[PATCH v2] arm: dts: imx8mq-evk: add phy-reset-gpios for fec1
Instead of resetting the ethernet phy through functions in imx8mq_evk.c, let the driver reset the phy via dts description adding a reset duration of 10 ms following atheros 8031's datasheet recommendation.
Signed-off-by: Alifer Moraes alifer.wsdm@gmail.com ---
Changes since v1:
Improve commit log (Michael Trimarchi)
arch/arm/dts/imx8mq-evk.dts | 2 ++ board/freescale/imx8mq_evk/imx8mq_evk.c | 18 ------------------ 2 files changed, 2 insertions(+), 18 deletions(-)
diff --git a/arch/arm/dts/imx8mq-evk.dts b/arch/arm/dts/imx8mq-evk.dts index 3693933451..55294ba9c8 100644 --- a/arch/arm/dts/imx8mq-evk.dts +++ b/arch/arm/dts/imx8mq-evk.dts @@ -104,6 +104,8 @@ pinctrl-0 = <&pinctrl_fec1>; phy-mode = "rgmii-id"; phy-handle = <ðphy0>; + phy-reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>; + phy-reset-duration = <10>; fsl,magic-packet; status = "okay";
diff --git a/board/freescale/imx8mq_evk/imx8mq_evk.c b/board/freescale/imx8mq_evk/imx8mq_evk.c index cb39d0f2d6..b2f464abb1 100644 --- a/board/freescale/imx8mq_evk/imx8mq_evk.c +++ b/board/freescale/imx8mq_evk/imx8mq_evk.c @@ -64,29 +64,11 @@ int dram_init(void) }
#ifdef CONFIG_FEC_MXC -#define FEC_RST_PAD IMX_GPIO_NR(1, 9) -static iomux_v3_cfg_t const fec1_rst_pads[] = { - IMX8MQ_PAD_GPIO1_IO09__GPIO1_IO9 | MUX_PAD_CTRL(NO_PAD_CTRL), -}; - -static void setup_iomux_fec(void) -{ - imx_iomux_v3_setup_multiple_pads(fec1_rst_pads, - ARRAY_SIZE(fec1_rst_pads)); - - gpio_request(IMX_GPIO_NR(1, 9), "fec1_rst"); - gpio_direction_output(IMX_GPIO_NR(1, 9), 0); - udelay(500); - gpio_direction_output(IMX_GPIO_NR(1, 9), 1); -} - static int setup_fec(void) { struct iomuxc_gpr_base_regs *gpr = (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR;
- setup_iomux_fec(); - /* Use 125M anatop REF_CLK1 for ENET1, not from external */ clrsetbits_le32(&gpr->gpr[1], BIT(13) | BIT(17), 0); return set_clk_enet(ENET_125MHZ);
Instead of resetting the ethernet phy through functions in imx8mq_evk.c, let the driver reset the phy via dts description adding a reset duration of 10 ms following atheros 8031's datasheet recommendation. Signed-off-by: Alifer Moraes alifer.wsdm@gmail.com
Best regards, Stefano Babic
Alifer Moraes
sbabic@denx.de
