[U-Boot] [PATCH v2] arm: ls1021x: Add support for initializing CAAM's stream id
There 4 JRs, 4 RTICs and 8 DECOs, and set them the same stream id for using the same SMMU3 on LS1021A.
Signed-off-by: Xiubo Li Li.Xiubo@freescale.com Signed-off-by: Alison Wang alison.wang@freescale.com --- Changes in v2: - Move changing CCSR macros to a separated patch.
arch/arm/include/asm/arch-ls102xa/config.h | 1 + .../include/asm/arch-ls102xa/ls102xa_stream_id.h | 57 ++++++++++++++++++++++ board/freescale/common/ls102xa_stream_id.c | 15 ++++++ board/freescale/ls1021aqds/ls1021aqds.c | 21 ++++++++ board/freescale/ls1021atwr/ls1021atwr.c | 21 ++++++++ 5 files changed, 115 insertions(+)
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 5e934da..f200bc8 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -36,6 +36,7 @@ #define CONFIG_SYS_LS102XA_USB1_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_LS102XA_USB1_OFFSET)
+#define CONFIG_SYS_FSL_SEC_OFFSET 0x00700000 #define CONFIG_SYS_LS102XA_USB1_OFFSET 0x07600000 #define CONFIG_SYS_TSEC1_OFFSET 0x01d10000 #define CONFIG_SYS_TSEC2_OFFSET 0x01d50000 diff --git a/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h b/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h index abd70fc..fa571b3 100644 --- a/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h +++ b/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h @@ -7,11 +7,68 @@ #ifndef __FSL_LS102XA_STREAM_ID_H_ #define __FSL_LS102XA_STREAM_ID_H_
+#include <fsl_sec.h> + +#define SET_LIODN_ENTRY_1(name, idA, off, compatoff) \ + { .compat = name, \ + .id = { idA }, .num_ids = 1, \ + .reg_offset = off + CONFIG_SYS_IMMR, \ + .compat_offset = compatoff + CONFIG_SYS_CCSRBAR_PHYS, \ + } + +#define SET_LIODN_ENTRY_2(name, idA, idB, off, compatoff) \ + { .compat = name, \ + .id = { idA, idB }, .num_ids = 2, \ + .reg_offset = off + CONFIG_SYS_IMMR, \ + .compat_offset = compatoff + CONFIG_SYS_CCSRBAR_PHYS, \ + } + +/* + * handle both old and new versioned SEC properties: + * "fsl,secX.Y" became "fsl,sec-vX.Y" during development + */ +#define SET_SEC_JR_LIODN_ENTRY(jrnum, liodnA, liodnB) \ + SET_LIODN_ENTRY_2("fsl,sec4.0-job-ring", liodnA, liodnB, \ + offsetof(ccsr_sec_t, jrliodnr[jrnum].ls) + \ + CONFIG_SYS_FSL_SEC_OFFSET, \ + CONFIG_SYS_FSL_SEC_OFFSET + 0x1000 + 0x1000 * jrnum), \ + SET_LIODN_ENTRY_2("fsl,sec-v4.0-job-ring", liodnA, liodnB,\ + offsetof(ccsr_sec_t, jrliodnr[jrnum].ls) + \ + CONFIG_SYS_FSL_SEC_OFFSET, \ + CONFIG_SYS_FSL_SEC_OFFSET + 0x1000 + 0x1000 * jrnum) + +/* This is a bit evil since we treat rtic param as both a string & hex value */ +#define SET_SEC_RTIC_LIODN_ENTRY(rtic, liodnA) \ + SET_LIODN_ENTRY_1("fsl,sec4.0-rtic-memory", \ + liodnA, \ + offsetof(ccsr_sec_t, rticliodnr[0x##rtic-0xa].ls) + \ + CONFIG_SYS_FSL_SEC_OFFSET, \ + CONFIG_SYS_FSL_SEC_OFFSET + 0x6100 + 0x20 * (0x##rtic-0xa)), \ + SET_LIODN_ENTRY_1("fsl,sec-v4.0-rtic-memory", \ + liodnA, \ + offsetof(ccsr_sec_t, rticliodnr[0x##rtic-0xa].ls) + \ + CONFIG_SYS_FSL_SEC_OFFSET, \ + CONFIG_SYS_FSL_SEC_OFFSET + 0x6100 + 0x20 * (0x##rtic-0xa)) + +#define SET_SEC_DECO_LIODN_ENTRY(num, liodnA, liodnB) \ + SET_LIODN_ENTRY_2(NULL, liodnA, liodnB, \ + offsetof(ccsr_sec_t, decoliodnr[num].ls) + \ + CONFIG_SYS_FSL_SEC_OFFSET, 0) + +struct liodn_id_table { + const char *compat; + u32 id[2]; + u8 num_ids; + phys_addr_t compat_offset; + unsigned long reg_offset; +}; + struct smmu_stream_id { uint16_t offset; uint16_t stream_id; char dev_name[32]; };
+void ls1021x_config_caam_stream_id(struct liodn_id_table *tbl, int size); void ls102xa_config_smmu_stream_id(struct smmu_stream_id *id, uint32_t num); #endif diff --git a/board/freescale/common/ls102xa_stream_id.c b/board/freescale/common/ls102xa_stream_id.c index 6154c9c..f434269 100644 --- a/board/freescale/common/ls102xa_stream_id.c +++ b/board/freescale/common/ls102xa_stream_id.c @@ -16,3 +16,18 @@ void ls102xa_config_smmu_stream_id(struct smmu_stream_id *id, uint32_t num) for (i = 0; i < num; i++) out_be32(scfg + id[i].offset, id[i].stream_id); } + +void ls1021x_config_caam_stream_id(struct liodn_id_table *tbl, int size) +{ + int i; + u32 liodn; + + for (i = 0; i < size; i++) { + if (tbl[i].num_ids == 2) + liodn = (tbl[i].id[0] << 16) | tbl[i].id[1]; + else + liodn = tbl[i].id[0]; + + out_le32((uint32_t *)(tbl[i].reg_offset), liodn); + } +} diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index f08e54f..a578ba7 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -450,6 +450,25 @@ static struct csu_ns_dev ns_dev[] = { }; #endif
+struct liodn_id_table sec_liodn_tbl[] = { + SET_SEC_JR_LIODN_ENTRY(0, 0x10, 0x10), + SET_SEC_JR_LIODN_ENTRY(1, 0x10, 0x10), + SET_SEC_JR_LIODN_ENTRY(2, 0x10, 0x10), + SET_SEC_JR_LIODN_ENTRY(3, 0x10, 0x10), + SET_SEC_RTIC_LIODN_ENTRY(a, 0x10), + SET_SEC_RTIC_LIODN_ENTRY(b, 0x10), + SET_SEC_RTIC_LIODN_ENTRY(c, 0x10), + SET_SEC_RTIC_LIODN_ENTRY(d, 0x10), + SET_SEC_DECO_LIODN_ENTRY(0, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(1, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(2, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(3, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(4, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(5, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(6, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(7, 0x10, 0x10), +}; + struct smmu_stream_id dev_stream_id[] = { { 0x100, 0x01, "ETSEC MAC1" }, { 0x104, 0x02, "ETSEC MAC2" }, @@ -489,6 +508,8 @@ int board_init(void) config_serdes_mux(); #endif
+ ls1021x_config_caam_stream_id(sec_liodn_tbl, + ARRAY_SIZE(sec_liodn_tbl)); ls102xa_config_smmu_stream_id(dev_stream_id, ARRAY_SIZE(dev_stream_id));
diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 8ab229d..8b73172 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -389,6 +389,25 @@ static struct csu_ns_dev ns_dev[] = { }; #endif
+struct liodn_id_table sec_liodn_tbl[] = { + SET_SEC_JR_LIODN_ENTRY(0, 0x10, 0x10), + SET_SEC_JR_LIODN_ENTRY(1, 0x10, 0x10), + SET_SEC_JR_LIODN_ENTRY(2, 0x10, 0x10), + SET_SEC_JR_LIODN_ENTRY(3, 0x10, 0x10), + SET_SEC_RTIC_LIODN_ENTRY(a, 0x10), + SET_SEC_RTIC_LIODN_ENTRY(b, 0x10), + SET_SEC_RTIC_LIODN_ENTRY(c, 0x10), + SET_SEC_RTIC_LIODN_ENTRY(d, 0x10), + SET_SEC_DECO_LIODN_ENTRY(0, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(1, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(2, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(3, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(4, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(5, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(6, 0x10, 0x10), + SET_SEC_DECO_LIODN_ENTRY(7, 0x10, 0x10), +}; + struct smmu_stream_id dev_stream_id[] = { { 0x100, 0x01, "ETSEC MAC1" }, { 0x104, 0x02, "ETSEC MAC2" }, @@ -425,6 +444,8 @@ int board_init(void) #endif #endif
Changes in v2:
Applied to u-boot-fsl-qoriq master branch, awaiting upstream.
York
Alison Wang
York Sun
