[U-Boot-Users] command compleation in latest u-boot?
Trying to move my boot to latest u-boot and I can't make command completion work. Does it work in current u-boot and what config options do you use?
Jocke
Hi Jocke,
IIRC, then you have to choose to enable either command completion (CONFIG_AUTO_COMPLETE) or command history (CONFIG_CMDLINE_EDITING). Command history is my choice here.
Best regards, Stefan
-----Original Message----- From: Stefan Roese [mailto:sr@denx.de] Sent: den 27 november 2007 19:36 To: u-boot-users@lists.sourceforge.net Cc: Joakim Tjernlund Subject: Re: [U-Boot-Users] command compleation in latest u-boot?
Hi Jocke,
Using both of them, but TAB still does not complete anything.
Jocke
On Tue, 2007-11-27 at 19:36 +0100, Stefan Roese wrote:
Hi Jocke,
Ahh, I can only use one. In my old boot I can use both because I applied a patch from Pantelis that I thought was in uboot already. Can you have a look at Pantelis patch an apply if appropriate?
Here is the patch: From: Pantelis Antoniou pantelis@embeddedalley.com To: u-boot-users@lists.sourceforge.net Cc: Frank Robbins frank.robbins@analogue-micro.com, Dan Malek dan@embeddedalley.com, Wolfgang Denk wd@denx.de, Peter Tympanick ptymps@ultsol.com Subject: [U-Boot-Users] [PATCH 1/8] Make autocomplete work with HUSH parser too. Date: Sun, 03 Dec 2006 00:15:50 +0200 (Sat, 23:15 CET)
Auto complete did not work when the HUSH parser was selected. Fix this obvious problem.
--- Signed-off-by: Pantelis Antoniou pantelis@embeddedalley.com ---
README | 4 ---- common/main.c | 25 +++++++++++++++++++++++-- 2 files changed, 23 insertions(+), 6 deletions(-)
diff --git a/README b/README index ecfd1f8..e28f935 100644 --- a/README +++ b/README @@ -1511,10 +1511,6 @@ The following options need to be configured:
Enable auto completion of commands using TAB.
- Note that this feature has NOT been implemented yet - for the "hush" shell. - - CFG_HUSH_PARSER
Define this variable to enable the "hush" shell (from diff --git a/common/main.c b/common/main.c index cc4b50f..a8ae07c 100644 --- a/common/main.c +++ b/common/main.c @@ -718,10 +718,11 @@ static void cread_add_str(char *str, int strsize, int insert, unsigned long *num } }
-static int cread_line(char *buf, unsigned int *len) +static int cread_line(const char *const prompt, char *buf, unsigned int *len) { unsigned long num = 0; unsigned long eol_num = 0; + int num2, col; unsigned long rlen; unsigned long wlen; char ichar; @@ -840,6 +841,7 @@ static int cread_line(char *buf, unsigned int *len) insert = !insert; break; case CTL_CH('x'): + case CTL_CH('u'): /* like that too */ BEGINNING_OF_LINE(); ERASE_TO_EOL(); break; @@ -889,6 +891,25 @@ static int cread_line(char *buf, unsigned int *len) REFRESH_TO_EOL(); continue; } +#ifdef CONFIG_AUTO_COMPLETE + case '\t': + + /* do not autocomplete when in the middle */ + if (num < eol_num) { + getcmd_cbeep(); + break; + } + + buf[num] = '\0'; + col = strlen(prompt) + eol_num; + num2 = num; + if (cmd_auto_complete(prompt, buf, &num2, &col)) { + col = num2 - num; + num += col; + eol_num += col; + } + break; +#endif default: cread_add_char(ichar, insert, &num, &eol_num, buf, *len); break; @@ -931,7 +952,7 @@ int readline (const char *const prompt)
puts (prompt);
- rc = cread_line(p, &len); + rc = cread_line(prompt, p, &len); return rc < 0 ? rc : len; #else char *p = console_buffer;
Yes, would be good if both is possible. Could you do me a favor and redo this patch against the current source code. Also it seems that this will trigger some compile warning for unused variables "num2, col" when CONFIG_AUTO_COMPLETE is not defined. Please check and resend a fixed version and I'll make sure that it gets applied when the next merge window opens.
Thanks.
the patch posted still applies cleanly (ignoring offsets and the crappy word wrapping). for sake of completeness, ive attached patch against current mainline git after giving it a spin against a recent version. -mike
diff --git a/common/main.c b/common/main.c index 379695c..4253eac 100644 --- a/common/main.c +++ b/common/main.c @@ -696,7 +696,7 @@ static void cread_add_str(char *str, int strsize, int insert, unsigned long *num } }
-static int cread_line(char *buf, unsigned int *len) +static int cread_line(const char *const prompt, char *buf, unsigned int *len) { unsigned long num = 0; unsigned long eol_num = 0; @@ -818,6 +818,7 @@ static int cread_line(char *buf, unsigned int *len) insert = !insert; break; case CTL_CH('x'): + case CTL_CH('u'): BEGINNING_OF_LINE(); ERASE_TO_EOL(); break; @@ -867,6 +868,27 @@ static int cread_line(char *buf, unsigned int *len) REFRESH_TO_EOL(); continue; } +#ifdef CONFIG_AUTO_COMPLETE + case '\t': { + int num2, col; + + /* do not autocomplete when in the middle */ + if (num < eol_num) { + getcmd_cbeep(); + break; + } + + buf[num] = '\0'; + col = strlen(prompt) + eol_num; + num2 = num; + if (cmd_auto_complete(prompt, buf, &num2, &col)) { + col = num2 - num; + num += col; + eol_num += col; + } + break; + } +#endif default: cread_add_char(ichar, insert, &num, &eol_num, buf, *len); break; @@ -909,7 +931,7 @@ int readline (const char *const prompt)
puts (prompt);
Add in ixp repository on testing branch
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD
Joakim Tjernlund
Mike Frysinger
Stefan Roese
