[U-Boot] [PATCH v2 1/2] eeprom: fix DM_I2C support without CONFIG_SYS_I2C_EEPROM_BUS
The current device model enabled eeprom code only works if CONFIG_SYS_I2C_EEPROM_BUS is set.
This patch makes it work without that define so that the bus number passed to 'eeprom_init' is used.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
Changes in v2: None
cmd/eeprom.c | 23 +++++++++++++++-------- 1 file changed, 15 insertions(+), 8 deletions(-)
diff --git a/cmd/eeprom.c b/cmd/eeprom.c index 6c29b33ba3..9e44960c7d 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -59,6 +59,10 @@ #endif #endif
+#if defined(CONFIG_DM_I2C) +int eeprom_i2c_bus; +#endif + __weak int eeprom_write_enable(unsigned dev_addr, int state) { return 0; @@ -67,7 +71,9 @@ __weak int eeprom_write_enable(unsigned dev_addr, int state) void eeprom_init(int bus) { /* I2C EEPROM */ -#if defined(CONFIG_SYS_I2C) +#if defined(CONFIG_DM_I2C) + eeprom_i2c_bus = bus; +#elif defined(CONFIG_SYS_I2C) if (bus >= 0) i2c_set_bus_num(bus); i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); @@ -124,14 +130,14 @@ static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, { int ret = 0;
-#if defined(CONFIG_DM_I2C) && defined(CONFIG_SYS_I2C_EEPROM_BUS) +#if defined(CONFIG_DM_I2C) struct udevice *dev;
- ret = i2c_get_chip_for_busnum(CONFIG_SYS_I2C_EEPROM_BUS, addr[0], + ret = i2c_get_chip_for_busnum(eeprom_i2c_bus, addr[0], alen - 1, &dev); if (ret) { printf("%s: Cannot find udev for a bus %d\n", __func__, - CONFIG_SYS_I2C_EEPROM_BUS); + eeprom_i2c_bus); return CMD_RET_FAILURE; }
@@ -141,15 +147,12 @@ static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, ret = dm_i2c_write(dev, offset, buffer, len);
#else /* Non DM I2C support - will be removed */ -#if defined(CONFIG_SYS_I2C_EEPROM_BUS) - i2c_set_bus_num(CONFIG_SYS_I2C_EEPROM_BUS); -#endif
if (read) ret = i2c_read(addr[0], offset, alen - 1, buffer, len); else ret = i2c_write(addr[0], offset, alen - 1, buffer, len); -#endif /* CONFIG_DM_I2C && CONFIG_SYS_I2C_EEPROM_BUS */ +#endif /* CONFIG_DM_I2C */ if (ret) ret = CMD_RET_FAILURE;
@@ -164,6 +167,10 @@ static int eeprom_rw(unsigned dev_addr, unsigned offset, uchar *buffer, int rcode = 0; uchar addr[3];
+#if defined(CONFIG_SYS_I2C_EEPROM_BUS) + i2c_set_bus_num(CONFIG_SYS_I2C_EEPROM_BUS); +#endif + while (offset < end) { alen = eeprom_addr(dev_addr, offset, addr);
This reverts commit 65a97e7fcf54feb7c4ebe1aee8a572830af4cf51.
The 'eeprom' command has been converted to work with DM_I2C in a patch submitted around the same time as this commit: commit 0c07a9b4078d ("eeprom: Add device model based I2C support to eeprom command")
Changes in v2: - added patch to fix DM_I2C eeprom code to work without CONFIG_SYS_I2C_EEPROM_BUS
cmd/Kconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 4bcc5c4557..74c5a1a6ed 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -455,7 +455,6 @@ config CRC32_VERIFY
config CMD_EEPROM bool "eeprom - EEPROM subsystem" - depends on !DM_I2C || DM_I2C_COMPAT help (deprecated, needs conversion to driver model) Provides commands to read and write EEPROM (Electrically Erasable
On Tue, 26 Mar 2019 at 06:39, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Changes in v2:
Am 30.03.2019 um 22:18 schrieb Simon Glass:
Changes in v2:
Who will take this series? It's assigned in to Marek in patchwork, but might go via Heiko's i2c tree? Or directly via Tom?
I have sent patches (move socfpga_vining to DM_I2C) that are based on this series...
Thanks, Simon
Changes in v2:
Heiko should at least AB/RB it , then I can take it via socfpga tree to avoid dependency problems.
Hello Marek, Simon,
Am 09.04.2019 um 21:30 schrieb Marek Vasut:
Changes in v2:
Just add to this patches my RB tag, so please pick it up, to prevent dependency problems, thanks!
bye, Heiko
Hello Heiko,
On Wed, Apr 10, 2019 at 7:20 AM Heiko Schocher hs@denx.de wrote:
Hello Marek, Simon,
Changes in v2:
OK, I'll do that.
Thanks, Simon
On 4/10/19 7:20 AM, Heiko Schocher wrote:
Hello Marek, Simon,
Changes in v2:
Then put the RB tag here , so that PW can pick it :)
Hello Marek,
Am 10.04.2019 um 10:05 schrieb Marek Vasut:
Hello Marek, Simon,
Changes in v2:
already done, see:
http://patchwork.ozlabs.org/patch/1065524/#2149315
bye, Heiko
On 4/10/19 10:19 AM, Heiko Schocher wrote:
Hello Marek,
Hello Marek, Simon,
On Tue, 26 Mar 2019 at 06:39, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote: > > This reverts commit 65a97e7fcf54feb7c4ebe1aee8a572830af4cf51. > > The 'eeprom' command has been converted to work with DM_I2C in a > patch > submitted around the same time as this commit: > commit 0c07a9b4078d ("eeprom: Add device model based I2C support to > eeprom command") > > Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com > --- > > Changes in v2: > - added patch to fix DM_I2C eeprom code to work without > CONFIG_SYS_I2C_EEPROM_BUS > > cmd/Kconfig | 1 - > 1 file changed, 1 deletion(-)
already done, see:
Thanks!
Hello Simon,
Am 26.03.2019 um 13:38 schrieb Simon Goldschmidt:
Changes in v2:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Simon,
Changes in v2: None
bye, Heiko
Heiko Schocher
Simon Goldschmidt
