[PATCH] spl: Always define preloader_console_init
A large number of boards call preloader_console_init unconditionally. Currently, they fail to build with CONFIG_SPL_SERIAL=n, because the function is undefined in that case. To fix the build, always define preloader_console_init, but make it no-op when CONFIG_SPL_SERIAL=n.
For the few boards that did check for CONFIG_SPL_SERIAL before calling preloader_console_init, remove the checks, since the function can now be called unconditionally.
Signed-off-by: Samuel Holland samuel@sholland.org --- arch/arm/mach-omap2/boot-common.c | 3 +-- arch/arm/mach-uniphier/spl_board_init.c | 2 -- common/spl/spl.c | 7 +++---- 3 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index 7538523724..d57382aabe 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -194,10 +194,9 @@ u32 spl_mmc_boot_mode(const u32 boot_device)
void spl_board_init(void) { -#ifdef CONFIG_SPL_SERIAL_SUPPORT /* Prepare console output */ preloader_console_init(); -#endif + #if defined(CONFIG_SPL_NAND_SUPPORT) || defined(CONFIG_SPL_ONENAND_SUPPORT) gpmc_init(); #endif diff --git a/arch/arm/mach-uniphier/spl_board_init.c b/arch/arm/mach-uniphier/spl_board_init.c index c7262d70a5..48764a1870 100644 --- a/arch/arm/mach-uniphier/spl_board_init.c +++ b/arch/arm/mach-uniphier/spl_board_init.c @@ -112,9 +112,7 @@ void spl_board_init(void)
initdata->early_clk_init();
-#ifdef CONFIG_SPL_SERIAL_SUPPORT preloader_console_init(); -#endif
ret = initdata->dpll_init(bd); if (ret) { diff --git a/common/spl/spl.c b/common/spl/spl.c index b0f0e1557b..fc5cbbbeba 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -574,8 +574,7 @@ void board_init_f(ulong dummy) } }
- if (CONFIG_IS_ENABLED(SERIAL_SUPPORT)) - preloader_console_init(); + preloader_console_init(); } #endif
@@ -724,13 +723,13 @@ void board_init_r(gd_t *dummy1, ulong dummy2) jump_to_image_no_args(&spl_image); }
-#ifdef CONFIG_SPL_SERIAL_SUPPORT /* * This requires UART clocks to be enabled. In order for this to work the * caller must ensure that the gd pointer is valid. */ void preloader_console_init(void) { +#ifdef CONFIG_SPL_SERIAL_SUPPORT gd->baudrate = CONFIG_BAUDRATE;
serial_init(); /* serial communications setup */ @@ -744,8 +743,8 @@ void preloader_console_init(void) #ifdef CONFIG_SPL_DISPLAY_PRINT spl_display_print(); #endif -} #endif +}
/** * This function is called before the stack is changed from initial stack to
Thanks, Stefan
- #if defined(CONFIG_SPL_NAND_SUPPORT) || defined(CONFIG_SPL_ONENAND_SUPPORT) gpmc_init(); #endif
- preloader_console_init(); } #endif
- This requires UART clocks to be enabled. In order for this to work the
- caller must ensure that the gd pointer is valid.
- This function is called before the stack is changed from initial stack to
Viele Grüße, Stefan
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Signed-off-by: Samuel Holland samuel@sholland.org Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Lokesh Vutla
Samuel Holland
Stefan Roese
