[U-Boot] [PATCH] cmd_bdinfo: simplify local static funcs a bit
If we move the local funcs to the top of the file, and use the __maybe_unused define, we can drop a lot of ugly ifdef logic and duplicated prototypes.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/cmd_bdinfo.c | 89 ++++++++++++++++++-------------------------------- 1 files changed, 32 insertions(+), 57 deletions(-)
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 688b238..67cb0da 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -26,24 +26,45 @@ */ #include <common.h> #include <command.h> +#include <linux/compiler.h>
DECLARE_GLOBAL_DATA_PTR;
-static void print_num(const char *, ulong); +__maybe_unused +static void print_num(const char *name, ulong value) +{ + printf("%-12s= 0x%08lX\n", name, value); +}
-#if !(defined(CONFIG_ARM) || defined(CONFIG_M68K) || defined(CONFIG_SANDBOX)) \ - || defined(CONFIG_CMD_NET) -#define HAVE_PRINT_ETH -static void print_eth(int idx); -#endif +__maybe_unused +static void print_eth(int idx) +{ + char name[10], *val; + if (idx) + sprintf(name, "eth%iaddr", idx); + else + strcpy(name, "ethaddr"); + val = getenv(name); + if (!val) + val = "(not set)"; + printf("%-12s= %s\n", name, val); +}
-#if (!defined(CONFIG_ARM) && !defined(CONFIG_X86) && !defined(CONFIG_SANDBOX)) -#define HAVE_PRINT_LNUM -static void print_lnum(const char *, u64); -#endif +__maybe_unused +static void print_lnum(const char *name, u64 value) +{ + printf("%-12s= 0x%.8llX\n", name, value); +} + +__maybe_unused +static void print_mhz(const char *name, unsigned long hz) +{ + char buf[32]; + + printf("%-12s= %6s MHz\n", name, strmhz(buf, hz)); +}
#if defined(CONFIG_PPC) -static void print_mhz(const char *, unsigned long);
int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -208,8 +229,6 @@ int do_bdinfo(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[])
#elif defined(CONFIG_M68K)
-static void print_mhz(const char *, unsigned long); - int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { bd_t *bd = gd->bd; @@ -257,8 +276,6 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#elif defined(CONFIG_BLACKFIN)
-static void print_mhz(const char *, unsigned long); - int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { bd_t *bd = gd->bd; @@ -377,8 +394,6 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#elif defined(CONFIG_X86)
-static void print_mhz(const char *, unsigned long); - int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int i; @@ -464,46 +479,6 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #error "a case for this architecture does not exist!" #endif
-static void print_num(const char *name, ulong value) -{ - printf("%-12s= 0x%08lX\n", name, value); -} - -#ifdef HAVE_PRINT_ETH -static void print_eth(int idx) -{ - char name[10], *val; - if (idx) - sprintf(name, "eth%iaddr", idx); - else - strcpy(name, "ethaddr"); - val = getenv(name); - if (!val) - val = "(not set)"; - printf("%-12s= %s\n", name, val); -} -#endif - -#ifdef HAVE_PRINT_LNUM -static void print_lnum(const char *name, u64 value) -{ - printf("%-12s= 0x%.8llX\n", name, value); -} -#endif - -#if defined(CONFIG_PPC) || \ - defined(CONFIG_M68K) || \ - defined(CONFIG_BLACKFIN) || \ - defined(CONFIG_X86) -static void print_mhz(const char *name, unsigned long hz) -{ - char buf[32]; - - printf("%-12s= %6s MHz\n", name, strmhz(buf, hz)); -} -#endif /* CONFIG_PPC */ - - /* -------------------------------------------------------------------- */
U_BOOT_CMD(
This is much cleaner - is the correct style to put attribute tags on the previous line?
when responding to add your own, there isn't any real protocol. just normal e-mail etiquette (no top posting/etc...). patchwork/humans will do the right thing when manually updating the changelog. -mike
Hi Mike,
Actually I meant the __maybe_unused tag before the function name.
ah. i'm not sure there is a hard rule here. i did that because one line would make the func def too long to fit. -mike
Will the linker remove the functions from the binary if they are unusued?
On Mon, Oct 31, 2011 at 2:15 PM, Tabi Timur-B04825 B04825@freescale.com wrote:
If built with -ffunction-sections and --gc-sections,, then the linker can do this sort of thing. Otherwise it can't, but the compiler can. I just tested Mike's code on my ARM compiler to make sure and it happily removed print_eth() when it was not used.
-- Timur Tabi Linux kernel developer at Freescale _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
i don't think you need function-sections to make this happen. since it is marked "static", gcc should do DCE on it. the __maybe_unused markings is just to kill off any warnings about the func not being used (which might occur in the #ifdef jungle below). that attribute does not tell gcc to retain the function even if it isn't referenced in this file (as far as gcc can tell). -mike
Hi Mike,
That's right, you don't need function-sections for the compiler to eliminate the code - my point was that the linker can't do this sort of thing...luckily it doesn't need to.
There might be an option to control this, a bit like -fkeep-static-consts, but I can't see it. Can't see it being very useful anyway.
Acked-by: Simon Glass sjg@chromium.org Signed-off-by: Mike Frysinger vapier@gentoo.org --- v2 - rebased onto current master
common/cmd_bdinfo.c | 89 ++++++++++++++++++--------------------------------- 1 files changed, 31 insertions(+), 58 deletions(-)
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 6c48594..73c03a8 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -26,25 +26,44 @@ */ #include <common.h> #include <command.h> +#include <linux/compiler.h>
-#if !(defined(CONFIG_ARM) || defined(CONFIG_M68K) || \ - defined(CONFIG_SANDBOX) || defined(CONFIG_X86)) \ - || defined(CONFIG_CMD_NET) -#define HAVE_PRINT_ETH -static void print_eth(int idx); -#endif +static void print_eth(int idx) +{ + char name[10], *val; + if (idx) + sprintf(name, "eth%iaddr", idx); + else + strcpy(name, "ethaddr"); + val = getenv(name); + if (!val) + val = "(not set)"; + printf("%-12s= %s\n", name, val); +}
int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -209,8 +228,6 @@ int do_bdinfo(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[])
-static void print_mhz(const char *, unsigned long); - int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { bd_t *bd = gd->bd; @@ -258,8 +275,6 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
-static void print_mhz(const char *, unsigned long); - int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { bd_t *bd = gd->bd; @@ -378,8 +393,6 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
-static void print_mhz(const char *, unsigned long); - int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int i; @@ -465,46 +478,6 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #error "a case for this architecture does not exist!" #endif
U_BOOT_CMD(
Dear Mike Frysinger,
v2
Applied, thanks.
Mike Frysinger
Tabi Timur-B04825
