)
IO READ protocols transfers both address and data on multiple data bits. 1-2-2(DUAL IO), 1-4-4(QUAD IO) transfer address on 2 data bits or 4 bits per rising edge of SCK respectively.
This patch update spi_nor_flash_parameter->spi_nor_read_command array based on DUAL or QUAD IO flag enabled in flash_info for a flash.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- Changes for v2: none
drivers/mtd/spi/spi_flash.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 51e28bf..4ff8d8b 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1071,8 +1071,12 @@ int spi_flash_scan(struct spi_flash *flash) flash->read_cmd = CMD_READ_ARRAY_FAST; if (spi->mode & SPI_RX_SLOW) flash->read_cmd = CMD_READ_ARRAY_SLOW; + else if (spi->mode & SPI_RX_QUAD && info->flags & RD_QUADIO) + flash->read_cmd = CMD_READ_QUAD_IO_FAST; else if (spi->mode & SPI_RX_QUAD && info->flags & RD_QUAD) flash->read_cmd = CMD_READ_QUAD_OUTPUT_FAST; + else if (spi->mode & SPI_RX_DUAL && info->flags & RD_DUALIO) + flash->read_cmd = CMD_READ_DUAL_IO_FAST; else if (spi->mode & SPI_RX_DUAL && info->flags & RD_DUAL) flash->read_cmd = CMD_READ_DUAL_OUTPUT_FAST;
This patch add support of memories with size above 128Mib. It has been ported from Linux commit "mtd: spi-nor: add a stateless method to support memory size above 128Mib".
It convert 3byte opcode into 4byte opcode based upon OPCODES_4B or Spansion flash. Also the commands are malloc'ed at run time based on 3byte or 4byte address opcode requirement.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com CC: Cyrille Pitchen cyrille.pitchen@wedev4u.fr CC: Marek Vasut marek.vasut@gmail.com CC: Vignesh R vigneshr@ti.com --- Changes for v2: Incorporated 'Cyrille Pitchen's comments - Use cmd array instead of pointer for erase and write - uses m25p80 driver way in spi_flash_addr()
drivers/mtd/spi/sf_internal.h | 29 +++++++++-- drivers/mtd/spi/spi_flash.c | 111 +++++++++++++++++++++++++++++++++++------- include/spi_flash.h | 2 + 3 files changed, 122 insertions(+), 20 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 06dee0a..15cad3d 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -27,7 +27,9 @@ enum spi_nor_option_flags { };
#define SPI_FLASH_3B_ADDR_LEN 3 -#define SPI_FLASH_CMD_LEN (1 + SPI_FLASH_3B_ADDR_LEN) +#define SPI_FLASH_4B_ADDR_LEN 4 +#define SPI_FLASH_MAX_ADDR_WIDTH 4 +#define SPI_FLASH_CMD_LEN (1 + SPI_FLASH_4B_ADDR_LEN) #define SPI_FLASH_16MB_BOUN 0x1000000
/* CFI Manufacture ID's */ @@ -57,13 +59,30 @@ enum spi_nor_option_flags { #define CMD_READ_DUAL_IO_FAST 0xbb #define CMD_READ_QUAD_OUTPUT_FAST 0x6b #define CMD_READ_QUAD_IO_FAST 0xeb + +/* 4B READ commands */ +#define CMD_READ_ARRAY_SLOW_4B 0x13 +#define CMD_READ_ARRAY_FAST_4B 0x0c +#define CMD_READ_DUAL_OUTPUT_FAST_4B 0x3c +#define CMD_READ_DUAL_IO_FAST_4B 0xbc +#define CMD_READ_QUAD_OUTPUT_FAST_4B 0x6c +#define CMD_READ_QUAD_IO_FAST_4B 0xec + +/* 4B Write commands */ +#define CMD_PAGE_PROGRAM_4B 0x12 + +/* 4B Erase commands */ +#define CMD_ERASE_4K_4B 0x21 +#define CMD_ERASE_CHIP_4B 0x5c +#define CMD_ERASE_64K_4B 0xdc + #define CMD_READ_ID 0x9f #define CMD_READ_STATUS 0x05 #define CMD_READ_STATUS1 0x35 #define CMD_READ_CONFIG 0x35 #define CMD_FLAG_STATUS 0x70 -#define CMD_EN4B 0xB7 -#define CMD_EX4B 0xE9 +#define CMD_EN4B 0xB7 +#define CMD_EX4B 0xE9
/* Bank addr access commands */ #ifdef CONFIG_SPI_FLASH_BAR @@ -133,6 +152,10 @@ struct spi_flash_info { #define RD_DUAL BIT(5) /* use Dual Read */ #define RD_QUADIO BIT(6) /* use Quad IO Read */ #define RD_DUALIO BIT(7) /* use Dual IO Read */ +#define OPCODES_4B BIT(8) /* + * Use dedicated 4byte address op codes + * to support memory size above 128Mib. + */ #define RD_FULL (RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO) };
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 7581622..f385221 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -22,12 +22,13 @@
DECLARE_GLOBAL_DATA_PTR;
-static void spi_flash_addr(u32 addr, u8 *cmd) +static void spi_flash_addr(struct spi_flash *flash, u32 addr, u8 *cmd) { /* cmd[0] is actual command */ - cmd[1] = addr >> 16; - cmd[2] = addr >> 8; - cmd[3] = addr >> 0; + cmd[1] = addr >> (flash->addr_width * 8 - 8); + cmd[2] = addr >> (flash->addr_width * 8 - 16); + cmd[3] = addr >> (flash->addr_width * 8 - 24); + cmd[4] = addr >> (flash->addr_width * 8 - 32); }
static int read_sr(struct spi_flash *flash, u8 *rs) @@ -74,6 +75,64 @@ static int write_sr(struct spi_flash *flash, u8 ws) return 0; }
+static u8 spi_flash_convert_opcode(u8 opcode, const u8 table[][2], size_t size) +{ + size_t i; + + for (i = 0; i < size; i++) + if (table[i][0] == opcode) + return table[i][1]; + + /* No conversion found, keep input op code. */ + return opcode; +} + +static inline u8 spi_flash_convert_3to4_read(u8 opcode) +{ + static const u8 spi_flash_3to4_read[][2] = { + { CMD_READ_ARRAY_SLOW, CMD_READ_ARRAY_SLOW_4B }, + { CMD_READ_ARRAY_FAST, CMD_READ_ARRAY_FAST_4B }, + { CMD_READ_DUAL_OUTPUT_FAST, CMD_READ_DUAL_OUTPUT_FAST_4B }, + { CMD_READ_DUAL_IO_FAST, CMD_READ_DUAL_IO_FAST_4B }, + { CMD_READ_QUAD_OUTPUT_FAST, CMD_READ_QUAD_OUTPUT_FAST_4B }, + { CMD_READ_QUAD_IO_FAST, CMD_READ_QUAD_IO_FAST_4B }, + + }; + + return spi_flash_convert_opcode(opcode, spi_flash_3to4_read, + ARRAY_SIZE(spi_flash_3to4_read)); +} + +static inline u8 spi_flash_convert_3to4_program(u8 opcode) +{ + static const u8 spi_flash_3to4_program[][2] = { + { CMD_PAGE_PROGRAM, CMD_PAGE_PROGRAM_4B }, + }; + + return spi_flash_convert_opcode(opcode, spi_flash_3to4_program, + ARRAY_SIZE(spi_flash_3to4_program)); +} + +static inline u8 spi_flash_convert_3to4_erase(u8 opcode) +{ + static const u8 spi_flash_3to4_erase[][2] = { + { CMD_ERASE_4K, CMD_ERASE_4K_4B }, + { CMD_ERASE_CHIP, CMD_ERASE_CHIP_4B }, + { CMD_ERASE_64K, CMD_ERASE_64K_4B }, + }; + + return spi_flash_convert_opcode(opcode, spi_flash_3to4_erase, + ARRAY_SIZE(spi_flash_3to4_erase)); +} + +static void spi_flash_set_4byte_opcodes(struct spi_flash *flash, + const struct spi_flash_info *info) +{ + flash->read_cmd = spi_flash_convert_3to4_read(flash->read_cmd); + flash->write_cmd = spi_flash_convert_3to4_program(flash->write_cmd); + flash->erase_cmd = spi_flash_convert_3to4_erase(flash->erase_cmd); +} + #if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) static int read_cr(struct spi_flash *flash, u8 *rc) { @@ -364,7 +423,7 @@ int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) { u32 erase_size, erase_addr; - u8 cmd[SPI_FLASH_CMD_LEN]; + u8 cmd[SPI_FLASH_CMD_LEN], cmdsz; int ret = -1;
erase_size = flash->erase_size; @@ -381,6 +440,8 @@ int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) } }
+ cmdsz = 1 + flash->addr_width; + cmd[0] = flash->erase_cmd; while (len) { erase_addr = offset; @@ -394,12 +455,12 @@ int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) if (ret < 0) return ret; #endif - spi_flash_addr(erase_addr, cmd); + spi_flash_addr(flash, erase_addr, cmd);
debug("SF: erase %2x %2x %2x %2x (%x)\n", cmd[0], cmd[1], cmd[2], cmd[3], erase_addr);
- ret = spi_flash_write_common(flash, cmd, sizeof(cmd), NULL, 0); + ret = spi_flash_write_common(flash, cmd, cmdsz, NULL, 0); if (ret < 0) { debug("SF: erase failed\n"); break; @@ -423,7 +484,7 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, unsigned long byte_addr, page_size; u32 write_addr; size_t chunk_len, actual; - u8 cmd[SPI_FLASH_CMD_LEN]; + u8 cmd[SPI_FLASH_CMD_LEN], cmdsz; int ret = -1;
page_size = flash->page_size; @@ -436,6 +497,8 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, } }
+ cmdsz = 1 + flash->addr_width; + cmd[0] = flash->write_cmd; for (actual = 0; actual < len; actual += chunk_len) { write_addr = offset; @@ -456,13 +519,13 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, chunk_len = min(chunk_len, (size_t)spi->max_write_size);
- spi_flash_addr(write_addr, cmd); + spi_flash_addr(flash, write_addr, cmd);
debug("SF: 0x%p => cmd = { 0x%02x 0x%02x%02x%02x } chunk_len = %zu\n", buf + actual, cmd[0], cmd[1], cmd[2], cmd[3], chunk_len);
- ret = spi_flash_write_common(flash, cmd, sizeof(cmd), - buf + actual, chunk_len); + ret = spi_flash_write_common(flash, cmd, cmdsz, + buf + actual, chunk_len); if (ret < 0) { debug("SF: write failed\n"); break; @@ -537,7 +600,7 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, return 0; }
- cmdsz = SPI_FLASH_CMD_LEN + flash->dummy_byte; + cmdsz = 1 + flash->addr_width + flash->dummy_byte; cmd = calloc(1, cmdsz); if (!cmd) { debug("SF: Failed to allocate cmd\n"); @@ -565,7 +628,7 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, else read_len = remain_len;
- spi_flash_addr(read_addr, cmd); + spi_flash_addr(flash, read_addr, cmd);
ret = spi_flash_read_common(flash, cmd, cmdsz, data, read_len); if (ret < 0) { @@ -1172,10 +1235,6 @@ int spi_flash_scan(struct spi_flash *flash) flash->flags |= SNOR_F_USE_FSR; #endif
- /* disable 4-byte addressing if the device exceeds 16MiB */ - if (flash->size > SPI_FLASH_16MB_BOUN) - set_4byte(flash, info, 0); - /* Configure the BAR - discover bank cmds and read current bank */ #ifdef CONFIG_SPI_FLASH_BAR ret = read_bar(flash, info); @@ -1211,5 +1270,23 @@ int spi_flash_scan(struct spi_flash *flash) } #endif
+ flash->addr_width = SPI_FLASH_3B_ADDR_LEN; + + if (flash->size > SPI_FLASH_16MB_BOUN) { + /* enable 4-byte addressing if the device exceeds 16MiB */ + flash->addr_width = SPI_FLASH_4B_ADDR_LEN; + if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_SPANSION || + info->flags & OPCODES_4B) + spi_flash_set_4byte_opcodes(flash, info); + else + set_4byte(flash, info, 1); + } + + if (flash->addr_width > SPI_FLASH_MAX_ADDR_WIDTH) { + dev_err(dev, "address width is too large: %u\n", + flash->addr_width); + return -EINVAL; + } + return 0; } diff --git a/include/spi_flash.h b/include/spi_flash.h index be2fe3f..5a91671 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -48,6 +48,7 @@ struct spi_slave; * @read_cmd: Read cmd - Array Fast, Extn read and quad read. * @write_cmd: Write cmd - page and quad program. * @dummy_byte: Dummy cycles for read operation. + * @addr_width: number of address bytes * @memory_map: Address of read-only SPI flash access * @flash_lock: lock a region of the SPI Flash * @flash_unlock: unlock a region of the SPI Flash @@ -84,6 +85,7 @@ struct spi_flash { u8 write_cmd; u8 dummy_byte;
+ u8 addr_width; void *memory_map;
int (*flash_lock)(struct spi_flash *flash, u32 ofs, size_t len);
This patch adds support to the JESD216 rev B standard and parses the SFDP tables to dynamically initialize the 'struct spi_nor_flash_parameter'.
It has been ported from Linux commit "mtd: spi-nor: parse Serial Flash Discoverable Parameters (SFDP) tables". It Also ports all modifications done on top of the mentioned commit.
This feature is enabled by defining FLASH_SFDP in spi_flash_info's flag field.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com CC: Cyrille Pitchen cyrille.pitchen@wedev4u.fr CC: Marek Vasut marek.vasut@gmail.com --- Changes for v2: Incorporated 'Cyrille Pitchen's comments - Fix typos in comments - corrected flash->dummy_byte value in spi_flash_read_sfdp - updated flash->dummy_byte calculation logic for READ commands - Used SPI_TX_QUAD, SPI_TX_DUAL condition check for x-4-4 and x-2-2 - Added fallback mechanism if SFDP read fails
drivers/mtd/spi/sf_internal.h | 204 ++++++++++++++++++++ drivers/mtd/spi/spi_flash.c | 429 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 633 insertions(+)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 15cad3d..eb606fa 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -12,6 +12,7 @@
#include <linux/types.h> #include <linux/compiler.h> +#include <linux/sizes.h>
/* Dual SPI flash memories - see SPI_COMM_DUAL_... */ enum spi_dual_flash { @@ -83,6 +84,7 @@ enum spi_nor_option_flags { #define CMD_FLAG_STATUS 0x70 #define CMD_EN4B 0xB7 #define CMD_EX4B 0xE9 +#define CMD_READ_SFDP 0x5a
/* Bank addr access commands */ #ifdef CONFIG_SPI_FLASH_BAR @@ -156,9 +158,211 @@ struct spi_flash_info { * Use dedicated 4byte address op codes * to support memory size above 128Mib. */ +#define FLASH_SFDP BIT(9) /* Parse SFDP tables */ #define RD_FULL (RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO) };
+struct sfdp_parameter_header { + u8 id_lsb; + u8 minor; + u8 major; + u8 length; /* in double words */ + u8 parameter_table_pointer[3]; /* byte address */ + u8 id_msb; +}; + +#define SFDP_PARAM_HEADER_ID(p) (((p)->id_msb << 8) | (p)->id_lsb) +#define SFDP_PARAM_HEADER_PTP(p) \ + (((p)->parameter_table_pointer[2] << 16) | \ + ((p)->parameter_table_pointer[1] << 8) | \ + ((p)->parameter_table_pointer[0] << 0)) + +#define SFDP_BFPT_ID 0xff00 /* Basic Flash Parameter Table */ +#define SFDP_SECTOR_MAP_ID 0xff81 /* Sector Map Table */ + +#define SFDP_SIGNATURE 0x50444653U +#define SFDP_JESD216_MAJOR 1 +#define SFDP_JESD216_MINOR 0 +#define SFDP_JESD216A_MINOR 5 +#define SFDP_JESD216B_MINOR 6 + +struct sfdp_header { + u32 signature; /* Ox50444653U <=> "SFDP" */ + u8 minor; + u8 major; + u8 nph; /* 0-base number of parameter headers */ + u8 unused; + + /* Basic Flash Parameter Table. */ + struct sfdp_parameter_header bfpt_header; +}; + +/* Basic Flash Parameter Table */ + +/* + * JESD216 rev B defines a Basic Flash Parameter Table of 16 DWORDs. + * They are indexed from 1 but C arrays are indexed from 0. + */ +#define BFPT_DWORD(i) ((i) - 1) +#define BFPT_DWORD_MAX 16 + +/* The first version of JESB216 defined only 9 DWORDs. */ +#define BFPT_DWORD_MAX_JESD216 9 + +/* 1st DWORD. */ +#define BFPT_DWORD1_FAST_READ_1_1_2 BIT(16) +#define BFPT_DWORD1_ADDRESS_BYTES_MASK GENMASK(18, 17) +#define BFPT_DWORD1_ADDRESS_BYTES_3_ONLY (0x0UL << 17) +#define BFPT_DWORD1_ADDRESS_BYTES_3_OR_4 (0x1UL << 17) +#define BFPT_DWORD1_ADDRESS_BYTES_4_ONLY (0x2UL << 17) +#define BFPT_DWORD1_DTR BIT(19) +#define BFPT_DWORD1_FAST_READ_1_2_2 BIT(20) +#define BFPT_DWORD1_FAST_READ_1_4_4 BIT(21) +#define BFPT_DWORD1_FAST_READ_1_1_4 BIT(22) + +/* 5th DWORD. */ +#define BFPT_DWORD5_FAST_READ_2_2_2 BIT(0) +#define BFPT_DWORD5_FAST_READ_4_4_4 BIT(4) + +/* 11th DWORD. */ +#define BFPT_DWORD11_PAGE_SIZE_SHIFT 4 +#define BFPT_DWORD11_PAGE_SIZE_MASK GENMASK(7, 4) + +/* 15th DWORD. */ + +/* + * (from JESD216 rev B) + * Quad Enable Requirements (QER): + * - 000b: Device does not have a QE bit. Device detects 1-1-4 and 1-4-4 + * reads based on instruction. DQ3/HOLD# functions are hold during + * instruction phase. + * - 001b: QE is bit 1 of status register 2. It is set via Write Status with + * two data bytes where bit 1 of the second byte is one. + * [...] + * Writing only one byte to the status register has the side-effect of + * clearing status register 2, including the QE bit. The 100b code is + * used if writing one byte to the status register does not modify + * status register 2. + * - 010b: QE is bit 6 of status register 1. It is set via Write Status with + * one data byte where bit 6 is one. + * [...] + * - 011b: QE is bit 7 of status register 2. It is set via Write status + * register 2 instruction 3Eh with one data byte where bit 7 is one. + * [...] + * The status register 2 is read using instruction 3Fh. + * - 100b: QE is bit 1 of status register 2. It is set via Write Status with + * two data bytes where bit 1 of the second byte is one. + * [...] + * In contrast to the 001b code, writing one byte to the status + * register does not modify status register 2. + * - 101b: QE is bit 1 of status register 2. Status register 1 is read using + * Read Status instruction 05h. Status register2 is read using + * instruction 35h. QE is set via Writ Status instruction 01h with + * two data bytes where bit 1 of the second byte is one. + * [...] + */ +#define BFPT_DWORD15_QER_MASK GENMASK(22, 20) +#define BFPT_DWORD15_QER_NONE (0x0UL << 20) /* Micron */ +#define BFPT_DWORD15_QER_SR2_BIT1_BUGGY (0x1UL << 20) +#define BFPT_DWORD15_QER_SR1_BIT6 (0x2UL << 20) /* Macronix */ +#define BFPT_DWORD15_QER_SR2_BIT7 (0x3UL << 20) +#define BFPT_DWORD15_QER_SR2_BIT1_NO_RD (0x4UL << 20) +#define BFPT_DWORD15_QER_SR2_BIT1 (0x5UL << 20) /* Spansion */ + +struct sfdp_bfpt { + u32 dwords[BFPT_DWORD_MAX]; +}; + +/* Fast Read settings. */ + +struct sfdp_bfpt_read { + /* + * The <supported_bit> bit in <supported_dword> BFPT DWORD tells us + * whether the Fast Read x-y-z command is supported. + */ + u32 supported_dword; + u32 supported_bit; + + /* + * The half-word at offset <settings_dword> in <setting_dword> BFPT + * DWORD encodes the op code, the number of mode clocks and the number + * of wait states to be used by Fast Read x-y-z command. + */ + u32 settings_dword; + u32 settings_shift; + + /* The SPI Read x-y-z command. */ + u8 read_cmd; + +}; + +static const struct sfdp_bfpt_read sfdp_bfpt_reads[] = { + /* Fast Read 1-1-2 */ + { + BFPT_DWORD(1), BIT(16), /* Supported bit */ + BFPT_DWORD(4), 0, /* Settings */ + CMD_READ_DUAL_OUTPUT_FAST, + }, + + /* Fast Read 1-2-2 */ + { + BFPT_DWORD(1), BIT(20), /* Supported bit */ + BFPT_DWORD(4), 16, /* Settings */ + CMD_READ_DUAL_IO_FAST, + }, + + /* Fast Read 2-2-2 */ + { + BFPT_DWORD(5), BIT(0), /* Supported bit */ + BFPT_DWORD(6), 16, /* Settings */ + 0xFF, /* Not supported cmd */ + }, + + /* Fast Read 1-1-4 */ + { + BFPT_DWORD(1), BIT(22), /* Supported bit */ + BFPT_DWORD(3), 16, /* Settings */ + CMD_READ_QUAD_OUTPUT_FAST, + }, + + /* Fast Read 1-4-4 */ + { + BFPT_DWORD(1), BIT(21), /* Supported bit */ + BFPT_DWORD(3), 0, /* Settings */ + CMD_READ_QUAD_IO_FAST, + }, + + /* Fast Read 4-4-4 */ + { + BFPT_DWORD(5), BIT(4), /* Supported bit */ + BFPT_DWORD(7), 16, /* Settings */ + 0xFF, /* Not supported cmd */ + }, +}; + +struct sfdp_bfpt_erase { + /* + * The half-word at offset <shift> in DWORD <dword> encodes the + * op code and erase sector size to be used by Sector Erase commands. + */ + u32 dword; + u32 shift; +}; + +static const struct sfdp_bfpt_erase sfdp_bfpt_erases[] = { + /* Erase Type 1 in DWORD8 bits[15:0] */ + {BFPT_DWORD(8), 0}, + + /* Erase Type 2 in DWORD8 bits[31:16] */ + {BFPT_DWORD(8), 16}, + + /* Erase Type 3 in DWORD9 bits[15:0] */ + {BFPT_DWORD(9), 0}, + + /* Erase Type 4 in DWORD9 bits[31:16] */ + {BFPT_DWORD(9), 16}, +}; + extern const struct spi_flash_info spi_flash_ids[];
/* Send a single-byte command to the device and read the response */ diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index f385221..68d715f 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1082,6 +1082,426 @@ int spi_flash_decode_fdt(struct spi_flash *flash) } #endif /* CONFIG_IS_ENABLED(OF_CONTROL) */
+/* + * Serial Flash Discoverable Parameters (SFDP) parsing. + */ + +/** + * spi_flash_read_sfdp() - read Serial Flash Discoverable Parameters. + * @flash: pointer to a 'struct spi_flash' + * @addr: offset in the SFDP area to start reading data from + * @len: number of bytes to read + * @buf: buffer where the SFDP data are copied into (dma-safe memory) + * + * Whatever the actual numbers of bytes for address and dummy cycles are + * for (Fast) Read commands, the Read SFDP (5Ah) instruction is always + * followed by a 3-byte address and 8 dummy clock cycles. + * + * Return: 0 on success, -errno otherwise. + */ +static int spi_flash_read_sfdp(struct spi_flash *flash, u32 addr, + size_t len, void *buf) +{ + u8 addr_width, read_cmd, dummy_byte; + int ret; + + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: Unable to claim SPI bus\n"); + return ret; + } + + read_cmd = flash->read_cmd; + addr_width = flash->addr_width; + dummy_byte = flash->dummy_byte; + + flash->read_cmd = CMD_READ_SFDP; + flash->addr_width = 3; + flash->dummy_byte = 1; + + ret = spi_flash_cmd_read_ops(flash, addr, len, (u8 *)buf); + if (ret < 0) + goto read_err; + ret = 0; + +read_err: + flash->read_cmd = read_cmd; + flash->addr_width = addr_width; + flash->dummy_byte = dummy_byte; + + spi_release_bus(flash->spi); + return ret; +} + +/** + * spi_flash_read_sfdp_dma_unsafe() - read Serial Flash Discoverable Parameters. + * @flash: pointer to a 'struct spi_flash' + * @addr: offset in the SFDP area to start reading data from + * @len: number of bytes to read + * @buf: buffer where the SFDP data are copied into + * + * Wrap spi_flash_read_sfdp() using a kmalloc'ed bounce buffer as @buf is now + * not guaranteed to be dma-safe. + * + * Return: -ENOMEM if kmalloc() fails, the return code of spi_flash_read_sfdp() + * otherwise. + */ +static int spi_flash_read_sfdp_dma_unsafe(struct spi_flash *flash, u32 addr, + size_t len, void *buf) +{ + void *dma_safe_buf; + int ret; + + dma_safe_buf = kmalloc(len, GFP_KERNEL); + if (!dma_safe_buf) + return -ENOMEM; + + ret = spi_flash_read_sfdp(flash, addr, len, dma_safe_buf); + memcpy(buf, dma_safe_buf, len); + kfree(dma_safe_buf); + + return ret; +} + +/** + * spi_flash_parse_bfpt() - read and parse the Basic Flash Parameter Table. + * @flash: pointer to a 'struct spi_flash' + * @info: pointer to a 'struct spi_flash_info' + * @bfpt_header: pointer to the 'struct sfdp_parameter_header' describing + * the Basic Flash Parameter Table length and version + * + * The Basic Flash Parameter Table is the main and only mandatory table as + * defined by the SFDP (JESD216) specification. + * It provides us with the total size (memory density) of the data array and + * the number of address bytes for Fast Read, Page Program and Sector Erase + * commands. + * For Fast READ commands, it also gives the number of mode clock cycles and + * wait states (regrouped in the number of dummy clock cycles) for each + * supported instruction op code. + * For Page Program, the page size is now available since JESD216 rev A, however + * the supported instruction op codes are still not provided. + * For Sector Erase commands, this table stores the supported instruction op + * codes and the associated sector sizes. + * Finally, the Quad Enable Requirements (QER) are also available since JESD216 + * rev A. The QER bits encode the manufacturer dependent procedure to be + * executed to set the Quad Enable (QE) bit in some internal register of the + * Quad SPI memory. Indeed the QE bit, when it exists, must be set before + * sending any Quad SPI command to the memory. Actually, setting the QE bit + * tells the memory to reassign its WP# and HOLD#/RESET# pins to functions IO2 + * and IO3 hence enabling 4 (Quad) I/O lines. + * + * Return: 0 on success, -errno otherwise. + */ +static int spi_flash_parse_bfpt(struct spi_flash *flash, + const struct sfdp_parameter_header *bfpt_header) +{ + struct spi_slave *spi = flash->spi; + struct sfdp_bfpt bfpt; + size_t len; + int i, err; + u32 addr; + u16 half; + + /* JESD216 Basic Flash Parameter Table length is at least 9 DWORDs. */ + if (bfpt_header->length < BFPT_DWORD_MAX_JESD216) + return -EINVAL; + + /* Read the Basic Flash Parameter Table. */ + len = min_t(size_t, sizeof(bfpt), + bfpt_header->length * sizeof(u32)); + addr = SFDP_PARAM_HEADER_PTP(bfpt_header); + memset(&bfpt, 0, sizeof(bfpt)); + err = spi_flash_read_sfdp_dma_unsafe(flash, addr, len, &bfpt); + if (err < 0) + return err; + + /* Fix endianness of the BFPT DWORDs. */ + for (i = 0; i < BFPT_DWORD_MAX; i++) + bfpt.dwords[i] = le32_to_cpu(bfpt.dwords[i]); + + /* Number of address bytes. */ + switch (bfpt.dwords[BFPT_DWORD(1)] & BFPT_DWORD1_ADDRESS_BYTES_MASK) { + case BFPT_DWORD1_ADDRESS_BYTES_3_ONLY: + flash->addr_width = 3; + break; + + case BFPT_DWORD1_ADDRESS_BYTES_4_ONLY: + flash->addr_width = 4; + break; + + case BFPT_DWORD1_ADDRESS_BYTES_3_OR_4: + flash->addr_width = 3; + break; + + default: /* Reserved */ + break; + } + + /* Flash Memory Density (in bits). */ + flash->size = bfpt.dwords[BFPT_DWORD(2)]; + if (flash->size & BIT(31)) { + flash->size &= ~BIT(31); + + /* + * Prevent overflows on params->size. Anyway, a NOR of 2^64 + * bits is unlikely to exist so this error probably means + * the BFPT we are reading is corrupted/wrong. + */ + if (flash->size > 63) + return -EINVAL; + + flash->size = 1ULL << flash->size; + } else { + flash->size++; + } + flash->size >>= 3; /* Convert to bytes. */ + flash->size <<= flash->shift; + + flash->read_cmd = CMD_READ_ARRAY_FAST; + + /* Fast Read settings. */ + for (i = 0; i < ARRAY_SIZE(sfdp_bfpt_reads); i++) { + const struct sfdp_bfpt_read *rd = &sfdp_bfpt_reads[i]; + u32 mode_dummy_cycle; + + if (!(bfpt.dwords[rd->supported_dword] & rd->supported_bit)) + continue; + + half = bfpt.dwords[rd->settings_dword] >> rd->settings_shift; + mode_dummy_cycle = ((half >> 5) & 0x07) + ((half >> 0) & 0x1f); + + switch (rd->read_cmd) { + case CMD_READ_QUAD_IO_FAST: + /* x-4-4 */ + if ((spi->mode & SPI_RX_QUAD) && + (spi->mode & SPI_TX_QUAD)) { + flash->read_cmd = rd->read_cmd; + flash->dummy_byte = (mode_dummy_cycle * 4) / 8; + } + break; + + case CMD_READ_QUAD_OUTPUT_FAST: + /* x-1-4 */ + if (spi->mode & SPI_RX_QUAD) { + flash->read_cmd = rd->read_cmd; + flash->dummy_byte = mode_dummy_cycle / 8; + } + break; + + case CMD_READ_DUAL_IO_FAST: + /* x-2-2 */ + if (((spi->mode & SPI_RX_DUAL) && + (spi->mode & SPI_TX_DUAL)) && + !(spi->mode & (SPI_RX_QUAD | SPI_TX_QUAD))) { + flash->read_cmd = rd->read_cmd; + flash->dummy_byte = (mode_dummy_cycle * 2) / 8; + } + break; + + case CMD_READ_DUAL_OUTPUT_FAST: + /* x-1-2*/ + if ((spi->mode & SPI_RX_DUAL) && + !(spi->mode & (SPI_RX_QUAD | SPI_TX_QUAD))) { + flash->read_cmd = rd->read_cmd; + flash->dummy_byte = mode_dummy_cycle / 8; + } + break; + + default: + debug("read_cmd=0x%x is not supported\n", rd->read_cmd); + break; + } + } + + if (flash->read_cmd == CMD_READ_ARRAY_FAST && spi->mode & SPI_RX_SLOW) + flash->read_cmd = CMD_READ_ARRAY_SLOW; + + /* Sector Erase settings. */ + for (i = 0; i < ARRAY_SIZE(sfdp_bfpt_erases); i++) { + const struct sfdp_bfpt_erase *er = &sfdp_bfpt_erases[i]; + u32 erasesize; + u8 opcode; + + half = bfpt.dwords[er->dword] >> er->shift; + erasesize = half & 0xff; + + /* erasesize == 0 means this Erase Type is not supported. */ + if (!erasesize) + continue; + + erasesize = 1U << erasesize; + opcode = (half >> 8) & 0xff; +#ifdef CONFIG_SPI_FLASH_USE_4K_SECTORS + if (erasesize == SZ_4K) { + flash->erase_cmd = opcode; + flash->erase_size = erasesize; + break; + } +#endif + if (!flash->erase_size || flash->erase_size < erasesize) { + flash->erase_cmd = opcode; + flash->erase_size = erasesize; + } + } + + flash->erase_size <<= flash->shift; + + flash->sector_size = flash->erase_size; + + /* Stop here if not JESD216 rev A or later. */ + if (bfpt_header->length < BFPT_DWORD_MAX) + return 0; + + /* Page size: this field specifies 'N' so the page size = 2^N bytes. */ + flash->page_size = bfpt.dwords[BFPT_DWORD(11)]; + flash->page_size &= BFPT_DWORD11_PAGE_SIZE_MASK; + flash->page_size >>= BFPT_DWORD11_PAGE_SIZE_SHIFT; + flash->page_size = 1U << flash->page_size; + flash->page_size <<= flash->shift; + + if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || + (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || + (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { + /* Quad Enable Requirements. */ + switch (bfpt.dwords[BFPT_DWORD(15)] & BFPT_DWORD15_QER_MASK) { + case BFPT_DWORD15_QER_NONE: + break; + + case BFPT_DWORD15_QER_SR2_BIT1_BUGGY: + case BFPT_DWORD15_QER_SR2_BIT1_NO_RD: + break; + + case BFPT_DWORD15_QER_SR1_BIT6: +#ifdef CONFIG_SPI_FLASH_MACRONIX + macronix_quad_enable(flash); +#endif + break; + + case BFPT_DWORD15_QER_SR2_BIT7: + + break; + + case BFPT_DWORD15_QER_SR2_BIT1: +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) + spansion_quad_enable(flash); +#endif + break; + + default: + return -EINVAL; + } + } + + return 0; +} + +/** + * spi_flash_parse_sfdp() - parse the Serial Flash Discoverable Parameters. + * @flash: pointer to a 'struct spi_flash' + * + * The Serial Flash Discoverable Parameters are described by the JEDEC JESD216 + * specification. This is a standard which tends to supported by almost all + * (Q)SPI memory manufacturers. Those hard-coded tables allow us to learn at + * runtime the main parameters needed to perform basic SPI flash operations such + * as Fast Read, Page Program or Sector Erase commands. + * + * Return: 0 on success, -errno otherwise. + */ +static int spi_flash_parse_sfdp(struct spi_flash *flash) +{ + const struct sfdp_parameter_header *param_header, *bfpt_header; + struct sfdp_parameter_header *param_headers = NULL; + struct sfdp_header header; + size_t psize; + int i, err; + + /* Get the SFDP header. */ + err = spi_flash_read_sfdp_dma_unsafe(flash, 0, sizeof(header), &header); + if (err < 0) + return err; + + /* Check the SFDP header version. */ + if (le32_to_cpu(header.signature) != SFDP_SIGNATURE || + header.major != SFDP_JESD216_MAJOR || + header.minor < SFDP_JESD216_MINOR) + return -EINVAL; + + /* + * Verify that the first and only mandatory parameter header is a + * Basic Flash Parameter Table header as specified in JESD216. + */ + bfpt_header = &header.bfpt_header; + if (SFDP_PARAM_HEADER_ID(bfpt_header) != SFDP_BFPT_ID || + bfpt_header->major != SFDP_JESD216_MAJOR) + return -EINVAL; + + /* + * Allocate memory then read all parameter headers with a single + * Read SFDP command. These parameter headers will actually be parsed + * twice: a first time to get the latest revision of the basic flash + * parameter table, then a second time to handle the supported optional + * tables. + * Hence we read the parameter headers once for all to reduce the + * processing time. Also we use kmalloc() instead of devm_kmalloc() + * because we don't need to keep these parameter headers: the allocated + * memory is always released with kfree() before exiting this function. + */ + if (header.nph) { + psize = header.nph * sizeof(*param_headers); + + param_headers = kmalloc(psize, GFP_KERNEL); + if (!param_headers) + return -ENOMEM; + + err = spi_flash_read_sfdp(flash, sizeof(header), + psize, param_headers); + if (err < 0) { + debug("SF: failed to read SFDP parameter headers\n"); + goto exit; + } + } + + /* + * Check other parameter headers to get the latest revision of + * the basic flash parameter table. + */ + for (i = 0; i < header.nph; i++) { + param_header = ¶m_headers[i]; + + if (SFDP_PARAM_HEADER_ID(param_header) == SFDP_BFPT_ID && + param_header->major == SFDP_JESD216_MAJOR && + (param_header->minor > bfpt_header->minor || + (param_header->minor == bfpt_header->minor && + param_header->length > bfpt_header->length))) + bfpt_header = param_header; + } + + err = spi_flash_parse_bfpt(flash, bfpt_header); + if (err) + goto exit; + + /* Parse other parameter headers. */ + for (i = 0; i < header.nph; i++) { + param_header = ¶m_headers[i]; + + switch (SFDP_PARAM_HEADER_ID(param_header)) { + case SFDP_SECTOR_MAP_ID: + debug("non-uniform erase sector maps not supported\n"); + break; + + default: + break; + } + + if (err) + goto exit; + } + +exit: + kfree(param_headers); + return err; +} + int spi_flash_scan(struct spi_flash *flash) { struct spi_slave *spi = flash->spi; @@ -1272,6 +1692,15 @@ int spi_flash_scan(struct spi_flash *flash)
+ /* Override the parameters with data read from SFDP tables. */ + if ((info->flags & RD_FULL) && (info->flags & FLASH_SFDP)) { + struct spi_flash sfdp_flash; + + memcpy(&sfdp_flash, flash, sizeof(struct spi_flash)); + if (spi_flash_parse_sfdp(flash)) + memcpy(flash, &sfdp_flash, sizeof(struct spi_flash)); + } + if (flash->size > SPI_FLASH_16MB_BOUN) { /* enable 4-byte addressing if the device exceeds 16MiB */ flash->addr_width = SPI_FLASH_4B_ADDR_LEN;
Hi Jagan,
-----Original Message----- From: Prabhakar Kushwaha [mailto:prabhakar.kushwaha@nxp.com] Sent: Thursday, December 21, 2017 5:43 PM To: u-boot@lists.denx.de Cc: jagannadh.teki@gmail.com; Poonam Aggrwal poonam.aggrwal@nxp.com; Suresh Gupta suresh.gupta@nxp.com; marek.vasut@gmail.com; cyrille.pitchen@wedev4u.fr; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [PATCH 0/3][v2] sf: Update spi-nor framework
May I rebase this patch-set on top of your " [PATCH v10 00/27] dm: Generic MTD Subsystem,with SPI-NOR interface" patch-set.
u-boot-spi.git repo will be good place for the rebase. It will help in merging my patch-set.
--pk
On Fri, Dec 29, 2017 at 6:05 PM, Prabhakar Kushwaha prabhakar.kushwaha@nxp.com wrote:
Hi Jagan,
yes with mtd-spinor-working branch
Jagan Teki
Prabhakar Kushwaha
