Linux mvneta driver unable to read MAC address from HW
Hello,
sorry for bothering you, but I am kinda stuck here.
I am running Debian buster (Linux 4.19.146) on a Synology DS214+ NAS (Marvell ARMADA XP). Unfortunately, I end up with random MAC addresses for the two Ethernet interfaces after boot. (Also with Debian sid, Linux 5.4.0.)
Since commit 8cc3e439ab92 ("net: mvneta: read MAC address from hardware when available") the mvneta Linux driver reads the MVNETA_MAC_ADDR_* registers when no MAC address is provided by the DT. In my case, only zeros are read, causing the driver to fall back to a random address. I was able to verify that the registers are correctly written by the bootloader by reading out the registers in the U-Boot prompt.
As a workaround, I now specify the MAC addresses in the DT. However, I would prefer not to do that. Also, it would be nice to get to the bottom of this.
Could it be, that for some reason, the clock of the MAC is removed either by U-Boot or Linux during boot?
Any hints that could help me investigate this further would be highly appreciated.
Cheers, Ezra.
Hello Ezra,
I suspect you have the mvneta driver as a module ? If this is the case, then indeed, the MAC address is lost because Linux turns of all unused clocks at the end of the boot. When the driver is built-in, there is a driver adding a reference to the clock before all unused clocks are disabled. When the driver is compiled as a module, this does not happen. So indeed, the correct solution here is to have U-Boot pass the MAC address in the Device Tree.
Thomas Petazzoni
Hi Thomas,
On 13 Oct 2020, at 08:35, Thomas Petazzoni thomas.petazzoni@bootlin.com wrote:
Yes, you are right, the driver is compiled as module. This explains everything, thank you very much for the clarification.
Have a nice day!
Cheers, Ezra.
Ezra Buehler
Thomas Petazzoni
