[PATCH] bootstd: Fix relative path use in extlinux bootmeth
Using relative path in a /boot/extlinux/extlinux.conf file fails to load linux kernel.
Using a /boot/extlinux/extlinux.conf file:
LABEL test LINUX ../linux/Image
Result in following error:
Retrieving file: ../linux/Image Skipping test for failure retrieving kernel Boot failed (err=-14)
However, using sysboot cmd successfully load kernel using same file:
sysboot mmc 1:1 any ${scriptaddr} /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/../linux/Image
Fix relative path using bootmeth extlinux by supplying bootfile path instead of subdir path in the call to pxe_setup_ctx, same as done in the sysboot command.
Fixes: 31aefaf89a5b ("bootstd: Add an implementation of distro boot") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- boot/bootmeth_extlinux.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/boot/bootmeth_extlinux.c b/boot/bootmeth_extlinux.c index 24be0760229c..6b2b84003836 100644 --- a/boot/bootmeth_extlinux.c +++ b/boot/bootmeth_extlinux.c @@ -150,7 +150,7 @@ static int extlinux_boot(struct udevice *dev, struct bootflow *bflow) info.dev = dev; info.bflow = bflow; ret = pxe_setup_ctx(&ctx, &cmdtp, extlinux_getfile, &info, true, - bflow->subdir, false); + bflow->fname, false); if (ret) return log_msg_ret("ctx", -EINVAL);
Hi Jonas,
Thank you for the fix.
I'd like to find a way to test some of this internal code, but so far have not had any easy ideas.
-- 2.40.1
Fixes: 31aefaf89a5b ("bootstd: Add an implementation of distro boot") Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Simon Glass sjg@chromium.org
Jonas Karlman
