[U-Boot-Users] [PATCH 4/5] 4xx: Update APC405 configuration
- enable esd's auto_update mechanism - support alternative flash layout on rev. 1.8 boards - update default environment - use common CFI flash driver - coding style cleanup
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- include/configs/APC405.h | 346 ++++++++++++++++++++++++++-------------------- 1 files changed, 193 insertions(+), 153 deletions(-)
diff --git a/include/configs/APC405.h b/include/configs/APC405.h index f6495e4..5b04888 100644 --- a/include/configs/APC405.h +++ b/include/configs/APC405.h @@ -1,4 +1,7 @@ /* + * (C) Copyright 2005-2008 + * Matthias Fuchs, esd gmbh germany, matthias.fuchs@esd-electronics.com + * * (C) Copyright 2001-2004 * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com * @@ -24,7 +27,6 @@ /* * board/config.h - configuration options, board specific */ - #ifndef __CONFIG_H #define __CONFIG_H
@@ -32,42 +34,78 @@ * High Level Configuration Options * (easy to change) */ - #define CONFIG_405GP 1 /* This is a PPC405 CPU */ #define CONFIG_4xx 1 /* ...member of PPC4xx family */ #define CONFIG_APCG405 1 /* ...on a APC405 board */
#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ +#define CONFIG_BOARD_EARLY_INIT_R 1 #define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */
#define CONFIG_SYS_CLK_FREQ 33333400 /* external frequency to pll */
#define CONFIG_BOARD_TYPES 1 /* support board types */
-#define CONFIG_BAUDRATE 9600 -#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 1 /* autoboot after 3 seconds */
#undef CONFIG_BOOTARGS -#define CONFIG_RAMBOOTCOMMAND \ - "setenv bootargs root=/dev/ram rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ - "bootm ffc00000 ffca0000" -#define CONFIG_NFSBOOTCOMMAND \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ - "bootm ffc00000" -#define CONFIG_BOOTCOMMAND CONFIG_RAMBOOTCOMMAND + +#define CFG_USB_LOAD_COMMAND "fatload usb 0 200000 pImage;" \ + "fatload usb 0 300000 pImage.initrd" +#define CFG_USB_SELF_COMMAND "usb start;run usb_load;usb stop;" \ + "run ramargs addip addcon usbargs;" \ + "bootm 200000 300000" +#define CFG_USB_ARGS "setenv bootargs $(bootargs) usbboot=1" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hostname=abg405\0" \ + "bd_type=abg405\0" \ + "serial#=AA0000\0" \ + "kernel_addr=fe000000\0" \ + "ramdisk_addr=fe100000\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$(serverip):$(rootpath)\0" \ + "addip=setenv bootargs $(bootargs) " \ + "ip=$(ipaddr):$(serverip):$(gatewayip):$(netmask)" \ + ":$(hostname)::off panic=1\0" \ + "addcon=setenv bootargs $(bootargs) console=ttyS0,$(baudrate)" \ + " $(optargs)\0" \ + "flash_self=run ramargs addip addcon;" \ + "bootm $(kernel_addr) $(ramdisk_addr)\0" \ + "net_nfs=tftp 200000 $(img);run nfsargs addip addcon;" \ + "bootm\0" \ + "rootpath=/tftpboot/abg405/target_root\0" \ + "img=/tftpboot/abg405/pImage\0" \ + "load=tftp 100000 /tftpboot/abg405/u-boot.bin\0" \ + "update=protect off fff80000 ffffffff;era fff80000 ffffffff;" \ + "cp.b 100000 fff80000 80000\0" \ + "ipaddr=10.0.111.111\0" \ + "netmask=255.255.0.0\0" \ + "serverip=10.0.0.190\0" \ + "splashimage=ffe80000\0" \ + "usb_load="CFG_USB_LOAD_COMMAND"\0" \ + "usb_self="CFG_USB_SELF_COMMAND"\0" \ + "usbargs="CFG_USB_ARGS"\0" \ + "" +#define CONFIG_BOOTCOMMAND "run flash_self;run usb_self" + +#define CONFIG_ETHADDR 00:02:27:8e:00:00
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
+#define CONFIG_NET_MULTI 1 +#undef CONFIG_HAS_ETH1 + #define CONFIG_MII 1 /* MII PHY management */ -#define CONFIG_PHY_ADDR 0 /* PHY address */ -#define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ +#define CONFIG_PHY_ADDR 0 /* PHY address */ +#define CONFIG_LXT971_NO_SLEEP 1 +#define CONFIG_RESET_PHY_R 1 /* use reset_phy() */
#define CONFIG_PHY_CLK_FREQ EMAC_STACR_CLK_66MHZ /* 66 MHz OPB clock*/
- /* * BOOTP options */ @@ -76,7 +114,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -93,95 +130,86 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_PING #define CONFIG_CMD_EEPROM +#define CONFIG_CMD_USB +#define CONFIG_CMD_AUTOSCRIPT
#define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION
#define CONFIG_SUPPORT_VFAT
-#undef CONFIG_WATCHDOG /* watchdog disabled */ +#define CONFIG_AUTO_UPDATE 1 /* autoupdate via CF or USB */
-#define CONFIG_RTC_MC146818 /* DS1685 is MC146818 compatible*/ -#define CFG_RTC_REG_BASE_ADDR 0xF0000500 /* RTC Base Address */ +#undef CONFIG_WATCHDOG /* watchdog disabled */
-#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ +#define CONFIG_RTC_MC146818 /* DS1685 is MC146818 compatible*/ +#define CFG_RTC_REG_BASE_ADDR 0xF0000500 /* RTC Base Address */ + +#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */
/* * Miscellaneous configurable options */ -#define CFG_LONGHELP /* undef to save memory */ -#define CFG_PROMPT "=> " /* Monitor Command Prompt */ - -#undef CFG_HUSH_PARSER /* use "hush" command parser */ -#ifdef CFG_HUSH_PARSER -#define CFG_PROMPT_HUSH_PS2 "> " -#endif +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */
#if defined(CONFIG_CMD_KGDB) -#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else -#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ #endif #define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ -#define CFG_MAXARGS 16 /* max number of command args */ -#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */
-#define CFG_DEVICE_NULLDEV 1 /* include nulldev device */ +#define CFG_DEVICE_NULLDEV 1 /* include nulldev device */
-#define CFG_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ +#define CFG_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/
-#define CFG_MEMTEST_START 0x0400000 /* memtest works on */ -#define CFG_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ +#define CFG_MEMTEST_START 0x0400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */
-#if 1 /* test-only */ #define CFG_EXT_SERIAL_CLOCK 14745600 /* use external serial clock */ -#else -#undef CFG_EXT_SERIAL_CLOCK /* no external serial clock used */ -#define CFG_IGNORE_405_UART_ERRATA_59 /* ignore ppc405gp errata #59 */ -#define CFG_BASE_BAUD 691200 -#endif
/* The following table includes the supported baudrates */ #define CFG_BAUDRATE_TABLE \ - { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ + { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ 57600, 115200, 230400, 460800, 921600 }
#define CFG_LOAD_ADDR 0x100000 /* default load address */ #define CFG_EXTBDINFO 1 /* To use extended board_into (bd_t) */
-#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */ +#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */
#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */
/* Only interrupt boot if space is pressed */ /* If a long serial cable is connected but */ /* other end is dead, garbage will be read */ -#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d seconds\n" -#define CONFIG_AUTOBOOT_DELAY_STR "d" +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d seconds\n" +#undef CONFIG_AUTOBOOT_DELAY_STR #define CONFIG_AUTOBOOT_STOP_STR " "
-#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ +#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
-#define CFG_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */ +#define CFG_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */
-/*----------------------------------------------------------------------- +/* * PCI stuff - *----------------------------------------------------------------------- */ -#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ -#define PCI_HOST_FORCE 1 /* configure as pci host */ -#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ +#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ +#define PCI_HOST_FORCE 1 /* configure as pci host */ +#define PCI_HOST_AUTO 2 /* detected via arbiter enable */
-#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_HOST PCI_HOST_FORCE /* select pci host function */ +#define CONFIG_PCI /* include pci support */ +#define CONFIG_PCI_HOST PCI_HOST_FORCE /* select pci host function */ #define CONFIG_PCI_PNP /* do pci plug-and-play */ /* resource configuration */
-#define CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */ - -#define CONFIG_PCI_CONFIG_HOST_BRIDGE 1 /* don't skip host bridge config*/ - +#define CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */ +#define CONFIG_PCI_SKIP_HOST_BRIDGE 1 #define CFG_PCI_SUBSYS_VENDORID 0x12FE /* PCI Vendor ID: esd gmbh */ #define CFG_PCI_SUBSYS_DEVICEID 0x0405 /* PCI Device ID: CPCI-405 */ #define CFG_PCI_CLASSCODE 0x0b20 /* PCI Class Code: Processor/PPC*/ @@ -192,119 +220,123 @@ #define CFG_PCI_PTM2MS 0xffc00001 /* 4MB, enable */ #define CFG_PCI_PTM2PCI 0x04000000 /* Host: use this pci address */
-/*----------------------------------------------------------------------- +/* * IDE/ATA stuff - *----------------------------------------------------------------------- */ -#undef CONFIG_IDE_8xx_DIRECT /* no pcmcia interface required */ -#undef CONFIG_IDE_LED /* no led for ide supported */ -#define CONFIG_IDE_RESET 1 /* reset for ide supported */ +#undef CONFIG_IDE_8xx_DIRECT /* no pcmcia interface required */ +#undef CONFIG_IDE_LED /* no led for ide supported */ +#define CONFIG_IDE_RESET 1 /* reset for ide supported */
-#define CFG_IDE_MAXBUS 1 /* max. 1 IDE busses */ -#define CFG_IDE_MAXDEVICE (CFG_IDE_MAXBUS*1) /* max. 1 drives per IDE bus */ +#define CFG_IDE_MAXBUS 1 /* max. 1 IDE busses */ +#define CFG_IDE_MAXDEVICE (CFG_IDE_MAXBUS) /* max. 1 drives per IDE bus */
-#define CFG_ATA_BASE_ADDR 0xF0100000 -#define CFG_ATA_IDE0_OFFSET 0x0000 +#define CFG_ATA_BASE_ADDR 0xF0100000 +#define CFG_ATA_IDE0_OFFSET 0x0000
-#define CFG_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ -#define CFG_ATA_REG_OFFSET 0x0000 /* Offset for normal register accesses */ -#define CFG_ATA_ALT_OFFSET 0x0000 /* Offset for alternate registers */ +#define CFG_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ +#define CFG_ATA_REG_OFFSET 0x0000 /* Offset for normal register access */ +#define CFG_ATA_ALT_OFFSET 0x0000 /* Offset for alternate registers */
-/*----------------------------------------------------------------------- +/* * Start addresses for the final memory configuration * (Set up by the startup code) * Please note that CFG_SDRAM_BASE _must_ start at 0 */ #define CFG_SDRAM_BASE 0x00000000 #define CFG_MONITOR_BASE 0xFFF80000 -#define CFG_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Monitor */ -#define CFG_MALLOC_LEN (2*1024*1024) /* Reserve 2MB for malloc() */ +#define CFG_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Monitor */ +#define CFG_MALLOC_LEN (2*1024*1024) /* Reserve 2MB for malloc() */
/* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ +#define CFG_BOOTMAPSZ (8 << 20) /* Init. Memory map for Linux */
-/*----------------------------------------------------------------------- +/* * FLASH organization */ -#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CFG_MAX_FLASH_SECT 128 /* max number of sectors on one chip */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#undef CFG_FLASH_PROTECTION /* don't use hardware protection */ -#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ -#define CFG_FLASH_BASE 0xFE000000 /* test-only...*/ -#define CFG_FLASH_INCREMENT 0x01000000 /* test-only */ - -#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ +#ifndef __ASSEMBLY__ +extern int flash_banks; +#endif
-#define CFG_JFFS2_FIRST_BANK 0 /* use for JFFS2 */ -#define CFG_JFFS2_NUM_BANKS 1 /* ! second bank contains u-boot */ +#define CFG_FLASH_BASE 0xFE000000 +#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CFG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CFG_MAX_FLASH_SECT 256 /* max num of sects on one chip */ +#define CFG_MAX_FLASH_BANKS flash_banks /* max num of flash banks */ + /* updated in board_early_init_r */ +#define CFG_MAX_FLASH_BANKS_DETECT 2 +#define CFG_FLASH_QUIET_TEST 1 +#define CFG_FLASH_INCREMENT 0x01000000 +#define CFG_FLASH_PROTECTION 1 /* use hardware protection */ +#define CFG_FLASH_AUTOPROTECT_LIST { \ + {0xfe000000, 0x500000}, \ + {0xffe80000, 0x180000} \ + } +#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +#define CFG_FLASH_BANKS_LIST { \ + CFG_FLASH_BASE, \ + CFG_FLASH_BASE + CFG_FLASH_INCREMENT \ + } +#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
-/*----------------------------------------------------------------------- +/* * Environment Variable setup */ -#define CFG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#define CFG_ENV_OFFSET 0x000 /* environment starts at the beginning of the EEPROM */ -#define CFG_ENV_SIZE 0x800 /* 2048 bytes may be used for env vars*/ - /* total size of a CAT24WC16 is 2048 bytes */ +#define CFG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ +#define CFG_ENV_OFFSET 0x000 /* environment starts at the */ + /* beginning of the EEPROM */ +#define CFG_ENV_SIZE 0x800 /* 2048 bytes may be used for env vars*/ +#define CONFIG_ENV_OVERWRITE 1 /* allow overwriting vendor vars */
-#define CFG_NVRAM_BASE_ADDR 0xF0000500 /* NVRAM base address */ -#define CFG_NVRAM_SIZE 242 /* NVRAM size */ +#define CFG_NVRAM_BASE_ADDR 0xF0000500 /* NVRAM base address */ +#define CFG_NVRAM_SIZE 242 /* NVRAM size */
-/*----------------------------------------------------------------------- +/* * I2C EEPROM (CAT24WC16) for environment */ #define CONFIG_HARD_I2C /* I2c with hardware support */ -#define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CFG_I2C_SPEED 100000 /* I2C speed and slave address */ #define CFG_I2C_SLAVE 0x7F
-#define CFG_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC08 */ -#define CFG_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ +#define CFG_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC08 */ +#define CFG_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ +/* mask of address bits that overflow into the "EEPROM chip address" */ #define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CFG_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ +#define CFG_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ /* 16 byte page write mode using*/ - /* last 4 bits of the address */ -#define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ + /* last 4 bits of the address */ +#define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ #define CFG_EEPROM_PAGE_WRITE_ENABLE
-/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CFG_DCACHE_SIZE 16384 /* For AMCC 405 CPUs, older 405 ppc's */ - /* have only 8kB, 16kB is save here */ -#define CFG_CACHELINE_SIZE 32 /* ... */ -#if defined(CONFIG_CMD_KGDB) -#define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- +/* * External Bus Controller (EBC) Setup */ -#define FLASH0_BA 0xFF000000 /* FLASH 0 Base Address */ -#define FLASH1_BA 0xFE000000 /* FLASH 1 Base Address */ -#define CAN_BA 0xF0000000 /* CAN Base Address */ -#define DUART0_BA 0xF0000400 /* DUART Base Address */ -#define DUART1_BA 0xF0000408 /* DUART Base Address */ -#define RTC_BA 0xF0000500 /* RTC Base Address */ -#define PS2_BA 0xF0000600 /* PS/2 Base Address */ -#define CF_BA 0xF0100000 /* CompactFlash Base Address */ -#define FPGA_BA 0xF0100100 /* FPGA internal Base Address */ -#define FUJI_BA 0xF0100200 /* Fuji internal Base Address */ -#define PCMCIA1_BA 0x20000000 /* PCMCIA Slot 1 Base Address */ -#define PCMCIA2_BA 0x28000000 /* PCMCIA Slot 2 Base Address */ -#define VGA_BA 0xF1000000 /* Epson VGA Base Address */ - -#define CFG_FPGA_BASE_ADDR FPGA_BA /* FPGA internal Base Address */ - -/* Memory Bank 0 (Flash Bank 0) initialization */ +#define FLASH0_BA (CFG_FLASH_BASE + CFG_FLASH_INCREMENT) /* FLASH 0 BA */ +#define FLASH1_BA CFG_FLASH_BASE /* FLASH 1 Base Address */ +#define CAN_BA 0xF0000000 /* CAN Base Address */ +#define DUART0_BA 0xF0000400 /* DUART Base Address */ +#define DUART1_BA 0xF0000408 /* DUART Base Address */ +#define RTC_BA 0xF0000500 /* RTC Base Address */ +#define PS2_BA 0xF0000600 /* PS/2 Base Address */ +#define CF_BA 0xF0100000 /* CompactFlash Base Address */ +#define FPGA_BA 0xF0100100 /* FPGA internal Base Address */ +#define FUJI_BA 0xF0100200 /* Fuji internal Base Address */ +#define PCMCIA1_BA 0x20000000 /* PCMCIA Slot 1 Base Address */ +#define PCMCIA2_BA 0x28000000 /* PCMCIA Slot 2 Base Address */ +#define VGA_BA 0xF1000000 /* Epson VGA Base Address */ + +#define CFG_FPGA_BASE_ADDR FPGA_BA /* FPGA internal Base Address */ + +/* Memory Bank 0 (Flash Bank 0) initialization */ #define CFG_EBC_PB0AP 0x92015480 #define CFG_EBC_PB0CR FLASH0_BA | 0x9A000 /* BAS=0xFF0,BS=16MB,BU=R/W,BW=16bit*/ +#define CFG_EBC_PB0AP_HWREV8 CFG_EBC_PB0AP +#define CFG_EBC_PB0CR_HWREV8 FLASH1_BA | 0xBA000 /* BS=32MB */
-/* Memory Bank 1 (Flash Bank 1) initialization */ +/* Memory Bank 1 (Flash Bank 1) initialization */ #define CFG_EBC_PB1AP 0x92015480 #define CFG_EBC_PB1CR FLASH1_BA | 0x9A000 /* BAS=0xFE0,BS=16MB,BU=R/W,BW=16bit*/
@@ -328,7 +360,7 @@ #define CFG_EBC_PB6AP 0x050007C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ #define CFG_EBC_PB6CR PCMCIA2_BA | 0xFA000 /*BAS=0x280,BS=128MB,BU=R/W,BW=16bit*/
-/*----------------------------------------------------------------------- +/* * FPGA stuff */
@@ -351,48 +383,56 @@ #define CFG_FPGA_INIT 0x00010000 /* FPGA init pin (ppc input) */ #define CFG_FPGA_DONE 0x00008000 /* FPGA done pin (ppc input) */
-/*----------------------------------------------------------------------- +/* * LCD Setup */ +#define CFG_LCD_BIG_MEM (VGA_BA + 0x200000) /* S1D13806 Mem Base */ +#define CFG_LCD_BIG_REG VGA_BA /* S1D13806 Reg Base */
-#define CFG_LCD_BIG_MEM 0xF1200000 /* Epson S1D13806 Mem Base Address */ -#define CFG_LCD_BIG_REG 0xF1000000 /* Epson S1D13806 Reg Base Address */ - -#define CONFIG_LCD_BIG 2 /* Epson S1D13806 used */ +#define CONFIG_LCD_BIG 2 /* Epson S1D13806 used */
/* Image information... */ -#define CONFIG_LCD_USED CONFIG_LCD_BIG -#define CFG_LCD_HEADER_NAME "../common/s1d13806_640_480_16bpp.h" -#define CFG_LCD_LOGO_NAME "logo_640_480_24bpp.c" +#define CONFIG_LCD_USED CONFIG_LCD_BIG
-#define CFG_LCD_MEM CFG_LCD_BIG_MEM -#define CFG_LCD_REG CFG_LCD_BIG_REG +#define CFG_LCD_MEM CFG_LCD_BIG_MEM +#define CFG_LCD_REG CFG_LCD_BIG_REG
#define CFG_VIDEO_LOGO_MAX_SIZE (1 << 20)
-/*----------------------------------------------------------------------- +/* * Definitions for initial stack pointer and data area (in data cache) */
/* use on chip memory ( OCM ) for temperary stack until sdram is tested */ -#define CFG_TEMP_STACK_OCM 1 +#define CFG_TEMP_STACK_OCM 1
/* On Chip Memory location */ #define CFG_OCM_DATA_ADDR 0xF8000000 #define CFG_OCM_DATA_SIZE 0x1000
-#define CFG_INIT_RAM_ADDR CFG_OCM_DATA_ADDR /* inside of SDRAM */ -#define CFG_INIT_RAM_END CFG_OCM_DATA_SIZE /* End of used area in RAM */ -#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) -#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET +#define CFG_INIT_RAM_ADDR CFG_OCM_DATA_ADDR /* inside of SDRAM */ +#define CFG_INIT_RAM_END CFG_OCM_DATA_SIZE /* End of used area in RAM */ +#define CFG_GBL_DATA_SIZE 128 /* reserved bytes for initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET
/* * Internal Definitions * * Boot Flags */ -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */
-#endif /* __CONFIG_H */ +/* + * PCI OHCI controller + */ +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_PCI_OHCI 1 +#define CFG_OHCI_SWAP_REG_ACCESS 1 +#define CFG_USB_OHCI_MAX_ROOT_PORTS 15 +#define CFG_USB_OHCI_SLOT_NAME "ohci_pci" +#define CONFIG_USB_STORAGE 1 +#define CFG_USB_OHCI_BOARD_INIT 1 + +#endif /* __CONFIG_H */
Applied to u-boot-ppc4xx. Thanks.
Best regards, Stefan
Matthias Fuchs
Stefan Roese
