[PATCH 1/1] doc: move README.log to HTML documentation
Convert README.log to reStructuredText and add it to the generated HTML documentation.
Assign doc/develop/logging.rst to the maintainer of LOGGING.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- MAINTAINERS | 1 + doc/README.log | 285 --------------------------------------- doc/develop/index.rst | 1 + doc/develop/logging.rst | 290 ++++++++++++++++++++++++++++++++++++++++ 4 files changed, 292 insertions(+), 285 deletions(-) delete mode 100644 doc/README.log create mode 100644 doc/develop/logging.rst
diff --git a/MAINTAINERS b/MAINTAINERS index 9da0459bf7..e4bf77536a 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -696,6 +696,7 @@ S: Maintained T: git https://gitlab.denx.de/u-boot/u-boot.git F: common/log* F: cmd/log.c +F: doc/develop/logging.rst F: test/log/ F: test/py/tests/test_log.py
diff --git a/doc/README.log b/doc/README.log deleted file mode 100644 index 1057981f45..0000000000 --- a/doc/README.log +++ /dev/null @@ -1,285 +0,0 @@ -Logging in U-Boot -================= - -Introduction ------------- - -U-Boot's internal operation involves many different steps and actions. From -setting up the board to displaying a start-up screen to loading an Operating -System, there are many component parts each with many actions. - -Most of the time this internal detail is not useful. Displaying it on the -console would delay booting (U-Boot's primary purpose) and confuse users. - -But for digging into what is happening in a particular area, or for debugging -a problem it is often useful to see what U-Boot is doing in more detail than -is visible from the basic console output. - -U-Boot's logging feature aims to satisfy this goal for both users and -developers. - - -Logging levels --------------- - -There are a number logging levels available, in increasing order of verbosity: - - LOGL_EMERG - Printed before U-Boot halts - LOGL_ALERT - Indicates action must be taken immediate or U-Boot will crash - LOGL_CRIT - Indicates a critical error that will cause boot failure - LOGL_ERR - Indicates an error that may cause boot failure - LOGL_WARNING - Warning about an unexpected condition - LOGL_NOTE - Important information about progress - LOGL_INFO - Information about normal boot progress - LOGL_DEBUG - Debug information (useful for debugging a driver or subsystem) - LOGL_DEBUG_CONTENT - Debug message showing full message content - LOGL_DEBUG_IO - Debug message showing hardware I/O access - - -Logging category ----------------- - -Logging can come from a wide variety of places within U-Boot. Each log message -has a category which is intended to allow messages to be filtered according to -their source. - -The following main categories are defined: - - LOGC_NONE - Unknown category (e.g. a debug() statement) - UCLASS_... - Related to a particular uclass (e.g. UCLASS_USB) - LOGC_ARCH - Related to architecture-specific code - LOGC_BOARD - Related to board-specific code - LOGC_CORE - Related to core driver-model support - LOGC_DT - Related to device tree control - LOGC_EFI - Related to EFI implementation - - -Enabling logging ----------------- - -The following options are used to enable logging at compile time: - - CONFIG_LOG - Enables the logging system - CONFIG_MAX_LOG_LEVEL - Max log level to build (anything higher is compiled - out) - CONFIG_LOG_CONSOLE - Enable writing log records to the console - -If CONFIG_LOG is not set, then no logging will be available. - -The above have SPL versions also, e.g. CONFIG_SPL_MAX_LOG_LEVEL. - - -Temporary logging within a single file --------------------------------------- - -Sometimes it is useful to turn on logging just in one file. You can use this: - - #define LOG_DEBUG - -to enable building in of all logging statements in a single file. Put it at -the top of the file, before any #includes. - -To actually get U-Boot to output this you need to also set the default logging -level - e.g. set CONFIG_LOG_DEFAULT_LEVEL to 7 (LOGL_DEBUG) or more. Otherwise -debug output is suppressed and will not be generated. - - -Convenience functions ---------------------- - -A number of convenience functions are available to shorten the code needed -for logging: - - log_err(_fmt...) - log_warning(_fmt...) - log_notice(_fmt...) - log_info(_fmt...) - log_debug(_fmt...) - log_content(_fmt...) - log_io(_fmt...) - -With these the log level is implicit in the name. The category is set by -LOG_CATEGORY, which you can only define once per file, above all #includes: - - #define LOG_CATEGORY LOGC_ALLOC - -or - - #define LOG_CATEGORY UCLASS_SPI - -Remember that all uclasses IDs are log categories too. - - -Log commands ------------- - -The 'log' command provides access to several features: - - level - access the default log level - format - access the console log format - rec - output a log record - test - run tests - -Type 'help log' for details. - - -Using DEBUG ------------ - -U-Boot has traditionally used a #define called DEBUG to enable debugging on a -file-by-file basis. The debug() macro compiles to a printf() statement if -DEBUG is enabled, and an empty statement if not. - -With logging enabled, debug() statements are interpreted as logging output -with a level of LOGL_DEBUG and a category of LOGC_NONE. - -The logging facilities are intended to replace DEBUG, but if DEBUG is defined -at the top of a file, then it takes precedence. This means that debug() -statements will result in output to the console and this output will not be -logged. - - -Logging destinations --------------------- - -If logging information goes nowhere then it serves no purpose. U-Boot provides -several possible determinations for logging information, all of which can be -enabled or disabled independently: - - console - goes to stdout - syslog - broadcast RFC 3164 messages to syslog servers on UDP port 514 - -The syslog driver sends the value of environmental variable 'log_hostname' as -HOSTNAME if available. - -Log format ----------- - -You can control the log format using the 'log format' command. The basic -format is: - - LEVEL.category,file.c:123-func() message - -In the above, file.c:123 is the filename where the log record was generated and -func() is the function name. By default ('log format default') only the -function name and message are displayed on the console. You can control which -fields are present, but not the field order. - - -Filters -------- - -Filters are attached to log drivers to control what those drivers emit. Only -records that pass through the filter make it to the driver. - -Filters can be based on several criteria: - - - maximum log level - - in a set of categories - - in a set of files - -If no filters are attached to a driver then a default filter is used, which -limits output to records with a level less than CONFIG_LOG_MAX_LEVEL. - - -Logging statements ------------------- - -The main logging function is: - - log(category, level, format_string, ...) - -Also debug() and error() will generate log records - these use LOG_CATEGORY -as the category, so you should #define this right at the top of the source -file to ensure the category is correct. - -You can also define CONFIG_LOG_ERROR_RETURN to enable the log_ret() macro. This -can be used whenever your function returns an error value: - - return log_ret(uclass_first_device(UCLASS_MMC, &dev)); - -This will write a log record when an error code is detected (a value < 0). This -can make it easier to trace errors that are generated deep in the call stack. - - -Code size ---------- - -Code size impact depends largely on what is enabled. The following numbers are -generated by 'buildman -S' for snow, which is a Thumb-2 board (all units in -bytes): - -This series: adds bss +20.0 data +4.0 rodata +4.0 text +44.0 -CONFIG_LOG: bss -52.0 data +92.0 rodata -635.0 text +1048.0 -CONFIG_LOG_MAX_LEVEL=7: bss +188.0 data +4.0 rodata +49183.0 text +98124.0 - -The last option turns every debug() statement into a logging call, which -bloats the code hugely. The advantage is that it is then possible to enable -all logging within U-Boot. - - -To Do ------ - -There are lots of useful additions that could be made. None of the below is -implemented! If you do one, please add a test in test/py/tests/test_log.py - -Convenience functions to support setting the category: - - log_arch(level, format_string, ...) - category LOGC_ARCH - log_board(level, format_string, ...) - category LOGC_BOARD - log_core(level, format_string, ...) - category LOGC_CORE - log_dt(level, format_string, ...) - category LOGC_DT - -More logging destinations: - - device - goes to a device (e.g. serial) - buffer - recorded in a memory buffer - -Convert debug() statements in the code to log() statements - -Support making printf() emit log statements a L_INFO level - -Convert error() statements in the code to log() statements - -Figure out what to do with BUG(), BUG_ON() and warn_non_spl() - -Figure out what to do with assert() - -Add a way to browse log records - -Add a way to record log records for browsing using an external tool - -Add commands to add and remove filters - -Add commands to add and remove log devices - -Allow sharing of printf format strings in log records to reduce storage size -for large numbers of log records - -Add a command-line option to sandbox to set the default logging level - -Convert core driver model code to use logging - -Convert uclasses to use logging with the correct category - -Consider making log() calls emit an automatic newline, perhaps with a logn() - function to avoid that - -Passing log records through to linux (e.g. via device tree /chosen) - -Provide a command to access the number of log records generated, and the -number dropped due to them being generated before the log system was ready. - -Add a printf() format string pragma so that log statements are checked properly - -Enhance the log console driver to show level / category / file / line -information - -Add a command to add new log records and delete existing records. - -Provide additional log() functions - e.g. logc() to specify the category - --- -Simon Glass sjg@chromium.org -15-Sep-17 diff --git a/doc/develop/index.rst b/doc/develop/index.rst index 072db63b5c..eb5095a9eb 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -8,3 +8,4 @@ Develop U-Boot :maxdepth: 2
crash_dumps + logging diff --git a/doc/develop/logging.rst b/doc/develop/logging.rst new file mode 100644 index 0000000000..fd1aff000c --- /dev/null +++ b/doc/develop/logging.rst @@ -0,0 +1,290 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (c) 2017 Simon Glass sjg@chromium.org + +Logging in U-Boot +================= + +Introduction +------------ + +U-Boot's internal operation involves many different steps and actions. From +setting up the board to displaying a start-up screen to loading an Operating +System, there are many component parts each with many actions. + +Most of the time this internal detail is not useful. Displaying it on the +console would delay booting (U-Boot's primary purpose) and confuse users. + +But for digging into what is happening in a particular area, or for debugging +a problem it is often useful to see what U-Boot is doing in more detail than +is visible from the basic console output. + +U-Boot's logging feature aims to satisfy this goal for both users and +developers. + + +Logging levels +-------------- + +There are a number logging levels available, in increasing order of verbosity: + +* LOGL_EMERG - Printed before U-Boot halts +* LOGL_ALERT - Indicates action must be taken immediate or U-Boot will crash +* LOGL_CRIT - Indicates a critical error that will cause boot failure +* LOGL_ERR - Indicates an error that may cause boot failure +* LOGL_WARNING - Warning about an unexpected condition +* LOGL_NOTE - Important information about progress +* LOGL_INFO - Information about normal boot progress +* LOGL_DEBUG - Debug information (useful for debugging a driver or subsystem) +* LOGL_DEBUG_CONTENT - Debug message showing full message content +* LOGL_DEBUG_IO - Debug message showing hardware I/O access + + +Logging category +---------------- + +Logging can come from a wide variety of places within U-Boot. Each log message +has a category which is intended to allow messages to be filtered according to +their source. + +The following main categories are defined: + +* LOGC_NONE - Unknown category (e.g. a debug() statement) +* UCLASS_... - Related to a particular uclass (e.g. UCLASS_USB) +* LOGC_ARCH - Related to architecture-specific code +* LOGC_BOARD - Related to board-specific code +* LOGC_CORE - Related to core driver-model support +* LOGC_DT - Related to device tree control +* LOGC_EFI - Related to EFI implementation + + +Enabling logging +---------------- + +The following options are used to enable logging at compile time: + +* CONFIG_LOG - Enables the logging system +* CONFIG_MAX_LOG_LEVEL - Max log level to build (anything higher is compiled + out) +* CONFIG_LOG_CONSOLE - Enable writing log records to the console + +If CONFIG_LOG is not set, then no logging will be available. + +The above have SPL and TPL versions also, e.g. CONFIG_SPL_LOG_MAX_LEVEL and +CONFIG_TPL_LOG_MAX_LEVEL. + + +Temporary logging within a single file +-------------------------------------- + +Sometimes it is useful to turn on logging just in one file. You can use this + +.. code-block:: c + + #define LOG_DEBUG + +to enable building in of all logging statements in a single file. Put it at +the top of the file, before any #includes. + +To actually get U-Boot to output this you need to also set the default logging +level - e.g. set CONFIG_LOG_DEFAULT_LEVEL to 7 (LOGL_DEBUG) or more. Otherwise +debug output is suppressed and will not be generated. + + +Convenience functions +--------------------- + +A number of convenience functions are available to shorten the code needed +for logging: + +* log_err(_fmt...) +* log_warning(_fmt...) +* log_notice(_fmt...) +* log_info(_fmt...) +* log_debug(_fmt...) +* log_content(_fmt...) +* log_io(_fmt...) + +With these the log level is implicit in the name. The category is set by +LOG_CATEGORY, which you can only define once per file, above all #includes, e.g. + +.. code-block:: c + + #define LOG_CATEGORY LOGC_ALLOC + +Remember that all uclasses IDs are log categories too. + + +Log command +----------- + +The 'log' command provides access to several features: + +* level - access the default log level +* format - access the console log format +* rec - output a log record +* test - run tests + +Type 'help log' for details. + + +Using DEBUG +----------- + +U-Boot has traditionally used a #define called DEBUG to enable debugging on a +file-by-file basis. The debug() macro compiles to a printf() statement if +DEBUG is enabled, and an empty statement if not. + +With logging enabled, debug() statements are interpreted as logging output +with a level of LOGL_DEBUG and a category of LOGC_NONE. + +The logging facilities are intended to replace DEBUG, but if DEBUG is defined +at the top of a file, then it takes precedence. This means that debug() +statements will result in output to the console and this output will not be +logged. + + +Logging destinations +-------------------- + +If logging information goes nowhere then it serves no purpose. U-Boot provides +several possible determinations for logging information, all of which can be +enabled or disabled independently: + +* console - goes to stdout +* syslog - broadcast RFC 3164 messages to syslog servers on UDP port 514 + +The syslog driver sends the value of environmental variable 'log_hostname' as +HOSTNAME if available. + + +Log format +---------- + +You can control the log format using the 'log format' command. The basic +format is:: + + LEVEL.category,file.c:123-func() message + +In the above, file.c:123 is the filename where the log record was generated and +func() is the function name. By default ('log format default') only the +function name and message are displayed on the console. You can control which +fields are present, but not the field order. + + +Filters +------- + +Filters are attached to log drivers to control what those drivers emit. Only +records that pass through the filter make it to the driver. + +Filters can be based on several criteria: + +* maximum log level +* in a set of categories +* in a set of files + +If no filters are attached to a driver then a default filter is used, which +limits output to records with a level less than CONFIG_MAX_LOG_LEVEL. + + +Logging statements +------------------ + +The main logging function is: + +.. code-block:: c + + log(category, level, format_string, ...) + +Also debug() and error() will generate log records - these use LOG_CATEGORY +as the category, so you should #define this right at the top of the source +file to ensure the category is correct. + +You can also define CONFIG_LOG_ERROR_RETURN to enable the log_ret() macro. This +can be used whenever your function returns an error value: + +.. code-block:: c + + return log_ret(uclass_first_device(UCLASS_MMC, &dev)); + +This will write a log record when an error code is detected (a value < 0). This +can make it easier to trace errors that are generated deep in the call stack. + + +Code size +--------- + +Code size impact depends largely on what is enabled. The following numbers are +generated by 'buildman -S' for snow, which is a Thumb-2 board (all units in +bytes):: + + This series: adds bss +20.0 data +4.0 rodata +4.0 text +44.0 + CONFIG_LOG: bss -52.0 data +92.0 rodata -635.0 text +1048.0 + CONFIG_LOG_MAX_LEVEL=7: bss +188.0 data +4.0 rodata +49183.0 text +98124.0 + +The last option turns every debug() statement into a logging call, which +bloats the code hugely. The advantage is that it is then possible to enable +all logging within U-Boot. + + +To Do +----- + +There are lots of useful additions that could be made. None of the below is +implemented! If you do one, please add a test in test/py/tests/test_log.py + +Convenience functions to support setting the category: + +* log_arch(level, format_string, ...) - category LOGC_ARCH +* log_board(level, format_string, ...) - category LOGC_BOARD +* log_core(level, format_string, ...) - category LOGC_CORE +* log_dt(level, format_string, ...) - category LOGC_DT + +More logging destinations: + +* device - goes to a device (e.g. serial) +* buffer - recorded in a memory buffer + +Convert debug() statements in the code to log() statements + +Support making printf() emit log statements at L_INFO level + +Convert error() statements in the code to log() statements + +Figure out what to do with BUG(), BUG_ON() and warn_non_spl() + +Figure out what to do with assert() + +Add a way to browse log records + +Add a way to record log records for browsing using an external tool + +Add commands to add and remove filters + +Add commands to add and remove log devices + +Allow sharing of printf format strings in log records to reduce storage size +for large numbers of log records + +Add a command-line option to sandbox to set the default logging level + +Convert core driver model code to use logging + +Convert uclasses to use logging with the correct category + +Consider making log() calls emit an automatic newline, perhaps with a logn() +function to avoid that + +Passing log records through to linux (e.g. via device tree /chosen) + +Provide a command to access the number of log records generated, and the +number dropped due to them being generated before the log system was ready. + +Add a printf() format string pragma so that log statements are checked properly + +Enhance the log console driver to show level / category / file / line +information + +Add a command to add new log records and delete existing records. + +Provide additional log() functions - e.g. logc() to specify the category -- 2.26.2
Applied to u-boot-dm, thanks!
sjg@google.com
