[U-Boot] Please pull u-boot-x86.git
Hi Tom,
The following changes since commit 9c748e02d99476e6a08d55eadfd8776edffe1e2e:
Merge branch 'next' of git://git.denx.de/u-boot-mips (2013-02-12 19:03:59 -0500)
git://git.denx.de/u-boot-x86.git master
for you to fetch changes up to 96dfc0633aabb4f8fb720d39d9deb29dde08749b:
x86: Remove unused real mode code (2013-02-14 20:19:03 -0800)
---------------------------------------------------------------- Simon Glass (5): x86: Remove eNET boards x86: Remove sc520 cpu x86: Remove unneeded cruft from main Makefile x86: Rename CONFIG_NO_X86_RESET_VECTOR to CONFIG_X86_RESET_VECTOR x86: Remove unused real mode code
Makefile | 6 +- README | 11 +- arch/x86/cpu/Makefile | 4 +- arch/x86/cpu/sc520/Makefile | 58 -------- arch/x86/cpu/sc520/asm-offsets.c | 45 ------ arch/x86/cpu/sc520/sc520.c | 66 --------- arch/x86/cpu/sc520/sc520_car.S | 94 ------------ arch/x86/cpu/sc520/sc520_pci.c | 142 ------------------ arch/x86/cpu/sc520/sc520_reset.c | 40 ----- arch/x86/cpu/sc520/sc520_sdram.c | 479 ------------------------------------------------------------ arch/x86/cpu/sc520/sc520_ssi.c | 93 ------------ arch/x86/cpu/sc520/sc520_timer.c | 89 ------------ arch/x86/cpu/u-boot.lds | 2 +- arch/x86/include/asm/arch-sc520/pci.h | 79 ---------- arch/x86/include/asm/arch-sc520/sc520.h | 372 ----------------------------------------------- arch/x86/include/asm/arch-sc520/ssi.h | 34 ----- arch/x86/include/asm/realmode.h | 36 ----- arch/x86/lib/Makefile | 10 -- arch/x86/lib/bios.S | 569 ----------------------------------------------------------------------- arch/x86/lib/bios.h | 3 - arch/x86/lib/bios_pci.S | 447 -------------------------------------------------------- arch/x86/lib/bios_setup.c | 179 ----------------------- arch/x86/lib/realmode.c | 93 ------------ arch/x86/lib/realmode_switch.S | 232 ----------------------------- arch/x86/lib/video.c | 6 - arch/x86/lib/video_bios.c | 196 ------------------------- arch/x86/lib/zimage.c | 23 --- board/eNET/Makefile | 52 ------- board/eNET/eNET.c | 284 ------------------------------------ board/eNET/eNET_pci.c | 128 ---------------- board/eNET/eNET_start.S | 30 ---- board/eNET/eNET_start16.S | 87 ----------- board/eNET/hardware.h | 36 ----- boards.cfg | 2 - include/configs/coreboot.h | 1 - include/configs/eNET.h | 619 ------------------------------------------------------------------------------ 36 files changed, 7 insertions(+), 4640 deletions(-) delete mode 100644 arch/x86/cpu/sc520/Makefile delete mode 100644 arch/x86/cpu/sc520/asm-offsets.c delete mode 100644 arch/x86/cpu/sc520/sc520.c delete mode 100644 arch/x86/cpu/sc520/sc520_car.S delete mode 100644 arch/x86/cpu/sc520/sc520_pci.c delete mode 100644 arch/x86/cpu/sc520/sc520_reset.c delete mode 100644 arch/x86/cpu/sc520/sc520_sdram.c delete mode 100644 arch/x86/cpu/sc520/sc520_ssi.c delete mode 100644 arch/x86/cpu/sc520/sc520_timer.c delete mode 100644 arch/x86/include/asm/arch-sc520/pci.h delete mode 100644 arch/x86/include/asm/arch-sc520/sc520.h delete mode 100644 arch/x86/include/asm/arch-sc520/ssi.h delete mode 100644 arch/x86/include/asm/realmode.h delete mode 100644 arch/x86/lib/bios.S delete mode 100644 arch/x86/lib/bios_pci.S delete mode 100644 arch/x86/lib/bios_setup.c delete mode 100644 arch/x86/lib/realmode.c delete mode 100644 arch/x86/lib/realmode_switch.S delete mode 100644 arch/x86/lib/video_bios.c delete mode 100644 board/eNET/Makefile delete mode 100644 board/eNET/eNET.c delete mode 100644 board/eNET/eNET_pci.c delete mode 100644 board/eNET/eNET_start.S delete mode 100644 board/eNET/eNET_start16.S delete mode 100644 board/eNET/hardware.h delete mode 100644 include/configs/eNET.h
On Thu, Feb 14, 2013 at 08:39:53PM -0800, Simon Glass wrote:
Hi Tom,
