[U-Boot] [PATCH 0/5] sf: defconfig/kconfig updates
defconfig/kconfig changes related to sf.
Jagan Teki (5): README: Remove CONFIG_SPI_FLASH_MTD help text defconfig: Move CONFIG_SPI_FLASH_BAR from configs sf: Kconfig: Add SPI_FLASH_BAR entry README: Remove CONFIG_SPI_FLASH_BAR help text README: Remove CONFIG_SPI_FLASH_DATAFLASH help text
README | 19 ------------------- configs/alt_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/gose_defconfig | 1 + configs/koelsch_defconfig | 1 + configs/lager_defconfig | 1 + configs/maxbcm_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/porter_defconfig | 1 + configs/silk_defconfig | 1 + drivers/mtd/spi/Kconfig | 8 ++++++++ include/configs/alt.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/bg0900.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/gose.h | 1 - include/configs/koelsch.h | 1 - include/configs/lager.h | 1 - include/configs/maxbcm.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/porter.h | 1 - include/configs/silk.h | 1 - 24 files changed, 19 insertions(+), 30 deletions(-)
Since the help text is added in drivers/mtd/spi/Kconfig
Signed-off-by: Jagan Teki jteki@openedev.com --- README | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/README b/README index c49af74..c9a7785 100644 --- a/README +++ b/README @@ -3090,15 +3090,6 @@ CBFS (Coreboot Filesystem) support memories can be connected with a given cs line. Currently Xilinx Zynq qspi supports these type of connections.
- CONFIG_SPI_FLASH_MTD spi-flash MTD layer - - Define this option to use mtd support for spi flash layer, this - adapter is for translating mtd_read/mtd_write commands into - spi_flash_read/spi_flash_write commands. It is not intended to - use it within sf_cmd or the SPI flash subsystem. Such an adapter - is needed for subsystems like UBI which can only operate on top - of the MTD layer. - CONFIG_SPI_FLASH_DATAFLASH SPI based Dataflash
Define this option to access AT45xxx Dataflash chips support
This commit moves: - CONFIG_SPI_FLASH_BAR
from include/configs/*.h into configs/*_defconfigs
Signed-off-by: Jagan Teki jteki@openedev.com --- configs/alt_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/gose_defconfig | 1 + configs/koelsch_defconfig | 1 + configs/lager_defconfig | 1 + configs/maxbcm_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/porter_defconfig | 1 + configs/silk_defconfig | 1 + include/configs/alt.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/bg0900.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/gose.h | 1 - include/configs/koelsch.h | 1 - include/configs/lager.h | 1 - include/configs/maxbcm.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/porter.h | 1 - include/configs/silk.h | 1 - 22 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/configs/alt_defconfig b/configs/alt_defconfig index f4fea7f..d994d78 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -17,4 +17,5 @@ CONFIG_TARGET_ALT=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_MISC is not set CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SH_SDHI=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 407d67c..65efa9d 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -5,4 +5,5 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 8e0fac8..a29ad01 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -4,3 +4,4 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 1a0e01f..463a7e2 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index bece0aa..72aee1c 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -17,4 +17,5 @@ CONFIG_TARGET_GOSE=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_MISC is not set CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SH_SDHI=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 13c8310..df49a71 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -17,4 +17,5 @@ CONFIG_TARGET_KOELSCH=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_MISC is not set CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SH_SDHI=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index 3805fcb..6b86f00 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -17,4 +17,5 @@ CONFIG_TARGET_LAGER=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_MISC is not set CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SH_SDHI=y diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index c5b3b67..b0b0d6c 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -5,3 +5,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index e355ba5..e6e4db5 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabresd/imximage.cfg,M # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 15f3434..dc8b5ca 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -17,4 +17,5 @@ CONFIG_TARGET_PORTER=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_MISC is not set CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SH_SDHI=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index 20c85fd..e4e4ebc 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -17,4 +17,5 @@ CONFIG_TARGET_SILK=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_MISC is not set CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SH_SDHI=y diff --git a/include/configs/alt.h b/include/configs/alt.h index 524da42..6d2c242 100644 --- a/include/configs/alt.h +++ b/include/configs/alt.h @@ -41,7 +41,6 @@
/* FLASH */ #define CONFIG_SPI -#define CONFIG_SPI_FLASH_BAR #define CONFIG_SH_QSPI #define CONFIG_SPI_FLASH_SPANSION #define CONFIG_SPI_FLASH_QUAD diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 466ded7..33e534a 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -204,7 +204,6 @@ #define CONFIG_CMD_SF #define CONFIG_CMD_SPI #define CONFIG_TI_SPI_MMAP -#define CONFIG_SPI_FLASH_BAR #define CONFIG_QSPI_SEL_GPIO 48 #define CONFIG_SF_DEFAULT_SPEED 48000000 #define CONFIG_DEFAULT_SPI_MODE SPI_MODE_3 diff --git a/include/configs/bg0900.h b/include/configs/bg0900.h index 76c1c6a..c45c8c2 100644 --- a/include/configs/bg0900.h +++ b/include/configs/bg0900.h @@ -49,7 +49,6 @@
/* SPI FLASH */ #ifdef CONFIG_CMD_SF -#define CONFIG_SPI_FLASH_BAR #define CONFIG_SPI_FLASH_STMICRO #define CONFIG_SF_DEFAULT_BUS 2 #define CONFIG_SF_DEFAULT_CS 0 diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 914e1cf..d84427d 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -125,7 +125,6 @@ #define CONFIG_SPI_FLASH_SPANSION #define CONFIG_CMD_SF #define CONFIG_CMD_SPI -#define CONFIG_SPI_FLASH_BAR #define CONFIG_TI_SPI_MMAP #define CONFIG_SF_DEFAULT_SPEED 48000000 #define CONFIG_DEFAULT_SPI_MODE SPI_MODE_3 diff --git a/include/configs/gose.h b/include/configs/gose.h index f088649..c08e73a 100644 --- a/include/configs/gose.h +++ b/include/configs/gose.h @@ -44,7 +44,6 @@ #define CONFIG_SYS_NO_FLASH #define CONFIG_SPI #define CONFIG_SH_QSPI -#define CONFIG_SPI_FLASH_BAR #define CONFIG_SPI_FLASH_SPANSION
/* SH Ether */ diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index ff948f9..c905cc2 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -44,7 +44,6 @@ #define CONFIG_SYS_NO_FLASH #define CONFIG_SPI #define CONFIG_SH_QSPI -#define CONFIG_SPI_FLASH_BAR #define CONFIG_SPI_FLASH_SPANSION
/* SH Ether */ diff --git a/include/configs/lager.h b/include/configs/lager.h index 546863e..1450e8f 100644 --- a/include/configs/lager.h +++ b/include/configs/lager.h @@ -42,7 +42,6 @@
/* SPI */ #define CONFIG_SPI -#define CONFIG_SPI_FLASH_BAR #define CONFIG_SH_QSPI #define CONFIG_SPI_FLASH_SPANSION #define CONFIG_SYS_NO_FLASH diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index 0839d39..4826044 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -43,7 +43,6 @@ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 #define CONFIG_SPI_FLASH_STMICRO #define CONFIG_SPI_FLASH_SPANSION -#define CONFIG_SPI_FLASH_BAR
/* Environment in SPI NOR flash */ #define CONFIG_ENV_IS_IN_SPI_FLASH diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 19f9e44..2b278a8 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -189,7 +189,6 @@
#ifdef CONFIG_FSL_QSPI #define CONFIG_CMD_SF -#define CONFIG_SPI_FLASH_BAR #define CONFIG_SPI_FLASH_SPANSION #define CONFIG_SPI_FLASH_STMICRO #define CONFIG_SYS_FSL_QSPI_LE diff --git a/include/configs/porter.h b/include/configs/porter.h index 9367349..59b14e9 100644 --- a/include/configs/porter.h +++ b/include/configs/porter.h @@ -42,7 +42,6 @@
/* FLASH */ #define CONFIG_SPI -#define CONFIG_SPI_FLASH_BAR #define CONFIG_SH_QSPI #define CONFIG_SPI_FLASH_SPANSION #define CONFIG_SPI_FLASH_QUAD diff --git a/include/configs/silk.h b/include/configs/silk.h index b105f5a..cd839aa 100644 --- a/include/configs/silk.h +++ b/include/configs/silk.h @@ -42,7 +42,6 @@
Added SPI_FLASH_BAR entry on Kconfig with help description
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/Kconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 6d1030d..3015395 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -34,6 +34,14 @@ config SPI_FLASH
If unsure, say N
+config SPI_FLASH_BAR + bool "SPI flash Bank/Extended address register support" + depends on SPI_FLASH + help + Enable the SPI flash Bank/Extended address register support. + Bank/Extended address registers are used to access the flash + which has size > 16MiB in 3-byte addressing. + config SPI_FLASH_DATAFLASH bool "AT45xxx DataFlash support" depends on SPI_FLASH && DM_SPI_FLASH
Signed-off-by: Jagan Teki jteki@openedev.com --- README | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/README b/README index c9a7785..94c5228 100644 --- a/README +++ b/README @@ -3079,11 +3079,6 @@ CBFS (Coreboot Filesystem) support Define this option to include a destructive SPI flash test ('sf test').
- CONFIG_SPI_FLASH_BAR Ban/Extended Addr Reg - - Define this option to use the Bank addr/Extended addr - support on SPI flashes which has size > 16Mbytes. - CONFIG_SF_DUAL_FLASH Dual flash memories
Define this option to use dual flash support where two flash
diff --git a/README b/README index 94c5228..53fc28e 100644 --- a/README +++ b/README @@ -3085,11 +3085,6 @@ CBFS (Coreboot Filesystem) support memories can be connected with a given cs line. Currently Xilinx Zynq qspi supports these type of connections.
- CONFIG_SPI_FLASH_DATAFLASH SPI based Dataflash - - Define this option to access AT45xxx Dataflash chips support - using spi flash interface. - - SystemACE Support: CONFIG_SYSTEMACE
-- 1.9.1
Applied to u-boot-spi/master
thanks!
Jagan Teki
