[PATCH u-boot-mvebu 1/2] ARM: dts: armada-385-turris-omnia: add `u-boot-env` NOR partition
Specify a separate partition `u-boot-env` for U-Boot's env settings for the Turris Omnia board.
Do this only in U-Boot's specific DTS. We do not want to do this in Linux' official DTS, because Omnia's stock U-Boot stores env at a different address, and there are still boards with stock U-Boot.
In a subsequent patch will add board code that fixes Linux's DTB before booting Linux.
Signed-off-by: Marek Behún marek.behun@nic.cz --- arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi index af0655daaa..3ff76c9462 100644 --- a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi +++ b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi @@ -43,6 +43,17 @@
spi-nor@0 { u-boot,dm-pre-reloc; + + partitions { + partition@0 { + reg = <0x0 CONFIG_ENV_OFFSET>; + }; + + partition@f0000 { + reg = <CONFIG_ENV_OFFSET CONFIG_ENV_SIZE>; + label = "u-boot-env"; + }; + }; }; };
Fixup SPI NOR partition nodes in Linux' device tree prior booting Linux.
Linux' devicetree does not contain "u-boot-env" partition and we do not want to add it there because the address is different between stock U-Boot and current upstream U-Boot.
Instead we add code that recreates partition nodes from scratch according to how U-Boot sees them (which is defined in U-Boot's device tree).
Signed-off-by: Marek Behún marek.behun@nic.cz --- Hi Stefan,
the code of the fixup_mtd_partitions() function I am adding with this patch is generic enough to be potentially used on other boards (for example EspressoBIN's board code does something similar, so it could use this function).
Indeed I want to generalize it, since there are multiple boards fixing partition nodes in DTS prior booting Linux and there is already code for this in common/fdt_support.c. The problem is that that code does not work with DM_MTD, but rather with the obsolete MTDPARTS and several boards use it. I want to convert those boards into using this new API, but this will take some time and should be done via u-boot-spi tree.
So please for now merge this code via the mvebu tree. In the meantime till this is merged into Tom's tree I shall be working on converting those other boards that use fdt_fixup_mtdparts() to use device tree for defining MTD partitions so that we can remove fdt_fixup_mtdparts(), move this new code into common/fdt_support.c and covert those boards to use this new code. --- board/CZ.NIC/turris_omnia/turris_omnia.c | 90 ++++++++++++++++++++++++ configs/turris_omnia_defconfig | 1 + 2 files changed, 91 insertions(+)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 8b2f94f959..a7e5f56eed 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -13,6 +13,7 @@ #include <init.h> #include <log.h> #include <miiphy.h> +#include <mtd.h> #include <net.h> #include <netdev.h> #include <asm/global_data.h> @@ -31,6 +32,8 @@
DECLARE_GLOBAL_DATA_PTR;
+#define OMNIA_SPI_NOR_PATH "/soc/spi@10600/spi-nor@0" + #define OMNIA_I2C_BUS_NAME "i2c@11000->i2cmux@70->i2c@0"
#define OMNIA_I2C_MCU_CHIP_ADDR 0x2a @@ -557,3 +560,90 @@ out: return 0; }
+#if defined(CONFIG_OF_BOARD_SETUP) +/* + * I plan to generalize this function and move it to common/fdt_support.c. + * This will require some more work on multiple boards, though, so for now leave + * it here. + */ +static bool fixup_mtd_partitions(void *blob, int offset, struct mtd_info *mtd) +{ + struct mtd_info *slave; + int parts; + + parts = fdt_subnode_offset(blob, offset, "partitions"); + if (parts < 0) + return false; + + if (fdt_del_node(blob, parts) < 0) + return false; + + parts = fdt_add_subnode(blob, offset, "partitions"); + if (parts < 0) + return false; + + if (fdt_setprop_u32(blob, parts, "#address-cells", 1) < 0) + return false; + + if (fdt_setprop_u32(blob, parts, "#size-cells", 1) < 0) + return false; + + if (fdt_setprop_string(blob, parts, "compatible", + "fixed-partitions") < 0) + return false; + + mtd_probe_devices(); + + list_for_each_entry(slave, &mtd->partitions, node) { + char name[32]; + int part; + + snprintf(name, sizeof(name), "partition@%llx", slave->offset); + part = fdt_add_subnode(blob, parts, name); + if (part < 0) + return false; + + if (fdt_setprop_u32(blob, part, "reg", slave->offset) < 0) + return false; + + if (fdt_appendprop_u32(blob, part, "reg", slave->size) < 0) + return false; + + if (fdt_setprop_string(blob, part, "label", slave->name) < 0) + return false; + + if (!(slave->flags & MTD_WRITEABLE)) + if (fdt_setprop_empty(blob, part, "read-only") < 0) + return false; + + if (slave->flags & MTD_POWERUP_LOCK) + if (fdt_setprop_empty(blob, part, "lock") < 0) + return false; + } + + return true; +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + struct mtd_info *mtd; + int node; + + mtd = get_mtd_device_nm(OMNIA_SPI_NOR_PATH); + if (IS_ERR_OR_NULL(mtd)) + goto fail; + + node = fdt_path_offset(blob, OMNIA_SPI_NOR_PATH); + if (node < 0) + goto fail; + + if (!fixup_mtd_partitions(blob, node, mtd)) + goto fail; + + return 0; + +fail: + printf("Failed fixing SPI NOR partitions!\n"); + return 0; +} +#endif diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index f860cf5e7d..5f7b1a67a2 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART=y +CONFIG_OF_BOARD_SETUP=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y
Hi Marek,
Hi Stefan,
Thanks for the details explanation and also thanks for working on this generalization of this "feature".
With this background:
Thanks, Stefan
- I plan to generalize this function and move it to common/fdt_support.c.
- This will require some more work on multiple boards, though, so for now leave
- it here.
- struct mtd_info *slave;
- int parts;
- parts = fdt_subnode_offset(blob, offset, "partitions");
- if (parts < 0)
return false;
- if (fdt_del_node(blob, parts) < 0)
return false;
- parts = fdt_add_subnode(blob, offset, "partitions");
- if (parts < 0)
return false;
- if (fdt_setprop_u32(blob, parts, "#address-cells", 1) < 0)
return false;
- if (fdt_setprop_u32(blob, parts, "#size-cells", 1) < 0)
return false;
- if (fdt_setprop_string(blob, parts, "compatible",
return false;
- mtd_probe_devices();
- list_for_each_entry(slave, &mtd->partitions, node) {
char name[32];
int part;
if (part < 0)
return false;
return false;
return false;
return false;
return false;
return false;
- return true;
- struct mtd_info *mtd;
- int node;
- mtd = get_mtd_device_nm(OMNIA_SPI_NOR_PATH);
- if (IS_ERR_OR_NULL(mtd))
goto fail;
- node = fdt_path_offset(blob, OMNIA_SPI_NOR_PATH);
- if (node < 0)
goto fail;
- if (!fixup_mtd_partitions(blob, node, mtd))
goto fail;
+fail:
- printf("Failed fixing SPI NOR partitions!\n");
Thanks, Stefan
partitions {
partition@0 {
partition@f0000 {
Viele Grüße, Stefan
Marek Behún
Stefan Roese
