[U-Boot] [PATCH] net: fix warning not initializing MAC address
following warning message blobs up, when initializing for example DaVinci EMAC:
Net: Ethernet PHY: KSZ8873 @ 0x02 DaVinci-EMACWarning: failed to set MAC address
Introduced from commit
commit 7616e7850804c7c69e0a22c179dfcba9e8f3f587 Author: Simon Glass sjg@chromium.org Date: Mon Jun 13 16:13:10 2011 -0700
Add Ethernet hardware MAC address framework to usbnet
Built-in Ethernet adapters support setting the mac address by means of a ethaddr environment variable for each interface (ethaddr, eth1addr, eth2addr).
This adds similar support to the USB network side, using the names usbethaddr, usbeth1addr, etc. They are kept separate since we don't want a USB device taking the MAC address of a built-in device or vice versa.
Signed-off-by: Simon Glass sjg@chromium.org Tested-by: Eric Bénard eric@eukrea.com
Fix this!
Signed-off-by: Heiko Schocher hs@denx.de cc: Simon Glass sjg@chromium.org --- net/eth.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/net/eth.c b/net/eth.c index a34fe59..2caaf60 100644 --- a/net/eth.c +++ b/net/eth.c @@ -296,7 +296,7 @@ int eth_initialize(bd_t *bis) if (strchr(dev->name, ' ')) puts("\nWarning: eth device name has a space!\n");
- if (eth_write_hwaddr(dev, NULL, eth_number)) + if (eth_write_hwaddr(dev, "eth", eth_number)) puts("Warning: failed to set MAC address\n");
eth_number++;
Fix this!
if (eth_write_hwaddr(dev, "eth", eth_number)) puts("Warning: failed to set MAC address\n"); eth_number++;
-- 1.7.6
We keep fixing this one ;)
http://patchwork.ozlabs.org/patch/112361/
- k
Hello Kumar,
Fix this!
-- 1.7.6
Good! (Sorry for posting another fix, but just back from vacation, and didn;t found time for looking in the u-boot ml ... :-(
Thanks for the hint! bye, Heiko
Heiko Schocher
Kumar Gala
