[U-Boot] [PATCH v3 1/5] arm64: layerscape: Move CONFIG_HAS_FSL_XHCI_USB to Kconfig
Use Kconfig to select QE-HDLC and USB pin-mux.
Signed-off-by: Ran Wang ran.wang_1@nxp.com --- Change in v3: New patch file.
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 7 +++++++ include/configs/ls1012afrdm.h | 4 ---- include/configs/ls1012aqds.h | 4 ---- include/configs/ls1012ardb.h | 4 ---- include/configs/ls1021aiot.h | 4 ---- include/configs/ls1021aqds.h | 4 ---- include/configs/ls1021atwr.h | 4 ---- include/configs/ls1043aqds.h | 3 --- include/configs/ls1043ardb.h | 3 --- include/configs/ls1046aqds.h | 3 --- include/configs/ls1046ardb.h | 3 --- include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - scripts/config_whitelist.txt | 1 - 14 files changed, 7 insertions(+), 39 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 3518d8601d..9fda8a1e83 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -489,3 +489,10 @@ config SYS_MC_RSV_MEM_ALIGN
config SPL_LDSCRIPT default "arch/arm/cpu/armv8/u-boot-spl.lds" if ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A + +config HAS_FSL_XHCI_USB + bool + default y if ARCH_LS1043A || ARCH_LS1046A + help + For some SoC(such as LS1043A and LS1046A), USB and QE-HDLC multi-use + the pins, select it when pin assigned to USB. diff --git a/include/configs/ls1012afrdm.h b/include/configs/ls1012afrdm.h index 6b1ba578e9..2e5af9cc4e 100644 --- a/include/configs/ls1012afrdm.h +++ b/include/configs/ls1012afrdm.h @@ -34,12 +34,8 @@ /* * USB */ -#define CONFIG_HAS_FSL_XHCI_USB - -#ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#endif
#define CONFIG_CMD_MEMINFO #define CONFIG_CMD_MEMTEST diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index b3121d2c21..e0949d0b53 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -119,12 +119,8 @@ #endif
/*XHCI Support - enabled by default*/ -#define CONFIG_HAS_FSL_XHCI_USB - -#ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#endif
/* MMC */ #ifdef CONFIG_MMC diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index e9edcd2bc9..66ff004384 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -22,12 +22,8 @@ /* * USB */ -#define CONFIG_HAS_FSL_XHCI_USB - -#ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#endif
/* * I2C IO expander diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 3fe7b8f44c..2cbea87d95 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -20,12 +20,8 @@ #define CONFIG_SYS_INIT_RAM_SIZE OCRAM_SIZE
/* XHCI Support - enabled by default */ -#define CONFIG_HAS_FSL_XHCI_USB - -#ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#endif
#define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 100000000 diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index f3d3aa2271..0046ded536 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -405,12 +405,8 @@ unsigned long get_board_ddr_clk(void); #endif
/* * Video diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 852ff57fb6..0172c9015d 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -45,12 +45,8 @@ #endif
#define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 100000000 diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 5aadd92efd..607c289d17 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -371,11 +371,8 @@ unsigned long get_board_ddr_clk(void); #endif
/* USB */ -#define CONFIG_HAS_FSL_XHCI_USB -#ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 -#endif
/* * Miscellaneous configurable options diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index ca1d862479..866817d579 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -281,12 +281,9 @@
/* USB */ #ifndef SPL_NO_USB -#define CONFIG_HAS_FSL_XHCI_USB -#ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 #endif -#endif
/* SATA */ #ifndef SPL_NO_SATA diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 9231cca9e9..d47616f2e7 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -137,11 +137,8 @@ unsigned long get_board_ddr_clk(void); #endif
/* SATA */ #define CONFIG_LIBATA diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 7bbd4ada70..32b08d8229 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -211,12 +211,9 @@
/* SATA */ #ifndef SPL_NO_SATA diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index dcd1b0c35c..74a21ab4e1 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -439,7 +439,6 @@ unsigned long get_board_ddr_clk(void); /* * USB */ -#define CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 9e9979e1c7..c368a56657 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -336,7 +336,6 @@ unsigned long get_board_sys_clk(void); /* * USB */ -#define CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index db5d88b4b5..214d333d28 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -887,7 +887,6 @@ CONFIG_HAS_ETH7 CONFIG_HAS_FEC CONFIG_HAS_FSL_DR_USB CONFIG_HAS_FSL_MPH_USB -CONFIG_HAS_FSL_XHCI_USB CONFIG_HAS_POST CONFIG_HCLK_FREQ CONFIG_HDBOOT
use Kconfig to select xhci accordingly.
drivers/usb/host/Kconfig | 6 ++++++ include/configs/ls1012afrdm.h | 1 - include/configs/ls1012aqds.h | 1 - include/configs/ls1012ardb.h | 1 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1046ardb.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - scripts/config_whitelist.txt | 1 - 14 files changed, 6 insertions(+), 13 deletions(-)
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index f797a2568c..70e38a0425 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -71,6 +71,12 @@ config USB_XHCI_DRA7XX_INDEX Select the DRA7XX xHCI USB index. Current supported values: 0, 1.
+config USB_XHCI_FSL + bool "Support for NXPLayerscape on-chip xHCI USB controller" + default y if ARCH_LS1021A || FSL_LSCH3 || FSL_LSCH2 + depends on !SPL_NO_USB + help + Enables support for the on-chip xHCI controller on NXP Layerscape SoCs. endif # USB_XHCI_HCD
config USB_EHCI_HCD diff --git a/include/configs/ls1012afrdm.h b/include/configs/ls1012afrdm.h index 2e5af9cc4e..2e9c619bd5 100644 --- a/include/configs/ls1012afrdm.h +++ b/include/configs/ls1012afrdm.h @@ -34,7 +34,6 @@ /* * USB */ -#define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
#define CONFIG_CMD_MEMINFO diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index e0949d0b53..70bf72c431 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -119,7 +119,6 @@ #endif
/*XHCI Support - enabled by default*/ -#define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
/* MMC */ diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index 66ff004384..110fcc6323 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -22,7 +22,6 @@ /* * USB */ -#define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
/* diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 2cbea87d95..dac4a81e2a 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -20,7 +20,6 @@ #define CONFIG_SYS_INIT_RAM_SIZE OCRAM_SIZE
/* XHCI Support - enabled by default */ -#define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
#define CONFIG_SYS_CLK_FREQ 100000000 diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 0046ded536..8346e3658f 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -405,7 +405,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 0172c9015d..8ccc81642d 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -45,7 +45,6 @@ #endif
#define CONFIG_SYS_CLK_FREQ 100000000 diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 607c289d17..641ffc1400 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -371,7 +371,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* USB */ -#define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 3
/* diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 866817d579..0e02be445a 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -281,7 +281,6 @@
/* USB */ #ifndef SPL_NO_USB -#define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 #endif
diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index d47616f2e7..2f2602f098 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -137,7 +137,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* SATA */ diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 32b08d8229..40ce8ff462 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -211,7 +211,6 @@
diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 74a21ab4e1..5a5debbfc0 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -439,7 +439,6 @@ unsigned long get_board_ddr_clk(void); /* * USB */ -#define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
#include <asm/fsl_secure_boot.h> diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index c368a56657..eef78f21b6 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -336,7 +336,6 @@ unsigned long get_board_sys_clk(void); /* * USB */ -#define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
#undef CONFIG_CMDLINE_EDITING diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 214d333d28..9344729906 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -5066,7 +5066,6 @@ CONFIG_USB_TTY CONFIG_USB_TUSB_OMAP_DMA CONFIG_USB_ULPI_TIMEOUT CONFIG_USB_XHCI_EXYNOS -CONFIG_USB_XHCI_FSL CONFIG_USB_XHCI_KEYSTONE CONFIG_USB_XHCI_OMAP CONFIG_USER_LOWLEVEL_INIT
Hi Ran,
nits: NXP Layerscape
help
- USB
- USB
- USB
- USB
#undef CONFIG_CMDLINE_EDITING diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 214d333d28..9344729906 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -5066,7 +5066,6 @@ CONFIG_USB_TTY CONFIG_USB_TUSB_OMAP_DMA CONFIG_USB_ULPI_TIMEOUT CONFIG_USB_XHCI_EXYNOS -CONFIG_USB_XHCI_FSL CONFIG_USB_XHCI_KEYSTONE CONFIG_USB_XHCI_OMAP CONFIG_USER_LOWLEVEL_INIT --
Other than that, Reviewed-by: Bin Meng bmeng.cn@gmail.com
Regards, Bin
Because COMFIG_DM_USB have been enabled and will not use it anymore.
include/configs/ls1012afrdm.h | 5 ----- include/configs/ls1012aqds.h | 3 --- include/configs/ls1012ardb.h | 4 ---- include/configs/ls1021aiot.h | 3 --- include/configs/ls1021aqds.h | 3 --- include/configs/ls1021atwr.h | 3 --- include/configs/ls1043aqds.h | 3 --- include/configs/ls1043ardb.h | 5 ----- include/configs/ls1046aqds.h | 3 --- include/configs/ls1046ardb.h | 5 ----- include/configs/ls2080aqds.h | 5 ----- include/configs/ls2080ardb.h | 5 ----- 12 files changed, 47 deletions(-)
diff --git a/include/configs/ls1012afrdm.h b/include/configs/ls1012afrdm.h index 2e9c619bd5..efb4c00cd9 100644 --- a/include/configs/ls1012afrdm.h +++ b/include/configs/ls1012afrdm.h @@ -31,11 +31,6 @@ "kernel_load=0x96000000\0" \ "kernel_size=0x2800000\0"
-/* -* USB -*/ -#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 - #define CONFIG_CMD_MEMINFO #define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80000000 diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index 70bf72c431..ffb512db45 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -118,9 +118,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #endif
-/*XHCI Support - enabled by default*/ -#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 - /* MMC */ #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index 110fcc6323..0caa474636 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -19,10 +19,6 @@ #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
/* * I2C IO expander diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index dac4a81e2a..c8eb234670 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -19,9 +19,6 @@ #define CONFIG_SYS_INIT_RAM_ADDR OCRAM_BASE_ADDR #define CONFIG_SYS_INIT_RAM_SIZE OCRAM_SIZE
-/* XHCI Support - enabled by default */ -#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 - #define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 100000000
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 8346e3658f..6669f2f960 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -404,9 +404,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #endif
-/*XHCI Support - enabled by default*/ -#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 - /* * Video */ diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 8ccc81642d..0f20e5e2cc 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -44,9 +44,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #endif
diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 641ffc1400..8cc2abb2b6 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -370,9 +370,6 @@ unsigned long get_board_ddr_clk(void); #endif #endif
-/* USB */ -#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 - /* * Miscellaneous configurable options */ diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 0e02be445a..762ecf1f4c 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -279,11 +279,6 @@ #endif #endif
-/* USB */ -#ifndef SPL_NO_USB -#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 -#endif - /* SATA */ #ifndef SPL_NO_SATA #define CONFIG_LIBATA diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 2f2602f098..3ce66ce6f1 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -136,9 +136,6 @@ unsigned long get_board_ddr_clk(void); #define CFG_LPUART_EN 0x2 #endif
-/* USB */ -#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 - /* SATA */ #define CONFIG_LIBATA #define CONFIG_SCSI_AHCI diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 40ce8ff462..bb27dd058a 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -209,11 +209,6 @@ #endif #endif
-/* USB */ -#ifndef SPL_NO_USB -#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 -#endif - /* SATA */ #ifndef SPL_NO_SATA #define CONFIG_LIBATA diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 5a5debbfc0..497930dd9a 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -436,11 +436,6 @@ unsigned long get_board_ddr_clk(void);
#endif
-/* - * USB - */ -#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 - #include <asm/fsl_secure_boot.h>
#endif /* __LS2_QDS_H */ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index eef78f21b6..48c3a5397f 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -333,11 +333,6 @@ unsigned long get_board_sys_clk(void);
#define CONFIG_MISC_INIT_R
-/* - * USB - */ -#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 - #undef CONFIG_CMDLINE_EDITING #include <config_distro_defaults.h>
Hi Ran,
nits: has been enabled
Regards, Bin
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Amrita Kumari amrita.kumari@nxp.com Signed-off-by: Ran Wang ran.wang_1@nxp.com --- Change in v3: 1.Move HAS_FSL_XHCI_USB and USB_XHCI_FSL define to other patch file.
Change in v2: 1.Adjust USB nodes position in dts to keep them sorted in unit-address. 2.Move macro CONFIG_HAS_FSL_XHCI_USB and CONFIG_USB_XHCI_FSL to Kconfig option. 3.Remove CONFIG_USB_MAX_CONTROLLER_COUNT.
Change in v1: Rebased to ba39608 ARM: DRA72x: Add support for detection of DRA71x SR 2.1
arch/arm/dts/fsl-ls1088a.dtsi | 14 ++++++++++++++ configs/ls1088ardb_qspi_defconfig | 8 ++++++++ include/linux/usb/xhci-fsl.h | 2 +- 3 files changed, 23 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/fsl-ls1088a.dtsi b/arch/arm/dts/fsl-ls1088a.dtsi index d943a9efa3..64b4fcf12b 100644 --- a/arch/arm/dts/fsl-ls1088a.dtsi +++ b/arch/arm/dts/fsl-ls1088a.dtsi @@ -76,6 +76,20 @@ num-cs = <4>; };
+ usb0: usb3@3100000 { + compatible = "fsl,layerscape-dwc3"; + reg = <0x0 0x3100000 0x0 0x10000>; + interrupts = <0 80 0x4>; /* Level high type */ + dr_mode = "host"; + }; + + usb1: usb3@3110000 { + compatible = "fsl,layerscape-dwc3"; + reg = <0x0 0x3110000 0x0 0x10000>; + interrupts = <0 81 0x4>; /* Level high type */ + dr_mode = "host"; + }; + pcie@3400000 { compatible = "fsl,ls-pcie", "snps,dw-pcie"; reg = <0x00 0x03400000 0x0 0x80000 /* dbi registers */ diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 2d5a134261..3034f506e2 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -31,3 +31,11 @@ CONFIG_FSL_DSPI=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_FSL_LS_PPA=y +CONFIG_USB=y +CONFIG_USB_GADGET=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/include/linux/usb/xhci-fsl.h b/include/linux/usb/xhci-fsl.h index bd54089722..a916afb885 100644 --- a/include/linux/usb/xhci-fsl.h +++ b/include/linux/usb/xhci-fsl.h @@ -58,7 +58,7 @@ struct fsl_xhci { #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 #define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0 -#elif defined(CONFIG_ARCH_LS2080A) +#elif defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LS1088A) #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_XHCI_USB2_ADDR #define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0
Signed-off-by: Amrita Kumari amrita.kumari@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Ran Wang ran.wang_1@nxp.com --- Change in v3: - none
Change in v2: Remove macro CONFIG_HAS_FSL_XHCI_USB and CONFIG_USB_XHCI_FSL and CONFIG_USB_MAX_CONTROLLER_COUNT from ls1088aqds.h since Kconfig option has covered. Change in v1: Rebased to ba39608 ARM: DRA72x: Add support for detection of DRA71x SR 2.1
configs/ls1088aqds_qspi_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 4b0d604fa0..a24a6011c9 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -31,3 +31,11 @@ CONFIG_FSL_DSPI=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_FSL_LS_PPA=y +CONFIG_USB=y +CONFIG_USB_GADGET=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_STORAGE=y
Change in v3:
- none
Hi Ran,
bool
How about LS2080? I see there is modification on 2080 related files in this patch.
help
nits: SoCs (
What is multi-use? I think you wanted to say: multiplex
nits: when pin is assigned
- USB
- USB
- I2C IO expander
- Video
- Miscellaneous configurable options
- USB
- USB
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index db5d88b4b5..214d333d28 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -887,7 +887,6 @@ CONFIG_HAS_ETH7 CONFIG_HAS_FEC CONFIG_HAS_FSL_DR_USB CONFIG_HAS_FSL_MPH_USB -CONFIG_HAS_FSL_XHCI_USB CONFIG_HAS_POST CONFIG_HCLK_FREQ CONFIG_HDBOOT --
Regards, Bin
Hi Bin
-----Original Message----- From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Thursday, October 12, 2017 2:01 PM To: Ran Wang ran.wang_1@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Ashish Kumar ashish.kumar@nxp.com; York Sun york.sun@nxp.com; open list u-boot@lists.denx.de Subject: Re: [PATCH v3 1/5] arm64: layerscape: Move CONFIG_HAS_FSL_XHCI_USB to Kconfig
Hi Ran,
bool
Actually HAS_FSL_XHCI_USB is not necessary to LS2080A, previous code is redundant.
help
- multi-use
nits: SoCs (
Yes, will change it
Got it. Will update it and other nits in rest patch files, many thanks.
- USB
- USB
- I2C IO expander
- Video
- Miscellaneous configurable options diff --git
- USB
- USB
Regards, Bin
Bin Meng
Ran Wang
