[U-Boot] Issue with fat16 format
After formatting SD card in fat16 format in windows, we are facing issue. I used git bisect and came to know that this issue is due to 8eafae209c35932d9a6560809c55ee4641534236 commit.
When we use "gparted" utility for formatting SD card in fat16 in linux, it works fine.
Please give your comments on this issue and point out what's causing this issue.
Regards, Vipul Kumar
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
Hello Vipul,
we are facing issue
could you, please, indicate what issue you face. Please, also tell which configuration file you are using.
As you are complaining about Rob's patch I put him and the reviewers of the patch on CC.
Best regards
Heinrich
Hi Heinrich,
-----Original Message----- From: Heinrich Schuchardt [mailto:xypron.debian@gmx.de] Sent: Sunday, June 17, 2018 1:07 AM To: Vipul Kumar vipulk@xilinx.com; u-boot@lists.denx.de Cc: Michal Simek michals@xilinx.com; Siva Durga Prasad Paladugu sivadur@xilinx.com; Rob Clark robdclark@gmail.com; Łukasz Majewski lukma@denx.de; Simon Glass sjg@chromium.org Subject: Re: [U-Boot] Issue with fat16 format
works fine.
issue.
Hello Vipul,
we are facing issue
Configuration file: zynq_zc702_defconfig
Issue: We are using BOOT.BIN and fit image (Kernel image + dtb + rootfs) to boot the board. Board is booting till u-boot successfully but when it goes to read image.ub for further booting, it gives below message:
ERROR: Hit any key to stop autoboot: 0 Copying FIT from SD to RAM... ** Unable to read file image.ub **
After this, I run the fatls command and it seems that it removed both BOOT.BIN and image.ub files.
Zynq> mmc info Device: sdhci@e0100000 Manufacturer ID: 27 OEM: 5048 Name: SD04G Bus Speed: 50000000 Mode : SD High Speed (50MHz) Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 3.7 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes
Zynq> fatls mmc 0:1
0 file(s), 0 dir(s)
Zynq>
Regards, Vipul
Best regards
Heinrich
Hi Heinrich/Rob,
Do we have any update on this issue.
Thanks, Siva
-----Original Message----- From: Vipul Kumar Sent: Monday, June 18, 2018 10:35 AM To: Heinrich Schuchardt xypron.debian@gmx.de; u-boot@lists.denx.de Cc: Michal Simek michals@xilinx.com; Siva Durga Prasad Paladugu sivadur@xilinx.com; Rob Clark robdclark@gmail.com; Łukasz Majewski lukma@denx.de; Simon Glass sjg@chromium.org Subject: RE: [U-Boot] Issue with fat16 format
Hi Heinrich,
Majewski
works fine.
issue.
Hello Vipul,
we are facing issue
Zynq> fatls mmc 0:1
0 file(s), 0 dir(s)
Zynq>
Regards, Vipul
Best regards
Heinrich
Vipul Kumar
